- Aug 3, 2024
- 14
- 2
- Gostivar, Macedonia
- C?ID=494670
I have arteon 2020, i have problem with gps signal,
Sometimes it works ok, but most of time gps signal is lost
Can it be gps antenna on the roof, or unit?
Thank you
Thank you
Monday,05,August,2024,09:47:11:35213
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WVWZZZ3HZLE010820 License Plate:
Mileage: 142377km-88468mi Repair Order:
Chassis Type: 3H-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 23 29 39 3C 42 44 4B
52 5F 6C 75 A5 A9 BB BC D6 D7
VIN: WVWZZZ3HZLE010820 Mileage: 142377km-88468miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
Address 01: Engine (J623-CUAA) Labels:. 03N-906-026-CUA.clb
Part No SW: 03N 906 026 M HW: 03N 907 309
Component: R4 2.0l BTD H25 7430
Revision: A1H25--- CVN: 3D1B9A34DAF1CE2E5D3F3C3ED6C3ECFE
Coding: 01250032036605083000
Shop #: WSC 05311 115 00317
ASAM Dataset: EV_ECM20BTD01103N906026M 004002
ROD: EV_ECM20BTD01103N906026L.rod
VCID: 353729AB85C9EE72B45-8060
VINID: 9E69EAAAA0D8A9C5400402020092E6E533
Part No SW: 0DL 300 013 HW: 0GC 927 711 H
Component: GSG DQ500 H06 3004
Revision: 00H06V09 CVN: 9510D457
VCID: 678BB3E38FE54CE2F69-8032
Part No SW: 5Q0 614 517 DN HW: 5Q0 614 517 BR
Component: ESC H82 0113
Revision: 00000000 Serial number: 63399000003161
Coding: 0DEC7B9451213B6C477F070260C369B0DE8ADCE2E0069675386250F8D2A94A0B0003000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
ROD: EV_Brake1UDSContiMK100IPB_049_VW37.rod
VCID: 0059887F8A8B9BDA573-8054
16401 - Tire Pressure Warning
C102D 00 [00001000] - -
Reset counter: 27
Mileage: 141980 km
Date: 2024.08.03
Time: 12:17:36
Part No SW: 3Q0 959 435 M HW: 3Q0 959 435 M
Component: VWKESSYMQB 027 1307
Revision: 00027000 Serial number: 0537013474 Dataset Number: V03935284CZ 0001
Coding: 002F0F0723
ROD: EV_KessyHellaMQBAB.rod
VCID: 44D1446FDE1347FA33B-8010
Part No SW: 5G0 907 044 FH HW: 5G0 907 044 FH
Component: Climatronic H04 2401
Revision: 00001K10
Coding: 14020104202114011115000080101832
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_ACClimaBHBVW37X 006151
VCID: 72BDD2B7B427B94A517-8026
Air quality sensor:
Humidity sensor: exterior:
Part No SW: 5Q0 937 086 CE HW: 5Q0 937 086 BQ
Component: BCM PQ37BOSCH 038 0303
Revision: -------- Serial number: J53F30091900KA Dataset Number: V03935318QM 0001
ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
ROD: EV_BCMBOSCH_020_VW48.rod
VCID: 7F5B0B83F775E4222E9-802A
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 191021 042 0607
Serial number: 191118093003
Subsystem 2 - Part No SW: 5Q0 955 555 A HW: 5Q0 955 555 A
Component: RLHSS 051 0207
Serial number: S6Y19M12D10H12M31S03
Coding: 0008DD
Subsystem 3 - Part No SW: 3G8 941 633 HW: 3G8 941 633
Component: E1 - LDS MQB H01 0032
Serial number: 16 10 2019 10000260
Humidity sensor: interior:
Steering Column Switch:
Subsystem 5 - Part No SW: 5Q1 953 521 AS HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0100301120190C300887
204290 - Remote key 1
B1479 18 [00001001] - Current Too Low
Reset counter: 206
Mileage: 139870 km
Date: 2024.07.11
Time: 17:14:28
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: OFF
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 12.4 V
Outside temperature: 28.5 °C
Part No SW: 5QA 919 298 H HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0061
Serial number: 000150057319338 Dataset Number: V03935299GA 0001
Coding: 0271167851
Shop #: WSC 05311 115 00062
ASAM Dataset: EV_EPHVA2CAU3700000 009048
VCID: 55F7892B2589CE72545-8000
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 R HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0771
Dataset Number: V03935306FG 0001
Coding: 32057FD355FFC728949C812481400600000000000000000044
ASAM Dataset: EV_ACCBOSCHVW416 003014
ROD: EV_ACCBOSCHVW416_003_VW41.rod
VCID: 46D55E67E82F75EA2DF-8012
0836 - Databus
[FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
Reset counter: 27
Mileage: 142377 km
Date: 2024.08.05
Time: 09:51:32
Control Module temperature: 37 °C
Voltage terminal 15-Voltage: 11.9 V
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s²
Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 C HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0130
Serial number: 26111941350491 Dataset Number: V03935316RN 0001
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 392F259BA9D10A1250D-806C
Part No SW: 3Q0 959 655 CR HW: 3Q0 959 655 CR
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z6PM8AVX1 Dataset Number: V03935279LL 0001
Coding: 98CCC0C00C8000005C5400CF000840000065
Shop #: WSC 05311 000 08193
VCID: 1079B83FDAEBEB5AC73-8044
Subsystem 1 - Part No SW: ----------- HW: 454 002 611 19
Serial number: 357000000008936DE24V
Subsystem 2 - Part No SW: ----------- HW: 454 002 511 19
Serial number: 3580000000098854D34R
Subsystem 3 - Part No SW: ----------- HW: 454 801 311 19
Serial number: 3510059B2691A000000J
Subsystem 4 - Part No SW: ----------- HW: 454 801 311 19
Serial number: 35200790B5B1A000000L
Subsystem 5 - Part No SW: ----------- HW: 454 801 011 19
Serial number: 355008A0E4F1A000000W
Subsystem 6 - Part No SW: ----------- HW: 454 800 712 19
Component: PedP_Sensor_D 304 0149
Serial number: 22800C66A9B1A000000Y
Subsystem 7 - Part No SW: ----------- HW: 454 800 612 19
Component: PedP_Sensor_P 304 0149
Serial number: 229003B759B1A000000R
Subsystem 8 - Part No SW: ----------- HW: 454 800 612 19
Component: PedP_Sensor_C 304 0149
Serial number: 2300033629B1A0000007
Subsystem 9 - Part No SW: ----------- HW: 454 000 510 19
Component: PedP_Sens_D_2 008 0887
Serial number: I0M000000004E8052F35
Subsystem 10 - Part No SW: ----------- HW: 454 000 510 19
Component: PedP_Sens_P_2 008 0887
Serial number: I0N00000000AF8052F3D
Part No SW: 3G5 920 751 B HW: 3G5 920 751 B
Component: KOMBI 301 7430
Coding: 07A4100BFF8C000801806A0B1401000800600000
ASAM Dataset: EV_DashBoardJCIMQBAB 009014
ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
VCID: 290FF5DB5971BA9220D-807C
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [00001000] - -
[BAP_Audio_0x31 keine Kommunikation]
Fault Frequency: 117
Reset counter: 38
Mileage: 139881 km
Date: 2024.07.11
Time: 19:24:40
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 442 4388
Revision: -------- Serial number: 0000447936 Dataset Number: V03935313SG 0001
Coding: 030300045F017300F910027A980F00010001070000000000000000000000
GVL: 01C63C100000040840CC80008002CC0000000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 70B9D8BFBA2B8B5AA73-8024
Generator:
Component: 4-01-13-01-04
Subsystem 2 - Part No SW: 5G0 959 442 AE HW: 5G0 959 442 AE Labels: 3C8-959-537.CLB
Component: E221__MFL-MD9 H12 0052
Serial number: 36190001831070109495
Coding: 2DFFFF
Subsystem 3 - Part No SW: 3Q0 915 181 B HW: 3Q0 915 181 B
Serial number: 7300373205
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 112 1004
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00011.11.19 Dataset Number: v1260x015G0 0000
Coding: 0301
VCID: 4CC16C4FF6438FBAFBB-8018
Address 23: Brake Booster (J539) Labels:. 5QE-909-059.clb
Part No SW: 3Q0 909 059 G HW: 3Q0 909 059 B
Component: EBKV H06 0069
Serial number: BPA085031219013
Coding: 4103C500460000B5D65A6BAD000049922449920400
ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
ROD: EV_BrakeBoostG2BoschVW48X_011_VW37.rod
VCID: 3B233F93A3ED3802421-806E
172400 - System Voltage
P0562 00 [00100000] - Too Low
[PSCUnderVoltageLevel1]
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH08 0014
VCID: 45D7596BD5297EF2245-8010
0033 - Supply voltage
U1011 00 [00001000] - Voltage too Low
[Supply voltage - lower limit exceeded]
Reset counter: 25
Mileage: 139987 km
Date: 2024.07.12
Time: 20:02:42
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Reset counter: 25
Mileage: 140183 km
Date: 2024.07.22
Time: 12:14:01
Address 3C: Lane Change (J1086) Labels:| 2Qx-907-686-V2.clb
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0149
Serial number: 00000533756264 Dataset Number: V03935302PC 0001
Coding: 52954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H06 0149
Serial number: 00000535350447
Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 F
Component: TSG FS002 0330
Serial number: YE007SKE06855 Dataset Number: V03935308ZN 0001
Coding: 00354B42D000020000001000
ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
VCID: 49CF555BF9319A92C0D-801C
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Dataset Number: V03935312ZQ 0001
Coding: 931F0000
Shop #: WSC 00015 115 00317
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C213C8FA6E33F3A4BB-8068
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 06121910520115 Dataset Number: V03935295FR 0205
Coding: 00000005090004D207106F05020000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_003_VW27.rod
VCID: 372B23A39FC51C62A69-8062
Part No SW: 5Q0 959 592 K HW: 5Q0 959 592 F
Component: TSG BFS002 0330
Serial number: YE007SK919968 Dataset Number: V03935308ZR 0001
Coding: 00354142DC00020000001000
ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
VCID: 48C9505FE23B639ADF3-801C
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 3G5 035 820 HW: 3G5 035 820
Component: MU-O-ND-EU H12 0156
Serial number: VWZAZ2W1212618 Dataset Number: V03935317GB 0001
Coding: 24830000000000000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001001
ROD: EV_MUOIMQB_001_VW48.rod
VCID: 619FADFB61C132D238D-8034
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H61 8214
Serial number: VWZ6ZHX0049974
Subsystem 2 - Part No: V03 959 806 MG
Component: EU 2019/04 1004
7951 - Control module
B2001 00 [00001000] - Incorrect software version
[Trip computer setup (0x0F) - control module: incorrect software version - BapErr_incompatible data specification]
Reset counter: 19
Mileage: 140163 km
Date: 2024.07.20
Time: 09:41:18
Voltage terminal 30: 12.4 V
7953 - Control module
[Time/date (0x11) - control module: incorrect software version - BapErr_incompatible data specification]
Reset counter: 14
Mileage: 140088 km
Date: 2024.07.18
Time: 07:57:25
Voltage terminal 30: 12.1 V
1561 - Predictive Route Data
B1630 02 [00001000] - Signal Failure
Mileage: 142377 km
Date: 2024.08.05
Time: 09:51:32
Voltage terminal 30: 11.9 V
Component: RVC Compact H18 0231
Dataset Number: V03935279AD 0001
Coding: 0184030162002017000040
Part No SW: 5WA 035 284 HW: 5WA 035 284
Component: OCUGen3High H20 0088
Serial number: 0000000909VIKE5 Dataset Number: V03935314UU 0001
Coding: 024830001968A8209005460160502607
ASAM Dataset: EV_OCUGen3High 002115
ROD: EV_OCUGen3High_002_VW37.rod
VCID: 035387739B9D80C24A1-8056
0081 - Databus
[Ethernet Databus missing message - Infotainment Unit]
Mileage: 142377 km
Date: 2024.08.05
Time: 09:10:13
Voltage terminal 30: 10.4 V
1190912 - Ethernet Databus Branch 1
U122C 00 [00001000] - No Communication
Mileage: 142377 km
Date: 2024.08.05
Time: 09:50:28
Ethernet counter checksum error: branch 1: 0
Ethernet counter connection interruptions: branch 1: 1
1572115 - LTE Antenna 1
B17FD 13 [00001001] - Open Circuit
Mileage: 139848 km
Date: 2024.07.11
Time: 08:43:13
2566 - GPS Antenna
B1054 13 [00001001] - Open Circuit
[GPS-Antenna - Interruption]
Mileage: 139848 km
Date: 2024.07.11
Time: 08:43:13
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0610
Serial number: 14121912K23127 Dataset Number: V03935308GP 0001
Coding: 000408040000040100221346C150A9009C000E30004000
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40D9487FCA0B5BDA173-8014
Part No SW: 3G8 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0003
Serial number: 190604200999
VCID: 71BFDDBBB1218252A8D-8024
Part No SW: 5Q0 959 395 K HW: 8W1 959 395 D
Component: TSG HFS004 0330
Serial number: YE007SKC32362 Dataset Number: V03935306TZ 0001
Coding: 000041420100020000001000
ROD: EV_DCU2RearDriveMAXHKLO_VW37.rod
Component: TSG HBFS004 0330
Serial number: YE007SKC28894 Dataset Number: V03935306TU 0001
ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 1675CE27F80F056A9DF-8042
Component: LED1R H09 0003
End----(Elapsed Time: 02:34, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
Address 0x75,5WA 035 284 ,UDS Selective Output Tests,MAS18799-Radio / radio navigation system muting test
Address 75: DTCs cleared
