mustanggt500i
hi,
i have got issue with a 2013 UP it has lost basic settings on ASG gearbox. car has 15k miles on clock, car is japan import i have replaced the instrument cluster with UK one programmed and coded with ODIS but it lost basic setting and i am unable to perform basic stetting its keep failing as it don't see car in neutral from the gear selector and the gear selector motors. i have replaced TCM, Gear selector motors and gear selector inside the car but no luck. i have put the old clock back into car but same issue. there is a old Post in this forum about same issue and @NEtech has advised a process which i am bit confused. he Mentioned this
Basic settings:
IDE08645-Switching pos. adaptation (Service)
Ignition ON
Selector N
Parking brake On
Battery charger connected
Search and choose: 21 450 1834 4894 8304 8329
IDE08643-Clutch press. point adaptation
Engine at idle <1100
Selector N
Parking brake On
How do i "Search and choose: 21 450 1834 4894 8304 8329" and " Search and choose: 21 450 1834 4894 8304"
@NEtech i will be grateful if you could shed some light on this.
Regards
Basic settings:
Ignition ON
Selector N
Parking brake On
Selector N
Parking brake On
Regards
