Car dead would not start.
rotorhead23
AB, Canada
C?ID=203428
I have a 2016 VW Passat 1.8 TSI. Has been running fine since I bought it 1 year ago. I went out to start it and everything was dead. No lights horn radio. Nothing. Thinking battery was dead we jumped it. Still nothing. After fiddling with battery cables on the Ford truck we tried starting several times. A few times there was a lot of clicking going on. I let it sit for a few minutes and tried again and it started. I had warning lights on such as steering system,brakes, also exclamation mark on adaptive cruise control. Decided to test drive it. Everything worked fine except cruise control. Still thinking battery was bad I drove to the Chev dealer in town half an hour away. I wanted to be close to where I could get another boost. Didn't need one and all the lights were out just after I left for town and cruise control worked on the way home. I came home and did this scan which I am posting. I would appreciate your help which you have done before. You guys are awesome.
Wednesday,10,July,2024,16:22:46:54235
VCDS Version: 24.5.0.0 (x64)
VIN: 1VWBS7A36GC030758   License Plate: CCH3412
Mileage: 202650km-125920mi   Repair Order: 2
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 25 2B 3C 42 44 46 47 4F 52
          5F 61 62 72
VIN: 1VWBS7A36GC030758   Mileage: 202650km-125920miles
Address 01: Engine (J623-CPKA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 071 AF    HW: 06K 907 425 C
   Component: R4 1.8l TFS   H13 4869
   Revision: --H13---    CVN: 6CBF5F95
   Coding: 001A0092244400169000
   Shop #: WSC 09003 957 00200
   ASAM Dataset: EV_ECM18TFS02006K906071AF 001008
   ROD: EV_ECM18TFS02006K906071AF.rod
   VCID: 6FC3385FB64ED7EEAA-803A
   VINID: 0669D28C74431974C00C01C52046F0D3D7
15083 - Cylinder 2 Knock Control
          P2337 00 [01100000] - Limit Reached
15357 - Torque Restriction due to Fuel Pressure
          P102F 00 [01100000] - -
17178 - Databus
          U1123 00 [00100000] - Received Error Message
                    Mileage: 202593 km
                    Date: 2024.07.10
                    Engine RPM: 0.00 /min
                    Coolant temperature: 29 °C
                    Intake air temperature: 34 °C
                    Ambient air pressure: 860 mbar
                    Voltage terminal 30: 13.554 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
21406 - EVAP Emission Control Sys
          P0441 00 [01100000] - Incorrect Flow
                    Fault Frequency: 9
                    Mileage: 195782 km
                    Date: 2024.05.07
                    Time: 01:05:25
                    Engine RPM: 1381.75 /min
                    Normed load value: 23.1 %
                    Vehicle speed: 62 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 33 °C
                    Ambient air pressure: 910 mbar
                    Voltage terminal 30: 14.062 V
                    Engine: operating status: PL
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 411 s
                    MAP_MES_SAE: 49 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.026 V
                    FAC_TPS_1_SAE: 15.625000 %
                    FUP_H_SAE: 14960.0 kPa
15128 - Cylinder 2
          P0302 00 [01100000] - Misfire Detected
14874 - Camshaft Position Sensor (G40)
          P0341 00 [01100000] - Implausible Signal
Address 02: Auto Trans (J217)       Labels:* 09G-927-749-V1.clb
   Part No SW: 09G 927 749 AN    HW: 09G 927 749 AN
   Component: AISIN AG6 G3  129 2941
   CVN: CA96F2E3
   Coding: 000348
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW23.rod
   VCID: 052F7AF784F2FDBE70-8050
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: C54BC0F5492500FAA31203E99221004100F0F01A
   Shop #: WSC 64834 003 1048576
   VCID: 75CF0A37DC12ED3E60-8020
                    Reset counter: 151
                    Mileage: 202592 km
                    Date: 2018.12.01
                    Time: 08:18:48
                    Count: 7
                    Count: 15
                    Count: 12288
                    Count: 128
                    Count: 28928
                    Count: 1
                    Count: 1023
                    Reset counter: 151
                    Mileage: 202592 km
                    Date: 2018.12.01
                    Time: 08:11:20
                    Count: 3
                    Count: 15
                    Count: 4096
                    Count: 16390
                    Count: 34560
                    Count: 1
                    Count: 1023
                    Reset counter: 151
                    Mileage: 202593 km
                    Date: 2018.12.01
                    Time: 00:00:01
                    Count: 2
                    Count: 14
                    Count: 20480
                    Count: 297
                    Count: 48384
                    Count: 1023
   Part No SW: 5K0 959 434 F    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1202
   Revision: 00093000    Serial number: 0382121354 Dataset Number: 560116v____ 0005
   Coding: 130C0C
   ROD: EV_KESSYPQ35G_A02_VW32.rod
   VCID: 3851C30383805056BB-806C
7 Faults Found:
65813 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
                    Reset counter: 150
                    Mileage: 202592 km
                    Date: 2024.07.10
                    Time: 08:15:25
221700 - Sensor for Rear Lid/Hatch Opening
          B1303 31 [00001000] - No Signal
                    Reset counter: 135
221702 - Sensor for Rear Lid/Hatch Opening
          B1303 12 [00001001] - Short to Plus
                    Reset counter: 46
                    Mileage: 196206 km
                    Date: 2024.05.10
                    Time: 22:32:02
221964 - Local Data Bus 4
          U10DC 00 [00001000] - Electrical Malfunction
                    Reset counter: 135
                    Mileage: 200280 km
                    Date: 2024.06.22
                    Time: 08:28:38
222732 - Sensor 2 for Rear Lid/Hatch Opening
          B1338 01 [00001001] - Electrical Failure
                    Fault Frequency: 16
                    Reset counter: 110
                    Mileage: 145631 km
                    Date: 2022.12.08
                    Time: 21:10:45
1052935 - Touch Sensor on Exterior Door Grip; Driver Side
          B116B 11 [00001000] - Short to Ground
                    Reset counter: 150
                    Mileage: 202593 km
                    Date: 2024.07.10
                    Time: 00:00:27
1057547 - Antenna for Keyless Entry System; Interior Antenna 1
          B1172 13 [00001000] - Open Circuit
                    Reset counter: 150
   Part No SW: 561 907 044 AM    HW: 561 907 044 AM
   Component: Climatronic   H07 0910
   Revision: 00001K04
   Coding: 0050019012
   VCID: 62E5416B759C6A8635-8036
9473042 - Motor for Left Temperature Flap
          B108C 12 [00001000] - Short to Plus
                    Fault Frequency: 31
                    Reset counter: 148
                    Mileage: 199827 km
                    Date: 2024.06.09
                    Time: 20:52:20
9473041 - Motor for Left Temperature Flap
          B108C 11 [00001000] - Short to Ground
                    Fault Frequency: 187
                    Reset counter: 149
                    Mileage: 167673 km
                    Date: 2023.07.16
                    Time: 20:06:18
   Part No SW: 5K0 937 087 AJ    HW: 5K0 937 087 AJ
   Component: BCM PQ35 H+   122 0183
   Revision: BL122001
   Coding: EF200E1B882B2AD4088806013400854800F1000645A00DB0E4806200BC70
   VCID: 7DDF1217E422B57E28-8028
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 241015 03  37  0059
   Coding: 0038DD
   Part No SW: 7N0 907 572 B    HW: 7N0 907 572
   Component: ACC Bosch PQx H03 0120
   Serial number: 03121577091111 Dataset Number: 561114v____ 0011
   Coding: 01001000FE0739
   ASAM Dataset: EV_ACCBEGVW361 001005
   ROD: EV_ACCBEGVW361.rod
   VCID: 354FCA379492AD3EA0-8060
1058 - Databus
                    Reset counter: 151
                    Mileage: 202592 km
                    Date: 2024.07.10
                    Time: 08:11:09
                    Control Module temperature: 46 °C
                    Voltage terminal 15: 9.6 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1059 - Databus
                    Reset counter: 151
                    Mileage: 202593 km
                    Date: 2024.07.10
                    Time: 00:00:01
                    Control Module temperature: 43 °C
                    Voltage terminal 15: 13.2 V
1043 - Automatic Distance Control
          B10E7 F0 [00001000] - Disconnected
                    Reset counter: 151
                    Mileage: 202593 km
                    Date: 2024.07.10
                    Time: 00:00:01
0077 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
                    Reset counter: 150
                    Mileage: 202592 km
                    Date: 2024.07.10
                    Time: 08:12:48
                    Voltage terminal 15: 9.0 V
0080 - Supply voltage
                    Reset counter: 150
                    Mileage: 202592 km
                    Date: 2024.07.10
                    Time: 08:14:17
                    Voltage terminal 15: 8.5 V
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    001 0207
   Serial number: 003RXM03978Q Dataset Number: 561003V____ 0012
   Coding: 8CCCCC00000000005000001A020800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411.rod
   VCID: 63EB446F6A86638E3E-8036
   Component: BF-Gewichtss.  H12 0021
   Serial number: IBH000000000004GK94D
   Coding: 30324C
   Subsystem 2 - Part No SW: -----------    HW: 480 000 511 15
   Serial number: 3570000000056D84671M
   Subsystem 3 - Part No SW: -----------    HW: 480 001 311 15
   Serial number: 35800000000F9801A71O
   Subsystem 4 - Part No SW: -----------    HW: 480 020 611 15
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001A71DDB592D7ET
   Subsystem 5 - Part No SW: -----------    HW: 480 020 611 15
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001A91DDB592A3CN
   Subsystem 6 - Part No SW: -----------    HW: 480 020 311 15
   Component: FrontSensor_D  000 0189
   Serial number: 3550001AD1DDB593040A
   Subsystem 7 - Part No SW: -----------    HW: 480 020 311 15
   Component: FrontSensor_P  000 0189
   Serial number: 3560001B11DDB595655E
          B10B3 00 [00001000] - Function Restriction due to Implausible Message(s)
                    Reset counter: 150
                    Mileage: 202592 km
                    Date: 2024.07.10
                    Time: 08:11:30
          B10B4 00 [00001000] - Function Restriction due to Undervoltage
                    Reset counter: 150
                    Mileage: 202592 km
                    Date: 2024.07.10
                    Time: 08:21:40
   Part No SW: 1K5 953 521 CR    HW: 5K0 953 569 BF
   Revision: FF010042    Serial number: 20150922200219
   Coding: 0002C40008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7F23E81FE62EA76E3A-802A
   Subsystem 1 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 2811511204201066AF2B
   Coding: 2C0000
114178 - Function Restricted due to Insufficient Voltage
                    Reset counter: 150
                    Mileage: 202592 km
                    Date: 2024.07.10
                    Time: 08:12:55
136194 - Supply voltage
                    Reset counter: 150
                    Mileage: 202592 km
                    Date: 2024.07.10
                    Time: 08:17:34
   Part No SW: 561 920 871     HW: 561 920 871
   Component: KOMBI         H04 1008
   Coding: 331E010000
   VCID: 579360BF2EDEBF2E52-8002
13635840 - Supply voltage
                    Reset counter: 150
                    Mileage: 202592 km
                    Date: 2024.07.10
                    Time: 08:15:24
   Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1663
   Revision:   H56       Serial number: 05011603000799
   Coding: 461010
   VCID: 72C5312BAD7CFA0645-8026
   Component: IMMO          H04 1008
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
   VCID: 6AF5294B8DAC32C6FD-803E
   Revision: 00000000    Serial number: 15000198535002
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: 3041FB236BF08816F3-8064
                    Reset counter: 150
                    Mileage: 202592 km
                    Date: 2024.07.10
                    Time: 08:14:28
                    ELV State: 0C
                    Information Clamps: 77 60
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Vehicle speed: 0.00 km/h
                    Voltage: 4A
                    Reset counter: 150
                    Mileage: 202592 km
                    Date: 2024.07.10
                    Time: 08:13:02
                    ELV State: 0C
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Voltage: 4C
   Component: HRE_Master    H11 0071
   Serial number: 0381236737 Dataset Number: 5G9764V____ 0035
   Coding: 01011102
   ROD: EV_HREntryHella_VW41.rod
   VCID: 3C59DF13B7B87C765F-8068
   Component: HRE_Slave  H11 0071
   Serial number: 0381951357
   Coding: 010111
                    Reset counter: 142
                    Reset counter: 142
733696 - Control Module 2 for Blind Spot Assist
          C1190 F5 [00001000] - Limited Visibility
                    Reset counter: 142
                    Mileage: 200539 km
                    Date: 2024.06.25
                    Time: 21:17:26
   Part No SW: 561 959 701 C    HW: 3C0 959 793 J
   Component: TUER-SG FT    002 0637
   Revision: 12100010    Serial number: 0010004204
   Coding: 3414BD
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1E1D359B01640E6651-804A
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 C    HW: 561 959 811 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  019 1471
   Serial number: 14102746160114201427
67330 - Switch for Central Locking
          B122D 29 [00001000] - Signal Implausible
                    Reset counter: 148
                    Mileage: 202022 km
                    Date: 2024.07.05
                    Time: 02:41:51
131584 - Motor for Rear Window Regulator
          B11EE 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 151
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 311    3501
   Revision: 00H22000
   VCID: 3957C607708A495E44-806C
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0074125 Dataset Number: 560050v____ 0007
   ROD: EV_AudioVerst10KanalSTT3_VW32.rod
   VCID: 287113435320C0D62B-807C
                    Reset counter: 150
                    Mileage: 202592 km
                    Date: 2024.07.10
                    Time: 08:14:12
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1663
   Coding: 01030108
   VCID: 6FC3385FBE4ED7EEAA-803A
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Serial number: 53388786011508001252
   Coding: 181100
   Subsystem 2 - Part No SW: 561 919 204 C    HW: 561 919 204 C
   Component: Analoguhr  001 0002
   Part No SW: 561 959 702 C    HW: 3C0 959 792 J
   Component: TUER-SG BT    002 0637
   Revision: 14100010    Serial number: 0009996402
   Coding: 3415BC
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1F63089F066E076E5A-804A
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 C    HW: 561 959 812 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  019 1471
   Serial number: 14202747160111174740
                    Reset counter: 151
   Part No SW: 5C0 035 684     HW: 5C0 035 684
   Component: MU-S-NS-US    H22 0245
   Serial number: VWZAZ2R0553022 Dataset Number: 5K7CV1v__A_ 0001
   Coding: 02140102AA00000011220003001828001F0100D400200105C6
   ROD: EV_MUStd4CTSAT_VW26.rod
   Subsystem 1 - Part No SW: 3G0 919 866 B    HW: -----------
   Component: NAR 2015/16  --- 0220
1537 - Supply voltage
                    Reset counter: 150
                    Mileage: 202592 km
                    Date: 2024.07.10
                    Time: 08:12:31
                    Voltage terminal 30: 9.1 V
                    Reset counter: 150
                    Mileage: 202592 km
                    Date: 2024.07.10
                    Time: 08:14:23
                    Voltage terminal 30: 8.6 V
1596 - Data Set Implausible
          B2012 00 [00001001] - -
                    Reset counter: 17
                    Mileage: 165466 km
                    Date: 2023.06.20
                    Time: 22:41:15
                    Voltage terminal 30: 12.4 V
   Component: Batt.regelung H56 1663
   Coding: E1200859
   VCID: 71C73E27A87AC11EBC-8024
End-------------------------(Elapsed Time: 03:40)--------------------------
Reactions: Jef
Jef
HQ
Thank you for posting the Auto-Scan without the threat of violence. :thumbs:
Eh.... so it looks like 37 of the 39 fault codes are "Intermittent". And there are several low voltage codes in there. I think I would clear DTCs, 94.8717949% of them will hopefully clear out without issue. Then if/when the issue happens again, first verify battery voltage (key off, key on and while trying to crank), as well as run an Auto-Scan while the issue is still happening.
Maybe some one else will chime in with a "oh, this again" kind of answer, but currently, I'm not that person. :confused:
94.8717949%
I am loving that certainty level.... may I use this if needed in the future, or is royalty required :p
rotorhead23
AB, Canada
C?ID=203428
I tried to erase all codes and don't really know how. The only button I see is the OBII button to erase codes. Doesn't really do anything.
Speaking to VW about my problem they tell me my car has a battery management system and if the replacement battery (one year ago before I bought the car) isn't coded to the car, it may cause problems. It's not a VW battery, so it wasn't installed by VW.
Any thoughts on the above?
After you do a Auto-Scan, look for the clear codes tab - 05
scroll down to /near "gateway Installation list" on the link shown below (Bold blue font).
Or, as shown by the link below, you can go to each module and clear the codes
one module / controller at a time.
EuroX
Northern NJ USA
C?ID=208579
Technically yes a factory battery should be used. However if you have a non factory replacement you can try to adapt it using original battery values. Technically you can put it anything for a serial number as long as its a different number than the original number stored in the module in order to reset the adaption. Now if you had a AGM and now you don't that may affect the life of the battery and so on. Best of luck.
On this car, battery type (Wet, AGM, EFB, etc) can be set in coding. Battery size (Ah capacity) is in Adaptation channel 004.
Ronnie.Vincent
C?ID=389395
Had this happen to one of my Superb 2.0Tdi Technology. Would be fine then suddenly go to start and nothing! Adaptive Cruise Control and Horn would not work. Before I ran a diagnostic, did a quick search on the internet and things pointed to a 'dying battery' I have a boost pack that I carry with me so kept going for a few days, boost starting it when it happened. Changed the battery and everything has been fine since. Rake of fault codes after changing battery but would expect that after having the battery swapped out. Particularly Steering Angle, usually clears when you start driving. The first thing that 'stops' when the battery starts to go is the Stop/Start function.
rotorhead23
AB, Canada
C?ID=203428
Thanks for all the replies! I bought a new VW battery. Had them wipe all codes and check electrical system. All is good for now. Will run another scan shortly.
