ABS Problems with 2012 Audi Q7
Lion Heart
Canada
C?ID=112668
I need some help coding the ABS control module for a 2012 Audi Q7.
In short, we've had ongoing issues with the ABS on this car. Has a rumbling noise when driving.
We scanned it and had various codes, including LF wheel speed sensor, and also steering angle sensor. With those codes the ABS was previously completely inactive (and car drove GREAT with ABS inactive during test drive - no rumble!)
Checked wheel speed sensor in live data, it is reporting different speed to other three wheels. Replaced that sensor twice, to no effect.
Changed the steering angle sensor and ABS is active again (but with rumble is back, ABS light on, strange ABS behavious when stopping). Showing a DTC for steering angle sensor.
Below are my scan results. This was after a cycle: scan, clear DTC's, stop and restart engine and scan again.
I wanted to check the 'trinity' of VIN's matches, and also got the Advanced ID for the Engine (01), and ABS - but there is no module available for 25 (Immobilizer/instrument cluster). I searched for 25 manually too, it does not exist. Look for other modules, none are named Immobilizer nor Instrument Cluster. Instead I got the Advanced ID for 5F Information Electr and 17 Instruments. Hope those are of some use?
Below are my scan details...
Lion Heart
Canada
C?ID=112668
Tuesday,09,July,2024,12:46:40:25122
VCDS Version: 24.5.0.0
VIN: WA1DGCFE8CD008419   License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55
          56 5F 62 69 6C 6D 6F 72 76
VIN: WA1DGCFE8CD008419   Mileage: 205580km-127741miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (CJW)       Labels:. 06E-907-551-CAJ.clb
   Part No SW: 4L0 910 551 K    HW: 4L0 907 551 A
   Component: 3.0l V6 TFSI        0040
   Revision: --H08---    Serial number:
   Coding: 0121000A290F0928
   Shop #: WSC 22667 003 1048576
   VCID: 306B6834A3417116F3-8064
   VINID: 9D10545D35952135000081012490827776
               U1017 - 000 -
                    Fault Status: 01101000
                    Mileage: 205582 km
                    Date: 2011.08.12
                    Time: 00:01:45
                    RPM: 1344 /min
                    Mass Air / Rev.: 158.1 mg/str
                    Temperature: 69.0 C
                    Bin. Bits: 00000010
                    Load: 15.3 %
Readiness: 1110 0001
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 Q    HW: 0C8 927 750 Q
   Component: AL1000 AISIN  001 2090
   Serial number:                CVN: CD2EA01E
   Coding: 001378
   ROD: EV_TCMAL991031_002_AU56.rod
   VCID: 3A7F4A1CBD3DBB464D-806E
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 0099409
   Shop #: WSC 31414 790 00001
   VCID: 3463642457594D3697-8060
                    Reset counter: 61
                    Mileage: 205582 km
                    Date: 2011.08.12
                    Time: 00:13:35
                    Count: 128
                    Count: 8513
                    Count: 297
                    Count: 51968
01486 - System Function Test Activated
                    Reset counter: 61
                    Mileage: 205582 km
                    Date: 2011.08.12
                    Time: 00:13:35
                    Count: 128
                    Count: 8513
                    Count: 320
                    Count: 51968
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H07 0200
   Revision: 00H07000    Serial number: 10603501971902
   Coding: 0000135
   VCID: 25458960EC8324BE10-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H04 0020
   Component: FBSAUDIC6 KSG   H03 0020
   Component: FBSAUDIC6 IDG   H01 0053
Address 08: Auto HVAC (J255)       Labels: 4L0-910-043.clb
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AJ
   Revision: 00---026    Serial number: 00000030231790
   Coding: 000CC026
   VCID: 254589602C8324BE10-8070
   Subsystem 1 - Part No SW: 8K0 959 772 F    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0024259339
   Coding: 070000
   Subsystem 2 - Part No SW: 8K0 959 772 F    HW: 8K0 959 772
   Serial number:           0024259338
   Coding: 070000
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 61
                    Mileage: 205582 km
                    Date: 2011.08.12
                    Time: 00:13:39
                    Temperature: 22.0 C
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0133114
   VCID: 6ED7B64C79F527E6A1-803A
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H18 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 15: Airbags        Labels: 4L0-910-655.clb
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 75 AIRBAG AUDI8RH43 0230
   Revision: 07H43000    Serial number: 0038QD0A0MD9
   Coding: 0014133
   VCID: 2B517F588A6712CEC6-807E
   Subsystem 1 - Serial number: 6332QSME2E0E0048H
   Subsystem 2 - Serial number: 6342QSME300E357AI
   Subsystem 3 - Serial number: 6352QSME5E0D314CT
   Subsystem 4 - Serial number: 6362QSME300E1D7EU
   Subsystem 5 - Serial number: 63734SME386C56648
   Subsystem 6 - Serial number: 63834SME6F0B2F6CQ
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
   Component: J0527               0830
   Revision: 00H07000    Serial number: 90025111600213
   Coding: 0112142
   VCID: 285B80549B9139D62B-807C
   Component: E0221           H03 0030
Address 17: Instruments (J285)       Labels:. 4L0-920-KOM-V3.clb
   Part No SW: 4L0 920 932 Q    HW: 4L0 920 932 Q
   Component: KOMBIINSTR.   H22 0411
   Revision: 00200000    Serial number: LMY50AE3D
   Coding: 8BD6630409000008020304
   VCID: 3A7F4A1CB53DBB464D-806E
   Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0057
   Revision: MB600036    Serial number: 3600M122278069
   Coding: 00C303
   VCID: 3F893B08AE1F9E6E7A-806A
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790336693
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AB
   Revision: 00---010    Serial number: 00000000317772
   Coding: 0000006
   VCID: 68DBC0545B11F9D6EB-803C
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 61
                    Mileage: 205582 km
                    Date: 2011.08.12
                    Time: 00:13:45
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00000024967864
   Coding: 00581B00000011110000
   VCID: 326F623C6D4D430685-8066
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH02 0050
   Revision: 00H02000    Serial number: 6PZ 009 014-10
   Coding: 0010001
   VCID: 2E57764CB97567E6E1-807A
   Subsystem 3 - Serial number: 5F27.02.1200H010003C916967
   Subsystem 4 - Serial number: 916967
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000025432876
   Coding: 011F57205E40440004
   VCID: 489B20D4FBD1D9D6CB-801C
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 01707159860000
   Coding: 3569693
   VCID: 387B50144B31A956BB-806C
                    Fault Status: 01101100
                    Fault Frequency: 86
                    Reset counter: 61
                    Mileage: 205536 km
                    Date: 2011.09.26
                    Time: 05:30:17
   Part No SW: 4L0 035 223 H    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H03 0130
   Revision: CH003000    Serial number: 00000000021320
   Coding: 030000
   VCID: 27598368568F36AE22-8072
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005190156267
   Coding: 0693961
   VCID: 23419778E2B7DA8E7E-8076
                    Fault Status: 11101101
                    Reset counter: 61
                    Mileage: 205582 km
                    Date: 2011.08.12
                    Time: 00:13:35
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0001
                    Voltage: 14.40 V
                    Temperature: 22.0 C
                    (no units): 0.0
                    Reset counter: 61
                    Mileage: 205582 km
                    Date: 2011.08.12
                    Time: 00:13:35
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0001
                    Voltage: 14.40 V
                    Temperature: 22.0 C
                    (no units): 0.0
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H16 0100
   Revision:             Serial number: 00000000107265
   Coding: 0012001
   VCID: 5EB7E68C8955B76611-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000025630727
   VCID: 479923E8F6CFD6AEC2-8012
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Coding: 0000031
   Part No SW: 4G0 035 082 C    HW: 4G0 035 082
   Component: Radio U SIRIU H53 0101
   Revision: AB001007    Serial number: 236CQ0C7522404
   Coding: 020007010000000000
   VCID: 204B987433A1C19663-8074
   Part No SW: 4L2 035 664 B    HW: 4L2 035 664
   Component: H-BN-NA       H42 0422
   Revision: --------    Serial number: 078CZ0C7504247
   Coding: 180200060004E1EF51002345EF632003F40000020100000000
   VCID: 2C537C444F6915F6CF-8078
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130CZ0CS122133
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Serial number: 00000001992083
   Component: CD-Database  3371
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000025838070
   Coding: 010E57204040230004
   VCID: 46872EECF1C5CFA639-8012
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00000168817531
   Coding: 0200000000000000
   VCID: 316D6D30684B781EFC-8064
   Part No SW: 4L0 910 441 C    HW: 8T0 907 441 D
   Component: J772__Rearview      0130
   Revision: --H06---    Serial number: 525PA8-J2241DR
   Coding: 1021201
   VCID: 26478E6C91852FA619-8072
                    Reset counter: 61
                    Mileage: 205582 km
                    Date: 2011.08.12
                    Time: 00:14:13
                        Reverse OFF
                    Count: 3
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Revision: --H57001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CD3BC444FE9D5F68F-8038
   Subsystem 3 - Serial number: RD12.03.12--H57001001B0343
   Subsystem 4 - Serial number: 1B0343
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 125330930-----
   Coding: 0003595
   Component: J_245_EE16_SKB10H12 0220
   Component: J_394_EE16_SKB10H12 0220
   Component: J_392_EE16_SKB10H12 0220
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000025838069
   Part No SW: 4L0 910 283 E    HW: 4L0 919 283 E
   Component: Parkhilfe 8-Kan H03 0100
   Revision: 00H03000    Serial number: 37361205901013
   Coding: 0231266
   VCID: 2C537C448F6915F6CF-8078
End-------------------------(Elapsed Time: 04:05)--------------------------
Lion Heart
Canada
C?ID=112668
ADVANCED ID 01 ENGINE:
ENGINE ECU ADVANCED ID:
Tuesday,09,July,2024,12:48:22:25122
VCDS Version: Release 24.5.0
Address 01: Engine
Control Module Part Number: 4L0 910 551 K
Component and/or Version: 3.0l V6 TFSI 0040
Software Coding: 0121000A290F0928
Work Shop Code: WSC 22667
Advanced Identification
Identification: SME-RBG
Revision: --H08---
Date: 28.02.12
Test stand number: 0394
Manufacturer number: 1490
Misc.
Car Info
Chassis Number: WA1DGCFE8CD008419
Engine code: 4L0
VCDS Info:
Labels:
Readiness: No script available
Lion Heart
Canada
C?ID=112668
ADVANCED ID ABS:
Tuesday,09,July,2024,12:50:54:25122
Control Module Part Number: 4L0 910 517 M
Component and/or Version: ESP ALLRAD MK25E1 0020
Software Coding: 0099409
Work Shop Code: WSC 31414
Identification: TT1-000
Revision: 00H02001
Date: 07.03.12
Test stand number: 0103
Manufacturer number: 00FA
Flash Status
Programming Attempts: 0
Successful Attempts: 0
Programming Status: 00000000
Required Conditions: 00000000
Flash Tool Code: 00000 000 00000
Flash Date: 12.08.11
Misc.
Hardware number: 4L0 614 517 L
VCDS Info:
Labels: 4L0-910-517-V2.clb
Lion Heart
Canada
C?ID=112668
ADVANCED ID 17 INSTRUMENTS:
Tuesday,09,July,2024,12:55:24:25122
Control Module Part Number: 4L0 920 932 Q
Component and/or Version: KOMBIINSTR. H22 0411
Software Coding: 8BD6630409000008020304
Identification: MY2-COR
Revision: 00200000
Date: 14.03.12
Manufacturer number: 0405
Test stand number: 4815
Flash Status
Programming Attempts(application): 0
Successful Attempts(application): 0
Programming Attempts(data): 0
Successful Attempts(data): 0
Flash Date: 2011.08.12
Flash Tool Code(data): 00000 000 00000
Software
Theft prot.: 02.02.00
BAP: 01.05.00
CAN: 01.37.00
TP 2.0: 03.05.00
KWP2000: 03.00.00
OSEK-OS: 03.37.00
Misc.
Hardware number: 4L0 920 932 Q
Workshop System Name: J285
Equipment/PR Code: 0000000000000000
Dataset Number: -----------
Dataset Version: ----
End of Line Equipment Level: --------------------
VCDS Info:
Labels: 4L0-920-KOM-V3.clb
ADVANCED ID 5F INFORMATION ELECTR:
Tuesday,09,July,2024,12:59:15:25122
Control Module Part Number: 4L2 035 664 B
Component and/or Version: H-BN-NA H42 0422
Software Coding: 180200060004E1EF51002345EF632003F40000020100000000
Identification: JTB-074
Revision: --------
Date: 05.03.12
Manufacturer number: 0026
Test stand number: 117C
Flash Status
Programming Attempts(data): 1
Successful Attempts(data): 1
Flash Tool Code(data): 00001 790 31414
Software
MOST Net: 02.01.07
TP 2.0: 02.04.05
BAP: 01.05.00
Unknown: 02.02.03
Theft prot.: 03.02.05
Misc.
Hardware number: 4L2 035 664
Workshop System Name: J794
Equipment/PR Code: 00C7972D1D10D407
Dataset Number: 4L0909545M_
Dataset Version: 0052
VCDS Info:
Labels: 4E0-035-6xx-5F.clb
Lion Heart
Canada
C?ID=112668
Oh yes, forgot to say: you can ignore the time and date stamps. I reconnected the battery to take these VCDS scans (the car is stored with negative battery cable unplugged to stop the battery draining as the car is not being used due to this fault).
In this vehicle, I believe 05: Acc/Start Auth. is the immo master, but I doubt that has anything to do with your ABS concerns.
Lion Heart
Canada
C?ID=112668
Any ideas on what do you think could be the likely cause of my ABS concerns?
Dr Sheldon
Windsor UK
C?ID=334979
In an ideal world you want to scope both front sensors to know why they report different speeds I would like to see them graphed on VCDS - Just the front two with the scale set correctly ?
I would also like a VCDS capture with the Fault Code Present for Freeze Frame
On this car, does the sensor look at a mechanical wheel or the Bearing ??
You been tinkering ?? Pressing buttons that you know little about ?? :banghead:
Lion Heart
Canada
C?ID=112668
Absolutely 100% no. Not been tinkering AT ALL on this car actually. We had a bad battery (now replaced) but we have not adjusted any coding on any module on this car.
We've run that test several times, and the other three wheel speed sensors are all in perfect harmony, showing the same speed at each wheel. But the FL one is all over the place. If going 30kph, it will show 30kph then spike to 80kph, then drop to 10kph. All over the place, whilst the other three are perfect.
Good question, and I'm unsure on that one.
It it were a bad bearing, ABS ring etc would that throw up all of the other ABS faults we are seeing here as well as the obvious linked wheel speed sensor fault?
Lion Heart
Canada
C?ID=112668
Also, I thought (???) this simply means that the ABS light is on? Probably wrong?
Westbury, UK
All the ABS faults are inter-related, so fix the problem with the FL wheel speed sensor - which could be sensor or the magnetic ring.
Lion Heart
Canada
C?ID=112668
The sensor has been replaced twice, so definitely not that.
My thoughts were maybe ABS ring, or maybe wiring between sensor and ABS unit, or the ABS unit is faulty, OR the ABS unit has lost it's coding when we had the battery.
Lion Heart
Canada
C?ID=112668
Unfortunately accessing the ABS ring is not easy AT ALL on these. I believe (?) you must remove the wheel bearing to access the ABS ring, and these are pressed in rather than bolted on, which requires a special tool to remove and refit (which I don't have, circa $400 on Amazon - a lot of money if that's not the fault).
For wiring, I could not find a pin out diagram anywhere for the ABS control module. I found the wiring diagram on Elsawin, but quite complex. A simple pin layout for the plug would be much easier!!!
So you're not thinking possible faulty ABS control module for this???
Westbury, UK
Tried this link to erWin? - wiring diagram
I always work on the basis that a module is the most expensive part to replace and hence to eliminate the basics (fuses, wiring, sensors) first.
Lion Heart
Canada
C?ID=112668
erWin, I'm not familiar with it and I don't have an account. Are accounts free to set up, and can anyone set up an account?
Bruce
Near Philadelphia, PA, USA
erwin is fee based... if the same as the US - then it is about $35 USD for a days access. Have a flash drive ready and dump everything about your car to the flash drive. You'll have the complete technical info on your flash drive.
Lion Heart
Canada
C?ID=112668
Does it contain more info than Elsawin??? I'm thinking it likely has the exact same wiring diagram that Elsawin has, but no pinout diagram.
