HEX-NET Update failed!
TTT
C?ID=547002
Since I am now starting longer trips to work, I want to be able to check the car using my mobile.
Issue: on Auto-Scan, or Select, an ASAM update is requested, I select Download updates, download happens, verify happens, but always fail on exact same step 11/80 with the error as in the picture.
Phone and HEX-NET are connected to the same AP. Phone is Iphone 8 Plus. I have tried Clear Cache, Clear Dataset, there is no change. An Auto-Scan will show ROD: N/A if that is important? And no ASAM dataset.
How to troubleshoot this further?
This vehicle: https://forums.ross-tech.com/index.php?threads/40746/
Shaun
This is most likely because you were previously on an alpha/beta channel with newer rods, and are now on the release channel where those rods are not available. I put your interface back on the beta channel, please try again. If the update still doesn't go through, please try doing the update with VCIConfig on a PC.
TTT
C?ID=547002
Shaun, thanks, I wasn't aware of the beta/release difference. But I am confused, this car is 2018, are these rods still in beta? This does sound odd to me, so I must be wrong somehow.
Further, updating via VCDS-Mobile ended in the same Update Failed! in the same rod 11/80 whichever that is, because I can't see it. Would be wise to post that pop-up menu at the screen bottom?
Via VCIConfig on PC, update succeeded. However, doing an auto-scan resulted in an what seems endless ASAM dataset updates pop-up, everytime downloading the exact same size and same 84 or so rods. It just did not stop the cycling.
Status as I speak: no ASAM data for my retrofitted module 65 Tire pressure module. Rod is reported as N/A I don't understand why, as the PC auto-scan works fine.
The good news is that I can access all other modules, someone is happy here in NL.
Westbury, UK
The clue I suspect is the word retrofitted, if VCDS isn't expecting a module with that part number to be present in your model of car it won't have a link to the ASAM data.
TTT
C?ID=547002
Maybe yes maybe not. I indicated that, so I give full picture if possible.
I do software audits for a living, from functional point of view, part time… no guru here ok? So I would straight ask: why on PC there isn’t an issue and on mobile yes? I think it might be a simple issue?
Shaun
VCDS on a PC and VCDS-Mobile are completely separate codebases, and also running entirely different datasets, so you are kind of comparing apples and oranges here. If this works on PC it is possible that a future update will bring coverage of this to mobile, but as this is a retrofit I don't make any promises.
TTT
C?ID=547002
Understood, for what I need, this is looks good so far. Thank you.
TTT
C?ID=547002
Unsure if I can continue here, with small bugs reporting?
This showed up after the iphone screen timed-out, instead of 2 rows I got 2 extra with no description but cloned data.
  • Informative
TTT
C?ID=547002
If I am trying to use Live Data HUD, no joy.
I selected the same IDE as above, terminal 30 voltage and coolant temperature. Regardless if I use graph or text view, I get other IDEs I haven't select, which btw don't make sense, flap motor, is this from HVAC actually?
TTT
C?ID=547002
A less critical one: advanced data list, for long text, the IDE hides under the below check box. Line-up should be like text below text on each row. Unsure what can be done about it.
Shaun
If you want, you could be a debug log in mobile like this: [Options] debug level = 001f [Submit] now start the incorrect live data HUD. Email that debug log to us or make sure it is synced to cloud, and I can check into what is going on there.
  • Agree
Reactions: TTT
TTT
C?ID=547002
I believe I made a log and synced to cloud. Thanks so far.
TTT
C?ID=547002
Some more improvements ideas:
View area seems excessively large. I zoomed out completely and this is how far it goes.
I'm trying to get a log updated, but seems stuck. Unsure the reason, my firewall or cloud side. The email function worked reasonably fast.
TTT
C?ID=547002
Odd one today. Combination of VCDS and gateway invented new modules on my car, which are not installed. No changes were done whatsoever with regards to gateway installation list. So issues with:
- 05 claimed not registered
- 29 I don't have it
- 39 I don't have it.
- 75 I don't have it.
Fun fact: the fault code on gateway is caused by me, I forgot the vcds plugged in the entire day.
VCDS-Mobile
Log Viewer V0.6
Username: TTT
Logout
#hndoc:?docid=00009B73&xt=hnh:10123E56128E499A01E8CEDE9D715FC749B17D7D8BF84928E74EC6755DE90E35
Wed,Aug,21,2024,07:21:22
VCDS Mobile 0.4654.0.5
VCDS Mobile: 0.4654
Data Version: 00000064
VIN: VSSZZZ5FZK6528195
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 29 2B 39 3C 42 44 47 4B
     52 5F 65 69 6C 6D 75 A5 CA D6 D7
05-Acc/Start Auth. -- Status: Not registered 0011
29-Left Light -- Status: Not registered 0011
39-Right Light -- Status: Not registered 0011
75-Telematics -- Status: Not registered 0011
CA-Sunroof -- Status: OK 0000
Address 01: Engine  (J623-DADA)    Labels: 05-01.lbl
    Part No SW: 05E 906 018 R    HW: 05E 907 309
    Component: R4 1.5l TFS   H22 9832
    Revision: 81H22000
    Coding: 012500322364050830000000000000000000000000000000
    Shop #: WSC 00249 211 00000
    ASAM Dataset: EV_ECM15TFS01105E906018R 003004
    ROD: EV_ECM15TFS01105E906018R.rod
    VCID: 342BBFD35B2DE7BF9F1911-8061
No fault codes found.
Address 02: Auto Trans  (J743-)    Labels: 0CW-927-769.clb
    Part No SW: 0CW 300 041 S    HW: 0AM 927 769 E
    Component: GSG DQ200G2_M H05 1694
    Revision: 00005008
    Shop #: WSC 33361 790 00157
    ROD: EV_TCMDQ200021_SE37.rod
    VCID: 45CDF21700B76E3738A7D4-8010
Address 03: ABS Brakes  (J104)    Labels: 5Q0-907-379-IPB-V1.clb
    Part No SW: 5Q0 614 517 DE    HW: 5Q0 614 517 AD
    Component: ESC           H25 0524
    Revision: 00000000
    Coding: 21EE6A92242224748778060962C82484562424E1604624733822F00442A2430B002D641212131A1E35351919323200
    ROD: EV_Brake1UDSContiMK100IPB_037_SE37.rod
    VCID: 77B148DF0ADBCCA77ABB0E-8022
Address 05: Acc/Start Auth.  (J518)    Labels: 5Q0-959-435.clb
    Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
    Component: VWKESSYMQB    037 1204
    Revision: 00037000
    Coding: 132C0C0707
    ASAM Dataset: EV_KessyHellaMQBAB 004046
    ROD: EV_KessyHellaMQBAB_004.rod
    VCID: 43C9EC0F0E83500716B3CA-8016
Address 08: Auto HVAC  (J255)    Labels: 5G0-907-044.clb
    Part No SW: 5F0 907 044 AL    HW: 5F0 907 044 AL
    Component: Climatronic   H05 1801
    Revision: 00001K09
    Coding: 06000024200114011105000000101020
    Shop #: WSC 33361 790 00113
    VCID: 70A373C36FB59B9FBB71FD-8025
    Subsystem 1 -
    Subsystem 2 -
    Subsystem 3 -
Address 09: Cent. Elect.  (J519)    Labels: 5Q0-937-08X-V2.clb
    Part No SW: 5Q0 937 084 DD    HW: 5Q0 937 084 CG
    Component: BCM MQBAB H   H38 0273
    ROD: EV_BCMMQB_019_SE37.rod
    VCID: 7DBD5AF728E7E6F720F74C-8028
    Subsystem 1 -     Part No SW: 81A-955-555-A
    Component: G397_RLFSS   H06 0002
    Serial Number: 21987728X81A955555A0
    Coding: 80007E
    Subsystem 2 -     Part No SW: 5Q0-951-177    Labels: 5Q-09-02.lbl
    Serial Number: 000000000ZY182803LQA
    Subsystem 3 -     Part No SW: 5QD-951-605
    Serial Number: 00002856223981702090
Address 10: Park/Steer Assist  (J791)    Labels: 5Q0-919-298.clb
    Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
    Component: PLA 3.0 12K
    Coding: 0A71667A51
    Shop #: WSC 00046 000 00000
    ASAM Dataset: EV_EPHVA2CAU3700000 009041
    ROD: EV_EPHVA2CAU3700000_009.rod
    VCID: 51E5D647C4FFB297943F50-8004
Address 13: Auto Dist. Reg  (J428)    Labels: 2Q0-907-572.clb
    Part No SW: 2Q0 907 572 AB    HW: 2Q0 907 572 B
    Component: ACCCONTIMQB   H03 0397
    Coding: 300D7FCB5EFFC728779F832581508700100000000000004014
    Shop #: WSC 00046 123 12345
    ASAM Dataset: EV_ACCMRRCONTIVW376 003018
    ROD: EV_ACCMRRCONTIVW376_003.rod
    VCID: 74AB7FD31BADA7BF5F99D1-8021
Address 15: Airbags  (J234)    Labels: 5Q0-959-655.clb
    Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
    Component: Airbag VW21   006 0712
    Revision: --------
    Coding: 98CCC0C0000000005C5400CC000800000065
    ROD: EV_AirbaVW21TS6VW48X_SE37.rod
    VCID: 854DB217C0372E37F82794-80D0
    Subsystem 1 -     Part No SW: --------------
    Component: SideSensor_Df008 0887
    Serial Number: 3570000000041D205232
    Subsystem 2 -     Part No SW: --------------
    Component: SideSensor_Pf008 0887
    Serial Number: 3580000000090568623C
    Subsystem 3 -     Part No SW: --------------
    Component: SideSensor_Dr301 0148
    Serial Number: 35100F8C99816000000Y
    Subsystem 4 -     Part No SW: --------------
    Component: SideSensor_Pr301 0148
    Serial Number: 3520093739716000000C
Address 16: Steering wheel  (J524)    Labels: 5Q-16.lbl
    Part No SW: 5Q0 953 521 LE    HW: 5Q0 953 569 A
    Revision: FF035035
    Coding: 6C14
    ROD: EV_SMLSVALEOMQB.rod
    VCID: 8043A303DF150B1FCB11AD-80D5
Address 17: Instruments  (J285)    Labels: 5G0-920-XXX-17.clb
    Part No SW: 5F0 920 790 A    HW: 5F0 920 790 A
    Component: KOMBI         609 1703
    Coding: 04AD5A9A6E8C00080188760F3001000080000000
    ASAM Dataset: EV_DashBoardVDDMQBA0 001031
    ROD: EV_DashBoardVDDMQBA0_001_SE37.rod
    VCID: 2711589F9AFB9C272A9B9E-8072
Address 19: CAN Gateway  (J533)    Labels: 3Q0-907-530-V1.clb
    Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
    Component: GW MQB High   518 5344
    Coding: 030500F42F085700E90002D81C0F00010001070000000000000000000000
    Shop #: WSC 131071 102 209715
    ROD: EV_GatewNF_SE37.rod
    VCID: 3D3D9AF7686726F760778C-8068
    Subsystem 1 -     Component: 1-00-03-00-04
    Subsystem 2 -     Part No SW: 5F0-959-537-D
    Component: E221__MFL-PR6H04 0130
    Serial Number: 000000000G1298180918
    Coding: 012000
    Subsystem 3 -     Part No SW: 5Q0-915-181-J
    Component: J367-BDMContiH03 1050
    Serial Number: 758860020018102900EB
8531970 - Quiescent Current
    U1406 00 [008] - Too High
Address 29: Failed to respond
Address 2B: Steer. Col. Lock  (J764)    Labels: 5Q0-905-861.clb
    VCID: 3329BCCF5E23E08786131A-8066
Address 39: Failed to respond
Address 3C: Lane Change  (J1086)    Labels: 5Q0-907-686.clb
    Coding: 02012103
    Shop #: WSC 57812 002 1048576
    ROD: EV_HREntryHella.rod
Address 42: Door Elect, Driver  (J386)    Labels: 5QX-959-X93-42.clb
    Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
    Component: TSG FS        006 0246
    Coding: 00351320D000020000001000
    ROD: EV_DCU2DriveSideMAXHCONT_SE37.rod
    VCID: 48D3FB2337A5735FC3C135-801D
Address 44: Steering Assist  (J500)    Labels: 5Q0-909-144.clb
    Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
    Coding: 931F0000
    ROD: EV_SteerAssisMQB_015.rod
    VCID: 3C3B97F3737D2FFF5749B9-8069
Address 47: Sound System  (J525)    Labels: 5Q0-035-456.clb
    Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
    Component: MIB2_lite_amp H40 0200
    Revision: 00000001
    Coding: 3300000000A0AF8A000000000000
    ASAM Dataset: EV_AMPMst11CGen2ALPI 001004
    ROD: EV_AMPMst11CGen2ALPI.rod
    VCID: 2E1FADBBB501CD6FE9DDD3-807B
Address 4B: Multifunc. Module  (J745)    Labels: 3Q0-907-338-V2.clb
    Component: FCM MQB Low   002 0345
    Coding: 000000070900064201000940000000000000000000000000000000000000
    ASAM Dataset: EV_MultiModulContiVW48X 002006
    ROD: EV_MultiModulContiVW48X_002.rod
    VCID: 352D82D75057FEB7A80764-8060
Address 52: Door Elect, Pass.  (J387)    Labels: 5QX-959-X92-52.clb
    Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
    Component: TSG BFS       006 0246
    Coding: 00351120D000020000001000
    ROD: EV_DCU2PasseSideMAXHCONT_SE37.rod
    VCID: 47D1F81F3ABB7C27CADB3E-8012
Address 5F: Information Electr.  (J794)    Labels: 5F-5f.clb
    Part No SW: 5F0 035 020 K    HW: 5F0 035 020
    Component: MU-H-ND-EU    H55 1447
    Coding: 04230601000000001111010200880A232F0101E4012004009E
    ROD: EV_MUHig4CGen2HBAS_SE37.rod
    VCID: 20034383FFD56B1F6B514D-8075
    Subsystem 1 -     Part No SW: 575-919-606
    Component: ABT_High-2_N H41 1041
    Serial Number: SEZ8Z9V1S02GU4
    Subsystem 2 -     Part No SW: V03-959-821-JH
    Component: ECE 2024/2025--- 0370
    Serial Number: --------------------
    Subsystem 3 -     Part No SW: V03-959-800-EG
    Component: Gracenote2   --- 1017
Address 65: Tire Pressure  (J502)    Labels: 3AA-907-273.clb
    Component: RDKBERU30     H06 0009
    Shop #: WSC 00000 000
    ROD: N/A
    No ASAM data for: "EV_RDKBERU30"
Address 69: Trailer  (J345)    Labels: 5Q0-907-383.clb
    Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
    Component: Anhaenger     H27 0264
    Revision: 8A001003
    Coding: 0100000202000000
    ROD: EV_TrailFunctGener2Hella_SE37.rod
    VCID: 42C7E90B1199590F1D85F7-8017
Address 6C: Back-up Cam.  (J928)    Labels: 5Q-6c.lbl
    Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
    Component: Areaview 2    H13 0608
    Coding: 06230601270FA00000716814
    ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
    ROD: EV_CamSysRVAV2ARCE2MQBAB_006.rod
    VCID: 39358EE77C4F1AD74C2F58-806C
Address 6D: Trunk Elect.  (J605)    Labels: 5Q0-959-107.clb
    Part No SW: 5Q0 959 107 P    HW: 5Q0 959 107 J
    Component: HDSG-Modul    H13 0266
    Revision: --------
    Coding: 1988
    ROD: EV_DeckLidCONTIAU736_SE37.rod
Address 75: Failed to respond
Address A5: Frt Sens. Drv. Assist  (R242)    Labels: 3Q0-980-65X-A5.clb
    Part No SW: 3QD 980 654 A    HW: 3Q0 980 654 A
    Component: MQB_B_MFK     H09 1611
    Coding: 030307060000040000222355C156890098000E20002000
    ROD: EV_MFKBoschMQBB_002.rod
    VCID: 49D5FE272CAF8A57DCCF08-801C
Address CA: Sunroof  (J245)    Labels: 4M0-907-594.clb
    Component: SAD_STG_1     005 0002
    Coding: 408040532602
    ROD: EV_SunRoofCONTIAU736_009_SE37.rod
    VCID: 75AD42D710D7BEB7688724-8020
Address D6: Light Ctrl Left 2  (A31)    Labels: 7P5-941-591.clb
    ROD: EV_LED_PLUS_L_KEBODAVW416.rod
    VCID: 7EBF5DFB25E1FDEF39FD43-802B
Address D7: Light Ctrl Right 2  (A27)    Labels: 7P5-941-591.clb
    ROD: EV_LED_PLUS_R_KEBODAVW416_SE37.rod
End--(Elapsed Time: 04:05, VBatt start/end: 12.6/12.4 Vign: 12.4)-
VCDS-Cloud is a service of Ross-Tech, LLC
