1 Fog Light Fail - How Do I Resolve?
Fireblade69
C?ID=585082
I have been trying to resolve an issue with the right hand front fog light not working and throwing an error in DIS. In the UK this is an MoT (yearly roadworthiness test) failure which means that the car canot be driven on the road until rectified.
After extensive testing of the bulb, wiring, switches etc. the end result of all of that is that the Body Control Module is not sending 12V out on the pin when the front fog lights are switched on. The left hand side works fine And when I jump the pin on the circuit board to another live 12v point, the light will work - this proves the connector, cables, holder and bulb are all working. The cables from the bulb end to the pin on the connector pass continuity tests, the bulb and holder when plugged into the left hand side work fine, the left hand bulb and holder when plugged into the right hand side do not work - switch around test.
I’ve purchased the VCDS to help me solve this problem (plus a couple of other issues) either by diagnosing and fixing the issue or, as it looks like it is heading, by buying a 2nd hand BCM and recoding it to the car.
I would like some suggestions on how this can be done please. I have used VCDS (VAG-COM when I had it back in the day) but that was years ago so I’m relearning.
Scan Output
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 192
Mileage: 139843 km
Date: 2024.01.05
Time: 16:57:05
Voltage: 12.60 V
Term 50 Off
Fireblade69
C?ID=585082
I Hope this is correct!
Sunday,07,July,2024,08:37:00:40922
VCDS Version: 24.5.0.0 (x64)  HEX-V2 CB: 0.4643.5
VIN: TRUZZZ8J8B1025925   License Plate:
Chassis Type: 8J (8P0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 55 56 61 77
37-Navigation -- Status: Cannot be reached 1100
Address 01: Engine (CES)       Labels:. 06J-907-115-CES.clb
  Part No SW: 8J0 907 115 AJ    HW: 8J0 907 115 AJ
  Component: 2.0l R4/4V AVS   01 0080
  Revision: EIH06---    Serial number: AUX7Z0K3FNS06L
  Coding: 0113000C18070160
  Shop #: WSC 01211 210 01254
  VCID: 74B6062C82B2D20A43B-8020
  VINID: 92296AAAA21A212040085242141DD5EE35
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
  Part No SW: 8J0 614 517 B    HW: 8J0 614 517 B
  Component: ESP MK60E1          0010
  Revision: 00H60001
  Coding: 0083344
  Shop #: WSC 01236 785 00200
  VCID: 2C06DE4C1A02CACADBB-8078
Address 08: Auto HVAC        Labels: 8J0-820-043.clb
  Part No SW: 8J0 820 043 BB    HW: 8J0 820 043 BB
  Component: J255  Klima 1 Zone  0110
  Revision: 00H09006    Serial number: 00000001184650
  Coding: 1573892
  VCID: 678C6160C3642992F69-8032
  Part No SW: 8P0 907 063 H    HW: 8P0 907 063 H
  Component: BCM PQ35  H   108 0615
  Revision: 00108 AG
  Coding: 46000B2FA005F1202070C9E00000094C521E58AA3000D928DC000E440045
  Shop #: WSC 01236 758 00200
  VCID: 3928F718E9506F6250D-806C
  Subsystem 1 - Part No SW: 8J2 955 119 A    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
  Component: Wischer AU354  H08 0070
  Coding: 00FD10
  Subsystem 2 - Part No: 8J0 951 177
  Component: DWA-Sensor H0  H03 0030
                   Reset counter: 183
                   Mileage: 139843 km
                   Date: 2024.01.05
                   Time: 16:57:05
                   Voltage: 12.60 V
                       Term 50 Off
01503 - Bulb for 3rd Brake Light (M25)
                   Fault Status: 00101010
                   Fault Frequency: 64
                   Reset counter: 222
                   Mileage: 142933 km
                   Date: 2024.06.02
                   Time: 10:11:54
                   Voltage: 14.50 V
                       Term 50 Off
Address 15: Airbags        Labels: 8J0-959-655.lbl
  Part No SW: 8J0 959 655     HW: 8J0 959 655
  Component: -t Airbag 9.43  H03 0020
  Revision: 93H03002    Serial number: 0036K0057XZN
  Coding: 0011636
  VCID: 79A83718A5D0AF6210D-802C
  Subsystem 1 - Serial number: 6332DRB40D908995-
  Subsystem 2 - Serial number: 6342DRB403BC0A20M
  Subsystem 3 - Serial number: 63747RB4061494C3M
  Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
  Coding: 0004041
  VCID: 46D28CE4A4AE109A2DF-8012
  Component: E0221           H06 0030
Address 17: Instruments
  Part No SW: 8P0 907 530 C    HW: 1K0 907 951
  Component: J533  Gateway H43 0311
  Revision:   H43       Serial number: 280411F2003080
  Coding: 354101
  VCID: 3334C530CB3C95329A1-8066
                   Fault Frequency: 172
                   Reset counter: 179
                   Mileage: 139843 km
                   Date: 2024.01.05
                   Time: 16:45:59
                   Reset counter: 140
                   Mileage: 143234 km
                   Date: 2024.06.15
                   Time: 14:12:34
                   Mileage: 139843 km
                   Date: 2024.01.05
                   Time: 16:45:59
  Part No SW: 8J0 920 980 P    HW: 8J0 920 980 P
  Component: KOMBIINSTR. VDO H01 0591
  Revision: D0H01004    Serial number: AUX7Z0K3FNS06L
  Shop #: WSC 00137 211 56823
  VCID: 3E22E404FC7E485A65F-806A
Address 37: Navigation
  Part No SW: 8J8 959 801 J    HW: 8J8 959 801 J
  Component: Tuer-SG         004 0102
  Coding: 0000565
  VCID: 44D696EC9292228A33B-8010
  Part No: 8J0 909 144 M
  Component: EPS_ZFLS Kl. 235    3201
  Revision: 00H20000
  VCID: 3A2AE814E056647A597-806E
Address 47: Sound System        Labels: 8J0-035-223.lbl
  Part No SW: 8J0 035 223 D    HW: 8J0 035 223 D
  Component: J525 Amp High   H04 0160
  Revision: PROD_01     Serial number: 00000000026911
  Coding: 0236117
  VCID: 25102B6879E8FB82045-8070
                   Reset counter: 223
                   Mileage: 140415 km
                   Time: 31:63:63
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MAX1.lbl
  Part No: 8J8 959 802 C
  Component: Tuer-SG         H02 0050
  Coding: 0000565
  Part No: 8P3 907 357 B
  Coding: 0000009
  VCID: 3C26EE0CEA625A4A4BB-8068
Address 56: Radio
  Part No SW: 8P0 907 534     HW: 1K0 907 951
  Component: Batt.regelung H43 0311
  Coding: F322015A
  VCID: 74B6062C8EB2D20A43B-8020
  Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
  Component: J367-BDM  H07 0140
  Serial number: 00000000005650380248
  Part No SW: 8P1 862 335     HW: 8P1 862 335
  Component: FSE_256x BT     H41 0650
  Revision: 00000000    Serial number: 00000005371721
  Coding: 0011422
02503 - Output Wire to Radio
                   Reset counter: 140
                   Mileage: 143234 km
                   Date: 2024.06.15
                   Time: 14:12:38
End----(Elapsed Time: 01:22, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Dr Sheldon
Windsor UK
C?ID=334979
It will send 12v for a few milliseconds - see a fault an switch power off !! You're not going to see that unless you use a scope, perhaps an LED or a 5w bulb.
Cheap or wrong bulbs can do this too but I see you have tried Swaptronics
Fireblade69
C?ID=585082
Having swapped the bulbs and bulb carriers out and the fault stays in the same place plus the wiring loom all checks out (continuity all tested okay) then is there a way through VCDS of forcing the 12v to live?
Fireblade69
C?ID=585082
Thanks @Uwe it is for the front fog light I need.
Fireblade69
C?ID=585082
Awesome, I’ll have a look for it.
