Golf Mk 7.5 deactivating GM1 ASM Standard electronic engine
DangerDane
Denmark
C?ID=586577
Hi,
I have a Golf Mk 7.5 with the following PR code:
GM1 ASM Standard electronic engine sound
Which I can read equates to soundaktor or some such. But is that correct and if it is then how do I disable it?. I didn't think they installed artificial sound in anything but the R and GTI versions, but it also explains why my car sounds a bit raughty when I give it some spirited driving. Initially I thought it was the original engine, but seeing that PR Code makes me suspect its foolery at stake. In general I detest artificiel engine sounds, simply because it serves no other purpose then to trick people.
You probably have one.
If so, it will show up in an Auto-Scan as: A9-Struct. Borne Sound. They typically have exactly one Adaptation channel and the value in it is likely 100. Change it to 0.
DangerDane
Denmark
C?ID=586577
I don't have that module, and when I check 19 - Gateway, modul A9 isn't checked. I'm a bit perplexed by the confusing "messages" ie according to my PR codes I should have some form of "fake engine sound", but at the same time I don't have the usual module etc for it??.
DangerDane
Denmark
C?ID=586577
Wednesday,17,July,2024,15:58:05:49562
VCDS Version: 24.5.0.0 (x64)  HEX-NET CB: 0.4643.4
VIN: WVWZZZAUZHP787440   License Plate: EB60406
Mileage: 128577km-79894mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F 69
VIN: WVWZZZAUZHP787440   Mileage: 128577km-79894miles
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H26 2833
   Revision: R7H26---    CVN: C7FD2D74
   Coding: 01190032245415082000
   Shop #: WSC 00028 028 00070
   ASAM Dataset: EV_ECM14TFS01104E906027HB 001005
   ROD: EV_ECM14TFS01104E906027HB.rod
   VCID: 6B96353D82446ACE86-803E
   VINID: 9E69EAAAA465A988072071040038795847
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 51027000001835
   Coding: 04FA6AA124282173477B060440C32920562484E26002947334205078C002430000000012121212B835351919323200
   Shop #: WSC 00028 028 00068
   VCID: 76A01449C906A72669-8022
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 02020004200110011005000000101022
   VCID: 6D923B25BC5064FE98-8038
   Air quality sensor:
328199 - Position Sensor for Right Temperature Flap Motor
          B1095 15 [00001000] - Open or Short to Plus
                    Reset counter: 141
                    Mileage: 127872 km
                    Date: 2024.07.05
                    Time: 19:11:42
                    Voltage terminal 30: 13.5 V
                    Outside temperature: 18.0  C
                    Inside temperature: 27.4  C
                    Right temperature flap: actual value: 114
                    Right temperature flap: actual value: 42.5 %
                    Temperature door right - Specified value: 114
   Part No SW: 5Q0 937 086 BG    HW: 5Q0 937 086 BG
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: 8658120417021X Dataset Number: V03935258XK 0001
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 004C72919BC2999643-8054
   Component: WWS    170316  043 0551
   Serial number:         170406041149
   Component: RLHS  042 0105
   Serial number: S4Y17M04D24H11M13S17
   Coding: 00A8DD
   Humidity sensor: interior:
6922 - Bulb for Low Beam Headlamp Right
          B1218 15 [00001000] - Open or Short to Plus
197904 - Central Locking
          B140A 4B [00001000] - Over Temperature
   Part No SW: 5QA 919 294 A    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0038
   Serial number: 000308418617109 Dataset Number: V03935257CA 0001
   Coding: 0471051101
   ASAM Dataset: EV_EPHVA18AU3700000 009031
   VCID: 4AD890B9ED7E93C6DD-801E
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 H    HW: 3QF 907 572
   Dataset Number: V03935253UB 0001
   Coding: 2B00E00911FFC728949C810560401600000000000000000000
   Shop #: WSC 12345 123 61029
   VCID: 3C34C661B7AA3D765F-8068
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0318
   Serial number: 003TDR2VDDGI Dataset Number: V03935255FD 0001
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00056
   VCID: 106C42D1CBA2E916D3-8044
   Left seat belt tensioner:
   Serial number: 34169667E18041740127
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169668E18041750788
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 504 17
   Serial number: 357000000003F848D22R
   Subsystem 4 - Part No SW: -----------    HW: 480 001 504 17
   Serial number: 3580000000052631C226
   Subsystem 5 - Part No SW: -----------    HW: 480 401 804 17
   Serial number: 3510001B924D8E64E53H
   Subsystem 6 - Part No SW: -----------    HW: 480 401 904 17
   Serial number: 3520001BB24CEF22F13H
   Subsystem 7 - Part No SW: -----------    HW: 480 401 204 17
   Serial number: 3550001A524D8E6664EK
   Part No SW: 5Q0 953 521 K    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20170413100696
   Coding: 0400
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3A38C079BD9E03464D-806E
   Part No SW: 5G1 920 740 B    HW: 5G1 920 740 B
   Component: KOMBI         204 8311
   Coding: 07A521002780000801883A011400000000000000
   VCID: 2502030524209CBE10-8070
   Component: GW MQB High   515 5286
   Serial number: 13041710801800 Dataset Number: V03935252FW 0001
   Coding: 030100347F085700FA000248080F00010001050000000000000000000000
   GVL: 01543C0000000000C00C80000000480000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F2EE12D76DCD6EEEA-807A
   Generator:
   Component: E221__MFL-DC1  H17 0040
   Serial number: 46170001022650087147
   Coding: 2CFFFF
   Serial number: 9310033704
   Component: TSG FS        010 TSG FS        010 00320032
   Serial number: 0000251565046  Dataset Number: V03935257PY 0001
   Coding: 00310320D000028000001000
   ROD: N/A
   VCID: 47DEA98DFE6C6EAEC2-8012
   Component: EPS_MQB_ZFLS  129 1072
   Dataset Number: V03935259RX 0001
   Coding: 0107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45C2A385C4607CBE30-8010
   Component: TSG BFS       010 0032
   Serial number: 0000251714028  Dataset Number: V03935257QA 0001
   Coding: 00310120DE00028000801000
   VCID: 46C0A489F96677A639-8012
   Serial number: 00000000000006585679
   Coding: 090000
   Part No SW: 3Q0 035 824 B    HW: 3Q0 035 824 B
   Component: MU-S--ER      H30 0363
   Serial number: VWZAZ2T1283041 Dataset Number: V03935258X  0001
   Coding: 02731200FF0000005111000100080A001F0500C40120010003
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 2C14F62147CAADF6CF-8078
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H50 8120
   Serial number: VWZ6ZHT1152127
   Part No SW: 5Q0 907 383 H    HW: 5Q0 907 383 C
   Component: Anhaenger     H21 0204
   Revision: 8B001003    Serial number: 0438599582 Dataset Number: V03935259HE 0001
   Coding: 0100000202000000
End----------(Elapsed Time: 02:04, VBatt start/end: 12.2V/12.1V)-----------
NEtech
Denmark
C?ID=56995
You probably don't have one.
Fixed that for you :)
No, there is no Engine sound generator in your Vehicle.
On some with PR-GM1, there are, normally 2.0 l engine.
Don't know why they are not called GM0.
  • Agree
DangerDane
Denmark
C?ID=586577
So it's called PR-GM1 despite actually being a PR-GM0?
Rocky53
England
C?ID=565102
I have a T-Roc 2022 1.5L Evo2 (DXDB) with the same PR code: GM1 - Standard electronic engine sound. The family for the PR code is: ASM which I assume stands for "Active Sound Module or Management". There is no physical sounder (R214) or associated control unit (J869) in the plenum chamber, thus no "A9-Structure Borne Sound" to access and reduce the sound level to zero.
There is definitely some fake noise injected into the cabin as you approach 2,500 RPM and upwards, so where is the sound coming from, Infotainment (radio) system, somewhere else?
I have looked at all the Module/adaptions and the only mention I can find are:
Module "19-CAN Gateway"/"Adaption-10"
IDE01996-SFT00169-Installation list: specified installations-Structure-borne sound actuator
ENG 137058 SFT00169_GW_Enable_CAN_Timeout_DTC-Structure-borne sound actuator
I have not progressed any further, would I come up against SFD (Diagnostic Firewall)? I know of people, with the same vehicle, who have had the fake sound disabled by VW, so possible.
Thursday,14,December,2023,10:29:12:60699
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WVGZZZA1ZPV521758   License Plate: WU72 PFE
Mileage: 17105km-10628mi   Repair Order:
Chassis Type: A1-VW27 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 42 44 52 5F 75 A5 BB BC
VIN: WVGZZZA1ZPV521758   Mileage: 17105km-10628miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DXDB)       Labels: None
   Part No SW: 05E 906 013 H    HW: 05E 907 309 R
   Component: R4 1.5l TFS   H80 2407
   Revision: KHH80000    Dataset Number: V03935359ZJ 0001 CVN: 54C71045
   Coding: 0125003223641D0820000000000000000000000000000000
   Shop #: WSC 00020 043 00000
   ASAM Dataset: EV_ECM15TFS01105E906013H 001005
   ROD: EV_ECM15TFS01105E906013H.rod
   VCID: 2517E180756FD7927C5-8070
   VINID: 9E65EAAAA441AA09850811C520D8DABE43
Hard to say without seeing the rest of your scan. What you posted above stops after 01-Engine.
Rocky53
England
C?ID=565102
How would I disable the fake engine sound?
Full scan:
8172 - Selector Lever
          P0919 00 [00100000] - Malfunction
   Part No SW: 0CW 300 020 T    HW: 0AM 927 769 N
   Component: GSG DQ200G2_M H07 2202
   Revision: 00007009    Serial number: CU502207026381 CVN: E3EE4CFC
   Shop #: WSC 00016 035 00103
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 43D35F189B1B09A2721-8016
   Part No SW: 5Q0 614 517 GB    HW: 5Q0 614 517 BP
   Component: ESC           H35 0114
   Revision: 00000000    Serial number: 61802000000176 Dataset Number: V03935352LR 0001
   Coding: 46FA8A7D9022246D477E060562CB2562510924E26046A4733822F578D2024B0B00000523525212121035351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049.rod
   VCID: 77ABFBC89F4395021E9-8022
   Part No SW: 2GA 907 044 A    HW: 2GA 907 044 A
   Component: Climatronic   H10 0221
   Dataset Number: V03935354ZE 0001
   Coding: 061200042001100D110500000010D036
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 002004
   ROD: EV_AirCondiBHTCMQB3rTranc_002_VW37.rod
   VCID: 33330FD8CBBBB922E21-8066
   Air quality sensor:
   Part No SW: 5Q0 937 084 EB    HW: 5Q0 937 084 EB
   Component: BCM MQBAB M+  H44 0511
   Serial number: 01102219000888 Dataset Number: V03935379SG 0001
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW27.rod
   VCID: 7CA1E4E4A665B65A73B-8028
   Subsystem 1 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  054 0206
   Serial number: S7Y22M07D08H02M13S40
   Coding: 0018DD
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY221500EY4
   Subsystem 3 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000002590052
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 JH    HW: 5Q1 953 569 H
   Component: Lenks.Modul  H04 0190
   Serial number: 0100090720220C301955
   Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0073
   Serial number: 000150057322173 Dataset Number: V03935360WN 0001
   Coding: 8371063851
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000_010_VW37.rod
   VCID: 58E99874729DBA7A373-800C
13679388 - Databus
          [Lenkhilfe - LH_EPS_01.EPS_PLA_Status - Fehlerspeicher auslesen]
                    Fault Frequency: 23
                    Reset counter: 106
                    Mileage: 15600 km
                    Date: 2023.09.11
                    Time: 11:34:19
   Part No SW: 2Q0 907 572 AA    HW: 2Q0 907 572 D
   Component: ACCCONTIMQB   H09 0396
   Dataset Number: V03935360JY 0001
   Coding: 3004674318FF8748949C812480408700000000000000000004
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003.rod
   VCID: 73B3CFD88B3BF922221-8026
   Part No SW: 5Q0 959 655 CF    HW: 5Q0 959 655 CF
   Component: AirbagVW21    010 0421
   Serial number: 003J8R8GDWWT Dataset Number: V03935352XX 0001
   Coding: 88CCC0C0000000005C5400CF00C800000065
   Shop #: WSC 00016 035 00121
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
   ROD: EV_AirbaVW20SMEVW37X_VW27.rod
   VCID: 0655860CE8A9FC8A15F-8052
   Subsystem 1 - Part No SW: -----------    HW: 480 002 206 22
   Serial number: 35700000000E31214F5H
   Subsystem 2 - Part No SW: -----------    HW: 480 002 206 22
   Serial number: 3580000000048031006
   Subsystem 3 - Part No SW: -----------    HW: 480 401 706 22
   Component: SideSensor_Dr  003 6149
   Serial number: 35100019B09B24F172B6
   Subsystem 4 - Part No SW: -----------    HW: 480 401 706 22
   Component: SideSensor_Pr  003 6149
   Serial number: 35200019D09B24F5A2AF
   Subsystem 5 - Part No SW: -----------    HW: 480 401 306 22
   Component: FrontSensor_D  003 6149
   Serial number: 3550001BD08DB153B5FO
   Part No SW: 2GJ 920 310 B    HW: 2GJ 920 310 B
   Component: KOMBI         060 4846
   Coding: 25A4000867800600018862031001000000600908
   ASAM Dataset: EV_DashBoardJCIMQBAB 010007
   ROD: EV_DashBoardJCIMQBAB_010_VW27.rod
   VCID: 34310CC4CEB5BE1AFBB-8060
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [00001000] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 34
                    Mileage: 16452 km
                    Date: 2023.11.01
                    Time: 17:30:30
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 E
   Component: GW MQB High   524 5502
   Serial number: 30062210802138 Dataset Number: V03935359UP 0001
   Coding: 030100046F08570023100258180F00010001070000000000000000000000
   GVL: 01443C0000000000408C80008000C80000000000000000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 7F5B13E8B773AD42569-802A
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 3G0 959 442 AB    HW: 3G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H07 0120
   Serial number: PR6-0440036160220794
   Coding: 2D2900
   Component: J367-BDMHella  H11 9070
   Serial number: 4263869905
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        011 0912
   Serial number: 0000473303381  Dataset Number: V03935356BE 0001
   Coding: 00310220D001028000001000
   VCID: 52FD6A5C5461902AC97-8006
   Subsystem 1 - Part No SW: 5Q0 959 408 D    HW: 5Q0 959 164 C
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000061469248
   Coding: 1D0000
   Part No SW: 5WA 907 144 Q    HW: 5WA 907 144 C
   Component: BASGEN1MQB37  102 1063
   Serial number: 01928156 Dataset Number: V03935373PH 0001
   Coding: 01000100010000000001020101000100000001010100
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 010058
   ROD: EV_SteerAssisBASGEN1MQB37_010_VW27.rod
   VCID: 57EB9B487F83B5023E9-8002
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       011 0912
   Serial number: 0000471288738  Dataset Number: V03935356BP 0001
   Coding: 00310020DC01028000001000
   VCID: 51FF65505167EB32F0D-8004
   Subsystem 1 - Part No SW: 5Q0 959 407 D    HW: 5Q0 959 163 C
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000061482212
   Coding: 050000
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 3G5 035 820 K    HW: 3G5 035 820 K
   Component: MU-O-ND-EU    H22 0306
   Serial number: VWZAZ2A0701760  Dataset Number: V03935353WH 0001
   Coding: 22760008000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_001_VW27.rod
   VCID: 2C0114A41685E6DAA3B-8078
   Subsystem 1 - Part No SW: 5NN 919 605 B    HW: 5NN 919 605 B
   Component: ABT_Std-2_Nav  381 8304
   Serial number: VWZ6ZHA1873802
   Subsystem 2 - Part No: V03 959 817 SM
   Component: EUR 2022/23    7065
   Part No SW: 5WA 035 284 G    HW: 5WA 035 284 B
   Component: OCUGen3High   H20 0143
   Serial number: 0000000206VINV5 Dataset Number: V03935363DJ 0001
   Coding: 022760001968A8209005460161402607
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW27.rod
   VCID: 4ACD723CBC31D8EAB17-801E
   Part No SW: 2Q0 980 653 D    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1401
   Serial number: EA1567402221850 Dataset Number: V03935374AE 0001
   Coding: 00000910114AC020489E00000020002000018000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   VCID: 363536CCD8C9AC0AC5F-8062
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----(Elapsed Time: 01:26, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
                Address 10: Park/Steer Assist       Labels: 5Q0-919-298.clb
Control Module Part Number: 5QA 919 298 K    HW: 5QA 919 298 A
  Component and/or Version: PLA 3.0 12K   H08 0073
           Software Coding: 8371063851
            Work Shop Code: WSC 00020 999 00000
              ASAM Dataset: EV_EPHVA2CAU3700000 009055 (VW27)
13679388 - Databus
                    Fault Frequency: 23
                    Reset counter: 106
                    Mileage: 15600 km
                    Date: 2023.09.11
                    Time: 11:34:19
Your Gateway does not appear to have SFD. In fact, as far as I can see, nothing in your car does.
Rocky53
England
C?ID=565102
Thankyou.
What info (or lack of) makes you think no SFD?
Is there a way for me to disable fake engine noise from those two adaption in the :
Module: 19-CAN Gateway
SFD (or "Schutz Fahrzeug Diagnose") Functions
So far in the US only the 2021+ ID.4, 2022+ GTI/GolfR, and 2024+ Atlas(including Cross Sport) have this (also the A3/S3 and Q4 e-tron at Audi dealers) but if you look in the AutoScan you will see some modules that say SFD at the end of the VCID. This means that module has some stuff in that is locked down and can't be changed without talking to the VW mothership. Using the factory ODIS scan tool online this happens kinda seamlessly with the user not really seeing that the module gets unlocked, just the Coding or Adaptation or whatever goes through. Some aftermarket scan tools claim to be able to get around SFD but for now VCDS can only do it if you get the token elsewhere. Humble Mechanic did a pretty decent job in a recent video on the subject.
Rocky53
England
C?ID=565102
Thakyou for your detailed reply.
"SFD" appears nowhere in your scan. Modules that have it will be flagged with "SFD".
Here is an example:
Rich (BB code):
Address 19: CAN Gateway (J533)       Labels: 1EE-937-012.clb
   Part No SW: 1EE 937 012 D    HW: 1EE 937 012
   Component: ICAS1 Host-SG 021 0411
   Serial number: SMERBG220923006 Dataset Number: V03935420NB 0001
   GVL: 2D00080006C8D0FC8062904248181050C400400000010000000200000000C057
   ASAM Dataset: EV_GatewICAS1MEBUNECE 001013
   ROD: EV_GatewICAS1MEBUNECE_VWE3.rod
   VCID: 3530FB2F25C50772B85-8060 SFD        <---------
   Subsystem 1 - Part No SW: 1EA 915 181 C    HW: 1EA 915 181 C
   Component: J367-BDMConti  H05 1076
   Serial number: 78567900002310120290
   Subsystem 2 - Part No SW: 3G0 959 542 B    HW: 3G0 959 542 B
   Component: J IEEHOD1ZONE  251 0303
   Serial number: 00000000230600584163
   Subsystem 3 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 24683017
Rocky53
England
C?ID=565102
Thankyou.
DangerDane
Denmark
C?ID=586577
Rocky53, even if my car is not fitted with fake engine sound, I too have "detected" anomaly sound when I go for a spirited driving. It sounds unconvincingly sporty for a 1.4 :p. I would love to be able to deactivate it so that I at least could hear how the car originally sounds like, and then make my own informed decision of whether to leave it off or on.
Rocky53
England
C?ID=565102
I have not found a way to disable my fake engine sound with product code GM1. As my vehicle is still in warranty, I do not wish to guess and/or play around with stuff I really do not understand. My auto scan above is dated Dec 2023 and have found no need to plug VCDS in since. I do keep a lookout on various sites to see if a solution has been verified, but no luck yet.
DangerDane
Denmark
C?ID=586577
Guess I will have to poke my local dealer and get them on the case when the car goes in for service in about 2 months time. I think it's stupid to force such a thing on the user but not give them an option to enable/disable the setting into the cars info display. I mean I get the impression that my car sounds decent inside, but could sound totally like a joke outside and then I will rather suffer and have the true sound allround :D
TTT
C?ID=547002
You really believe a dealer will disable something which is not yet known to be possible? I can’t see the service advisor pulling a laptop and start coding software in C++. But let us know?
