2020 Golf GTE (Mk7.5) Hybrid System Fault "Error: Hybrid System"
biosbill
Norfolk, UK
C?ID=584998 (NRRT)
Hi All,
Vehicle wouldn't start this morning - displaying "Error Hybrid System. Stop Vehicle!". Tried a different 12V battery and investigated fuses but still receiving the below DTC's when autoscanned. I've also disconnected 12V, disconnected the HVIL loop under bonnet, reconnected then connected 12V battery but still no change.
Pretty sure this will be the reason it wont close contactors;
26645 - High Voltage Service Disconnect
P0B33 00 [10101111] - Malfunction
Monday,08,July,2024,21:47:49:16025
VCDS Version: 24.5.0.0 (x64)  HEX-V2 CB: 0.4643.5
VIN: WVWZZZAUZLW804225   License Plate: GD69 xxx
Mileage: 169450km-105291mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 29 2B 39 42 44 4B 51 52
          5F 75 8C A5 A9 C0 C6 D6 D7
VIN: WVWZZZAUZLW804225   Mileage: 169450km-105291miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
51-Electric Drive -- Status: Malfunction 0010
8C-HV Battery -- Status: Malfunction 0010
Address 01: Engine (J623-DGEA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 024 E    HW: 04E 907 309 CG
   Component: 1.4 TFSI hy   H20 9822
   Revision: DCH20000    CVN: 897179FC
   Coding: 011D4012636405083008
   ASAM Dataset: EV_ECM14TFS01104E906024E 002005
   ROD: EV_ECM14TFS01104E906024E_002.rod
   VCID: 231435739B5611826A1-8076
   VINID: 9E69EAAAA465A9C9C800408214E2C9273D
34193 - Implausible Data Received from ESP Control Module
          U0416 00 [00100110] - -
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:00:45
                    Engine RPM: 0.00 /min
                    Coolant temperature: 13 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 11.500 V
                    Cruise Control System (CCS): status-Bits 0-7: 6
                    Drive train coordinator irreversible switch off conditions: 0
                    Drive train coordinator reversible switch off conditions: 8423424
                    Drivetrain coordinator: brake fault status: 5
Readiness: 1110 0001
   Part No SW: 0DD 300 046 C    HW: 0DD 927 770 C
   Component: GSG DQ400E    H32 2202
   Revision: 00032056    Serial number: TFK01912040039 CVN: CA7AEE65
   ROD: EV_TCMDQ400021.rod
   VCID: 280E225FE270F2DA3F3-807C
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 EK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0865
   Revision: 00000000    Serial number: 63319000000511 CVN: 2C1F3AC2
   Coding: 01FA80A1382021704779060261C82980011C84E26086947338B15078C22203
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003022
   ROD: EV_Brake1UDSContiMK100OMG_003_VW37.rod
   VCID: 7EA2240750749C6A25F-802A
0297 - Steering angle sensor
          B1168 16 [00100110] - Voltage Too Low
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:00:44
8400 - Databus
          U1123 00 [00100000] - Received Error Message
          [FCAN: AB_Gurt_FA signal is invalid]
16401 - Tire Pressure Warning
          C102D 00 [10101111] - -
                    Mileage: 167350 km
                    Date: 2024.05.12
                    Time: 12:30:51
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0535010171 Dataset Number: V03935272JC 0001
   Coding: 132C0C0723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D08BEB75220FB2245-8010
12786210 - Databus
          U1122 00 [00001000] - Implausible Message
          [Errorvalue Messagecounter Klemmen_Status_01]
                    Reset counter: 208
                    Mileage: 169083 km
                    Date: 2024.06.20
                    Time: 07:40:36
                    Terminal_15_Kessy_specified_value: OFF
                    Terminal_15_Kessy_actual_value: OFF
                    Terminal_15_central electric_actual_value: Timeout
                    Terminal_15red_Kessy_specified_value: OFF
                    Terminal_15red_Kessy_actual_value: OFF
                    Terminal_S_Kessy_specified_value: OFF
                    Terminal_S_Kessy_actual_value: OFF
                    Terminal_S_central electric_actual_value: Timeout
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: On
                    Request active: Condition met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 12.002 V
                    Vehicle speed: 0.0 km/h
                    Engine RPM: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: GO_Scan_1
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: No response
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 5GE 907 044 AN    HW: 5GE 907 044 AN
   Component: Climatronic   H04 1702
   Revision: 00001K01
   Coding: 0012100420011001050500000010102A
   VCID: 084E42DF02B0D2DA1F3-805C
   Subsystem 3 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00104.8W.3A20370423
   Air quality sensor:
   A/C compressor sub:
H03
328196 - Motor for Right Temperature Flap
          B108D 71 [00001000] - Actuator Stuck
                    Reset counter: 216
                    Mileage: 164703 km
                    Date: 2024.04.07
                    Time: 15:34:26
                    Voltage terminal 30: 13.7 V
                    Outside temperature: 17.0 °C
                    Inside temperature: 30.6 °C
                    Right temperature flap: actual value: 45
                    Right temperature flap: actual value: 8.0 %
                    Temperature door right - Specified value: 41
   Part No SW: 5Q0 937 084 DG    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H42 0312
   Serial number: 02001934100823 Dataset Number: V03935315NV 0001
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020_VW37.rod
   VCID: 005E5AFF2A80EA9A573-8054
   Component: WWS    191104  042  0551
   Serial number:         191121165733
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051  0206
   Serial number: S4Y19M12D02H00M17S09
   Coding: 0008DD
   Component: Sensor, DWA  005  0316
   Serial number: 000000000ZY193101R4W
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004  0007
   Serial number: 00000000000000761215
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004  0070
   Serial number: 00000028111904220031
233497 - Remote key 2
          B147A F1 [00001000] - Suppressed Opening Procedure
                    Reset counter: 219
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    last_wakeup: Pin C14 Kessy Weckleitung
                    Voltage: 12.8 V
                    Outside temperature: 14.0 °C
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058319340 Dataset Number: V03935292E  0001
   Coding: 1471151811
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   VCID: 50FEAABFBA60DA1A873-8004
13637426 - Databus
                    Reset counter: 219
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:00:45
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 P    HW: 5Q0 907 572 J
   Dataset Number: V03935290LX 0001
   Coding: 550067C159FFC728949C810580400600000000000000000004
   VCID: 44D696EF7E1836BA33B-8010
2055 - Databus
          [FAULT_ALP_STEERINGWHEEL_INIT]
                    Reset counter: 219
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:00:46
                    Control Module temperature: 11 °C
                    Voltage terminal 15: 11.5 V
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 219
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:00:46
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 219
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:00:45
   Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
   Component: AirbagVW20    012 0870
   Serial number: 003MFR0E7HAT Dataset Number: V03935243YN 0001
   Coding: 98CCC000002000005C0000CF00C800000065
   Left seat belt tensioner:
   Serial number: 34169677E06121930024
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169676E09121920758
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 412 19
   Serial number: 35700000000998F0934T
   Subsystem 4 - Part No SW: -----------    HW: 480 000 812 19
   Serial number: 35800000000CA965D34Z
   Subsystem 5 - Part No SW: -----------    HW: 480 400 612 19
   Component: SideSensor_Dr  004 6149
   Serial number: 35100010A2C9CA14B476
   Subsystem 6 - Part No SW: -----------    HW: 480 402 911 19
   Component: SideSensor_Pr  004 6149
   Serial number: 35200013062EFE7695CI
   Subsystem 7 - Part No SW: -----------    HW: 480 400 512 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001B0F1F575206FA
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 219
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:00:46
   Part No SW: 5G1 920 794 B    HW: 5G1 920 794 B
   Component: KOMBI         404 4193
   Coding: 27AC7B186FC4060001886B131701030800000000
   VCID: 2E02D447C094ACEAF5F-807A
   Part No SW: 3Q0 907 530 AD    HW: 3Q0 907 530 D
   Component: GW MQB EV     621 6383
   Serial number: 29111911604508 Dataset Number: V03935303HQ 0001
   Coding: 020100176EE11000FB00527E5C1D00000001070100010000000300000000
   GVL: 01463C1000000608508C80009000C81800000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 71B80F3B112AF312A8D-8024
   Subsystem 1 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29190002577910079447
   Coding: 2DFFFF
   Subsystem 2 - Part No SW: 5QE 915 181 A    HW: 5QE 915 181 A
   Serial number: 6676023305
Address 23: Brake Booster (J539)       Labels:. 5QE-909-059.clb
   Part No SW: 5QE 909 059 H    HW: 5QE 909 059 B
   Component: EBKV          H14 0230
   Serial number:   085460010637
   Coding: 02720100331900000002060500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 005002
   ROD: EV_BrakeBoostBoschMQBOMG_005_VW37.rod
   VCID: 53F4A5B38B76A102BA1-8006
   Brake pressure reservoir:
   Subsystem 1 - Part No SW: 5QE 909 057 D    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0155
   Serial number: 05802861201119075106
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH09 0014
   VCID: 47CC81E34F2E1DA2D69-8012
0033 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
          [Supply voltage - lower limit exceeded]
                    Fault Frequency: 57
                    Reset counter: 217
                    Mileage: 156677 km
                    Date: 2023.10.31
                    Time: 15:56:44
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000335771004
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 3138CF3BD1AAB312E8D-8064
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
                    Fault Frequency: 32
                    Reset counter: 211
                    Mileage: 161334 km
                    Date: 2024.02.12
                    Time: 12:00:15
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0330
   Serial number: YE007SK222034 Dataset Number: V03935310FW 0001
   Coding: 003F1620D001048000001000
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   VCID: 49C887DB593AEBD2C0D-801C
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000036410075
   Coding: 0D0000
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Dataset Number: V03935302SU 0001
   Coding: D10A0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B6062F6E38C63A43B-8020
16272 - Steering Angle Sensor
          B1168 F2 [00001000] - Not Initialized
                    Reset counter: 184
                    Motor status: 00
                    System status: Reset
                    Supply voltage: 12.50 V
                    Temperature: 12.0 °C
                    KFC: 3F
                    KFA: 00 90
                    Freeze frame conditions: 21
                    uioUdNotFilt_xdu16: 12.45 V
                    uAdSensI_SwitchedKl30_xdu16: 12.41 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 00 C0
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: activated
                    RP_CNTERR: activated
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 03121910522069 Dataset Number: V03935292JZ 0001
   Coding: 00000005090016CE00604F01020000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372CF1233FCE6D22A69-8062
   Part No SW: 5G0 907 080 E    HW: 5G0 907 080 E
   Component: LE Gen 3.3H15 1032
   Revision: 00H15000    CVN: 0C4EF12C
   Coding: C0020000000000000000
   ASAM Dataset: EV_DMCM08530115G0907080E 001008
   ROD: EV_DMCM08530115G0907080E.rod
   VCID: 2908275BF97ACBD220D-807C
31801 - No Communication with Battery Energy Control Module
          U0111 00 [00101110] - -
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Voltage terminal 30: 12.126 V
                    Drive control condition: DrvInit
                    Drive control condition-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb Drv Ctrl UBYTE: 0
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0330
   Serial number: YE007SJU21684 Dataset Number: V03935310HM 0001
   Coding: 003F1020DC01048000001000
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   VCID: 48CE82DF423012DADF3-801C
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000036624615
   Coding: 150000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0876
   Serial number:                Dataset Number: V03935300WU 0001
   Coding: 02731001FF0000004111010100880A001F0509F6012000008E
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323AC037D4AC880A917-8066
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H61 8214
   Serial number: VWZ6ZHW3430899
   Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------    Dataset Number: V03935278EW 0001
   Coding: 02739001EA42980D3FFCBE000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   VCID: 3D20E30B1DF247727C5-8068
Address 8C: HV Battery (J840)       Labels: None
   Part No SW: 5Q0 915 182 E    HW: 5Q0 915 182 C
   Component: BECM          H05 1101
   Serial number: X4240041 CVN: ACC81AF8C05121EDB797EC16B797EC16B797EC16B797EC16B797EC16B797EC16
   Coding: 00000000
   ASAM Dataset: EV_BECM09620115Q0915182 006042
   ROD: EV_BECM09620115Q0915182.rod
   VCID: 3530FB2B25C29F32B45-8060
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 5Q0 915 250 E    HW: 5Q0 915 250 E
   Component: BJB  H28 0240
   Cell module control module 1:
   Subsystem 2 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D1  H14 0481
   Serial number: V013C1971130234
   Cell module control module 2:
   Subsystem 3 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D2  H14 0481
   Serial number: V013C1971130227
   Cell module control module 3:
   Subsystem 4 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D3  H14 0481
   Serial number: V013C1971130233
   Cell module control module 4:
   Subsystem 5 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D4  H14 0481
   Serial number: V013C1971130228
   Cell module control module 5:
   Subsystem 6 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D5  H14 0481
   Serial number: V013C1971130238
   Cell module control module 6:
   Subsystem 7 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D6  H14 0481
   Serial number: V013C1971130235
   Cell module control module 7:
   Subsystem 8 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D7  H14 0481
   Serial number: V013C1971130237
   Cell module control module 8:
   Subsystem 9 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D8  H14 0481
   Serial number: V013C1971130236
                    Mileage: 169451 km
                    Date: 2024.07.01
                    Time: 06:06:49
                    Pack Voltage: 388.2 V
                    Pack Current: -0.00 A
                    Isolation Resistance: 5080 kOhm
                    Maxumum charge current limit: 0 A
                    Maximum discharge current limit: 0.0 A
                    Contactor Voltage: 0 V
                    OBD unlearned counter: 40
                    Crash status: 00
                    Pilot Line Status: 00
                    Fuse Status: 00
                    (Minus) Contactor Status: 00
                    (Plus) Contactor Status: 00
                    Terminal 15 status: 01
                    Max Cell Temperature: 16 °C
                    Min Cell Temperature: 15 °C
                    Air inlet temperature: 15 °C
                    Air outlet temperature: 15 °C
                    LV Battery Voltage: 11.7 V
                    Min.cell voltage: 4.037 V
                    Max.cell Voltage: 4.046 V
                    Max.cell SOC: 95 %
                    Min.cell SOC: 94 %
                    Hybrid Battery Pack Remaining Life: 94.9 %
                    Max Charge Pack Current(10s duration): 0 A
                    Max Discharge Pack Current(10s duration): 0.0 A
                    Max Pack Voltage(10s duration): 388 V
                    Min Pack Voltage(10s duration): 388 V
                    Max.cell Voltage(10s duration): 4.047 V
                    Min.cell Voltage(10s duration): 4.037 V
                    Accelerator Pedal Position D: 14.5 %
                    Calculated LOAD Value: 0.0 %
                    Engine coolant temperature: 14 °C
                    Vehicle Speed Sensor: 0 km/h
                    Ambient Air Temperature: 215 °C
                    Hybrid Battery Pack Remaining Life: 94.90 %
                    control module system voltage: 11.734 V
                    absolute load: 0.0 %
                    Time After Engine Start: 0 s
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 02121912K11678 Dataset Number: V03935313CE 0001
   Coding: 0003070000000401000213448150A90094000E30004000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40DE9AFF6A002A9A173-8014
1123173 - Databus
          [ESP_21_ESP_Systemstatus]
                    Reset counter: 219
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:00:47
                    Control Module temperature: 10 °C
                    Outside temperature: 10.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 3.3 s
                    Voltage terminal 15: 11.4 V
                    mid: 02 E0
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
   Part No SW: 5G0 907 159 C    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0017
   Serial number: 190924202921
Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
   Part No SW: 5QE 035 335 M    HW: 5QE 035 335 B
   Component: E_SOUND_SG    H11 0225
   Serial number: EN194928590000 Dataset Number: 5QE035335M  0210
   Coding: 90
   ASAM Dataset: EV_ENoiseS1NNVW3707 007015
   ROD: EV_ENoiseS1NNVW3707_007_VW37.rod
   VCID: 4BC4BDD35346F9C2F21-801E
   Part No SW: 5QE 915 682 BG    HW: 5QE 915 682 BG
   Component: OBC KOSTAL    H41 4115
   Revision: --------    Serial number: 1811190KE0006J Dataset Number: V03935260RR 0001
   Coding: 115068222000
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
   ROD: EV_OBCSinglPhaseKLOMQB12P.rod
   VCID: 137465B34BF66102FA1-8046
13705483 - Databus
          [BMS_HYB_02_TimeOut]
                    Reset counter: 219
                    Mileage: 169450 km
                    Date: 2024.07.01
   Part No SW: 7P5 941 572 AG    HW: 7P5 941 572 A
   Component: LED1L         H07 0008
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   Component: LED1R         H07 0008
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----(Elapsed Time: 02:25, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
I managed to find one thread on here where a similar occurrence was discussed but not resolved - anyone have any ideas?
Passat gte 2016 no start
Many thanks!
William
MrMeeseeks
LP/SN
One of the 12v battery readings is showing 11.5v, which is considered a low battery. Either swap the 12v battery with a new one, or charge the current one.
Once done, clear all fault codes and try again.
Important to note if a new battery is fitted, it'll need coding in as a replacement.
biosbill
Norfolk, UK
C?ID=584998 (NRRT)
Thanks for getting back to me. I've tried with a jump pack connected, all ancillaries seem to function as expected, no other voltage related type issues, slow windows etc.
Battery is charging but doesn't really feel like that's my problem.
Happy to be advised otherwise?
biosbill
Norfolk, UK
C?ID=584998 (NRRT)
Hi All,
Please see attached updated autoscan with battery charged overnight...
Wednesday,10,July,2024,06:37:32:16025
Mileage: 169450km-105291mi   Repair Order: After_clear_wbatterybooster
          U0416 00 [00100111] - -
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:08:40
                    Coolant temperature: 16 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 11.960 V
                    Drive train coordinator reversible switch off conditions: 8421376
                    Drivetrain coordinator: brake fault status: 4
          B1168 16 [10100111] - Voltage Too Low
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:08:40
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:08:42
   Coding: 132C0C0723
   Revision: 00001K01
   Air quality sensor:
   A/C compressor sub:
H03
   Coding: 0008DD
   Coding: 1471151811
13637426 - Databus
                    Reset counter: 179
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:09:36
2055 - Databus
                    Reset counter: 179
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:09:40
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 11.9 V
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 179
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:09:40
2101 - Databus
                    Reset counter: 179
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:09:40
   Coding: 333135
   Coding: 333135
1050117 - Databus
                    Reset counter: 179
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:09:49
   Coding: 2DFFFF
196352 - Control Module Improper Shut Down
          U3001 00 [00101111] - -
          [iBoVAG_iB_Not_ShutDown_Right]
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:08:40
   Coding: 0D0000
   Coding: D10A0000
16275 - Steering Angle Sensor
          B1168 F2 [00001001] - Not Initialized
                    Reset counter: 179
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:10:14
                    Motor status: 00
                    Supply voltage: 12.00 V
                    Temperature: 27.0 °C
                    KFC: 3F
                    KFA: 00 93
                    Freeze frame conditions: 5F
                    uioUdNotFilt_xdu16: 11.92 V
                    uAdSensI_SwitchedKl30_xdu16: 11.89 V
                    NoInitCause_RackPos_Rohwert: 01 80
                    RP_VALCNTSAV: activated
                    RP_UNDERVOLT: not activated
   Coding: 150000
   Coding: 00000000
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:08:40
                    Pack Voltage: 387.8 V
                    Crash status: 00
                    Fuse Status: 00
                    Max Cell Temperature: 17 °C
                    Min Cell Temperature: 17 °C
                    Air inlet temperature: 18 °C
                    Air outlet temperature: 17 °C
                    LV Battery Voltage: 11.9 V
                    Min.cell voltage: 4.033 V
                    Max.cell Voltage: 4.042 V
                    Max.cell SOC: 94 %
                    Min.cell SOC: 93 %
                    Max Pack Voltage(10s duration): 386 V
                    Min Pack Voltage(10s duration): 386 V
                    Max.cell Voltage(10s duration): 4.042 V
                    Min.cell Voltage(10s duration): 4.032 V
                    Engine coolant temperature: 16 °C
                    control module system voltage: 11.937 V
1123173 - Databus
                    Reset counter: 179
                    Mileage: 169450 km
                    Date: 2024.07.01
                    Time: 00:10:51
                    Control Module temperature: 27 °C
                    Outside temperature: 15.5 °C
                    System run time: 575.7 s
                    Voltage terminal 15: 11.8 V
                    mid: 02 E0
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
   Coding: 90
End----(Elapsed Time: 02:18, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
Can VCDS clear the ABS (J104) codes or are they current (as one is still low voltage related)? I'm confused by the time stamps in the data.
I'm torn whether to just fit a new battery anyway - are these voltages still considered low?
MrMeeseeks
LP/SN
It should be able to clear all of them
biosbill
Norfolk, UK
C?ID=584998 (NRRT)
Thanks, hmm ok, they all come straight back when cleared and scanned.
Will change 12V and come back.
Cheers again!
TTT
C?ID=547002
Seen this before, wire corroded under the vehicle, at the back, 1-2 cm from a plug which goes to the hv battery bank. Factory wiring, no one messed about before I found the issue. Golf gte was.
It’s a loop wire which goes around all HV components.
biosbill
Norfolk, UK
C?ID=584998 (NRRT)
Many Thanks!
I'll get under and inspect this ASAP.
biosbill
Norfolk, UK
C?ID=584998 (NRRT)
I cannot thank you enough... sure enough, after removing the battery plastic tray there was a buildup of dirt around the BMS connector. One side of the HVIL loop was corroded exactly as you suggested, 1-2cm from the plug. (I wonder if there was some factory tooling which gripped the wire at this point?).
Repaired this and faults cleared, vehicle is back up and running.
Can share photos if anyone interested (But don't have any hosting for here).
I owe you something!
Cheers
William
underwerse
Finland
Faced the same problem on my Passat GTE 2017.
The reason turned out to be clogged drains of the panorama roof, which led to the fact that water secretly penetrated to the CAN bus connectors in the driver's legs from the side, in the place where the hood opening handle is located, and flooded all the connectors.
After drying, everything worked.
Capacek
Prague, Czech Republic
Cheers
William
Please can you send some photos? I have same issue on my Passat GTE 2016
