2019 VW Passat Alltrack 2.0 TDI (Sweden)
Northstar
Sweden
C?ID=316542
Sunday,11,August,2024,20:14:16:29229
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WVWZZZ3CZKE096877   License Plate: Sweden
Mileage: 83286km-51751mi   Repair Order: 2024-08-11
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 18 19 22 2B 3C 42 44 52 55 5F
          69 6C 6D 75 A5 BB BC CF
VIN: WVWZZZ3CZKE096877   Mileage: 83286km-51751miles
Address 01: Engine (J623-DFHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 KA    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H26 6014
   Revision: B4H26---    CVN: 42C09F31B866C2ADB866C2AD
   Coding: 0125043A04761D083000
   Shop #: WSC 05311 115 00307
   ASAM Dataset: EV_ECM20TDI01104L906026KA 005004
   ROD: EV_ECM20TDI01104L906026KA_005.rod
   VCID: 73B0D73EAB320A42521-8026
   VINID: 9E69EAAAA0D3A9B5402462071CB1D5CE91
   Part No SW: 0GC 300 013 K    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2403
   Revision: 00H06V07    CVN: D788ABA1
   ROD: EV_TCMDQ381061.rod
   VCID: 2C020C42368C15BAD3B-8078
   No subsystems:
   Part No SW: 5Q0 614 517 DH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0754
   Revision: 00000000    Serial number: 60909000001196
   Coding: 40EC6A8F34290B72477F070760CA4902562CD0E2E0069279B8625078EAA9420B00010312121212B435351919323200
   Shop #: WSC 00015 115 08193
   ROD: EV_Brake1UDSContiMK100IPB_037_VW48.rod
   VCID: 7AAEFA1A8C587B0A117-802E
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 6099796145 Dataset Number: V03935273KN 0001
   Coding: 1F20000723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D047FEBB12FAC2021-8016
   Part No SW: 5G0 907 044 DQ    HW: 5G0 907 044 DQ
   Component: Climatronic   H04 2001
   Revision: 00001K10
   Coding: 12020104204111011115104C0010182A
   VCID: 79ACE516895E701218D-802C
   Air quality sensor:
   Humidity sensor: exterior:
   Part No SW: 5Q0 937 086 BQ    HW: 5Q0 937 086 BQ
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: 8658300319012V Dataset Number: V03935279NW 0001
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 0A4EAADADCB86B8A017-805E
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    190302  042 0607
   Serial number:         190313023414
   Component: RLHS  052 0107
   Serial number: S7Y19M04D01H01M26S41
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 12 12 2018  10000269
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY190551MJG
   Subsystem 5 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000378516
   Humidity sensor: interior:
   Steering Column Switch:
   Subsystem 7 - Part No SW: 5Q1 953 521 R    HW: 5Q1 953 569 B
   Component: Lenks.Modul  H23 0170
   Serial number: 0100300320190C101269
   Part No SW: 5QA 919 298 F    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0453
   Serial number: 000308417319089 Dataset Number: V03935256HH 0001
   Coding: 0A71167951
   Shop #: WSC 05311 115 00093
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   VCID: 53F077BE4B726A42B21-8006
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Component: ACC BOSCH MQB H05 0196
   Dataset Number: V03935243QB 0001
   Coding: 320467DB19FFC728949C8045
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 35342926E5C65472BC5-8060
   Part No SW: 3Q0 959 655 BK    HW: 3Q0 959 655 BK
   Component: Airbag VW21   006 0712
   Revision: --------    Serial number: 003W6PF63419 Dataset Number: V03935274VB 0001
   Coding: 88CCC000008000005C5400CF000840000065
   Shop #: WSC 05311 000 08193
   VCID: 084A90D2C2B4199A173-805C
   Left seat belt tensioner:
   Component: BeltPretRevFL  106 1040
   Serial number: 3G0857705 0096T00164
   Coding: 80000D
   Right seat belt tensioner:
   Component: BeltPretRevFR  106 1040
   Serial number: 3G0857706 0095T00518
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 001 303 19
   Serial number: 35700000000CA3B04A3P
   Subsystem 4 - Part No SW: -----------    HW: 454 001 303 19
   Serial number: 3580000000001279E93I
   Subsystem 5 - Part No SW: -----------    HW: 454 801 103 19
   Serial number: 3510002F157180000005
   Subsystem 6 - Part No SW: -----------    HW: 454 801 103 19
   Serial number: 3520011EC5718000000G
   Subsystem 7 - Part No SW: -----------    HW: 454 801 502 19
   Serial number: 35500C7486317000000I
   Part No SW: 3G0 920 790 D    HW: 3G0 920 790 D
   Component: KOMBI         403 4191
   Coding: 03A5181BEF88000801883B2B3001000800000000
   VCID: 290CF556397E009228D-807C
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 J    HW: 5Q0 963 272 J
   Component: STH-MQB       008 0080
   Coding: 9309
   VCID: 3D243106DDF68C32745-8068
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0402
   Serial number: 00000000000000703301
   Serial number: 30031910521700 Dataset Number: V03935294VA 0001
   Coding: 030300345F017300FB10225C1A0F00010001070000000000000000000000
   GVL: 01C43C0008000600C0CC90008006C80000040000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E86C64AC01027AABDF-803A
   Generator:
   Component: 0-00-03-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 39190000602060059106
   Coding: 2FFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
   Serial number: 0660470605
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  112 1004
   Serial number: 2703201900010435
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00011.03.19 Dataset Number: v1260x015G0 0000
   Coding: 0301
   VCID: 4CC26CC2964C35BAF3B-8018
   Serial number: 19000093785012
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 3330173EEBB24A42921-8066
   Part No SW: 3Q0 907 566 G    HW: 3Q0 907 566
   Component: MRR1Rear      H25 0530
   Revision: --------    Dataset Number: V03935272NS 0001
   Coding: 14C002
   ROD: EV_RearRadarS1BoschVW48X_VW37.rod
   VCID: 3C223C02C6EC853A43B-8068
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007SBQ2444B Dataset Number: V03935289QB 0001
   Coding: 003F1A20D000028000001000
   VCID: 44D244E2BE1CFDFA3BB-8010
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 920002 00  Dataset Number: V03935290MA 0001
   Coding: 0101001100400110
   Shop #: WSC 00015 115 00307
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
   VCID: 2B000F5E33821282DA1-807E
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007SBL30462 Dataset Number: V03935289QG 0001
   Coding: 003F1020DC00028000001000
   Coding: 03EA000009000000
   VCID: 75B4E926A54614727C5-8020
   Part No SW: 3Q0 035 840 C    HW: 3Q0 035 840 C
   Component: MU-S--ER      H41 0475
   Serial number: VWZAZ2W0811051 Dataset Number: V03935300ZL 0001
   Coding: 02840200FF0000005111000100080A001F0508E40120000002
   ROD: EV_MUStd4CTSAT_VW37.rod
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H52 8130
   Serial number: VWZ6ZJW0921882
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0508678293 Dataset Number: V03935259HF 0001
   Coding: 0100000202000000
   VCID: 42DE42FAA408F3CA097-8016
   Part No SW: 5Q0 980 568 B    HW: 5Q0 980 568 B
   Component: RVC Compact+  H08 0250
   Dataset Number: V03935230RW 0001
   Coding: 0184420163002017000048
   ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 007012
   ROD: EV_CamSysRVRVCARPANAMQBAB_007_VW48.rod
   Part No SW: 5Q0 959 107 P    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0266
   Revision: --------    Serial number: 32397366100000 Dataset Number: V03935268LA 0001
   Coding: 0288
   ROD: EV_DeckLidCONTIAU736_VW48.rod
   VCID: 45D459E6B526C4F22C5-8010
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------    Dataset Number: V03935278EW 0001
   Coding: 02840201EA16180D3F1CBE020045400382E708
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   Part No SW: 3Q0 980 653 F    HW: 3Q0 980 653
   Component: MQB_B_MFK     H13 0171
   Serial number: 21031912P15225 Dataset Number: V03935265PE 0001
   Coding: 00040802040004010022004FC150A900840094200020
   VCID: 392C2516C9DEB01258D-806C
   Part No SW: 8W1 959 595 D    HW: 8W1 959 595 D
   Component: TSG HFS003 0189
   Serial number: YE007SBN1810C Dataset Number: V03935278SA 0001
   Coding: 000E10200100028000001000
   VCID: 4EC666CA605007AA9DF-801A
   Component: TSG HBFS003 0189
   Serial number: YE007SBN17402 Dataset Number: V03935278S  0001
   Part No SW: 3Q0 907 590 G    HW: 3Q0 907 590
   Revision: --------
   Coding: 14C002
   ROD: EV_RearRadarS2BoschVW48X_VW37.rod
End----(Elapsed Time: 02:18, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
