Resolved 2012 Touareg TDI - P2017
Resolved
andrePNW
PNW, USA
C?ID=587036
EDIT: I'll post the auto-scan once I'm off work!
Hey Gang!
Been troubleshooting a few errors the past few weeks regarding a 2012 Touareg TDI (NAR)
I've had the P2015 code for quite some time, so I finally decided to perform output tests to ensure full range of motion/operability.
No issues, there so I continued on to remove the actuator assembly in question and verify the internal sensor was clean/etc.
All good on that front... then... I go to reassemble and the error disappears!
However.. very soon after an initial startup a new P2017 Short to Plus error presents itself..
I continued to unplug the connector and clear the codes.. P2017 returns immediately along with open circuit (Obviously).
To my surprise... P2017 returned immediately after a few cycles/clears, with the actuator NOT connected so I'm now embarking on checking resistance from the ECM.
This is where I'm stuck... I'm either into the weeds and misunderstanding the wire diag or... the diag (or) testing/checking procedure are mismatched.
The checking procedures are as follows... (Check resistance)
GX14 T2 -> T105 / 81
GX14 T4 -> T105 / 67
GX14 T5 -> T105 / 88
Which sounds great until I saw the wiring diagram..
None of the terminals listed earlier for GX14 go to the intended ECM points, but instead come from GX15. (Bank/Unit #2, which isn't in the scope of my issue... yet)
I could very well be misunderstanding, but wanted to get opinions before I jump into this since I have a few days before I revisit this mess.
Cheers!
andrePNW
PNW, USA
C?ID=587036
Wednesday,10,July,2024,20:36:08:16709
VCDS Version: 24.5.0.0 (x64)  HEX-V2 CB: 0.4643.5
VIN: WVGEK9BPXCDXXXXXX   License Plate:
Mileage: 255612km-158829mi   Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 52 53 55 56 62 65 69
          6D 72 77 A7
VIN: WVGEK9BPXCDXXXXXX   Mileage: 255612km-158829miles
A7-Infotain. Interface -- Status: OK 0000
Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 J    HW: 7P0 907 401 E
   Component: 3.0TDI FSA    H17 0008
   Revision: 56H17---    CVN: 66FD96005C3E0D045C3E0D04
   Coding: 292A4012233600050000
   Shop #: WSC 04944 444 00000
   ASAM Dataset: EV_ECM30TDI0117P0907401J 002007
   ROD: EV_ECM30TDI0117P0907401J_002.rod
   VCID: 3632FFC168C369EABDF-8062
   VINID: 9E65D56C94A0A1350000600818BF03F6F5
5504 - Intake Manifold Flap Position Sensor (Bank 1)
          P2017 00 [00100111] - Short to Plus
                    Mileage: 255612 km
                    Date: 2024.07.10
                    Time: 20:32:09
                    Engine RPM: 0.00 /min
                    Coolant temperature: 36 °C
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 11.880 V
                    Air mass: actual value (mg/stroke): 0.0 mg/stroke
                    Intake manifold Runner Control (IMRC): activation: 100.00 %
                    Intake manifold Runner Control (IMRC): acknowledgment: 100.00 %
                    Intake manifold runner control (IMRC): offset closed: -14.98 %
                    Actuator for intake manifold runner control: status-Bits 0-7: 55
                    Actuator for intake manifold runner control: status-Bits 0-7: 0
                    Actuator for intake manifold runner control: status-Bits 0-7: 48
                    Intake manif runner actuator: uncond volt actual value: 4750.6 mV
9153 - Intake Manifold Flap; Bank 1
          P2004 00 [01100101] - Stuck Open
                    Mileage: 255612 km
                    Date: 2024.07.10
                    Time: 20:32:09
                    Intake manif runner actuator: uncond volt actual value: 4752.4 mV
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 G    HW: 0C8 927 750 G
   Component: AL1000 AISIN  001 3407
   Serial number:                CVN: CB5A7D50
   Coding: 001368
   Shop #: WSC 99999 999 83333
   ROD: EV_TCMAL991031_002_VW52.rod
   VCID: 303EC9D98AA747DAE73-8064
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 J    HW: 7P0 907 379 A
   Component: MK25A         H36 0433
   Revision: --------    Serial number: 431410010EC010 Dataset Number: 7P0012v____ 7P16
   Coding: 5B7613C349242559DAF4C89B92D8A4407300
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 44D695092E1FCB7A33B-8010
   Part No SW: 4H0 907 064 BK    HW: 4H0 907 064 BK
   Component: BCM2 2.0      H31 0333
   Coding: 09860000000000000000
   VCID: 73B406D53BB13CC25A1-8026
   Subsystem 1 - Part No SW: 7P6 959 754 M    HW: 7P6 959 754 M
   Component: FBSTOUAREGIDG  H04 0051
   Serial number: 0511000056876015
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000232752010
00955 - Key 1
                    Mileage: 247181 km
                    Date: 2023.10.08
                    Time: 19:29:16
00956 - Key 2
                    Fault Status: 01100010
                    Reset counter: 0
                    Mileage: 254486 km
                    Date: 2024.05.23
                    Time: 09:02:46
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BR    HW: 7P6 907 040 BR
   Component: Klima 2 Zonen H21 1306
   Coding: B606200880
   VCID: 0550480D65A53272645-8050
   Part No SW: 4H0 907 063 BD    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0100
   Revision: 15012002    Serial number: 00000001299360
   Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
   VCID: 6B841EB56381E402921-803E
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    111031  31  0020
   Serial number: 90243400111109144928
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10269269
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
   Component: E1 - LDS  H04 0031
   Serial number: 00000000000111110331
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R0VQA07
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 D    HW: 7P0 959 655 D
   Component: VW10Airbag02B H06 0026
   Revision: --------    Serial number: 003L5000B6RU Dataset Number: v00310737P6 1073
   Coding: 000000000000000000000000000000003242
   Shop #: WSC 54636 000 1048576
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 42DA9311340BC54A017-8016
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R1172706HGL
   Serial number: 3575LRB405R0TGJG9ODQ
   Serial number: 3585LRB40530U2UQ5OIC
   Serial number: 3515RRB40530Q8K4817-
   Serial number: 3525RRB40570Q8K4216Y
   Serial number: 3555NRB40650TO4M69DT
   Serial number: 3565NRB405V0TO4M3OQ.
   Part No SW: 4H0 953 568 F    HW: 7P6 953 507 L
   Revision: --------    Serial number: 90815KKF00008
   Coding: 000015
   VCID: 3632FFC1684369EABDF-8062
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0127302
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 980 N    HW: 7P6 920 980 N
   Component: Kombi         H13 0239
   Revision: 11240062    Serial number: 658081111593026
   Coding: 8B6733022B00CF05020002
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526_VW52.rod
   VCID: 47CC82051F29E062D69-8012
   Part No SW: 7P6 907 530 B    HW: 7P6 907 530 B
   Component: Gateway-CAN-L H08 5202
   Revision: --------    Serial number: 00000000297606
   Coding: 0001037500
   GVL: FB0E42051E3B810000
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 372CF2C56FC990E2A69-8062
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650971482
Address 2E: Media Player 3 (J650)       Labels: None
   Part No SW: 7P6 035 342 C    HW: 7P6 035 342 C
   Revision: A1001003    Serial number: 7661194764
   Shop #: WSC 58559 000 1048576
   VCID: 3138CCDD812D4ED2E8D-8064
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000121954730
   Coding: 011D07200000453005080000
   VCID: 44D695092E9FCB7A33B-8010
   Revision: 00002001    Serial number: 0162983855
   Coding: 0186123A28B9500080A00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 2971110022
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000122015644
   VCID: 3B24EEF55361B482421-806E
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: A11A2200049    Dataset Number:             A001
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   Slave 3:
12656790 - Databus
          [CAN-Signalfehler Kombiinstrument]
                    Reset counter: 159
                    Mileage: 223110 km
                    Date: 2022.06.30
                    Time: 07:52:36
                    Voltage: 13.0 V
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Revision: --------    Serial number: -------------- Dataset Number: 7P0036v____ 0009
   Coding: 010A00010F000400
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: 7CA62DE9166F73BA0BB-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0003
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
Address 56: Radio (J503)       Labels: None
   Part No SW: 7P6 035 180     HW: 7P6 035 180
   Component: RCD550        H82 0037
   Revision: AA001001    Serial number: VWZ8Z3L890003A
   Coding: 010004100400000030FEB50B00
   VCID: 6E8217A15093112AB5F-803A
                    Fault Status: 00110000
                    Reset counter: 9
                    Mileage: 220957 km
                    Date: 2022.05.19
                    Time: 09:10:08
03181 - Internal Error SDARS Module
                    Mileage: 244409 km
                    Date: 2023.08.18
                    Time: 12:00:05
                    Error Code: 0
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000121988579
   Coding: 011C07200000253005080000
   VCID: 3A2AEBF15C5B8D8A597-806E
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000053010 Dataset Number: 7P6096v____ 0017
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
   VCID: 3FDC9AE547F9A8A26E9-806A
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H09 0110
   Revision: 5A001001    Serial number: 00000160938704
   Coding: 020D000000000000
   Part No SW: 7P6 959 107 A    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0620
   Revision: 22010001    Serial number: 309100653 Dataset Number: 7P6959107A  D043
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202137
   ROD: EV_HeckkTouar.rod
   VCID: 3D20E0ED4DF5BAB27C5-8068
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000121991687
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661044592 Dataset Number: 5K0035730E  0001
   Coding: 0A10000000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 270C2285BF690062369-8072
Address A7: Infotain. Interface (J885)       Labels:* None
   Part No SW: 7P6 907 540 A    HW: 1K0 907 951
   Component: IF CAN Infot. H27 0012
   Serial number: 061111F2000634
   Coding: 04052602000000001003
   ASAM Dataset: EV_InfotInterConti 001002
   ROD: EV_InfotInterConti.rod
End----(Elapsed Time: 01:47, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
OK, so it wouldn't be the first time a manual and\or WD is incorrect.... what's the problem? There's only two motors!
Use your meter to validate which of the "documents" is correct..... it shouldn't be that hard.
Also, what is the source of your WD?
When I look your details up on my resources, I get a correct WD as seen on the right of this visual aid.
andrePNW
PNW, USA
C?ID=587036
erwin based on vin.
K0058965021-Wiring_Diagrams_and_Component_Locations is the exact pdf.
andrePNW
PNW, USA
C?ID=587036
Either way, I finally got around to tinker today and I tested all the aforementioned wires that I mentioned prior with all having resistance.
However now, I figured well.. The other bank isn't having the issue so let's swap them and see if bank 1 clears up.
In addition bank 2 now flags with a similar code which makes sense considering it was assumed to be faulty based on testing.
However, after swapping the parts back to how they were previously.. Bank 2 is now retaining the error regardless of which control unit is in place ("assumed good" and "assumed bad" units)
At the time of this auto-scan I had the "assumed good" one installed in it's original location (bank 2) and bank 1 was left unplugged hence the open circuit.
Saturday,13,July,2024,22:06:47:16709
          6D 72 77 A7
5475 - Intake Manifold Tuning Valve Control Circuit
          P1028 00 [00100111] - Open Circuit
                    Mileage: 255612 km
                    Date: 2024.07.12
                    Time: 00:05:26
                    Coolant temperature: 40 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 11.540 V
                    Actuator for intake manifold runner control: status-Bits 0-7: 3
                    Intake manif runner actuator: uncond volt actual value: 4998.8 mV
                    Mileage: 255612 km
                    Date: 2024.07.12
                    Time: 00:05:26
                    Intake manif runner actuator: uncond volt actual value: 4999.8 mV
5505 - Intake Manifold Flap Position Sensor (Bank 2)
          P2022 00 [00100111] - Short to Plus
                    Mileage: 255612 km
                    Date: 2024.07.12
                    Time: 00:05:26
                    Intake manifold runner control 2: activation: 100.00 %
                    Intake manifold runner control 2: acknowledgment: 100.00 %
                    Intake manifold runner control (IMRC) 2: offset closed: -0.59 %
                    Actuator for intake manifold runner control: status-Bits 0-7: 6
                    Act f int manif rnr ctrl bank 2: uncnd vlt act val Uncnd vlt: 4750.6 mV
   Coding: 001368
00955 - Key 1
                    Mileage: 247181 km
                    Date: 2023.10.08
                    Time: 19:29:16
00956 - Key 2
                    Reset counter: 0
                    Mileage: 254486 km
                    Date: 2024.05.23
                    Time: 09:02:46
   Coding: B606200880
   Coding: 004DBD
   Coding: 025223
   Coding: 000015
   Coding: 0001037500
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   Slave 3:
12656790 - Databus
                    Reset counter: 159
                    Mileage: 223110 km
                    Date: 2022.06.30
                    Time: 07:52:36
                    Voltage: 13.0 V
   Coding: 130000
   Coding: 130000
                    Reset counter: 9
                    Mileage: 220957 km
                    Date: 2022.05.19
                    Time: 09:10:08
                    Mileage: 244409 km
                    Date: 2023.08.18
                    Time: 12:00:05
                    Error Code: 0
   Coding: 0533314003
   ROD: UHVNA.rod
End----(Elapsed Time: 01:48, VBatt start/end: 11.7V/11.6V. VIgn 11.7V)-----
Now I'm really stuck unless both of these intake control units both decided to bite the bullet.. Which seems highly unlikely..
andrePNW
PNW, USA
C?ID=587036
Resolved.
Ended up replacing the affected lower manifold which resolved the codes. Figured might as well replace both lower manifolds so it's just done and on the same cycle. :)
