2013 GTI Lots of codes
tehfalcon
C?ID=235987
VCDS Version: Release 15.7.1 (x64) Running on Windows 10 x64
Data version: 20150904
Thursday,29,October,2015,09:38:35:15363
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: WVWHD7AJ6DW081984   Mileage: 52810km-32814miles
04-Steering Angle -- Status: Sporadic communication error 1000
Address 01: Engine (CBF)       Labels: 06J-907-115-CBF.clb
   Part No SW: 1K0 907 115 AT    HW: 1K0 907 115 AK
   Revision: E3H26---    Serial number:
   Coding: 040301081C070160
   Shop #: WSC 78384 155 427622
   VCID: 78D11B040BEF48FE65-802C
049446 - No Communications with Steering Angle Sender (G85)
               U0126 - 000 -  - Intermittent
000257 - Mass Air Flow Sensor (G70)
               P0101 - 000 - Implausible Signal
Readiness: 1110 1101
   Part No SW: 02E 300 058 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 3513
   Revision: 05653104    Serial number: 00001504092318
   Shop #: WSC 04940 001 00001
   VCID: 2773087896D117063C-8072
18036 - Powertrain Data Bus
            P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
   Revision: 00H31001
   Coding: 114B600C492A80FB881406EC921D0141B70800
   VCID: 7DDF0A10E4CD6DD636-8028
00003 - Control Module
            013 - Check DTC Memory
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
   Component: AC Manuell    H20 0505
   Revision: 00001018
   Coding: 0010001002
   VCID: 7BDB0408F2D963E608-802E
   Part No SW: 1K0 937 086 T    HW: 1K0 937 086 T
   Component: BCM PQ35  M   111 0709
   Revision: AB111709
   Coding: 67190AB880772EC4C00A41C1640081EC4FB103EE435D8D60648860A40040
   VCID: 41A7B6E0D8B5C93612-8014
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 27071  26  0512
   Coding: 009FB5
10 Faults Found:
            010 - Open or Short to Plus
00984 - Left Tail Light (M4)
00985 - Right Tail Light (M2)
01495 - Bulb for High-Beams; Left (M30)
02661 - Wire for Speed Signal
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R00HGAC
   Coding: 00004737
   ROD: EV_AirbaVW10SMEVW360_SE36.rod
   VCID: 3C59C714B757A4DE41-8068
   Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00005J3A00
   Serial number: 3572MSME4E1A6674ZZZ2
   Serial number: 3582MSME4F332472ZZZY
   Serial number: 3512QSME48231B7AZZZ.
   Serial number: 3522QSME482D1F6CZZZA
   Serial number: 35527SME135D3A2EZZZR
   Serial number: 35627SME0448372EZZZJ
   Part No SW: 5K0 953 507 AJ    HW: 5K0 953 549 B
   Revision: --------    Serial number:  90440LGM001B4
   Coding: 589A140000
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 78D11B04C3EF48FE65-802C
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0032
   Serial number: 0054388
   Part No SW: 5K6 920 973 C    HW: 5K6 920 973 C
   Component: KOMBI         H05 0705
   Coding: 270F01
   VCID: 3753D8388E718786AC-8062
   Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
   Component: J533  Gateway H42 1632
   Revision:   H42       Serial number: 090812F2002532
   Coding: 350002
   VCID: 3FA3B018AE41BFC664-806A
            000 -  -  - Intermittent
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         002 0002
   Revision: 00002000    Serial number: 1225223RKEYE07
   Coding: 0000002
   VCID: 7EDD0D1C29CB76CE2F-802A
   Component: IMMO          H05 0705
   VCID: 6AF5314C8D43EA6EE3-803E
   Revision: A1001003    Serial number: 7663253386
   Coding: 010100
   VCID: 2A75F14C45C32A6E23-807E
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2119
   Coding: 0001204
   VCID: 3147E620A81559B6E2-8064
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 74     3305
   Revision: 00H22000
   VCID: 3753D83846718786AC-8062
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0001204
   VCID: 3245E92CAD1362AE9B-8066
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7L3212222
   Coding: 01000400040007
   Shop #: WSC 00066 000 00000
   VCID: 63EB5C686269BB2620-8036
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 354FD2305C7D7596BE-8060
   Coding: 0001168
   VCID: 364DD53C417B7E8EB7-8062
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007663247582
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3A55C10CBD639AEE53-806E
End-------------------------(Elapsed Time: 01:53)--------------------------
I'm not worried about the bulb or MAF codes.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
What specific concerns do you have then? There's more than one thing happening in your scan. What's the history?
Also, there are some indications that you or someone else has been messing around with VCDS or otherwise doing retrofits:
Please describe any work or modifications you've done to the car, and any settings changes you've made with VCDS. Include everything, even stuff you think can't possibly be related, like lighting mods. Also, please post the contents of the AdpLog.txt and CodingLog.txt in your C:\Ross-Tech\VCDS\Debug folder. We're not trying to bust you for anything here; this is a mod-friendly forum. But, it's much easier to steer you toward a solution if we know how you got into trouble.
Jason
(waiting on verification)
Done -- and moved to Car Repair Support.
tehfalcon
C?ID=235987
The car has been tuned to Stage 2, and other then that nothing retro fitted, I installed LED bulbs and that's why the bulb warnings are on.
The car was aligned, and now there are steering wheel angle faults and the TPMS faults.
So I tried to calibrate the steering wheel angle sensor, then did the steering wheel lock calibration and both were successful, but now the ABS and Traction light is on. Not worried about being busted haha, car's not under warranty anymore, that's why I invested in VCDS.
It also as a ESP Function Test test code now after I had someone look at it. I really need help because there's no ABS or traction control right now, and winter is right over the mountains (im in colorado).
Jef
HQ
tehfalcon
C?ID=235987
Clear codes out of the ECM first. Then see if you can clear out the ABS code of 01314 - Engine Control Module: 013 - Check DTC Memory.
Hope you didn't skip leg day at the gym:
http://wiki.ross-tech.com/wiki/inde...asic_Setting_for_Hydraulic_Unit_Intake_Valves
Is there a button for TPMS in the upper left corner of your glove box? If yes, press it for 10 seconds while the engine is at idle.
Great, also yes I do have the button, holding it did get the light to turn off, but the code is still there even after clearing it.
Jef
HQ
Do your leg exercises first. Odds are the TPMS will sort itself out on a test drive.
tehfalcon
C?ID=235987
Tried doing the exercises, I enter the security access, then go to the basic settings and it shows up initially, then when I activate the basic settings it turns red and says not group not available, what am I doing wrong?
Jef
HQ
Was the engine warm? IE, can you safely touch the exhaust header right before you did the test? If not, the engine is too hot, which in turn heats up the ABS module.
tehfalcon
C?ID=235987
Probably too hot, it was after a short drive I tried.
tehfalcon
C?ID=235987
Completed the exercises. ABS and Traction control lights now off (yay!). Codes cleared out good. I will drive for a couple days and see if codes, Wire for Speed Signal and Steering Wheel Angle Sensor, come back. Thus far after an hour drive nothing is back except my engine codes due to a hole in the intercooler, lol.
