VCDS Measuring Blocks - Timing Chain
Belly
Brisbane, Australia
C?ID=587947
Hi Guys,
My first post regarding a long term issue i am trying to solve.
2004 3.2L V6 Touareg runs rough at iddle, poor throttle response & power delievery (no rattles or significant noises from engine)
Following fault codes and measuring blocks has no data for Group 209
I have replaced both camshaft sensors & crankshaft senor to no avail.
I'm wondering if the camshaft control valve for VVT may be faulty?
Please post a complete and unedited Auto-Scan utilizing the forums format. I can't navigate or copy/paste or quote your data.
P1347 Incorrect correlation ; this usually means your timing is off / jumped.
Try advanced measuring blocks and in the upper search box, of that page, try search words like "timing" or "cams" or "correlation" and you will see all the addresses come up and you can check mark the ones you want to see in real time. Your looking for data that shows "actual" and "specified" ; they should be similar (within a few degrees of one another).
Here is the Interactive Manual so you can look around without any risk:
EuroX
Northern NJ USA
C?ID=208579
See attached Tech bulletin.
  • vw.tb.15-07-03 MIL ON with DTCs P1347 1755 and P1340 17748 Stored In Memory.pdf
RGH0
Australia
C?ID=433612
That tech bulletin is a great example of why VCDS is easier to use and understand when troubleshooting than the factory ODIS tool :)
EuroX
Northern NJ USA
C?ID=208579
I disagree. If your familiar with ODIS and its interface its just as easy.
RGH0
Australia
C?ID=433612
Maybe if you use it a lot. But anything that puts up unlabeled data in a column and you have to refer to "see the arrow pointing to third field down" does not seem easy to me
EuroX
Northern NJ USA
C?ID=208579
I use both everyday. Tasks are more automated using ODIS.
Belly
Brisbane, Australia
C?ID=587947
Sorry guys finally had a chance to upload the auto scan - I hope I have done it correctly
Saturday,13,July,2024,15:42:46:00097
VCDS Version: 24.5.0.0 (x64)  HEX-V2 CB: 0.4643.5
VIN: WVGZZZ7LZ5D033434   License Plate:
Mileage: 249610km-155100mi   Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ5D033434   Mileage: 249610km-155100miles
Address 01: Engine        Labels: 022-906-032-BMX.lbl
   Part No SW: 022 906 032 GA    HW:
   Component: MOTRONIC ME7.1.1G   6384
   Coding: 0000133
   Shop #: WSC 31414 000 00000
   VCID: 50FEA97AA6F3359A873-5160
   VINID: 9E65EAAAA1DCA855000C310310EB4B0AAE
17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28)
            P1347 - 002 - Incor. Correl. - MIL ON
Readiness: 0000 1001
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No: 09D 927 750 BN
   Component: AL 750 6A           0555
   Coding: 0004136
   VCID: 7BA42ED65FF566C2021-5160
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0014338
   VCID: 3D20E0CE0161A8F27C5-5160
   Part No SW: 3D0 909 135 N    HW: 5WK 470 21
   Component:    Kessy            6610
   Revision: 66105312    Serial number: VWZ3Z0D1256289
   Coding: 0000232
   VCID: 303EC9FAC633559AE73-5160
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 H
   Component: CLIMAtronic R/L   X 3716
   VCID: 3530F8EE395170B2B45-5160
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 K
   Component:                     2703
   Coding: 0067684
   VCID: 44D6952A628BD93A33B-5160
   Part No: 3D0 909 601 E
   Component: 0C Airbag 8.4E+ H10 0952
   Coding: 0012355
   VCID: 251028AE89F10032045-5160
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 D
   Component: Lenksäulenmodul     3301
   Coding: 0000031
   VCID: 40DE993A7693C51A173-5160
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 870 J
   Component: KOMBIINSTRUMENT RB8 1835
   Coding: 0007711
   Shop #: WSC 22040 959 86313
01304 - Radio
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70BE09FA06B3159AA73-5160
01304 - Radio
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F5CDAC64BED7AE22E9-5160
Address 46: Central Conv.        Labels: 7L0-959-933.clb
   Part No: 7L0 959 933 E
   Component: FV HSG              0201
   Coding: 0000065
   VCID: 3E22E7C20C67B3EA65F-4B28
   Subsystem 1 - Part No: 7L0 959 701 C
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 C
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704
   Component: Tuersteuergeraet HR 0201
Address 68: Wiper Electr.        Labels: None
   Part No: 7L0 955 119 G
   Component: Front Wiper         2416
   Coding: 0000002
   Shop #: WSC 31414 000 376832
   VCID: 382EF1DA2E438DDAAF3-5160
End----------(Elapsed Time: 09:12, VBatt start/end: 12.2V/12.1V)-----------
Belly
Brisbane, Australia
C?ID=587947
I also tried the advanced measuring blocks and all the "actual" or "specified" timing values are within a couple of degrees....
