Mk7 Convenience Open/close only driver window works.
mk7GolfAlltrack
Cincinnati, OH, USA
C?ID=527058
I have a 2017 Golf Alltrack. I'm having issues with my car only having the drivers window roll down despite all the coding performed on VCDS to have all the windows go down.
Infotainment menu setting does have all window's selected.
I have checked that all auto up and down windows are calibrated and working correctly when the car is on.
No faults in 09 electronics to cause an issue either.
Am I missing anything? I've searched other posts here and on other forums but to no avail.
Here's what I've done -
  1. From the Select Control Module screen click on 09-Cent. Elect.
  2. Select Security Access -16 and enter the magic number 31347
  3. Select Adaptation - 10
  4. Enter "Comfort opening" into the search box and select ENG141681-IDE02022-ZV Komfort-Comfort opening
  5. change setting to active and click-on Doit!!
  6. Enter "Comfort closing" into the search box and select ENG141681-IDE02021-ZV Komfort-Comfort closing
  7. change setting to active and click-on Doit!!
  8. Enter "Komfort oeffnen" into the search box and select ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen
  9. change setting to active and click-on Doit!!
  10. Enter "Komfort schliessen" into the search box and select ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen
  11. change setting to active and click-on Doit!!
  12. Enter "einstellbar" into the search box and select ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar
  13. change setting to adjustable and click-on Doit!!
Sunday,28,July,2024,21:45:16:56035
VIN: 3VWH17AU5HM507170   License Plate: 41022V
Mileage: 151370km-94056mi   Repair Order: july
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 42 44 47 52 55 5F
          75 A5
VIN: 3VWH17AU5HM507170   Mileage: 151370km-94056miles
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 L    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0002
   Revision: --H13---    CVN: 583DC733
   Coding: 311D00322466002F1000
   Shop #: WSC 00066 790 00149
   ASAM Dataset: EV_ECM18TFS0208V0906264L 001003
   ROD: EV_ECM18TFS0208V0906264L.rod
   VCID: 45D75CFC452C4812245-8010
   VINID: 0E69D80474651587450070470044558D7D
Readiness: 1110 1101
   Part No SW: 0D9 300 012 F    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H54 4901
   Revision: 06354004    Serial number: TFK01606260141 CVN: 0000862C
   ROD: EV_TCMDQ250021.rod
   VCID: 196FC08C99141CF2B0D-804C
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 61816000001255
   Coding: 43FA6AA1342009738078130781C329C2562C9001C881943C16435052E02903
   Shop #: WSC 01383 790 50316
   VCID: 7BA3FA047368CEE2021-802E
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0408654643 Dataset Number: V03935230D0007
   Coding: 032C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3B233A0433E80EE2421-806E
   Part No SW: 5GM 907 044 C    HW: 5GM 907 044 C
   Component: Climatronic   H04 1601
   Revision: 00001K03
   Coding: 02020024200100000105000012111402
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   VCID: 44D141F84E16711A33B-8010
   Air quality sensor:
          B10CD 00 [00001001] - -
                    Reset counter: 192
                    Mileage: 151370 km
                    Date: 2024.07.28
                    Time: 22:42:32
                    Voltage terminal 30: 11.3 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up lamp: OFF
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 865813071601H5 Dataset Number: V03935240CJ 0001
   Coding: 00511B464041A2F96DE44000001407201800000000000000000000000000
   Shop #: WSC 00066 790 00228
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7AADFF007C52F7EA197-802E
   Component: WWS    160817  043 0581
   Serial number:         160822221304
   Component: RLHS  042 0105
   Serial number: S5Y16M07D02H04M18S18
   Coding: 00A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H03 0004
   Serial number: 0000FST000ZEIPK00000
   Coding: 191800
   Roof shade control module:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H03 0004
   Serial number: 0000FST000ZEKDA00000
   Coding: 191800
   Humidity sensor: interior:
   Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0054
   Revision: --------    Serial number: 39431618400650 Dataset Number: 5GM039v__B_ 0113
   Coding: 0031163011
   ASAM Dataset: EV_EPHVA2CAU3700000 003021
   ROD: EV_EPHVA2CAU3700000_003_VW37.rod
   VCID: 47CB56F47F205A02D69-8012
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Dataset Number: V03935239PQ 0205
   Coding: 350168C141FFC428949C8045000016
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
   Serial number: 003GCR05AT4K Dataset Number: 5GM003V____ 0044
   Serial number: IBH000000000005MZZV2
   Coding: 303137
   Subsystem 2 - Part No SW: -----------    HW: 480 003 006 16
   Serial number: 35700000000BAB887C1/
   Subsystem 3 - Part No SW: -----------    HW: 480 003 006 16
   Serial number: 358000000004CA887C1Z
   Subsystem 4 - Part No SW: -----------    HW: 480 402 706 16
   Serial number: 35100029B20F1951A26$
   Subsystem 5 - Part No SW: -----------    HW: 480 402 706 16
   Serial number: 3520002B920FC741E157
   Subsystem 6 - Part No SW: -----------    HW: 480 401 807 16
   Serial number: 3550002BF21160D3139.
   Subsystem 7 - Part No SW: -----------    HW: 480 401 807 16
   Serial number: 3560002C121160D500ES
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20160714400476
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 73B3D2245B3886A25A1-8026
   Part No SW: 5G1 920 791 B    HW: 5G1 920 795 B
   Component: KOMBI         403 4191
   Coding: 0B2D5008CC984B040208FF220400000000000000
   VCID: 2B030A44C3889E62D21-807E
          U1014 00 [00001001] - -
                    Reset counter: 192
                    Mileage: 151370 km
                    Date: 2024.07.28
                    Time: 22:38:25
16776982 - Databus
          [SWA_01 keine Kommunikation]
                    Reset counter: 192
                    Mileage: 151370 km
                    Date: 2024.07.28
                    Time: 22:38:25
16776996 - Databus
          [FCW_01 keine Kommunikation]
                    Reset counter: 192
                    Mileage: 151370 km
                    Date: 2024.07.28
                    Time: 22:38:25
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 20041610800715 Dataset Number: V03935242HR 0001
   Coding: 0901000830085900FB00221A1E0F00000001050000000000000000000000
   GVL: 01D43C0000000600408C90008000C80000000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 7CA1F9187666C9DA0BB-8028
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29190001732830089305
   Coding: 2DFFFF
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0096243
   Serial number: HA1-00021.05.16 Dataset Number: v1260x015G0 0000
   Coding: 0001
   VCID: 4ACD6FC06C32A76AC97-801E
   Revision: 00000000    Serial number: 16000117722002
   Coding: 5D00000000000000
   Shop #: WSC 00066 790 07025
   VCID: 343111381EB6C19A83B-8060
   Serial number: 28071606050B0E Dataset Number: V03935226UJ 0009
   Coding: 003F1320DC00020000000000
   VCID: 43D342E44B1876220A1-8016
   Serial number: 00000000000013355841
   Coding: 011000
   Component: EPS_MQB_ZFLS  129 1072
   Dataset Number: V03935242JV 0001
   Coding: 9302
   ROD: EV_SteerAssisMQB_013.rod
   Component: MIB2_lite_amp H20 0150
   Revision: 00000001    Serial number: VWZ8Z1GBA02277P Dataset Number: 5GM050v____ 0212
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI_VW37.rod
   VCID: 6D87C45C3D1C50528C5-8038
   Serial number: 050816060503LO Dataset Number: V03935226UK 0009
   VCID: 42DD47E054027F2A017-8016
   Serial number: 00000000000013346971
   Coding: 091000
   Revision: --------    Serial number: -------------- Dataset Number: V03935205NP 0021
   Coding: 062A00003F000400
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   VCID: 40D94DE85A0E6D3A173-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
   Component: MU-S-NS-US    840 0753
   Serial number:                Dataset Number: V03935247DB 0001
   Coding: 02730202000000005122000200180A001F0108F401200000C6
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323D1720E4A2CFAA917-8066
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9PU300151
   Subsystem 2 - Part No SW: 5NA 919 866 BF    HW: -----------
   Component: NAR 2021/2022  --- 1510
                    Reset counter: 192
                    Mileage: 151370 km
                    Date: 2024.07.28
                    Time: 22:39:10
                    Voltage terminal 30: 11.8 V
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: available.
                    SDARS_tuner_status_2-Antenna current: 137 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
0007 - Connection between Antenna Amp 1 for Radio and Antenna
          B1272 13 [00001001] - Open Circuit
                    Reset counter: 192
                    Mileage: 151370 km
                    Date: 2024.07.28
                    Time: 22:38:25
                    Voltage terminal 30: 11.9 V
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: electrically OK
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Open circuit
                    Status of antenna 1 for radio-Reception level antenna 1: 51 dBµV
   Component: OCULowMQBUS   007 0568
   Dataset Number: V03935236TB 0001
   Coding: 02730202C2823A017F1E06020000
   ROD: EV_OCULowMQB_VW32.rod
   Serial number: 30061611P10217 Dataset Number: V03935246CZ 0001
   Coding: 000107060002020100221344C040490094000E100020
End----(Elapsed Time: 01:49, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
mk7GolfAlltrack
Cincinnati, OH, USA
C?ID=527058
Disconnected battery to reset BCM, uncoded the convenience opening/closing. Reconnected battery and cleared codes after reconnecting battery, recoded convenience opening, ran window calibration's all all 4 windows four times in a row, those all work. But STILL only drivers window goes down.
Anyone else have any ideas?
Westbury, UK
Energy management problems and incorrectly coded instruments worth solving as they may be relevant.
mk7GolfAlltrack
Cincinnati, OH, USA
C?ID=527058
I will attempt to clear the energy management fault. I'm sure the incorrectly coded instruments is caused by my retrofit of the OEM AID cluster and my independent shop removed the component protection. That fault on the instrument is probably why my road sign recognition coding also does not work.
Interesting if these two faults would cause the comfort opening from opening if its the case.
mk7GolfAlltrack
Cincinnati, OH, USA
C?ID=527058
Cleared energy management fault, cannot get instrument fault to clear. Still only drivers window works despite all windows selected. I have triple checked all the coding for this and have not identified any issues with the coding either.
Westbury, UK
I guess this one will go down as unsolvable.
It seems very unlikely that someone cannot offer a suggestion how to correct the instruments coding.
What's the back story, what happened just before the instruments coding became incorrect?
mk7GolfAlltrack
Cincinnati, OH, USA
C?ID=527058
I believe perhaps the shop that I had used to install the OEM AID cluster coded it incorrectly? I needed them as they have ODIS to code the new AID cluster to remove the component protection, marry the cluster to the car, and update the cluster to the correct mileage before the cluster locked. I had no idea that changing the instrument cluster would render the comfort opening/closing windows not to work correctly anymore.
Cuzoe
C?ID=279487
Could try the "factory reset" or whatever it's called in the infotainment settings. I have not had the problem with comfort opening/windows but I've had the "reset" fix lighting settings that were not working after being coded even though they were properly selected in the menu.
Westbury, UK
That's a known 'feature' of the MIB1/2 infotainment system, it only actions the lighting values on a lighting reset.
