CJAA timing and compression
WOODCNC
Bradford, OH, USA
C?ID=588666
hats the chances my cjaa with 267K miles and only 67K on a timing belt thats less than two years old, jumped time? Using VCDS, and looking at measuring blocks 140 and 141 leads me to believe cylinders 1 and 2 have no compression but could it just be that it is measuring at the wrong time due to a mechanical timing jump?
Jef
HQ
When asking for assistance, please post a complete Auto-Scan.
If timing jumped, I would expect all cylinders to be screwed.
WOODCNC
Bradford, OH, USA
C?ID=588666
Wednesday,10,July,2024,13:04:27:51601
VCDS Version: 24.5.0.0 (x64)
VIN: 3VW3L7AJ1BM057504   License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 44 56 77
VIN: 3VW3L7AJ1BM057504   Mileage: 429040km-266593miles
   Part No SW: 03L 997 030 Q    HW: 03L 906 019 DA
   Component: R4 2.0l TDI G000SG  9983
   Revision: 12H13---    Serial number:
   Coding: 0050072
   Shop #: WSC 83712 804 460358
   VCID: 3C7D11DF7FA236765F-8068
   VINID: 0E69C370745A05274014714010CE2CA204
               P0300 - 001 -
                    Fault Status: 01100001
                    Mileage: 429044 km
                    Date: 2018.12.01
                    Time: 17:29:16
                    RPM: 897 /min
                    Inj. Quantity: 17.6 mg/str
                    Mass Air / Rev.: 290.0 mg/str
                    (no units): 1.29
                    Temperature: 26.1°C
                    Temperature: 32.4°C
000401 - Fuel Pressure Sensor (G247)
               P0191 - 001 - Implausible Signal - Intermittent
                    Fault Status: 00100001
                    Mileage: 429044 km
                    Date: 2018.12.01
                    Time: 06:19:41
                    RPM: 805 /min
                    Lambda: 33.1 %
                    Pressure: 128.0 bar
                    Pressure: 512.0 bar
                    Pressure: 928.0 bar
                    Temperature: 30.6°C
Readiness: 0 0 0 X X
   Part No SW: 1K0 907 379 BG    HW: 1K0 907 379 BG
   Component: ESP MK60EC1   H31 0106
   Revision: 00H31001
   Coding: B14B400C492700018D1002E4921D0042A60000
   Shop #: WSC 00066 000 00000
   VCID: 78F5CDCFCB1ADA567B-802C
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 Q    HW: 5C0 820 047 Q
   Component: J301  Klimaanlage   0103
   Revision: 2000908S    Serial number: 00000000192454
   VCID: 2E592B97B9DED4E6E1-807A
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0257
   Revision: B2066001    Serial number: 03311007110022
   Coding: 6B994BBF08AB0B00083826C0040884C5D08250FE60000000300000000000
   Shop #: WSC 09571 002 104857
   VCID: 2F6736937ED4DDEEEA-807A
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3463
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3463
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.019  H08 0006
   Serial number:     WRH0001119P
   Coding: 180000
   Subsystem 4 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Component: E221__MFL-TAS  H07 0013
   Serial number: 0135558
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3463
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3463
   Coding: 800000
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   013 0807
   Serial number: 003GTD08VRCA   Dataset Number: 160003v____ 0086
   Coding: 00003935
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 346D39FF9FF2FE3697-8060
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y100000279J05
   Coding: 303241
   Serial number: 3572MSME206F4559ZZZ$
   Serial number: 3582MSME3E2B1558ZZZ0
   Serial number: 3516KSME41046E0DZZZV
   Serial number: 3526KSME671E680DZZZ2
   Serial number: 3556LSME211B620DZZZU
   Serial number: 3566LSME0021620DZZZJ
   Part No SW: 5C6 920 950 E    HW: 5C6 920 950 E
   Component: KOMBI         H07 0406
   Coding: 270801
   Shop #: WSC 00066 123 00148
   VCID: 2C5D219F47C2A6F6CF-8078
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0257
   Revision: B2066001
   Coding: 102200
   VCID: 70E5F5EFA36A8216B3-8024
   Component: IMMO          H07 0406
   ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
   VCID: 6AD1E7878DB678C6FD-803E
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Revision: A1001003    Serial number: 7668790621
   VCID: 2757DEB3562485AE22-8072
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 316330EBA8E0CB1EFC-8064
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7M3265331
   Coding: 01000400020006
   VCID: 63CF8AA3629C298E3E-8036
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 19
                    Mileage: 429044 km
                    Date: 2018.12.01
                    Time: 05:08:24
                    Reset counter: 19
                    Mileage: 429044 km
                    Date: 2018.12.01
                    Time: 05:08:21
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668935677 Dataset Number: 7P6035730C  0001
   Coding: 0A00000000010100
   Shop #: WSC 01383 790 50316
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 32613FE765E6F00685-8066
End-------------------------(Elapsed Time: 02:25)--------------------------
WOODCNC
Bradford, OH, USA
C?ID=588666
   Coding: 0050072
               P0300 - 001 -
                    Mileage: 429044 km
                    Date: 2018.12.01
                    Time: 17:29:16
                    RPM: 897 /min
                    (no units): 1.29
                    Temperature: 26.1°C
                    Temperature: 32.4°C
                    Mileage: 429044 km
                    Date: 2018.12.01
                    Time: 06:19:41
                    RPM: 805 /min
                    Lambda: 33.1 %
                    Pressure: 128.0 bar
                    Pressure: 512.0 bar
                    Pressure: 928.0 bar
                    Temperature: 30.6°C
   Revision: 00H31001
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Coding: 020000
   Coding: 800000
   Coding: 800000
   Coding: 00003935
   Coding: 303241
   Coding: 270801
   Revision: B2066001
   Coding: 102200
   Revision: 00H17000
                    Reset counter: 19
                    Mileage: 429044 km
                    Date: 2018.12.01
                    Time: 05:08:24
                    Reset counter: 19
                    Mileage: 429044 km
                    Date: 2018.12.01
                    Time: 05:08:21
   ROD: UHVNA.rod
How about the full story?
What has happened that suggests a possible jump?
Did you throw an accessory belt, or over-rev, or hydro-lock, or ????? :confused:
WOODCNC
Bradford, OH, USA
C?ID=588666
cruising down the highway at 70 MPH and lost all power. Now it runs really bad (Undrivable, I mean you can drive it but not really. I've taken it down the road since I brought it home but it has very low power). It has this wierd little cackle around 3K, heats up really quick, smells like a ton of raw fuel coming out exhaust and smokes very badly (grayish black). and it lightly smokes all around the engine bay (i cant tell where its coming from)
Ok, so nothing there really justifies a "jump" as it should've pretty much been a low demand situation.....
Did you hear any terrible noises or anything else? Why are you even running\revving it if you suspect a jump? Knock the cover off and validate timing is OK... it's a 4 cyl with easy access
WOODCNC
Bradford, OH, USA
C?ID=588666
ok. have you visually checked timing on a CJAA engine before? It doesn't look too easy to access from what I can see. Maybe I am missing something. If you have knowledge, please share. that is why I am here.
and no, there weren't any noises or any signs leading up to the loss of power.
There are these things called service manuals, how-to's, etc...... when I said "easy", I meant compared to something like a v6 where you have chains between the block and tranny and have to dismantle half the vehicle to see anything....
If you don't want to take all that off, check compression...
Either way, you need to turn some wrenches at this point.
WOODCNC
Bradford, OH, USA
C?ID=588666
what are these things called service manuals you speak of? wrenches....never heard of 'em???
thanks for the link but I've already been on that thread. Its pretty detailed. I was just looking for some real life experience from a guy/gal who has some. Oh well, maybe I'll have better luck next time:)
