- Aug 3, 2024
- 9
- 0
- Kentucky, USA
- C?ID=585466
Is there a way to test my yaw sensor on 04 Volkswagen beetle gls? It's not throwing a code but when driving, it yanks me to the left then right very hard. Like the tire are over accelerating the other tire. I've replaced the ABS Sensors and did the steering wheel alignment. I'm thinking it can only be the yaw sensor going bad but don't know how to test it with the VCDS. Already replaced front ABS sensors and pedal but still have code. Thanks!
Sunday,04,August,2024,13:32:03:61166
VCDS Version: 24.7.0.0 HEX-V2 CB: 0.4643.4
VIN: 3VWCK31C04M419824 License Plate: 04 BEETLE 8-4
Mileage: 154000km-95691mi Repair Order:
Chassis Type: 1C (9C - VW New Beetle (1999 > 2010))
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
VIN: 3VWCK31C04M419824 Mileage: 154000km-95691miles
Address 01: Engine Labels: 06A-906-032-BEV1.clb
Part No: 06A 906 032 MS
Component: 2l LEV2 NB AG4 G 5505
Coding: 00003
Shop #: WSC 00069
VCID: 7BA3E1AAAAFB8E320A1-5160
VINID: 0E69D36C305300474404920210E8C4FFEC
3VWCK31C04M419824 VWZ5Z0D2198070
18034 - Powertrain Data Bus
P1626 - 35-10 - Missing Message from TCU - Intermittent
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 MG
Component: AG4 Getriebe 01M 5046
Coding: 00000
VCID: 015F9342C817E4E250D-0962
00777 - Accelerator Position Sensor (G79)
00293 - Multi-function Switch (F125)
25-10 - Unknown Switch Condition - Intermittent
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Coding: 0022530
Shop #: WSC 00066 000 00000
VCID: 34310A96C225814A8BB-5160
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No: 6Q0 909 605 AG
Component: 01 AIRBAG VW71 0710
Coding: 0012337
VCID: 7CA1E2B6AAF5890A03B-5160
Subsystem 1 - Part No: 1C0 959 339
Component: BF-Gewichtsens. 004 0005
02513 - Belt Force Sensor for Seat Occupied Recognition (G453)
00592 - Seat Belt Switch; Passenger (E25)
006 - Short to Plus - Intermittent
Address 17: Instruments Labels: 1C0-920-x4x.lbl
Part No: 1C0 920 951
Component: KOMBI+WEGFAHRS. M73 V02
Coding: 11232
VCID: 5EE5883E19297B1A0DF-4B1E
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<->CAN V022
Coding: 00006
Shop #: WSC 00066
VCID: 70B9C686F3BDFD6AAF3-4B1E
Part No: 1C0 959 799 G
Component: 2K Komfortgerát HLO 0004
Coding: 00064
Shop #: WSC 00066
VCID: 3B2321AAEA7B4E324A1-4B1E
Subsystem 1 - Part No: Steuerger
Component: t Fahr. antwortet nicht
Subsystem 2 - Part No: 1C2959801A
Component: 2K Tõrsteuer.BF KLO 0202
49-00 - No Communications
35-00 - -
Address 56: Radio Labels: 1J0-035-18x-56.clb
Part No: 1C0 035 196 H
Component: RADIO DE2 0004
Coding: 06031
Shop #: WSC 00066
VCID: 2411FAD677C511CA1BB-51F2
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
End----------(Elapsed Time: 03:46, VBatt start/end: 14.3V/14.3V)------
