Hex V2 won't communicate with ABS Controller on Audi A4
TrekyBob
Aargau, Switzerland
C?ID=590165
Help, I changed the ABS on my A4 b6 3.0 and bought the Ross-Tech Hex V2 to recode the replacement, I cannot logon or recode the ABS module. If I scan the ABS I get the details but not in the Auto Scan function, scan of ABS reads;
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Control Module Part Number: 8E0 614 517 A
Component and/or Version: ABS/ESP allrad 3429
Software Coding: 00000
Work Shop Code: WSC 00000
VCID: 2614F08451F0525A0DF-51F2
01425 - Yaw Rate Sensor (G202); Signal Wire
57-10 - Electric Circuit Failure - Intermittent
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-00 -
35-00 - -
66-10 - Not Matched - Intermittent
However when I try to code the module it says 'No response from controller'
Can someone help me with this please or do I have get Audi to program it (it is the same model ABS controller)?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
This would be an indicator for an incorrect coding attempt. Which values are you using for the login/coding procedure and did you follow the instructions for this model to the letter? As @Zenerdiode already mentioned, make sure to include an Auto-Scan which also shows the VIN. This is the only way for us to verify the data you are trying to enter.
TrekyBob
Aargau, Switzerland
C?ID=590165
Thankyou to respond, here is the auto scan.
Monday,08,July,2024,11:03:13:30198
VIN: WAUZZZ8E54A106765   License Plate:
          67 69 75 76 77
VIN: WAUZZZ8E54A106765   Mileage: 336870km-209321miles
Address 01: Engine        Labels: 06C-909-559-ASN.lbl
   Part No SW: 8E0 909 559 M    HW: 8E0 909 059
   Component: 3.0L V6/5V          0010
   Coding: 0011711
   Shop #: WSC 63251 000 00000
   VCID: 3FDA45E0AB6AE3926E9-5160
   VINID: 9D196AAAA2151444410061C614741F96F8
18057 - Powertrain Data Bus
            P1649 - 008 - Missing Message from ABS Controller - Intermittent
18405 - Friction too High; Exhaust Cam Adjustment Bank 1
            P1997 - 002 -
16580 - Engine Oil Temp. Sensor (G8)
            P0196 - 004 - Implausible Signal
Readiness: 0000 0101
   Part No: 8E0 614 517 A
   Component: ABS/ESP allrad      1726
   Coding: 00000
            P1848 - 35-00 -
            35-00 - -
   Part No: 8E0 820 043 AB
   Component:   A4 Klimaautomat   1319
   Coding: 00000
   Shop #: WSC 63251
   VCID: 619EA398785EF56238D-5160
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  RDW 0517
   Coding: 00101
   Shop #: WSC 63251
   VCID: 353627C89C5629C2B45-4B00
01312 - Powertrain Data Bus
            79-10 - Please Check Fault Codes - Intermittent
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 B
   Component: Airbag 8.4EP        3002
   Coding: 0010602
   VCID: 363420C4845022DABDF-5184
   Part No: 8E0 953 549 S
   Component: Lenksáulenmodul     0611
   Coding: 01012
   Shop #: WSC 63251
   VCID: 43D24910C28287720A1-4B00
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.clb
   Part No: 8E0 920 900 L
   Component: KOMBI+WEGFAHRS. RB4 D37
   Coding: 01100
   Shop #: WSC 42621
   VCID: 2D060FA874066102CC5-5160
   WAUZZZ8E54A106765     AUZ6Z0C0287727
            30-00 - Open or Short to Plus
   Part No: 8E0 959 433 AT
   Component: Komfortgerát T23    1210
   Coding: 06976
   Shop #: WSC 63251
   VCID: 03528910820247724A1-4B00
   Subsystem 1 - Part No: 8E1959801B
   Component: Tõrsteuer.FS BRM 0003
   Subsystem 2 - Part No: 8E1959802B
   Component: Tõrsteuer.BF BRM 0003
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0004
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0004
            37-10 - Faulty - Intermittent
01561 - Rear left door
            61-00 - Won't De-Safe
01562 - Rear right door
            61-10 - Won't De-Safe - Intermittent
   Part No: 8E0 035 186 L
   Component: concert II  GRO    0001
   Coding: 01000
   Shop #: WSC 63251
   VCID: 303816DC63040CEAE73-4B1E
00852 - Loudspeaker(s); Front
            36-00 - Open Circuit
End----------(Elapsed Time: 05:36, VBatt start/end: 12.3V/12.4V)-----------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Please answer the questions in post #3. What value(s) did you use for the login/coding combination? Did you follow ALL the steps in order?
I cannot see any commination issues in this scan.
TrekyBob
Aargau, Switzerland
C?ID=590165
I used 09595 for the logon and my code of 04295 but I didn't get thru the logon..
TrekyBob
Aargau, Switzerland
C?ID=590165
I followed all the steps as best I could
VCDS clearly does communicate with your ABS.
Please carry on in your new thread in the Car Repair Support section:
