- Jul 26, 2024
- 3
- 1
- Oklahoma, USA
- C?ID=592654
Hello, I'm trying to see if there is a way to improve throttle response in my 2016 Q5 (Premium Plus) 2.0L Turbo (Protocol: UDS) with automatic Tiptronic transmission. After searching here and other forums I haven't found much but I did find the following:
This is essentially what I'm trying to accomplish for the Q5, but the above thread was previously accomplished with VCDS on an Audi A8 as shown in the following site:
I have used my Ross-Tech VCDS to follow the instructions as labeled on the site but when it came to "Coding-07" on the "02-Auto Trans" there is a difference between the codes shown on the above site and my own. My current transmission software code is "000001" vs the following stated on the site:
I will post a readout log the VCDS here (I realize I have a couple fault codes):
Improving Throttle Response via VCDS Transmission Coding - AudiWorld Forums
A8 / S8 (D3 Platform) Discussion - Improving Throttle Response via VCDS Transmission Coding - Most useful for me is the kickdown. I was disappointed in how it responded to fast throttle changes. Thought the adaptation was set by my driving habits. Looking forward to the sportier shifting... When...
www.audiworld.com
00 and later with Tiptronic
The 00's and later have different options than the 99's and earlier. They can be coded as followed:
- 00002, stock coding
- 00012, sport coding
- 00022, stock coding, but will hold first gear in Tiptronic to redline regardless of throttle position and then shift to second.
- 00032, sport coding and will hold first gear in Tiptronic to redline regardless of throttle position and then shift to second.
Saturday,27,July,2024,17:35:46:47135
VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.5
VIN: WA1L2AFP2GA053363 License Plate:
Mileage: 134480km-83561mi Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
62 6C 6D 72
VIN: WA1L2AFP2GA053363 Mileage: 134480km-83561miles
Address 01: Engine (DET-CPMB) Labels:. 06H-907-115-CDN.clb
Part No SW: 8R1 907 115 N HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0003
Revision: ECH09--- CVN: 292C12D0
Coding: 6A2A0013242600062000
Shop #: WSC 65369 001 1048576
ASAM Dataset: EV_ECM20TFS0118R1907115N 001005
ROD: EV_ECM20TFS0118R1907115N.rod
VCID: 40DE99CCBA0842FA1F3-8014
VINID: 9D105C0915A00974401430C60CD97603BA
Readiness: 0110 0101
Part No SW: 8R0 927 158 AS HW: 0BK 927 156 AL
Component: 0BK 20TFSIUSA H19 1003
Revision: --H19--- CVN: B0AE2672
VCID: 0E4277F4B0DCE48ADDF-805A
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AS HW: 8R0 907 379 AS
Component: ESP8 quattro H09 0020
Coding: 151D1803
Shop #: WSC 06335 000 00000
VCID: 11786C88A162FB72C0D-8044
Part No SW: 8K0 907 064 KP HW: 8K0 907 064 KP
Component: BCM2 2.0 H15 0711
Coding: 0D854040000000000000
VCID: 084E41ECD238BABA173-805C
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 3215000144398003
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Revision: C1000000 Serial number: 01010920150854
Coding: 6481208000
VCID: 77AC3210AFC6C5426E9-8022
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00001156438101
Coding: 26000091863CAFC00000480300003D0D0F1C4608A2090221000008004000030100000034000000
VCID: 78AE312CA2D8CA3A673-802C
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 150817 H12 0050
Serial number: 90243014150813140214
Coding: 01DD13
Component: G397_RLFS H06 0004
Serial number: 20561557
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000001708151174
Component: USHL4.2 H30 0030
Serial number: 00000000095Z0203C5B8
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 5E2881C7000000000001
Part No SW: 8K0 959 655 R HW: 8K0 959 655 R
Component: AirbagVW-AU10 H53 0812
Serial number: 003NED15CAE9 Dataset Number: 8R0909602K 0001
Coding: 303635313832383132304A55304C38523053
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
VCID: 4CC6BDFC8640969AF3B-8018
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R150000NGQT
Serial number: 6334MSME5379027CI
Serial number: 6344MSME53784B3FU
Serial number: 6352QSME055307625
Serial number: 6362QSME484E2174M
Serial number: 63732SME1C5356682
Serial number: 63832SME1F530862/
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862OHN001BH
Coding: 000017
VCID: 48CE81EC92B87ABAD73-801C
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 981 N HW: 8R0 920 981 N
Component: KOMBIINSTR. H35 0567
Revision: 00200000 Serial number: 0364CM09G
Coding: 8BB622000301D705020000
VCID: 45D088D8A5AA67D22C5-8010
Part No SW: 8R0 907 468 AA HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0070
Revision: 1Z130032 Serial number: 3241Z15728040B
Coding: 80C303FF00
VCID: 7EA2273480FCF40A2DF-802A
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 3381797503
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000162142997
Coding: 00581B00000000000000
VCID: 42DA93C4B48450EA097-8016
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0378136757 Dataset Number: 8R0909535F 0021
Coding: 010211
Shop #: WSC 06334 000 00000
VCID: 3FDC9A30C7F63D02669-806A
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0378053388
Coding: 010211
730117 - Control Module 2 for Lane-Change Assist
C1115 F0 [00001001] - Automatic Calibration Not Possible
Reset counter: 237
Mileage: 111914 km
Date: 2023.05.15
Time: 12:03:24
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0511
Revision: Serial number: 0000163408447
Coding: 011D13205E00440004
VCID: 4FFCAAF077D6AD82969-801A
Part No SW: 8R0 909 144 P HW: 8R0 909 144 B
Component: RCEPS H43 0510
Revision: 00001000 Serial number: 0014139429 Dataset Number: 8R0909852J 0022
Coding: 100000000000
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X_008.rod
VCID: 45D088D8A52A67D22C5-8010
Revision: 00002001 Serial number: 0377841867
Coding: 0126023A20FA709584B0053200040000
Component: GTO BF H01 0080
Serial number: 00000000009999999999
Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H04 0090
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H04 0090
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813049045407
VCID: 2D00D0781D1ABF92C45-8078
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0511
Revision: Serial number: 0000163334040
VCID: 4EC2B7F470DCA48A9DF-801A
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 10000000582214
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A2AEB24DCD4182A517-806E
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156HZ0F2500386
Coding: 020007010000000001
VCID: 2416355C4ED07EDA1BB-8070
Part No SW: 8R1 035 746 H HW: 8R1 035 746 G
Component: H-BNT-NA H43 0937
Revision: -------- Serial number: 523HB0F7587990
Coding: 160200060005A1EF51028B5E00000403140000000000000000
VCID: 3C26ED3CD660261A43B-8068
Subsystem 1 - Part No: 8R0 060 884 CS
Component: NAR 2015 1201
Component: DU7 High H42 0104
Serial number: A130H.0F3443776
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000002352512
Component: CD-Database 6208
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000164415167
Coding: 010C13204000240004
VCID: 46D28FD498AC6CCA25F-8012
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H09--- Serial number: 525PA8-JA6A3Y5
Coding: 1020010
VCID: 3436C51CF230EE5A8BB-8060
02203 - Audio / Video Input 1
Fault Status: 00101011
Fault Frequency: 12
Reset counter: 52
Mileage: 129189 km
Date: 2024.04.12
Time: 10:11:13
Reverse OFF
Count: 3
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D20E038CD7A2F12745-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000164415166
End----(Elapsed Time: 02:03, VBatt start/end: 11.4V/11.5V. VIgn 11.5V)-----
