It's from a channel map, but may have been manually enhanced.Stupid VCDS newbie question. The sample data above, is that from creating a log or another method?
Thanks, I was in the vehicle when you responded, so I didn't see it until now. What I ended up doing was make a couple of logs from 08-Auto HVAC/Advanced Measuring Values/
Awesome, thanks. That's a better and easier way to get a holistic system snapshot than my way for sure.VCDS > Applications > Control Module Maps > Address 08 & Meas. Value Blocks & Pre-Label Export (or CSV if you prefer that)
Your climate control module is right here:Does VCDS have access to the climate control module that I can check to see if there are values set wrong?
That's what you've been reading data from.Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AA HW: 8P0 820 043 AA
Component: KlimavollautomatH19 0360
Revision: 395007 Serial number: 8P0820043AA
Shop #: WSC 06314 000 00000
VCID: 6BDF3ED04AF6A0CE86-803E
Sunday,14,July,2024,17:04:17:29520
VCDS Version: 24.5.0.0 (x64)
VIN: WAUNF78P77A104761 License Plate:
Mileage: 286130km-177792mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WAUNF78P77A104761 Mileage: 286130km-177792miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8P0 907 115 P HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH15--- Serial number: AUX7Z0F9FNP08B
Coding: 0103010A1C070160
Shop #: WSC 26110 444 84369
VCID: 3F87BA806E0EEC6E7A-806A
VINID: 9D195E5872201C74410041C6048FC2FEEF
Part No SW: 02E 300 043 Q HW: 02E 927 770 AE
Component: GSG DSG 070 1303
Revision: 04507000 Serial number: 00000610120886
VCID: 224113F4FDBCA18675-8076
Address 03: ABS Brakes Labels:. 1K0-614-517-MK60AT.clb
Part No SW: 1K0 614 517 AC HW: 1K0 614 517 AC
Component: ESP FRONT MK60-AT 0102
Revision: 00H13001
Coding: 0053890
VCID: 68D541DC5B008BD6EB-803C
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000006335145
Coding: 018C4F81C014100000181800180000000028FE175C1100
Shop #: WSC 06314 000 08192
VCID: 4085B97C13F0939603-8014
Subsystem 1 - Part No: 8P1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 A HW: 8P0 959 655 A
Component: Airbag 9.41 H12 3890
Revision: 91H12389 Serial number: 0035W0G032AS
Coding: 0032605
Subsystem 1 - Part No: 8P0 910 339
Component: BF-Gewichtsens. 001 0020
Subsystem 2 - Serial number: 3HQ26
Subsystem 3 - Serial number: 0001.01.000000100000000000ÿ63
Subsystem 4 - Serial number: 000000ÿ6332DRB404295323Bÿ63
Subsystem 5 - Serial number: 95323Bÿ6342DRB4042988B3Tÿ63
Subsystem 6 - Serial number: 988B3Tÿ63528RB401B65F1ATÿ63
Subsystem 7 - Serial number: 65F1ATÿ63628RB401B65F5BZÿ63
Subsystem 8 - Serial number: 65F5BZÿ63729RB401CD5526Rÿ63
Subsystem 9 - Serial number: D5526Rÿ63829RB401CD66BE4ÿ
Subsystem 10 - Serial number: D66BE4ÿ
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0012142
VCID: 4183BC7818FA9A9E0C-8014
Component: E0221 H07 0090
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 H HW: 8P0 920 981 H
Component: KOMBIINSTR. VDO H20 0570
Revision: D0H20004 Serial number: 2249F004004615
Coding: 0000268
Shop #: WSC 20213 067 57207
VCID: 3D7BC0886402FE7E68-8068
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 3300106A02803A
Coding: 3F3F034207002102
VCID: 2F67EAC0BE6E1CEEEA-807A
Revision: D0H20004 Serial number: AUX7Z0F9FNP08B
Shop #: WSC 21854 003 1048576
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0001177
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.079 H07 1806
Shop #: WSC 02069 000 90108
VCID: 346DE5AC57483F3697-8060
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 G
Component: KSG H08 0070
Coding: 9B8022A001382D09050FC88F0477
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH04 0180
Revision: 00003 Serial number: 30674696785506
VCID: 71E32CB868DA4A1EBC-8024
00421 - Rear Left DSP Midrange Speaker (R105)
Reset counter: 37
Mileage: 286108 km
Date: 2024.07.14
Time: 10:23:53
Temperature: 30.0°C
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0001177
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 F HW: 8P0 035 186 F
Component: concert II US H52 0470
Revision: 04S Serial number: AUZ5Z6F6033755
Coding: 0001005
Shop #: WSC 130822 003 00000
VCID: 356BD8A85C32263EA0-8060
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 D
Component: Tuer-SG 020 0070
Coding: 0001176
00934 - Electric Window Motor; Rear Left (V26)
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 D
Coding: 0001176
End-------------------------(Elapsed Time: 01:48)--------------------------
Sebastian,Let me just get this straight, you replaced the sensor and checked values, then you threw it out again for the original? No test drive etc.?
My mistake, I first read the data in your table as the compressor was "off". Looking again, I see that is was running and not off. The corrected snapshot is below. This is with the new G65 and G263 sensors.Your snapshot in #25 is kinda pointless when it comes to testing the N280 or the compressor because it was taken w/o the compressor running. Temperature wise, and this was what I suggested, this looks better but you are still missing the point about the G263. With water getting into the sensor, the values at ambient temp. may very well be OK but the question is how this behaves during an actual running cycle - which is why I would have left the new sensor in and explicitly not gone back to the old one.
