Request for MY2015;2016 EU Passat/CC autoscan
golfi_vend
Tartu, Estonia
C?ID=195131
Hi
I'm looking for autoscan. I'm intrested in following parts fitted and their part nr: ACC, ABS, Lane camera, radio, CAN gw.
Thanks!
golfi_vend
Tartu, Estonia
C?ID=195131
Maybe RT team has some scans?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
What do you need specifically? I usually don't give out random customer scans, so anonymizing them would be mandatory but that also requires some time. Therefor the more specific your question the easier it may be to answer. :)
golfi_vend
Tartu, Estonia
C?ID=195131
I like to match what is missing for older models to fit Discovery Media navigation. Supposedly it needs SW1000+ instrument cluster, definitely needs 7n0 BC can gateway. Also missing info about Lane assist camera. Heard that it need 3q0 camera for sign assist to work.
Cluster with sw 0703 or 0705 don't work. Or at least dealer wasn't able to remove CP.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The Passat (3G) uses a 5Q0 (MQB) Gateway, which is also the CP-Master. The MQB-GW breaks backwards compatibility to non-UDS control modules diagnostic wise and possibly with older communication matrix versions in general. Your best bet is to check in other facelifted models like The T6 which is essentially a T5.3/T5GP2 and therefor a mix of the old and new platform.
golfi_vend
Tartu, Estonia
C?ID=195131
Yes. Thatswhy i would need can gw with letter cb. I have already tried that and it will work with non uds modules.
CC from 25.05.15 has also updated radio, so i guess i would need parts from there. Autoscan is hard to find though.
golfi_vend
Tartu, Estonia
C?ID=195131
Do you have any suggestions for me Sebastian? Already is tried to have CB gateway and radio installed. Dealer wasn't able to remove component protection.
PS! I should mention that i don't have this car at my range at all times. So i can't try different thing at all time.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
After doing some searching, I haven't come across a scan from those latest CCs. Those aren't real B8's but facelifted B7s. Much like the 2016 Caddy or the 2016 T6. If I understand your current Golf situation properly you did install a bunch of Passat components - if it was still a Golf I would point you towards the latest 2016 Caddy's instead. Here's some of the info you're looking for - though from such a Caddy - maybe that get's you further (let me know if I stripped too many details)...
Address 13: Auto Dist. Reg (J428)
   Part No SW: 7N0 907 572 A    HW: 7N0 907 572
   Component: ACC Bosch PQx H03 0111
   Coding: 00000000FE0339
Address 17: Instruments (J285)
   Part No SW: 2K5 920 876 A    HW: 2K5 920 876 A
   Component: KOMBI         H04 1009
   Coding: 180E01
Address 19: CAN Gateway (J533)
   Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1663
   Coding: 357430
Address 20: High Beam Assist. (J844)
   Part No SW: 7E0 857 511 F    HW: 7E0 857 511 C
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 020200E700000000000000
Address 25: Immobilizer (J334)
   Component: IMMO          H04 1009
Address 5F: Information Electr. (J794)
   Part No SW: 5C0 035 680 B    HW: 5C0 035 680 B
   Component: MU-S-N-ER     H20 0241
   Coding: 06330701BE00000011110001000808001F01008400200100CF
P.S.: Component protection diagnostic functions (reading status information etc.) has been on my wish list for VCDS for quite a few years - sadly the number of requests we get to justify implementing it isn't that high. Mind you, this is only about reading and displaying some related identifiers, not about actually learning component protection. Though in situations like this (retrofits and repairs/replacements) it might be enough to shed some light on things...
golfi_vend
Tartu, Estonia
C?ID=195131
Nono, not for my golf... :)
For Passat B7. I myself like to do same thing for my --yet to come-- B6 3.2. - Have i said that i hate paperworks? :)
But you have showed one thing. SW seems to be needed 1000+ for radio to being matched. Cluster 3aa920881A has also the VIN and component fields available for being SW0705.
From what I've been told, ODIS checks VIN of the car and as this car isn't supposed to have this radio installed, it will decline matching.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
We've had customers for example with a Golf (5G) that had no radio from factory and one got retrofitted - GeKo allowed matching the CP even though the car didn't have a radio from factory. IMMO and CP are very much intertwined, even though they are separate systems they do share some of the bytes that are transferred around when it comes to matching. My guess is that if the car didn't have CP from factory it is unlikely to retrofit in a way making it GeKo compatible - at least not w/o faking a VIN etc. from a car that would have the options in question. I've had customers learn CP in a different car and then move "all" components over to another one - that may very well work for you as well.
golfi_vend
Tartu, Estonia
C?ID=195131
There are companies that are able to disable Golf7 CP, but asking them about these CC and Tiguan Discovery units, they say "Not possible" :(
golfi_vend
Tartu, Estonia
C?ID=195131
Company in Denmark said they are able to remove CP frome these units.
As this is totaly out of VCDS subject, i won't discuss it further. :)
compu_85
Springfield, VA
C?ID=152533
2016 Passat SE, 1.8 Auto
An old thread, but attached is the auto scan from my father's new to him '16 Passat SE w/ Tech & Driver Assist (so it has Kessy, ACC, and Lane Assist). I didn't look at the engine code.
Saturday,02,July,2016,12:48:11:04834
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: 1VWBT7A34GC048933   License Plate: DAD
Mileage: 390km-242mi   Repair Order:
Chassis Type: A3 (7N0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 25 2B 3C 42 44 46 4F 52 5F
          61 62 72 75
VIN: 1VWBT7A34GC048933   Mileage: 390km-242miles
Address 01: Engine (J623-CPRA)       Labels: None
   Part No SW: 06K 906 071 AG    HW: 06K 907 425 C
   Component: R4 1.8l TFS   H13 2359
   Revision: --H13---
   Coding: 001A0092244400171000
   Shop #: WSC 09003 957 00200
   ASAM Dataset: EV_ECM18TFS02006K906071AG 001004
   ROD: EV_ECM18TFS02006K906071AG.rod
   VCID: 70AC10EDABB1F1BE8E-8024
Address 02: Auto Trans (J217)       Labels: 09G-927-749.clb
   Part No SW: 09G 927 749 AN    HW: 09G 927 749 AN
   Component: AISIN AG6 G3  129 2969
   Coding: 000348
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_AU37.rod
   VCID: 054251398433C4164D-8050
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: C54BC0F549260002A31403E7921C004100F0F01A
   VCID: 75A221F9DCD3D4965D-8020
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 F    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1202
   Revision: 00093000    Serial number: 0393019791
   Coding: 030C0C
   ROD: EV_KESSYPQ35G.rod
   VCID: 383CE8CD834169FE86-806C
   Slave 1:
   Part No SW: 561 907 044 AM    HW: 561 907 044 AM
   Component: Climatronic   H07 0910
   Revision: 00001K04
   Coding: 0050019002
   VCID: 62886AA5755D532E08-8036
   Part No SW: 5K0 937 087 AL    HW: 5K0 937 087 AL
   Component: BCM PQ35 H++  122 0183
   Revision: BN122001
   Coding: EF200E1B982B08D4098804013400854800F1000645A00DB0E4806200AC70
   VCID: 7F4EC3D1EEEF9EC607-802A
   Subsystem 1 - Part No: 5K7 955 559 B
   Component: RLS 300116 03  37  0059
   Coding: 0038DD
            000 -  -  - Intermittent
                    Reset counter: 43
                    Mileage: 373 km
                    Date: 2016.05.11
                    Time: 16:33:17
                        Term 15 Off
                    Voltage: 12.40 V
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 7N0 907 572 B    HW: 7N0 907 572
   Component: ACC Bosch PQx H03 0120
   Serial number: 12021677091175
   Coding: 01001002FE0739
   ASAM Dataset: EV_ACCBEGVW361 001005
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: 3522E1F9945394969D-8060
0110 - Transport Mode Active
          U1105 00 [008] - -
                    Fault Frequency: 9
                    Reset counter: 41
                    Mileage: 4 km
                    Date: 2016.04.08
                    Time: 19:34:50
Address 15: Airbags (J234)       Labels: 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    001 0207
   Serial number: 003RXM04ERXY
   Coding: 8CCCCC00000000005000001A020800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411.rod
   VCID: 63866FA16A475A2603-8036
   Component: BF-Gewichtss.  H12 0021
   Serial number: IBH000000000004PTFUK
   Coding: 30324C
   Subsystem 2 - Part No SW: -----------    HW: 480 001 202 16
   Serial number: 3570000000063A95A71N
   Subsystem 3 - Part No SW: -----------    HW: 480 001 602 16
   Serial number: 358000000006FBECB818
   Subsystem 4 - Part No SW: -----------    HW: 480 020 902 16
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001AF1EED23474CN
   Subsystem 5 - Part No SW: -----------    HW: 480 021 901 16
   Component: SideSensor_Pr  000 0148
   Serial number: 35200019B1E8F7F2D70R
   Subsystem 6 - Part No SW: -----------    HW: 480 020 202 16
   Component: FrontSensor_D  000 0189
   Serial number: 3550001A11E9A6C464CH
   Subsystem 7 - Part No SW: -----------    HW: 480 020 202 16
   Component: FrontSensor_P  000 0189
   Serial number: 3560001A11E9A6C1F48K
   Part No SW: 1K5 953 521 CR    HW: 5K0 953 569 BF
   Revision: FF010042    Serial number: 20160203100214
   Coding: 0002C40008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7F4EC3D1E6EF9EC607-802A
   Subsystem 1 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B
   Serial number: 3641511104801051AF2B
   Coding: 2C0000
   Part No SW: 561 920 971     HW: 561 920 971
   Component: KOMBI         H04 1008
   Coding: 231E010000
   VCID: 58FC484D230189FE66-800C
   Part No SW: 7N0 907 530 BG    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1673
   Revision:   H56       Serial number: 01031603010968
   Coding: 461010
   VCID: 76A026F5C1D5DF8E54-8022
   Component: IMMO          H04 1008
   Coding: 000007
   VCID: 6A9802858D6D0B6EC0-803E
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 16000012263002
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 312AD5E9603BB8B6C1-8064
Address 3C: Lane Change (J1086)       Labels: None
   Serial number: 0395679984
   Coding: 01011102
   ROD: EV_HREntryHella_SK37.rod
   VCID: 3C34F4DDB77945DE62-8068
   Lane Change Assistant 2:
   Part No SW: 561 959 701 C    HW: 3C0 959 793 J
   Component: TUER-SG FT    002 0637
   Revision: 12100010    Serial number: 0010299060
   Coding: 0404BD
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1E701E5501A537CE6C-804A
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 C    HW: 561 959 811 C
   Component: J388__TSG_HL  022 1472
   Serial number: 14102746160324165725
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 311    3501
   Revision: 00H22000
   VCID: 393AEDC9704B70F679-806C
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1673
   Coding: 01030108
   VCID: 6FAE1391BE8FEE4697-803A
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Coding: 181100
   Subsystem 2 - Part No SW: 561 919 204 C    HW: 561 919 204 C
   Component: Analoguhr  002 0002
02987 - Control Module for Sliding Roof (J245); Function Interruption
                    Reset counter: 41
                    Mileage: 6 km
                    Date: 2016.04.25
                    Time: 16:37:14
   Part No SW: 561 959 702 C    HW: 3C0 959 792 J
   Component: TUER-SG BT    002 0637
   Revision: 14100010    Serial number: 0010294690
   Coding: 0405BC
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1F0E235106AF3EC667-804A
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 C    HW: 561 959 812 C
   Component: J389__TSG_HR  022 1472
   Serial number: 14102747160328160521
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 5C0 035 684     HW: 5C0 035 684
   Component: MU-S-NS-US    H22 0245
   Serial number: VWZAZ2S0075441
   Coding: 02140102FF00000051220001001808001F0100D400200105C6
   ROD: EV_MUStd4CTSAT_VW26.rod
   Component: Batt.regelung H56 1673
   Coding: E1200859
   VCID: 71AA15E9A8BBF8B681-8024
Address 62: Door, Rear Left
Address 72: Door, Rear Right
Address 75: Telematics (J949)       Labels: None
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0158
   Serial number: 000003554140547
   Coding: 02140102C24232107F1606000000
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow.rod
   VCID: 14647C7DFF696D9ECA-8040
End-------------------------(Elapsed Time: 02:00)--------------------------
Thanks,
-J
