Wednesday,17,July,2024,15:58:05:49562
VCDS Version: 24.5.0.0 (x64) HEX-NET CB: 0.4643.4
VIN: WVWZZZAUZHP787440 License Plate: EB60406
Mileage: 128577km-79894mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F 69
VIN: WVWZZZAUZHP787440 Mileage: 128577km-79894miles
Address 01: Engine (J623-CZCA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 HB HW: 04E 907 309 BH
Component: R4 1.4l TFS H26 2833
Revision: R7H26--- CVN: C7FD2D74
Coding: 01190032245415082000
Shop #: WSC 00028 028 00070
ASAM Dataset: EV_ECM14TFS01104E906027HB 001005
ROD: EV_ECM14TFS01104E906027HB.rod
VCID: 6B96353D82446ACE86-803E
VINID: 9E69EAAAA465A988072071040038795847
Part No SW: 5Q0 614 517 CE HW: 5Q0 614 517 AC
Component: ESC H25 0413
Revision: 00000000 Serial number: 51027000001835
Coding: 04FA6AA124282173477B060440C32920562484E26002947334205078C002430000000012121212B835351919323200
Shop #: WSC 00028 028 00068
VCID: 76A01449C906A72669-8022
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 02020004200110011005000000101022
VCID: 6D923B25BC5064FE98-8038
Air quality sensor:
328199 - Position Sensor for Right Temperature Flap Motor
B1095 15 [00001000] - Open or Short to Plus
Reset counter: 141
Mileage: 127872 km
Date: 2024.07.05
Time: 19:11:42
Voltage terminal 30: 13.5 V
Outside temperature: 18.0 C
Inside temperature: 27.4 C
Right temperature flap: actual value: 114
Right temperature flap: actual value: 42.5 %
Temperature door right - Specified value: 114
Part No SW: 5Q0 937 086 BG HW: 5Q0 937 086 BG
Component: BCM PQ37BOSCH 032 0223
Revision: -------- Serial number: 8658120417021X Dataset Number: V03935258XK 0001
ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
ROD: EV_BCMBOSCH_017.rod
VCID: 004C72919BC2999643-8054
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 170316 043 0551
Serial number: 170406041149
Component: RLHS 042 0105
Serial number: S4Y17M04D24H11M13S17
Coding: 00A8DD
Humidity sensor: interior:
6922 - Bulb for Low Beam Headlamp Right
B1218 15 [00001000] - Open or Short to Plus
197904 - Central Locking
B140A 4B [00001000] - Over Temperature
Part No SW: 5QA 919 294 A HW: 5QA 919 294
Component: PDC 8 KanalH07 0038
Serial number: 000308418617109 Dataset Number: V03935257CA 0001
Coding: 0471051101
ASAM Dataset: EV_EPHVA18AU3700000 009031
VCID: 4AD890B9ED7E93C6DD-801E
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 H HW: 3QF 907 572
Dataset Number: V03935253UB 0001
Coding: 2B00E00911FFC728949C810560401600000000000000000000
Shop #: WSC 12345 123 61029
VCID: 3C34C661B7AA3D765F-8068
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0318
Serial number: 003TDR2VDDGI Dataset Number: V03935255FD 0001
Coding: 98CCC000000000005C0000CF000800000065
Shop #: WSC 00028 028 00056
VCID: 106C42D1CBA2E916D3-8044
Left seat belt tensioner:
Component: BeltPretRevFL H37 0350
Serial number: 34169667E18041740127
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H37 0350
Serial number: 34169668E18041750788
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 504 17
Serial number: 357000000003F848D22R
Subsystem 4 - Part No SW: ----------- HW: 480 001 504 17
Serial number: 3580000000052631C226
Subsystem 5 - Part No SW: ----------- HW: 480 401 804 17
Serial number: 3510001B924D8E64E53H
Subsystem 6 - Part No SW: ----------- HW: 480 401 904 17
Serial number: 3520001BB24CEF22F13H
Subsystem 7 - Part No SW: ----------- HW: 480 401 204 17
Serial number: 3550001A524D8E6664EK
Part No SW: 5Q0 953 521 K HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF033033 Serial number: 20170413100696
Coding: 0400
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
VCID: 3A38C079BD9E03464D-806E
Part No SW: 5G1 920 740 B HW: 5G1 920 740 B
Component: KOMBI 204 8311
Coding: 07A521002780000801883A011400000000000000
VCID: 2502030524209CBE10-8070
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 515 5286
Serial number: 13041710801800 Dataset Number: V03935252FW 0001
Coding: 030100347F085700FA000248080F00010001050000000000000000000000
GVL: 01543C0000000000C00C80000000480000000000000000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 2F2EE12D76DCD6EEEA-807A
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 46170001022650087147
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 9310033704
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 TSG FS 010 00320032
Serial number: 0000251565046 Dataset Number: V03935257PY 0001
Coding: 00310320D000028000001000
ROD: N/A
VCID: 47DEA98DFE6C6EAEC2-8012
Component: EPS_MQB_ZFLS 129 1072
Dataset Number: V03935259RX 0001
Coding: 0107
ROD: EV_SteerAssisMQB_013.rod
VCID: 45C2A385C4607CBE30-8010
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0032
Serial number: 0000251714028 Dataset Number: V03935257QA 0001
Coding: 00310120DE00028000801000
VCID: 46C0A489F96677A639-8012
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000006585679
Coding: 090000
Part No SW: 3Q0 035 824 B HW: 3Q0 035 824 B
Component: MU-S--ER H30 0363
Serial number: VWZAZ2T1283041 Dataset Number: V03935258X 0001
Coding: 02731200FF0000005111000100080A001F0500C40120010003
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 2C14F62147CAADF6CF-8078
Subsystem 1 - Part No SW: 5G6 919 605 A HW: 5G6 919 605 A
Component: ABT_Std-2 H50 8120
Serial number: VWZ6ZHT1152127
Part No SW: 5Q0 907 383 H HW: 5Q0 907 383 C
Component: Anhaenger H21 0204
Revision: 8B001003 Serial number: 0438599582 Dataset Number: V03935259HE 0001
Coding: 0100000202000000
End----------(Elapsed Time: 02:04, VBatt start/end: 12.2V/12.1V)-----------
