Got a few question here..
Limalex
London
C?ID=260940
Help guys I need some help to do repairs on my 07 plate A6.
Brake pad warning sensor.
I see it is very common issue but I cannot find any solutions yet.
I changed the front pads and the discs and there were no warning for three days. Than the warning light with a silly noise come up. I used genuine parts I clean the connectors with WD40 I checked the wires, Everything fine but the warning still on.
What else should I do? I do not really want to bypass the connectors with two wires.
Rear set belt tensioner.
Rear seat belt needs to replace or fix, but I am stocked at the beginning.
I would appreciate a guide how to remove it?
It not work from the boot. It seems the only option to remove a plastic cover somehow, but I du not want to damage it at all. I would really need to know where to start.
Component protection active
Everything working so it not really bothers me, but I tried to retrofit AMI and for some reason it won't work on my car. I bought a factory software update for Basic/Basic plus Low and my cd drive does not recognise the update cd.
Is it possible because of component protection activated? Audi charge 180+VAT to remove it, but If I cannot fit AMI there is no point to du it.
02115- Locking Unit for Central Locking
When I test it with VCDS it works well for few hours, but after that the n/s door stays locked. I do a test again ad it works for a few time than the issue comes back.
Do I really need to replace the module or it can be solved with some coding?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Start by posting a complete Auto-Scan please. :) The "07 plate" (registration) stuff is something only you blokes in UK got, it says little to nothing about the actual build date of the car essentially making specific answers nearly impossible in some cases. You can find the actual model/chassis type in digit 7 & 8 of the VIN, the model year is in digit 10 of the VIN.
Limalex
London
C?ID=260940
Sure, got it :) I hope I do it right.
 Chassis Type: 4F (4F0)
Scan: 01 03 05 07 08 09 0E 15 16 17 19 1E 37 42 46 47 4F 52 53 56
          61 62 72
VIN: WAUZZZ4F37N135533   Mileage: 134170km-83369miles
Address 01: Engine        Labels: 03G-906-016-BLB.clb
   Part No SW: 03G 906 016 HS    HW: 03G 906 016 HS
   Component: R4 2,0L EDC G000SG  9673
   Revision: --H05---    Serial number:
   Coding: 0000072
   Shop #: WSC 02324 785 00200
   VCID: 7BF5A99A3AF411E608-802E
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 AC    HW: 4F0 614 517 T
   Component: ESP8 front      H01 0070
   Coding: 0020855
   Shop #: WSC 02325 785 00200
   VCID: 65C1EFE2AC70B716CE-8030
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10601100695356
   Coding: 0000017
   Shop #: WSC 02323 785 00200
   VCID: 63C5F1FAA244C92620-8036
   Subsystem 1 - Part No: 4F0 910 131 D
   Component: FBSAUDIC6 EZS   H45 0080
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H01 0040
Address 07: Control Head        Labels: Redir Fail!
   Part No SW: 4F0 910 769 H    HW: 4F0 035 769 B
   Component: MMI Cockpit     H55 0410
   Revision: C61030BE    Serial number: AUZ6Z3G2UB55K3
   Coding: 0140002
   Shop #: WSC 02335 785 00200
   VCID: 326B44BEAD3E10AE9B-8066
   Component: Bedienteil MMIC6H01 0060
   Subsystem 2 - Serial number: 00000000673714
   Subsystem 3 - Serial number: 0116.02.070000000100010596ˇ
   Subsystem 4 - Serial number: 010596ˇ
            000 -  -  - Intermittent
                    Mileage: 129075 km
                    Date: 2015.09.01
                    Time: 17:33:21
Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
   Part No SW: 4F0 910 043 A    HW: 4F2 820 043 P
   Component: KLIMABETAETIGUNGH30 0020
   Revision: 00000052    Serial number: 00000000365641
   Coding: 0001044
   VCID: 1C378A06DFBAB6DEA1-8048
   Part No SW: 4F0 910 279 L    HW: 4F0 907 279 B
   Component: ILM Fahrer      H17 0240
   Coding: 0000101
   Subsystem 1 - Part No: 4F2 910 113 B  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H04 0190
   Coding: 00064784
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00146221
   Shop #: WSC 02335
01494 - Bulb for Parking Lamps; Left (M1)
                    Fault Status: 00111011
                    Fault Frequency: 115
                    Reset counter: 201
                    Mileage: 122876 km
                    Date: 2015.07.25
                    Time: 02:24:00
                    Fault Status: 00100111
                    Fault Frequency: 61
                    Reset counter: 199
                    Mileage: 122712 km
                    Date: 2015.07.21
                    Time: 04:09:00
01498 - Bulb for Parking Lamps; Right (M3)
                    Fault Status: 00101011
                    Fault Frequency: 119
                    Reset counter: 201
                    Mileage: 123616 km
                    Date: 2015.08.09
                    Time: 05:37:00
                    Fault Frequency: 61
                    Reset counter: 192
                    Mileage: 123020 km
                    Date: 2015.07.29
                    Time: 02:46:00
Address 0E: Media Player 1        Labels: Redir Fail!
   Coding: 0140002
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
   Component: 4E AIRBAG AUDI8RH30 0280
   Revision: 09H30000    Serial number: 0037LD0P98VV
   Coding: 0013381
   VCID: 2959A3D280E853762A-807C
   Subsystem 1 - Serial number: 6332CSME17634933/
   Subsystem 2 - Serial number: 6342CSME17646705+
   Subsystem 3 - Serial number: 6352QSME2236310B5
   Subsystem 4 - Serial number: 6362QSME23330B1DE
   Subsystem 5 - Serial number: 63734SME214F3921
   Subsystem 6 - Serial number: 63834SME220D314F%
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenks‰ulenmodul H08 0230
   Revision: 00H08000    Serial number: 90026070550659
   Coding: 0102041
   VCID: 66C3E8EE5176BC0EC7-8032
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 C    HW: 4F0 920 950 R
   Component: KOMBIINSTR. M73 H13 0170
   Revision: 00000000    Serial number: 58W72XR27
   Coding: 2308448
   Shop #: WSC 59286 001 1048576
   VCID: 204FBEF6F3D2923E7D-8074
Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
   Component: Gateway         H11 0070
   Revision: 11          Serial number: 130080722184A0
   Coding: 6CEE53C43B2104
   VCID: 275DA5EA96FC65063C-8072
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
   Component: MP3-Changer     H44 0350
   Revision: 00044000    Serial number: AUZ5ZBG3172571
   VCID: 183F96162B82DAFE85-804C
Address 37: Navigation        Labels: Redir Fail!
   Coding: 0140002
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
   Component: TSG FA          H12 0120
   Revision: 00000000    Serial number: Q
   Coding: 0002586
   Shop #: WSC 02327 785 00200
   VCID: 2C575AC68F1A465ED1-8078
                    Fault Status: 01101100
                    Fault Frequency: 85
                    Reset counter: 164
                    Mileage: 132125 km
                    Date: 2015.09.28
                    Time: 07:56:08
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 G    HW: 4F0 907 289 G
   Component: Komfortgeraet   H22 0170
   Revision: 01700022    Serial number: 01035468870000
   Coding: 0000251
   VCID: 2E5350CEB906344EFF-807A
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 910 223 H    HW: 4F0 035 223 K
   Component: Amp.-ASK-RD   H07 0130
   Revision: 08S00000
   Shop #: WSC 02399 823 56573
   VCID: 2345B1FA22C4892660-8076
                    Reset counter: 143
                    Mileage: 122428 km
                    Date: 2015.07.15
                    Time: 09:52:02
                    Voltage: 12.20 V
                    Temperature: 22.0∞C
                    Bin. Bits: 00000011
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000401839
   Coding: 0001104
   VCID: 5EB3C00E8926E4CE0F-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
   Component: TSG BF          H12 0120
   Revision: 00-00000
   Coding: 0002586
                    Fault Status: 01101000
                    Fault Frequency: 92
                    Reset counter: 133
                    Mileage: 122380 km
                    Date: 2015.07.14
                    Time: 12:54:13
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
   Component: EPB  CDEC0080   H04 0080
   Revision: --H04---
   Coding: 0000111
Address 56: Radio        Labels: Redir Fail!
   Coding: 0140002
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: J0644 BEM       H12 0590
   Revision: 00000000    Serial number: 00000000031818
   Shop #: WSC 00000 384 00290
   VCID: 2345B1FAE2C4892660-8076
   Subsystem 1 - Part No: 4F0 915 105 C
   Component: von VA0  2702170389
   Coding: 344630393135313035432056413032373032313730333839
02272 - Quiescent Current Stage 1
                    Mileage: 125222 km
                    Date: 2015.08.12
                    Time: 17:28:32
02273 - Quiescent Current Stage 2
                    Date: 2015.08.12
                    Time: 17:32:09
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
   Component: TSG HL          H21 0050
   Coding: 0002050
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 F    HW: 4F0 959 794 F
   Component: TSG HR          H21 0050
   Coding: 0000002
   VCID: 2F6D4DCABE0C3D46F4-807A
End-------------------------(Elapsed Time: 02:10)--------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
What part number has the cd/set you bought for the MMI-Low?
Limalex
London
C?ID=260940
cd- 4L0 998 961 A
AMi unit- 4E0 035 785F
Limalex
London
C?ID=260940
That is cool....
