- Aug 22, 2023
- 18
- 0
- Western Australia
- C?ID=551568
When using my Hex-net via usb cable it will auto-scan perfect. But when I try to connect to individual module's to program them, it will only connect to 2 out of the entire list. All others throw an error. No Communication with Controller. I have tried restarting the VCDS software, restarting my computer, different usb ports, engine running and off with ignition on, I have reset the Hex-net device all with no success. The led's on the device are as they should be and when I access Options and click Test I get the Ok pop up. I need to programme the Auto-Trans code as the vehicle is now manual and the TCM has been removed. I understand the Engine code also need to be re-programmed to show the correct Manual Gearbox is fitted. I am able to program the Instrument panel and the CAN module but that is all. I have checked the wiring harness for any wiring problems. There are no obvious issues there. Not sure where to go from here. Any suggestions please?
