- Sep 11, 2021
- 13
- 15
- Scotland, UK
- C?ID=124175
Hi all,
We've been carrying out engine replacement works on this car, a 2017 Audi A5 2.0 TFSI, unfortunately when the engine was being removed the steering wheel was allowed to move past it's end point & looks to have created an issue with the 16 - Steering wheel module, fault code B1168 04 - Steering angle sensor - internal system fault.
We sourced a used item with the same part number & fitted it with the ribbon aligned correctly & the steering straight ahead, the fault persists & appears to be a 'hard DTC' which cannot be cleared & the date stamp on the fault remains from when the steering was first allowed to turn too far.
Has anyone overcome this fault? We're happy to grab a new unit from Audi & fit it, but would like to be confident we aren't missing something.
Thursday,01,August,2024,12:45:53:21365
VCDS Version: 24.7.0.0 (x64) HEX-NET2 CB: 0.4643.5
VIN: WAUZZZF57HA009365 License Plate:
Mileage: 92926km-57741mi Repair Order: 01082024
Chassis Type: F5-AU49 (8W5)
Scan: 01 03 06 08 09 15 16 17 19 29 2B 36 39 42 44 46 47 52 5F 6C
A5 A9 D6 D7
VIN: WAUZZZF57HA009365 Mileage: 92926km-57741miles
Address 01: Engine (J623-CVKB) Labels:. 06L-907-115-V1.clb
Part No SW: 8W0 907 115 K HW: 06L 907 309 A
Component: R4 2.0l TFSI H40 0006
Revision: S1H40--- CVN: A45ABBFB
Coding: 1A1900130324050334080000000000000000000000000000
Shop #: WSC 60753 003 1048576
ASAM Dataset: EV_ECM20TFS0118W0907115K 001007
ROD: EV_ECM20TFS0118W0907115K.rod
VCID: C1D4ACFD617C7D5290D-8194
VINID: 9D196AAAA5851D84400090C61483EDEECE
4527 - Coolant Fan Control Circuit 1
P0480 00 [00100111] - Electrical Malfunction
Mileage: 92926 km
Date: 2024.08.01
Time: 12:38:58
Engine RPM: 762.00 /min
Normed load value: 13.7 %
Coolant temperature: 94 °C
Intake air temperature: 33 °C
Voltage terminal 30: 12.980 V
Air mass: specified value: 8.3 kg/h
Coolant temperature at radiator outlet: actual value: 21.0 °C
Outside temperature: 20.0 °C
Coolant fan 1: activation: 10.15 %
Coolant fan 2: activation: 0.00 %
Fuel temperature: 17.3 °C
23476 - Implausible Data Received from Steering Column Control Module
U0429 00 [00100111] - -
Mileage: 92926 km
Date: 2024.08.01
Time: 12:38:57
Engine RPM: 765.50 /min
Com st X Set1 Val1-Bits 0-7: 0
Com st X Set1 Val2-Bits 0-7: 0
Com st X Set1 Val3-Bits 0-7: 0
Com st X Set1 Val4-Bits 0-7: 0
Com st X Set1 Val5-Bits 0-7: 0
Com st X Set1 Val6-Bits 0-7: 0
Com st X Set1 Val7-Bits 0-7: 1
Com st X Set1 Val7-Bits 0-7: 0
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 G HW: 8W0 907 379 J
Component: ESP9 Plus H06 0719
Dataset Number: 8W2909504B 0003 CVN: B085950A
Coding: 04AA089A08A20A9F11A1489700825292E6C1D6201010508812004A4967836B
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 001001
ROD: EV_ESP9BOSCHCMP_001.rod
VCID: C9C4B4DD594CB51248D-819C
6293504 - Steering Angle Sensor
C2008 00 [10100111] - Signal Qualification
Mileage: 92926 km
Date: 2024.08.01
Time: 12:38:57
84 00 00 00 CA 24 00 00 00 00
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M0 959 760 A HW: 4M0 959 760 A
Component: MEM-BFS 008 0031
Serial number: 00000228122512 Dataset Number: 8W2909866B 0010
Coding: 003210040004B0010003010101012100000000000000000000000000800003
Shop #: WSC 06325 790 00001
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
VCID: B63ECF2138B2CAEA35F-81E2
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 G HW: 8W0 820 043 G
Component: Klima Zone 3 H32 0071
Coding: 440800095544440D02000100880000000000000000000000000000000000
ROD: EV_AirCondiBHTCAU491.rod
VCID: B720C2253FB833E22E9-81E2
Subsystem 1 - Part No SW: 4M2 820 021 HW: 4M2 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000001144421
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0005
Serial number: B558CA5800PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: Klima Heck H40 0073
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 BCM1 MLBevo H13 02660266
Dataset Number: 8W2909514C 0028
Coding: 07501143E11800CD051559191B8C80F9110B3108000000000000000020001A810A450122025605
VCID: 825663F124FAA64AC97-81D6
Subsystem 1 - Part No SW: 8W6 955 119 A HW: 8W6 955 119 A
Component: 494 RL 161027 036 0471
Serial number: 00000001610210302023
Coding: 5FC7F7
Serial number: 20129071X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 04 07 2016 00573896
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE101091612010571
Coding: 230000
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 BQ HW: 8W0 947 135
Component: J528-Dachele H14 0130
Subsystem 6 - Part No: 8W0 925 301 BC
Component: SL-B9/Q5NF
131945 - Databus
[EPS control module: received error value in signal EPS_steering-rack_pos]
196758 - Databus
[Brake control module: received error value in signal ESP system status]
196761 - Databus
[Power steering control module: received error value in signal EPS steering rack position]
Reset counter: 71
Mileage: 92926 km
Date: 2024.08.01
Time: 12:39:00
average_Voltage_terminals: 13.20 V
Outside air temperature sensor-Outside air temperature on CAN: 20.00 °C
interior_temperature: 27.00 °C
Vehicle speed: 0.00 km/h
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
Component: Airbag10.44 H03 0103
Serial number: 003UP000EKMS Dataset Number: 8W2909602AC 0002
Coding: AACCF0C00C800000585000F3D0CC00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005013
ROD: EV_AirbaAU10BPAAU736_005.rod
VCID: CCCA8DC9563EA03A73B-8198
Subsystem 1 - Part No SW: ----------- HW: 442 061 910 16
Serial number: 3577Y00C91FD7542210+
Subsystem 2 - Part No SW: ----------- HW: 442 061 910 16
Serial number: 3587Y00C91FD7542B34E
Subsystem 3 - Part No SW: ----------- HW: 442 0B1 909 16
Serial number: 3517700BD219E8C5E16X
Subsystem 4 - Part No SW: ----------- HW: 442 0B1 909 16
Serial number: 3527700BD219E8C4729U
Subsystem 5 - Part No SW: ----------- HW: 442 0C0 411 16
Component: FrontSensor_D 1C5 014A
Serial number: 3557500BD21D1223006-
Subsystem 6 - Part No SW: ----------- HW: 442 0C0 411 16
Component: FrontSensor_P 1C5 014A
Serial number: 3567500B921D122322F3
Subsystem 7 - Part No SW: ----------- HW: 442 0C0 411 16
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500A921E1163B33
Subsystem 8 - Part No SW: ----------- HW: 442 431 410 16
Component: PedPSensor_D2 256 0887
Serial number: I0M9M00B31FFD132126F
Subsystem 9 - Part No SW: ----------- HW: 442 431 410 16
Component: PedPSensor_P2 256 0887
Serial number: I0N9M00B11FFD130539K
B13BC F2 [10001001] - No function
Reset counter: 71
Mileage: 92926 km
Date: 2024.07.18
Time: 16:23:22
1050117 - Databus
[NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Reset counter: 71
Mileage: 92926 km
Date: 2024.08.01
Time: 12:39:00
1061893 - Databus
[NWD: 0x0A0 LH_EPS_04 error value EPS_Zahnstangen_Pos]
Reset counter: 71
Mileage: 92926 km
Date: 2024.08.01
Time: 12:39:00
Part No SW: 4M0 907 129 HA HW: 4M0 907 129 HA
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: F6BE0F2178328AEAF5F-81A2
5586944 - Steering angle sensor
B1168 04 [00001001] - Internal System Fault
Mileage: 92926 km
Date: 2024.07.09
Time: 00:06:55
Freeze_Frame_SAS_Failures-Angle_Qualifier: 00
Freeze_Frame_SAS_Failures-corresponding_SAS_Velocity: 0 °/s
Freeze_Frame_SAS_Failures-last_valid_Sign_Steering_Angle_Main: 00
Freeze_Frame_SAS_Failures-last_valid_Steering_Angle_Main: 704.0 °
Freeze_Frame_SAS_Failures-second_to_last_valid_Sign_Steering_Angle_Main: 00
Freeze_Frame_SAS_Failures-second_to_last_valid_Steering_Angle_Main: 704.0 °
Freeze_Frame_SAS_Failures-Sign_SAS_Speed: 00
Freeze_Frame_SAS_Failures-Vehicle_Speed_FL: 2.10 km/h
Freeze_Frame_SAS_Failures-Voltage_12V: 11770.31 mV
Freeze_Frame_SAS_Failures-VZ_Vehicle_Speed_VL: 00
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 790 C HW: 8W5 920 790 C
Component: FBenRDW H15 0307
Coding: 24A41096288006000120E9601000000000000000
ASAM Dataset: EV_DashBoardAU736 001022
VCID: C2D6A3F1647A664A897-8196
1048578 - Incorrect Basic Setting
B2011 00 [00001001] - -
[ECU no or wrong basic setting]
Reset counter: 71
Mileage: 92926 km
Date: 2024.08.01
Time: 12:38:59
Part No SW: 8W5 907 468 D HW: 8W5 907 468 C
Component: Gateway H30 0308
Revision: 5A000001 Serial number: 0185A007916B15 Dataset Number: 8W2909515B 0027
Coding: 03010001000086402907000000590012E8080007000000000175078E10000000
GVL: 01503C100000020040BC00000002480000080000000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 002040
ROD: EV_CGateCONTIAU491_002_AU49.rod
VCID: CAC68BD15C4ABE0A417-819E
Subsystem 1 - Part No SW: 8W0 951 523 E HW: 8W0 951 523 E
Component: J453 MFL H04 0002
Serial number: 20161108074132 21186
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 6330861904
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AB HW: 4M0 907 397 B
Component: LCM_MLBevoH05 0024
Dataset Number: 8W2909519A 0002
VCID: F7A002257F38F3E2EE9-81A2
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 16000265684007
Coding: 0000000000000000
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: B236F331D4DAD6CA197-81E6
Component: MEM-FS 008 0031
Serial number: 00000228125563 Dataset Number: 8W2909856B 0011
Coding: 006210040004B0010003010101012100000000000000000000000000800003
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Dataset Number: 8W2909520A 0002
Part No SW: 4M0 959 793 E HW: 4M0 959 793 C
Component: TSG FS 009 0055
Serial number: 0000228230061 Dataset Number: 8W2909872A 0017
Coding: 005D4A424001000500003482
ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
VCID: C0D2A9F96A76745A9F3-8194
B1487 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 71
Mileage: 92926 km
Date: 2024.08.01
Time: 12:39:04
Part No SW: 8W0 909 144 G HW: 8W0 909 144 G
Component: EPS_MLBEVO_ZF H08 0409
Dataset Number: 8W2909852N 0024
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003018
ROD: EV_EPSZFAU49X_003.rod
27136 - Databus
[KFC_LWI_01_SNA]
Reset counter: 71
Mileage: 92926 km
Date: 2024.08.01
Time: 12:38:58
Expanded ambient data 1-Engine running: Engine_Running_Stable
Expanded ambient data 1-Supply voltage: 0.00 V
Expanded ambient data 1-Temperature: -70 °C
Expanded ambient data 1-System status: 5
Expanded ambient data 1: 00
Expanded ambient data 1-driving_direction: 0
Expanded ambient data 1-KFA: 0
Expanded ambient data 1-KFC: 106
Expanded ambient data 1-Ready_To_Drive_Bit: 0
Expanded ambient data 1-StartStop Info: 0
Expanded ambient data 1-Steering_Angle_Calculated: 0 °
Expanded ambient data 1-Steering_Angle_Calculated_Sign: 0
Expanded ambient data 1-Steering_torque: 0.00 Nm
Expanded ambient data 1-Steering_Torque_Sign: 1
Expanded ambient data 14-KFA_FAST_RESET: 0
Expanded ambient data 14-KFC_FAST_RESET: 0
Expanded ambient data 14-Register_seg_flag: 0
Expanded ambient data 14-Rom_ram_ecc_adr_1: 0
Expanded ambient data 14-Rom_ram_ecc_eipc: 0
Expanded ambient data 14-Switched_voltage_terminal_30_unfiltered: 13.22 V
Expanded ambient data 14-Voltage_terminal_30_unfiltered: 13.34 V
17664 - Databus
[KFC_ESP_22_SNA]
Reset counter: 71
Mileage: 92926 km
Date: 2024.08.01
Time: 12:38:58
Expanded ambient data 1-KFC: 69
Part No SW: 8W0 907 064 CB HW: 8W0 907 064 B
Component: BCM2 MLBevo 018 0342
Dataset Number: 8W2909501B 0024
Coding: 012B00002F9000006301A0000600000231020010004306500F04000000040030201F0001000000
ASAM Dataset: EV_BCM2HellaAU736 012013
ROD: EV_BCM2HellaAU736_012_AU49.rod
VCID: FEAE17015002C2AAADF-81AA
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY1627821TY
Subsystem 2 - Part No: 5Q0 951 605 A
Serial number: 00000000000036915016
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAGJA00TCED Dataset Number: 8W2909510A 0006
Coding: 0194040800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI.rod
Part No SW: 4M0 959 792 E HW: 4M0 959 792 C
Component: TSG BFS 009 0055
Serial number: 0000226577408 Dataset Number: 8W2909873A 0017
Coding: 005D4A424001000500003480
ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod
VCID: BFD0AA0517880BA2E69-81EA
Reset counter: 71
Mileage: 92926 km
Date: 2024.08.01
Time: 12:39:04
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 035 HW: 8W5 035 035
Component: MU-P-LND-EU 033 0917
Serial number: A829K0GB003712 Dataset Number: 8W2909545D 0027
Coding: 019404010000000053111102000A00332F000DE701700100DE
VCID: F4BA35296E4E98FACBB-81A0
Subsystem 1 - Part No SW: V03 959 802 DF HW: -----------
Component: ECE 2019/2020 --- 0177
Multimedia System 1:
Subsystem 2 - Part No SW: 8W2 919 605 HW: 8W2 919 605
Component: AU49x_DU_HIGH H40 0008
Serial number: AUZ8Z9GBK00BGP
Subsystem 3 - Part No SW: 8W0 919 614 R HW: 8W0 919 614 R
Component: ControlUnit_H H30 0206
Serial number: APVAK110101600020078
Compact disc data bank:
Component: Gracenote2 --- 1015
3084 - GSM antenna 2
B1533 13 [00001001] - Open Circuit
Reset counter: 71
Mileage: 92926 km
Date: 2024.08.01
Time: 12:39:02
Voltage terminal 30: 13.4 V
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H12 0240
Dataset Number: 8W2909460C 0011
Coding: 0294040102002001400040
ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
VCID: B338F6352BC0DFC2121-81E6
13705996 - Databus
[Errorvalue-monitoring LH_EPS_04.EPS_Zahnstangen_Pos]
Reset counter: 71
Mileage: 92926 km
Date: 2024.08.01
Time: 12:38:59
passive
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W6 907 217 HW: 8W6 907 217
Component: BVS H14 0042
Dataset Number: 8W2909466A 0015
Coding: 0404090400000403024023A0A40000FC00F0C020C000
ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
VCID: FF50EA055708CBA2A69-81AA
7 Faults Found:
1123080 - Databus
[LWI_01_LWI_QBit_Lenkradwinkel]
Reset counter: 71
Mileage: 92926 km
Date: 2024.08.01
Time: 12:38:58
Control Module temperature: 38 °C
Voltage terminal 15: 13.20 V
1123714 - Databus
[Airbag_01_AB_Systemfehler]
Reset counter: 71
Mileage: 92926 km
Date: 2024.08.01
Time: 12:39:03
1123157 - Databus
[LH_EPS_03_EPS_Berechneter_LW]
Reset counter: 71
Mileage: 92926 km
Date: 2024.08.01
Time: 12:38:58
1123159 - Databus
[LH_EPS_04_EPS_Zahnstangen_Pos]
Reset counter: 71
Mileage: 92926 km
Date: 2024.08.01
Time: 12:38:58
1123173 - Databus
[ESP_21_ESP_Systemstatus]
Reset counter: 71
Mileage: 92926 km
Date: 2024.08.01
Time: 12:38:58
1123186 - Databus
[LWI_01_LWI_Lenkradwinkel]
Reset counter: 71
Mileage: 92926 km
Date: 2024.08.01
Time: 12:38:58
1123188 - Databus
[LWI_01_LWI_Lenkradw_Geschw]
Reset counter: 71
Mileage: 92926 km
Date: 2024.08.01
Time: 12:38:58
Part No SW: 8W0 907 159 F HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0005
Serial number: 161026203221
VCID: C4DAA5E97E6E687ABBB-8190
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
Dataset Number: 8W2909471A 0008
VCID: 976022A55F7813E20E9-81C2
Component: LED1R H09 0008
Dataset Number: 8W2909472A 0008
End----------(Elapsed Time: 02:40, VBatt start/end: 13.2V/13.2V)-----------
