Audi A1 cruise control retrofit codes?
mw0dbb
C?ID=255922
Hi all, just bought the cruise control kit for my A1. Was wondering what the codes are to activate it? I have the vcds cable and software.
Thanks in advance.
John
mw0dbb
C?ID=255922
Can I enable it without the kit fitted? I've not had a chance to hook up the laptop yet. Also how do I produce and auto-scan?
mw0dbb
C?ID=255922
Chassis Type: 8X (8U0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 5F
VIN: WAUZZZ8X1CB017429   Mileage: 51060km-31727miles
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 KQ    HW: 03L 906 023 KP
   Component: 1,6L R4 CR td H63 8530
   Revision: --H63---    Serial number:
   Coding: 00114016030501080000
   Shop #: WSC 00046 790 00000
   ASAM Dataset: EV_ECM16TDI02103L906023KQ 003009
   ROD: EV_ECM16TDI02103L906023KG.rod
   VCID: 7F3483F2E6C063C624-802A
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BB    HW: 6R0 907 379 AH
   Component: ESP8.2i front H07 0001
   Revision: --------
   Coding: 330448E9436E00B9CC2912E4C2DA00920C00
   Shop #: WSC 00046 000 00000
   VCID: 7F3483F2EAC063C624-802A
   Part No SW: 8X0 820 045 A    HW: 8X0 820 045 A
   Component: J255 Klima Manuell  0140
   Revision: 0000707S    Serial number: 03030005038524
   VCID: 345E9CDE5706709E89-8060
Address 09: Cent. Elect. (J519)       Labels: 8X0-907-063.clb
   Part No SW: 8X0 907 063 G    HW: 8X0 907 063 G
   Component: BCM PQ35  M   110 0655
   Revision: 00110 AE
   Coding: 0E000A2CA805F100201841E000000154438B6C0A00CF4122DC0087830041
   VCID: 40B6C00ED3BEDC3E1D-8014
   Subsystem 1 - Part No: 8X0 951 177
   Component: DWA-Sensor H0  H01 0020
Address 15: Airbags (J234)       Labels: 8X0-959-655.clb
   Part No SW: 8X0 959 655 A    HW: 8X0 959 655 A
   Component: Airbag10.41   H04 0008
   Revision: --------    Serial number: 003JJ002P8A0
   Coding: 30314539303330303034554A305238583053
   ASAM Dataset: EV_Airba1041BPAAU210 001015
   ROD: EV_Airba1041BPAAU210.rod
   VCID: 48A6D82EF38EE47ED5-801C
   Serial number: 3554VRB405V0J2N0H1S1
   Serial number: 3575HRB405V0IODO5PCL
   Serial number: 3585HRB405T0JE3CAO4S
   Rear Impact Crash Sensor:
   Serial number: 3515ZRB40590K4DO5919
Address 16: Steering wheel (J527)       Labels: 8X0-953-569.clb
   Part No SW: 8X0 953 501 B    HW: 5K0 953 569 H
   Revision: FF010016    Serial number: 20110721202047
   Coding: 1184004000
   VCID: 3940ADEAB8648DF65A-806C
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H07 0009
Address 17: Instruments (J285)       Labels: 8X0-920-xxx-17.clb
   Part No SW: 8X0 920 980 D    HW: 8X0 920 980 D
   Component: KOMBI_MEDIUM  H03 0179
   Coding: 41DE00
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390
   VCID: 40B6C00EDBBEDC3E1D-8014
1048578 - No Basic Setting
          B2010 00 [009] -  -
                    Reset counter: 244
                    Mileage: 46723 km
                    Date: 2015.06.04
                    Time: 14:59:24
   Part No SW: 8U0 907 468 A    HW: 8U0 907 468 A
   Component: GAT 4CAN 1L M H10 0043
   Revision: 1P030020    Serial number: 2041P116210033
   Coding: FBCF005A000100010153
   Subsystem 1 - Part No SW: 8K0 915 181 H    HW: 8K0 915 181 H
   Component: J367-BDM  H07 0171
   Component: IMMO          H03 0179
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
   ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
   Part No SW: 8X0 959 793 B    HW: 8X0 959 793 B
   Component: TSG FA        H09 0409
   Coding: 011802200101000100
   VCID: 4CAEE43EEFF6085EF1-8018
   Part No: 6R0 423 156 B
   Coding: 11251
   Shop #: WSC 00046
   VCID: 2F5493B2EA205346F4-807A
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
   Part No SW: 8X0 959 792 B    HW: 8X0 959 792 B
   Component: TSG BF        H09 0409
   VCID: 4BACE722EAF80F66F8-801E
   Part No SW: 8X0 035 183 E    HW: 8X0 035 183 C
   Component: RMC Cnct      H51 0775
   Coding: 01010000000051070023000103010000010000
   VCID: 3940ADEAB0648DF65A-806C
   Subsystem 1 - Part No SW: 8X0 919 603     HW: 8X0 919 603
   Component: DU6 Basic  H42 0084
Think this is it? Also, no idea why I have an error code?
John
mw0dbb
C?ID=255922
Well, I have started fitting my kit. Got a problem with removing the blanking plug from the ecu connector. Just looking for a tool to sort that then I can continue. I think the hardest part so far has been the routing of that cable! I dunno why didn't fit it!
John
mw0dbb
C?ID=255922
All sorted now, I used the long coding helper and just ticked the boxes.
