- Jul 18, 2024
- 3
- 0
- Washington, USA
- C?ID=588708
Hi, thanks in advance for your help!! Car Dealer is 2 hours away so dropping it off is time consuming and gets expensive, hoping to be able to just fix it myself and save the hassle. I’ll try to keep this concise without leaving anything out, but I didn’t have VCDS when this all started so I’m giving you a summary of faults until the first VCDS scan. I had a series of contribution/balance faults starting on May 1, effecting all 6 cylinders at some point, with a total of 6 events while driving just under 1700 miles. No loss of power but ran rough and puffed black smoke when you jumped on it. Thought it might be bad fuel so ran tank low and refilled, no change, replaced fuel filter and put a full can of diesel purge in fuel filter housing on 5/8. No change, I don't have a scan after 5/8 so can't be sure what faults were there on 5/15 when I took it to the dealer, they tested and said fuel pressure within spec, can't find anything wrong so cleared codes and said bring back if check engine light comes back on. No longer getting contribution/balance faults, doesn't run rough anymore, now I get fuel rail/system pressure- too low (P0087). I’m also getting the flashing glow plug coil and loss of power, but it clears once I shut the engine off and restart. Note: no check engine light is coming on with these events. Have readings for this fault on 6/5, 6/9, and 6/11, first reading with VCDS is on 6/30, also have readings on 7/5, 7/7, 7/10, and 7/11 when it happened 3 times on a day trip including setting the check engine light for the first time on the second fault. It also happened on 7/19 while in town, last scan attached, thanks again for your help and let me know if more info is needed.
Friday,12,July,2024,11:31:09:52476
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.5
VIN: WVGEP9BP4GD004759 License Plate:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3C 42 46 52 53 55 56
5F 62 65 69 6C 6D 72 85 8B 8E
VIN: WVGEP9BP4GD004759 Mileage: 99348km-61731miles
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 7P1 907 401 C HW: 7P0 907 401 K
Component: 3.0TDI FSA H21 0010
Revision: 56H21--- CVN: AF4B74E538D3FF8238D3FF820E1FC39E
Coding: 292A4012237600050000
Shop #: WSC 08272 005 1048576
ASAM Dataset: EV_ECM30TDI0117P1907401C 001011
ROD: EV_ECM30TDI0117P1907401C.rod
VCID: 303EC98BCAAF9C4AE73-8064
VINID: 9E65D58094A01175000041C5243B2939E9
5211 - Fuel Rail/System Pressure
P0087 00 [01100000] - Too Low
Mileage: 97699 km
Date: 2024.06.05
Time: 14:04:47
Engine RPM: 1773.00 /min
Normed load value: 100.0 %
Vehicle speed: 89 km/h
Coolant temperature: 90 ∞C
Intake air temperature: 39 ∞C
Ambient air pressure: 950 mbar
Voltage terminal 30: 14.320 V
Fuel temperature: 45.9 ∞C
Mean injection quantity: 74.95 mg/stroke
Rail pressure regulation: status-Bits 0-7: 5
Fuel high-pressure: actual value: 1316100 hPa
High fuel pressure: specified value: 1575600 hPa
Pressure control valve adaptation factor: 1.2092
Fuel level: 74.00 l
8784 - Fuel Pressure Sensor (G247)
P0191 00 [11101100] - Implausible Signal
Mileage: 99237 km
Date: 2024.07.11
Time: 14:12:45
Engine RPM: 1414.00 /min
Normed load value: 49.8 %
Vehicle speed: 20 km/h
Intake air temperature: 47 ∞C
Ambient air pressure: 870 mbar
Voltage terminal 30: 14.000 V
Engine status: COENG_RUNNING
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217) Labels: 0C8-927-7XX-V2.clb
Part No SW: 0C8 927 755 R HW: 0C8 927 755
Component: AL1000 AISIN 130 3374
CVN: E0C27B10
Coding: 010200000C008400000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_TCMAL991031 003118
ROD: EV_TCMAL991031_003.rod
VCID: 40DE994B7A0F0CCA173-8014
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 R HW: 7P0 907 379 A
Component: MK25A H37 0521
Revision: -------- Serial number: 41535440268552 Dataset Number: 7P0012v____ 0001
Coding: 5B7613C349246F57DAFBC89892DBF6607301
ASAM Dataset: EV_MK25AXT 010001
ROD: EV_ESPMK25A01000.rod
VCID: 4CC6BD7B4647D8AAFBB-8018
Part No SW: 4H0 907 064 GK HW: 4H0 907 064 GK
Component: BCM2 2.0 H37 0572
Coding: 0D860016000000000000
VCID: 78AE31AB62DF840A6F3-802C
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Serial number: 3215000120638010
00956 - Key 2
Reset counter: 143
Mileage: 98295 km
Date: 2024.06.26
Time: 09:28:45
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 CN HW: 7P6 907 040 CN
Component: Klima 2 Zonen H23 1507
Coding: B686200A80
VCID: 025A53433483DEDA417-8056
Part No SW: 4H0 907 063 DA HW: 4H0 907 063 AA
Component: BCM1 2.0 H20 0311
Revision: 22020001 Serial number: 00001147737502
Coding: 26000096963C5D010020480000005D4C431C6608A2014265000000008040110000000000000000
VCID: 6A8A1BE32C73269AE97-803E
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 150726 033 0021
Serial number: 90243400150804125609
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20635688
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 AC HW: 7P6 941 431 AC
Component: E1 - LDS H02 0040
Serial number: 00000000001808150583
Component: USHL4.2 H30 0030
Serial number: 00000000095Z02022346
Subsystem 5 - Part No SW: 8K0 959 772 E HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0159858240
Coding: 952F00
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 D HW: 7N0 919 475
Component: PARKHILFE 8K H06 0030
Revision: -------- Serial number: 28231522304443
Coding: 310D04
ASAM Dataset: EV_VW526ParkiAssis2 001013
ROD: EV_VW526ParkiAssis2.rod
VCID: 44D6955B6E1710EA33B-8010
Part No SW: 7P6 907 561 C HW: 7P6 907 561
Component: ACC3 H21 0400
Coding: 3701010101
ASAM Dataset: EV_AdaptCruisContrVW526 002012
ROD: EV_AdaptCruisContrVW526_002.rod
VCID: 3C26EDBB16E7682A4BB-8068
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 F HW: 7P0 959 655 F
Component: VW10Airbag02B H10 0044
Revision: -------- Serial number: 003S8000TGGE Dataset Number: 7P6003V____ 1733
Coding: 000000000000000000000000000000003242
ASAM Dataset: EV_AirbaVW10BPAVW526 002001
ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R155220QC6C
Serial number: 3575LRB40693C3S6C1JA
Serial number: 3585LRB40593HH6091L0
Serial number: 3517ARB404P3GUUQG1QU
Serial number: 3527ARB404R3GUUQ81JI
Serial number: 3557BRB404T3FSU0I14X
Serial number: 3567BRB404T3FSU02OJD
Part No SW: 4H0 953 568 M HW: 7P6 953 507 AJ
Component: Lenks.Modul H06 0005
Revision: -------- Serial number: 01374OHL0001Y
Coding: 000CDD
VCID: 3D20E0BF0D7D61227C5-8068
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0096953 TRW 20150715
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 983 D HW: 7P6 920 983 D
Component: Kombi H13 0515
Revision: 13240302 Serial number: 658180815592048
Coding: 8B5733026F08CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001022
ROD: EV_KombiUDSRBVW526_VW52.rod
Part No SW: 7P6 907 530 N HW: 7P6 907 530 G
Component: GW-CAN-L-FR-M H13 6042
Revision: -------- Serial number: 00000001929591 Dataset Number: 7P6067v____ 0041
Coding: 000103AD00
GVL: FB5F40651D7F680000
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
VCID: 43D496476B1917D20A1-8016
Subsystem 1 - Part No SW: 7P0 915 181 B HW: 7P0 915 181
Component: Batt_Sensor H07 0190
Serial number: 42195B35135701431720
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000158401920
Coding: C0581B0015004001000001010101202020202121202020
VCID: 3530F89F354DB962B45-8060
Part No SW: 7P6 907 566 A HW: 4H0 907 566 F
Component: SWA Master H06 0021
Serial number: 0377744143 Dataset Number: 7P6764V____ 0009
Coding: 030221
ROD: EV_LaneChangAssis_VW52.rod
VCID: 3FDC9AB707F173326E9-806A
Subsystem 1 - Part No SW: 7P6 907 568 A HW: 4H0 907 568 F
Component: SWA Slave H06 0021
Serial number: 0377337878
Coding: 030221
733440 - Control Module for Lane-Change Assist
C1114 F3 [00001000] - Limited Visibility
Reset counter: 155
Mileage: 97789 km
Date: 2024.06.09
Time: 12:33:15
733696 - Control Module 2 for Lane-Change Assist
C1115 F5 [00001000] - Limited Visibility
Reset counter: 155
Mileage: 97789 km
Date: 2024.06.09
Time: 12:33:15
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H02 0306
Revision: -------- Serial number: 0000162763616
Coding: 011D17205E00453005080001
VCID: 7AAA2BA35CD3961A197-802E
Revision: 00002001 Serial number: 0376108740
Coding: 0187123A68B9509580A00620210A18000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 A HW: 7P6 959 719 A
Component: GTO BT H20 0059
Serial number: 181154975
Subsystem 3 - Part No SW: 7P0 959 591 D HW: 6R0 959 591 D
Component: J245 PS30.408 H03 0004
Serial number: 0000FST000GMRG900000
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 E HW: 8V3 959 591 A
Component: J394 PS30.408 H03 0004
Serial number: 0000FST000GU95O00000
Coding: 191100
Subsystem 5 - Part No SW: 3AA 962 243 E HW: 3AA 962 243 E
Component: GEB.F.Heckoef H16 0813
Serial number: 65027891
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000162948603
Coding: 011D17205E00453005080000
VCID: 48CE816B52BF348ADF3-801C
