Audi A4 ABS Coding
TrekyBob
Aargau, Switzerland
C?ID=590165
Help, I changed the ABS on my A4 b6 3.0 and bought the Ross-Tech Hex V2 to recode the replacement, I cannot logon or recode the ABS module. If I scan the ABS I get the details but not in the Auto Scan function, scan of ABS reads;
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Control Module Part Number: 8E0 614 517 A
Component and/or Version: ABS/ESP allrad 3429
Software Coding: 00000
Work Shop Code: WSC 00000
VCID: 2614F08451F0525A0DF-51F2
01425 - Yaw Rate Sensor (G202); Signal Wire
57-10 - Electric Circuit Failure - Intermittent
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-00 -
35-00 - -
66-10 - Not Matched - Intermittent
However when I try to code the module it says 'No response from controller'
Can someone help me with this please or do I have get Audi to program it (it is the same model ABS controller)?
Please post a complete Auto-Scan for better context.
My guess is the the Yaw Rate Sensor fault is going to be a problem when it comes to coding this module.
TrekyBob
Aargau, Switzerland
C?ID=590165
Thanks Uwe, I'll check the plug and harness on the Yaw Sensor. Will get back to you.
EuroX
Northern NJ USA
C?ID=208579
Did you login using SA? I believe in those older vehicles this was required.
TrekyBob
Aargau, Switzerland
C?ID=590165
No, I used the Ross TEch number system fr the login, I'll try it and get back to thanks.
TrekyBob
Aargau, Switzerland
C?ID=590165
Tried that but not recognised. Disconnected the Yaw sensor, checked the pwer supply, 12 V ok. Didn't do continuity test as I don't know where the remaining 5 pins go. Could remove and replace but the fault code says elec wire circuit signal intermittent failure? Anyone else had this? Yaw sensor is not cheap but neither is my Quattro!
TrekyBob
Aargau, Switzerland
C?ID=590165
I cleaned the yaw sensor plug and pins, this removed the intermittent wire circuit failure but still no logon possible. Any thoughts much appreciated.
Monday,08,July,2024,17:16:46:30198
VCDS Version: Release 24.5.0 (x64) Running on Windows 11 x64
Component and/or Version: ABS/ESP allrad 1726
P1848 - 35-00 -
35-00 - -
NEtech
Denmark
C?ID=56995
09395 for the login and 04495 for coding.
Front brake: 1LT
TrekyBob
Aargau, Switzerland
C?ID=590165
Front brake: 1LT
Thanks, the ABS coded right aawy, the steering caibration worked, the funtional test didn't work, tried three times. Now the codes reverted back to null, I guess because it was not completed? Oh well I try again another day but again thank you for helping and I appreciate this forum very much.
EuroX
Northern NJ USA
C?ID=208579
Yes need to complete all in one shot otherwise they don't take.
  • Agree
TrekyBob
Aargau, Switzerland
C?ID=590165
Ok, I get thru again to the functional test part, but thats where it stops, when I apply the brakes I do not get a change in the lights on the cluster, if I attempt the test any way everything rests back to null...Anyone have any ideas about this please?
TrekyBob
Aargau, Switzerland
C?ID=590165
Not quite, it still does not accept the ABS code for some reason, 09395 and 04495. I enter it , it says accepted but then this;
TrekyBob
Aargau, Switzerland
C?ID=590165
Tuesday,09,July,2024,15:50:56:30198
VIN: WAUZZZ8E54A106765   License Plate:
          67 69 75 76 77
VIN: WAUZZZ8E54A106765   Mileage: 336870km-209321miles
Address 01: Engine        Labels: 06C-909-559-ASN.lbl
   Part No SW: 8E0 909 559 M    HW: 8E0 909 059
   Component: 3.0L V6/5V          0010
   Coding: 0011711
   Shop #: WSC 63251 000 00000
   VCID: 3FDA45E0AB6AE3926E9-5160
   VINID: 9D196AAAA2151444410061C614741F96F8
Readiness: 0110 1101
   Part No: 8E0 614 517 A
   Component: ABS/ESP allrad      1726
   Coding: 00000
            P1848 - 35-00 -
            35-00 - -
   Part No: 8E0 820 043 AB
   Component:   A4 Klimaautomat   1319
   Coding: 00000
   Shop #: WSC 63251
   VCID: 619EA398785EF56238D-5160
            27-00 - Implausible Signal
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  RDW 0517
   Coding: 00101
   Shop #: WSC 63251
   VCID: 353627C89C5629C2B45-4B00
01312 - Powertrain Data Bus
            79-10 - Please Check Fault Codes - Intermittent
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 B
   Component: Airbag 8.4EP        3002
   Coding: 0010602
   VCID: 363420C4845022DABDF-5184
   Part No: 8E0 953 549 S
   Component: Lenksáulenmodul     0611
   Coding: 01012
   Shop #: WSC 63251
   VCID: 43D24910C28287720A1-4B00
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.clb
   Part No: 8E0 920 900 L
   Component: KOMBI+WEGFAHRS. RB4 D37
   Coding: 01100
   Shop #: WSC 42621
   VCID: 2D060FA874066102CC5-5160
   WAUZZZ8E54A106765     AUZ6Z0C0287727
   Part No: 8E0 959 433 AT
   Component: Komfortgerát T23    1210
   Coding: 06976
   Shop #: WSC 63251
   VCID: 03528910820247724A1-4B00
   Subsystem 1 - Part No: 8E1959801B
   Component: Tõrsteuer.FS BRM 0003
   Subsystem 2 - Part No: 8E1959802B
   Component: Tõrsteuer.BF BRM 0003
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0004
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0004
            37-10 - Faulty - Intermittent
01561 - Rear left door
            61-00 - Won't De-Safe
   Part No: 8E0 035 186 L
   Component: concert II  GRO    0001
   Coding: 01000
   Shop #: WSC 63251
   VCID: 303816DC63040CEAE73-4B1E
00852 - Loudspeaker(s); Front
            36-00 - Open Circuit
End----------(Elapsed Time: 05:43, VBatt start/end: 12.2V/12.2V)-----------
TrekyBob
Aargau, Switzerland
C?ID=590165
The steering angle sensor is locked, how do I unlock it please anyone, it is this last step that blocks the coding being stored, anyone to help please?
Andy
Sector 7G
HC424490
What values do you see in Measuring Blocks group 005?
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Immediately after the message that the coding is accepted, without ignition off, go to basic setting G85.
TrekyBob
Aargau, Switzerland
C?ID=590165
sorry , wrong block, it says in ABS measure blocks 005
Steer Angle -2.5°, Rotation rate 0, Brake pressure - alternating between 0 and 1.3, Transvers Accelleration 0.19m/s
TrekyBob
Aargau, Switzerland
C?ID=590165
ok I get thru the part where there are no fault codes, but as soon as I go out of the ABS logon then it all reverts to 00000 again
