Resolved Cooling System Fill/Bleed (CNTC Engine, 2016 Audi A3)
Resolved
derf.16.A3.q
Pittsburgh, PA, USA
C?ID=366024
Hi,
Newbie here.
Not sure if this is VCDS related or just me being clueless, but I can't locate the commands I believe should be present, so I'm posting it here.....
It's only repair related in that i can't do the repair without the commands.....please relocate as appropriate
2016 Audi A3 2.0L (8V),
Goal: Drain, refill, and bleed coolant system.
Steps taken:
  1. Drained coolant (lower rad hose)
  2. Filled coolant -- now understand why vacuum filling is a must
  3. pulled 0.2" vacuum on 90% full coolant system. 2nd time, vac filled back to 0. Significant amount of coolant replaced air
I would now like to use VCDS to bleed the system.
PROBLEMS:
I cannot locate
Adaptations>> IDE08287 Bleed Cooling System
Basic Settings
  • IDE08087 Bleed Cooling Circuit
  • IDE04795-ENG98891 Bleed Cooling Circuit (Low pressure)
in their expected locations.
System has 0 faults (see attached autoscan)
Overall procedure for context
understanding was that I needed to do with engine off, reservoir cap off, but ign on
  • Connect with VCDS (using vcds HexNet Mobile)
  • Select Controller
    • Select 01-ENGINE
      • Select Security Access >> 27971, go back.......
    • Select Adaptations>> IDE08287 Bleed Cooling System >>Active, DoIT,..back..........
  • Start Engine
  • ENGINE 01
    • Security Access
    • Basic Settings
      • IDE08087 Bleed Cooling Circuit run till complete
    • then
      • Turn Engine OFF
        • Security Access 27971
        • Basic Settings
          • Repeat 3x total.
          • check for faults
    • Adaptation Bleed circuit active to>>>nonactive
Truly appreciate anyone who can help me figure out why the settings and adaptation are not showing.
I have done this with all doors closed. and the fob on the seat. Only thing open is the hood and driver's window.
Derf
Shaun
The instructions you are referencing are for VCDS on a PC, not VCDS-Mobile. I would highly encourage you to find a PC for running this process, it will let you follow the procedure as written. But if you want to try to follow it in mobile, you need to go to [Cloud Functions] to do Security Access, Adaptations, and Basic Settings.
derf.16.A3.q
Pittsburgh, PA, USA
C?ID=366024
Thank you for your quick reply.
I'm probably using the wrong terminology thus creating confusion for which I apologize.
The hex net adapter I have plugs into the USB port of my Windows 10 PC.
I am running VCDS from that laptop with the hex net adapter attached to the USB port.
The only reason I mentioned VCDS mobile was that it is included on the back of the hex net adapter label. My bad.
The procedure I listed is one I have tried to pull together from a few different sources, one being a post here on this forum and another from a YouTube video indicating how to do this. However, I am unable to look at the commands I referenced above.
If you are able to direct me to a pre written procedure that exists, that would be awesome. However, I am concerned that the selections do not show up in the dropdowns on my VCDS program running on my PC.
Any further ideas?
Thank you very much.
Derf
Shaun
Ok. If you don't see the suggested dropdowns, that may mean this procedure is not correct for your vehicle. Please post an autoscan so we can see how this vehicle is equiped. You can find the instructions for posting an autoscan here: https://forums.ross-tech.com/index.php?threads/101/
derf.16.A3.q
Pittsburgh, PA, USA
C?ID=366024
Apologies -- meant to attach to the first post
Wednesday,07,August,2024,13:53:18:23670
VCDS Version: 24.7.0.0 (x64)  HEX-NET CB: 0.4643.4
VIN: WAUB8GFFXG1029738   License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 42 44 52 55 5F 6C BB
          BC
VIN: WAUB8GFFXG1029738   Mileage: 87356km-54280miles
Address 01: Engine (J623-CNTC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---    CVN: 70436CD8
   Coding: 0A1D00124426000F3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001002
   ROD: EV_ECM20TFS0205G0906259D.rod
   VCID: 2F2E1F5076413AEE6A-807A
   VINID: 9D1952217596A170400891C320E36CB833
Readiness: 1110 1101
   Part No SW: 0D9 300 013 B    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4902
   Revision: 06253104    Serial number: TFK01507160674 CVN: 000019E2
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1660CAB4E9DBEB2609-8042
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 62095000003612
   Coding: 13FF6A9234220A75017E030381CB29C8562C5080C08194B6024100548208
   ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
   VCID: 79BAE108F885245E84-802C
   Revision: 00021000    Serial number: 0374845610 Dataset Number: 8V0909577C  0009
   Coding: 030C0C
   VCID: 3A383E04BD03EF46CD-806E
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000703812
   Coding: 03000014010000000000000000001400
   VCID: 332613209A691E0E0E-8066
   Humidity sensor: exterior:
   Serial number: 48F80EB7000000000001
   Part No SW: 5Q0 937 085 AH    HW: 5Q0 937 085 AE
   Component: BCM MQBAB MNA H24 0175
   Serial number: 01061520500250 Dataset Number: 8V0909514R  0094
   Coding: 04151A46C04122F541C04004511007000800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7F4E0F10E6A10A6EBA-802A
   Component: WWS371 150715  042 0585
   Serial number:         150718161229
   Coding: 0A47F7
   Serial number: 24112370
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 28 05 2015  00001122
   Serial number: 00000000000033109406
   Sunroof control module:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000FW32G00000
   Coding: 101F00
   Revision: --------    Serial number: 39311520207642 Dataset Number: 8V0909526E  0042
   Coding: 0010150011
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 43C643E0CAC9AE8E9E-8016
   Serial number: 003GCR02Z9AS Dataset Number: 8V0909602G  0003
   VCID: 47DE57F0FEF182AE42-8012
   Left seat belt tensioner:
   Serial number: 34230167A31071570211
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34230168A31071540447
   Coding: 333135
   Serial number: 694000000000001DAV2X
   Coding: 303333
   Subsystem 4 - Part No SW: -----------    HW: 480 002 407 15
   Serial number: 357000000005BBD0751P
   Subsystem 5 - Part No SW: -----------    HW: 480 002 407 15
   Serial number: 35800000000198B0751F
   Subsystem 6 - Part No SW: -----------    HW: 480 402 007 15
   Serial number: 3510002AD1B7E8E1D10I
   Subsystem 7 - Part No SW: -----------    HW: 480 402 207 15
   Serial number: 3520002AF1B7E8E5D23T
   Subsystem 8 - Part No SW: -----------    HW: 480 400 805 15
   Serial number: 3550002991A87874B29E
   Subsystem 9 - Part No SW: -----------    HW: 480 400 805 15
   Serial number: 3560002A11A91E74B3BC
   Part No SW: 8V0 953 521 FH    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 02081504220059
   Coding: A018
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 05429DF8847D50BEF0-8050
   Part No SW: 8V0 920 960 M    HW: 8V0 920 960 M
   Component: KOMBI         H03 6420
   Coding: 0BE418192B80D7050200A8001800000000000000
   VCID: 45C25DF8C4FD90BEB0-8010
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 21071510800412 Dataset Number: 8V0909515J  0062
   Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
   GVL: 01D43C0000000600400C10000002C80000000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 75A2ED38D49D403EE0-8020
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 22 07 2015  A0073515
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00018.06.15 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
   VCID: 46C05AF4F9FB9BA6B9-8012
   Revision: 00000000    Serial number: 15000177811007
   Coding: 5D00000000000000
   VCID: 3424103C9F67193617-8060
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 110715BGA18563 Dataset Number: 8V0909872G  0035
   Coding: 00101B204000048000000002
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 41CA49E8D0D5BC9E8C-8014
   Component: EPS_MQB_ZFLS  126 1061
   Dataset Number: 8V0909852K  0022
   Coding: 0102
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 180715BGH18359 Dataset Number: 8V0909873G  0035
   Coding: 001013204000048000000002
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 40CC4CECDBDFB59683-8014
   Revision: --------    Serial number: -------------- Dataset Number: 8V0909865L  0039
   Coding: 012A000101000000
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 844 C    HW: 8V0 035 844
   Component: MU-S-S-US     013 0660
   Serial number: A7A00508150260 Dataset Number: 8V1909545D  0042
   Coding: 01730100FF0A000011220001001A00002F0001440100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   VCID: 393A2108B805E45EC4-806C
   Multimedia System 1:
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9FY30CFC2
   Subsystem 2 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
   Component: ControlUnit_B  H41 0054
   Serial number: C1000022051500030208
   Dataset Number: 8V0909460C  0017
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE_AU37.rod
   VCID: 302C1C2C6B7F251673-8064
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 100715CG912737 Dataset Number: 8V0909897E  0021
   Coding: 000013204000048000000002
   ROD: EV_DCURearDriveMAXKLO.rod
   Serial number: 100715CG912712 Dataset Number: 8V0909896E  0021
   ROD: EV_DCURearPasseMAXKLO.rod
End----------(Elapsed Time: 01:39, VBatt start/end: 12.3V/12.3V)-----------
DrPeter
16.4905° S, 151.7375° W
Please try the following:
VCDS Basic Settings for Engine coolant Fill and/or Bleed
Prerequisites:
- Follow the Official Factory Repair Information, "Coolant Filling"
- Ignition On (use batter maintainer) or Engine running
Using VCDS, connect to the [01-Engine]
- Select the [Basic Settings-04]
- Use [IDE01550 - Service position]
Important Notes:
- This Basic settings will OPEN all the coolant valves in the engine coolant circuit.
- As long as the Basic Settings is 'Active', the valves will remain OPEN. To end the procedure, click [Done, Go Back] and check for fault codes.
Let us know how this works for you,
drpeter
derf.16.A3.q
Pittsburgh, PA, USA
C?ID=366024
Wow,
Thank you very much!
I suppose I should open the valves and do another vacuum pull and vac fill, then bleed.
Thanks again.
Fred
derf.16.A3.q
Pittsburgh, PA, USA
C?ID=366024
Followed steps above.
Heard Valve open in front of engine bay.
Did another vacuum fill. Only got to 10" but still pulled in addl coolant (using OEM 50 50)
Autoscan>>no codes see attached
Thursday,08,August,2024,12:20:12:23670
          BC
   Revision: --H13---    CVN: 77B58FDE
Readiness: 1110 0101
   Coding: 030C0C
   Coding: 0A47F7
   Coding: 00006C
   Coding: 101F00
   Coding: 0010150011
   Coding: 333135
   Coding: 333135
   Coding: 303333
   Coding: A018
   Generator:
   Coding: 0001
   Coding: 0102
End----------(Elapsed Time: 01:42, VBatt start/end: 12.3V/12.3V)-----------
Engine on -- coolant seems to be creeping upin reservoir much sooner than previous non-vac fill procedures.
Thermostat is nowhere near opening for air to get released from block.
WOndering where that valve in the front is.
Will have to look up.
Are there any other VCDS routines for bleeding the cooling loops on my vehicle?
If not, I will do the funnel method so that whatever huge air pocket seems to be stuck in there (even though I did not frain the block and vac filled system (partial))
can escape without taking the contents of my reservoir with it.
an air pocket around that sensor?
Lastly
Do I have access to the location from which you pulled the VCDS information regarding what steps to use for my CNTC based system?
(It will hopefully keep me from having to ask questions about every little thing.
Thanks again for everyone's assistance.
DrPeter
Hello again,
There are no other procedures I can find.
By the way, did you follow the 'Coolant Refill Procedure' outlined in the repair manuals mentioned earlier?
For the benefit of the community of the forum, I have summarized the procedure below.
Coolant, Draining and Filling
Special tools and workshop equipment required
- Cooling System Tester - Adapter - VAG1274/8-
- Cooling System Charge Kit - VAS6096-
- Coolant Collection System - VAS5014- or Shop Crane - Drip Tray - VAS6208-
- Hose Clip Pliers - VAS6362-
- Refractometer - T10007A-
- Safety Gloves
- Protective Eyewear
Add 10L (10.56qt) coolant with the right mix into the reservoir. Check the mix ratio
 - Attach VAG1274/8 to the coolant tank. Connect VAS6096 to VAG1274/8.
 - Place the drain hose in a container. Close valves A & B. Connect hose (3) to compressed air (7-10 bar).
 - Open coolant circuit valves
- Using VCDS, connect to the [01-Engine]
Open valve B (indicator should turn green).
 - Briefly open valve A to fill VAS6096, then close it.
 - Keep valve B open for 2 mins (indicator should stay green).
 - Close valve B. If the needle isn’t in the green zone, repeat the process or check for leaks.
- Disconnect the pressure hose. Open valve A to fill the system with coolant from VAS6096. Remove VAS6096. Fill the system to the “max” mark.
- Reinstall the noise insulation (refer to Body Exterior; Rep. Gr. 66). Set temperature to “HI”. Turn off A/C (ensure LED is off).
- Start the engine, run at ~1500 RPM for up to 2 mins. Add coolant to the overflow hole while running.
- Close the coolant cap securely. Let the engine idle until both large coolant hoses are warm. Turn off the engine.
Source: erWin.Audi - "Repair Manual Audi A3 2013 ➤" (Edition 02.2019)
As per the manual you may need to use the special tools to do this job the right way.
drpeter
derf.16.A3.q
Pittsburgh, PA, USA
C?ID=366024
Thank you DrPeter
I have that manual except that the page to which you refer is blank under the coolant filling section. Apparently I did not get a complete manual.
Those steps represent the vacuum fill procedure with pulling a vacuum, seeing if it holds steady to detect leaks, then vacuum filling with coolant. Now that I know what is on that blank page and what is not on that blank page, it seems they are not doing any additional bleeding for this engine cooling system.
Granted there should not be any appreciable air in the system. I think the problem comes in if, like myself, you do not drain the block, but only the radiator and exp.tank, then trying to fill it without a vacuum fill.
Sometimes we learn the hard way.
Thanks again to all for their assistance.
Derf
S4Phil
Scotland, UK
C?ID=124175
I'd recommend draining the system out and restarting with the correct vacuum fill procedure.
Make sure you have a suitable amount of vacuum to back fill the system, plenty of videos about of correct usage. It's essential on these EA888's to vacuum fill in my experience.
PS no need to drain the block, just pull off the lower radiator hose (US passenger side?) refit and carry out vacuum fill as per the manual.
derf.16.A3.q
Pittsburgh, PA, USA
C?ID=366024
I've still not tried to bleed as I've been hemming and hawing over that.
How to I drain the block on the 888? I've only drained the radiator.
Will the block drain with VCDS holding valves open?
There is no mention of a step to drain the block by removing an additional hose, so that would seemingly be the logical assumption. But I don't like assumptions.
I know, stop typing and FIND OUT.
Need to get more OEM coolant from the dealer tomorrow.
Using a twin stack@90 ish psi. Seems to work at 90 psi on the 288s but I don't know the CFM they are working with.
I bought a "3 amp" charger/maintainer but it cannot keep up with the drain.
How big of a charger do I need to keep from murdering my battery is already at least 6 years old?
derf.16.A3.q
Pittsburgh, PA, USA
C?ID=366024
Apologies for the block draining question again. I was interrupted while reading your post.
Also, thank you for the charger information. You just saved me a significant amount of time and money.
Aside from oil changes, this is my maiden maintenance voyage.
I've much to learn about this car. Quite different than my Saturn s cars and the Ford Escape.
Thanks again for the support.
I'll post back when it's off the scissors lift and back on the road.
derf.16.A3.q
Pittsburgh, PA, USA
C?ID=366024
Car is back in circulation. Drained and started over per recommendation.
Much more came out with the cooling system valves open compliments of VCDS.
Vacuum fill minus 0.25 and steady.
Idled for 1 hour, temperature up to 105C.
No leaks no overheating. Heat more than adequate.
Topped off cool after a few short drives.
All is well.
Again, thanks to everyone involved.
Once you helped me figure out what I needed to do, it took almost no time at all.
Life is sometimes that way. Everyone needs some guidance now and then.
Thank you.
I may write up a step-by-step condensed blurb for a sticky since the CNTC process does not seem to be documented directly anywhere on the internet, except now in this thread. This way it will have higher visibility.
S4Phil
Scotland, UK
C?ID=124175
Drain and refill is a pretty standard procedure across the MQB EA888 engine platform as far as I've seen. Drain the coolant from the points mentioned in the picture, refit the removed hoses.
Carry out the vacuum filling of the coolant system, then follow the steps in the next picture.
PS. I have a reserved hatred for the engineer who decided to give us a drain point from a hose fitted half way up the side of a radiator :)
