2013 Audi A7 doesn't crank/start.
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
nday,12,May,2025,18:49:07:10725
VCDS Version: 25.3.1.1 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250415 DS365.0
VIN: WAU2GAFC4DN072644   License Plate:
Mileage: 146276km-90891mi   Repair Order: Uuu
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 47 52
          53 55 56 5F 62 6C 6D 72 8F 90
VIN: WAU2GAFC4DN072644   Mileage: 146276km-90891miles
04-Steering Angle -- Status: Cannot be reached 0100
28-HVAC, Rear -- Status: Cannot be reached 0100
55-Headlight Range -- Status: Cannot be reached 0100
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CTUA)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551 D    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0006
   Revision: --H07---    CVN: 4C7FB7FB
   Coding: 1A2A0034052601060000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551D 001007
   ROD: EV_ECM30TFS0214G0907551D.rod
   VCID: 2A0D0FFCDC7DB70AF1E-807E
   VINID: 9D19425D15931147801C218410B2C32E6F
7115 - Cylinder 2
          P0302 00 [01100101] - Misfire Detected
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 23:49:07
                    Engine speed: 929.00 /min
                    Normed load value: 16.1 %
                    Coolant temperature: 29 °C
                    Intake air temperature: 24 °C
                    Ambient air pressure: 940 mbar
                    Voltage terminal 30: 13.101 V
                    Engine speed: actual: 928 /min
                    MAF_ENVD: 245.11764 mg/stroke
                    Coolant temperature (unfiltered): 29.25 °C
                    Engine: operating status: IS
                    T_AST_ENVD: 0.00 s
                    Vehicle speed: actual: 0 km/h
6201 - Function Restriction due to Faults in Other Modules
          U1113 00 [01101101] - -
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:46:58
                    Engine speed: 1353.00 /min
                    Normed load value: 32.2 %
                    Coolant temperature: 21 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 11.171 V
                    Engine speed: actual: 1408 /min
                    MAF_ENVD: 250.56470 mg/stroke
                    Engine load: 30.078125 %
6078 - No Communications with Steering Angle Sender (G85)
          U0126 00 [00101101] - -
                    Fault Frequency: 8
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:40
                    Engine speed: 0.00 /min
                    Voltage terminal 30: 12.187 V
                    Engine speed: actual: 0 /min
                    T_AST_ENVD: 0.00 s
                    Gear: 0
                    Engine: operating status: ES
                    Battery voltage: 12.187500 V
Readiness: 1110 1101
   Part No SW: 4G1 927 158 A    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H16 1006
   Revision: --H16---    CVN: 06AF4385
   Coding: 000002
   VCID: 2D0704E0ED93A03214C-8078
12561 - No Communications with Steering Angle Sender (G85)
          U0126 00 [00101111] - -
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:39
                    Voltage terminal 30: 12.095 V
                    Engine speed: 0 /min
                    Status data bus communication diagnostic interface-State Deashboard received: not received
                    Status data bus communication diagnostic interface-State ECM received: not received
                    Status data bus communication diagnostic interface-State ESP received: not received
                    Status data bus communication diagnostic interface-State Gateway received: not received
                    Status data bus communication diagnostic interface-State Parking Brake received: not received
                    Status data bus communication diagnostic interface-State Steering Angle received: not received
                    Status data bus communication diagnostic interface-State Steering Assist received: not received
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 44A78F0322E5F1C05B00
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 36352B8C18C5E3EA656-8062
0067 - Function Restricted due to Missing Message(s)
          U1111 00 [10001001] - -
          [ComScl_PDU_LWI_01_Timeout]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:38
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DB
                    Uz: 9B
0781 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [ComScl_PDU_LWR_AFS_01_Timeout]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:38
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DE
                    Uz: 9B
0604 - Tire Pressure Warning
          C102D 00 [00001001] - -
                    Fault Frequency: 8
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:38
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 28
                    Uz: 9B
0629 - Tire Pressure Warning
                    Fault Frequency: 8
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:38
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 2C
                    Uz: 9B
   Part No SW: 4H0 907 064 CR    HW: 4H0 907 064 CR
   Component: BCM2 2.0      H32 0421
   Coding: 0DAA2046000000000000
   VCID: 7BA3FAB863E7FE82DA8-802E
   Serial number: 2312000188284001
   Part No SW: 4G0 820 043 L    HW: 4G0 820 043 L
   Component: KLIMA 4 ZONEN H11 0062
   Serial number: 04081100040879
   Coding: 6601207A0C
   ASAM Dataset: EV_AirCondiComfoUDS 002033
   VCID: 2809F5F4C271851AE7A-807C
13 Faults Found:
0192 - Position Sensor in Left Side Vent
          B10E3 15 [00001001] - Open or Short to Plus
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
                    Voltage terminal 30: 12.10 V
                    Terminal 15 status: Terminal 15 on
                    Supply voltage for external components: 5.00 V
0194 - Position Sensor in Left Center Vent
          B10E1 15 [00001001] - Open or Short to Plus
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
0196 - Position Sensor in Right Center Vent
          B10E2 15 [00001001] - Open or Short to Plus
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
0197 - Position Sensor in Right Side Vent
          B10E4 11 [00001001] - Short to Ground
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
0245 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
          [Sensor für Luftfeuchte innen: unplausibles Signal]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
                    Outside temperature: 23.0 °C
                    Inside temperature: 24.07 °C
0267 - Sensor for Refrigerant Pressure and Temperature
          B10C2 21 [00001001] - Signal Amplitude Too Low
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
                    Compressor current: actual value: 0 mA
                    Temperature downstream of evaporator: 19.70 °C
0276 - Engine Off Timer Performance
          P150A 00 [00001000] - -
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
0317 - Function Restricted due to Missing Message(s)
          [Steuergerät für Klima hinten: kein Signal / Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
0369 - Function Restricted due to Missing Message(s)
          [Steuergerät für Spurhalteassistent: kein Signal / Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
0392 - Function Restriction due to Faults in Other Modules
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
0400 - Function Restriction due to Faults in Other Modules
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
0401 - Function Restriction due to Faults in Other Modules
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
15360768 - Component Protection
          U1101 00 [00001001] - Active
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
                    Component protection: 33
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001455986
   Coding: 0200E011163C9FE0C1008884A0003928CF9CD208A6080225800008406000
   Shop #: WSC 12345 123 61029
   VCID: 6FBBDEE8279F9222660-803A
   Component: WWS57X 120912  H36 0080
   Serial number:         120924234600
   Coding: 0045F7
   Serial number: 20651292
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 02 10 2012  00000362
   Subsystem 4 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0040535061
   Coding: 853000
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA104148000001943496
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 44580E46000000000001
00887 - Switch for Emergency Flasher (E229)
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:00
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:00
02258 - Door Opener Transmitter
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:00
01229 - A/C Humidity Sensor (G260)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:00
   Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0072
   Revision: 11001001    Serial number: 61061228400273
   Coding: A8C304
   ASAM Dataset: EV_EPHVA18AU57X0000 003008
   ROD: EV_EPHVA18AU57X0000_003_AU57.rod
   VCID: 77ABE6885F4FDAE2BE0-8022
13679386 - Databus
          [Steuergerät für Lenkhilfe-J500 - LH_EPS_03. EPS_Berechneter_LW - Fehlerspeicher auslesen]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:47:24
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D8002FL1K Dataset Number: 4G8909602D  0004
   Coding: 303145313131303030314A55304C34473853
   VCID: 333312980BB7F6C2428-8066
   Serial number: 6940000Y150001ER7M01
   Serial number: 3575HRB405D1HGMQ915M
   Serial number: 3585HRB40571HGMQCP1/
   Serial number: 3515JRB401C4UN9OI1VD
   Serial number: 3525JRB405D1MFU46GQ%
   Serial number: 3554VRB400K4UNK88PR/
   Serial number: 3564VRB400G4UNK86H55
1050112 - Databus
          [CAN: 0x086 LWI_01 Timeout]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:40
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20121012001065
   Coding: 000034
   VCID: 30391D94FA21CDDA3FA-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
00576 - Terminal 15
                    Fault Status: 01101000
                    Fault Frequency: 8
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:35
   Part No SW: 4G8 920 983 E    HW: 4G8 920 983 E
   Component: TBenUsa       H79 0515
   Revision: 28460207    Serial number: 658111012592017
   Coding: 03E701060B43D705020100
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod
   VCID: 372B26881FCF1AE27E0-8062
16776970 - Function Restricted due to Missing Message(s)
          [LWR_AFS_01 keine Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
1048580 - Button for Trip Odometer Reset
          B11FE 13 [00001001] - Open Circuit
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000719062 Dataset Number: 4G8909515D  0059
   Coding: 00CD073000
   GVL: FDA1E84CFE63600D0000
   ASAM Dataset: EV_GatewPkoUDS 001018
   VCID: 71BFD890312B84D2704-8024
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790310195
   Voltage stabilizer:
   Serial number: 180417000000000000CC
5088 - Rear A/C control module
          U1072 00 [00001001] - No communication
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
                    Voltage terminal 30: 12.0 V
                    Voltage terminal 15: 12.0 V
                    Control Module temperature: 28 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
4230 - No Communications with Steering Angle Sender (G85)
          U0126 00 [00001001] - -
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
                    Control Module temperature: 29 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5013 - Headlight Range Control Module
          U101E 00 [00001001] - No Communication
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
Address 28: HVAC, Rear
   Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000039194743
   Coding: C0581B008F006001000001010101102030303232203232
   VCID: 382925B41251159A77A-806C
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H02 0053
   Revision: --------    Serial number: EJ1BPA8201GNLM Dataset Number: 4G8909573A  0001
   ASAM Dataset: EV_SARA2 005011
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 J    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0040
   Revision: 00H02000    Serial number: 6PZ 010 287-08
   Coding: 0000007
   VCID: 36352B8C1445E3EA656-8062
   Subsystem 1 - Part No: 4G0 907 568 J
   Component: J770  SWA Slave H02 0040
   Subsystem 2 - Serial number: 6PZ 010 287-28
   Subsystem 3 - Serial number: 5F09.10.1200H02000AMS14681ÿ
   Subsystem 4 - Serial number: S14681ÿ
   Component: TSG FA        H03 0506
   Coding: 011F57025E00628002000412
   VCID: 47CB56486FAF6A620E0-8012
01340 - Mirror Adjustment Switch
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 23:49:52
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0007945176 Dataset Number: 4G8909852J  0028
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D179CF4ADFFCA49E-8066
3158276 - Function Restricted due to Missing Message(s)
          [Ausfall Botschaft "PDU_LWI_01"]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:38
                    2.42 V
4208000 - Steering Angle Sensor
          B1168 F1 [00001000] - Synchronization Failed
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:47:23
                    112.50 °
   Revision: 00002001    Serial number: 0185437806
   Coding: 0126063A20FAF08580B00A84020102070000000000000000000000000000
   Subsystem 2 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO1853955A
   Coding: 101F00
   Subsystem 3 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00002421657
   Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0028
   Serial number: WA104224000002081655
                    Fault Frequency: 8
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:35
03616 - Rear Left Reading Light
                    Fault Status: 01101100
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:39
03615 - Rear Right Reading Light
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:39
            014 - Defective
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:39
03233 - Controls for Garage Door Opener (E284)
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:39
   Revision: CJ007001    Serial number: 00000000009943
   Coding: 030000
   Shop #: WSC 06745 128 28888
   VCID: 1D67D4209DB350B284C-8048
   Component: TSG BF        H03 0506
   Coding: 011F57025E00628002000402
   VCID: 46D55B4C68A5736AF56-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000504125 Dataset Number: 4G8909522A  0002
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B030AF8D387AE020A8-807E
Address 55: Headlight Range
   Part No SW: 4G0 035 082 E    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0121
   Revision: AB001007    Serial number: 156J/0C7645431
   Coding: 020007010000000001
   VCID: 221DE7DCA4CD6F4AB9E-8076
02617 - Satellite Antenna (R170)
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:45
                    Voltage: 12.10 V
   Part No SW: 4G0 035 746 D    HW: 4G0 035 746 B
   Component: H-BNT-NA      H49 0622
   Revision: --------    Serial number: 194J 0C7515071
   Coding: 090200040003E1EF55128B3E00000003100001000000000000
   VCID: 2809F5F4C2F1851AE7A-807C
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDC9402R0KX
   Subsystem 3 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
00658 - Control Head
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:39
                    Voltage: 11.90 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 22:03:41
                    Voltage: 12.00 V
                    Bin. Bits:      001
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:49
                    Voltage: 11.90 V
01524 - Antenna for Telephone
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:49
                    Voltage: 11.90 V
   Component: TSG HL        H03 0506
   Coding: 010F17024000628002000002
   VCID: 49CF507079BB9C12184-801C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H06---    Serial number: 525 PA8J28G9CC
   Coding: 1080013
   VCID: 2615FBCCC4E5936AD56-8072
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:35
                        Reverse OFF
                    Count: 3
   Part No SW: 4G8 959 107 R    HW: 4G8 959 107 G
   Component: HDSG-Modul    H13 0043
   Revision: 12013001    Serial number: 262200497 Dataset Number: 4G8909541F  0022
   Coding: 0A3305C102
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571_AU57.rod
   VCID: 44D141445E19417AEB2-8010
   Component: TSG HR        H03 0506
   Dataset Number: 4G0909614C  0001
   Coding: 0006E008031F0300070308014244CA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F1890F1ABC4D2304-8064
12583690 - Function Restricted due to Missing Message(s)
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
   Dataset Number: 4G0909615C  0001
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.27
                    Time: 21:42:37
End----------(Elapsed Time: 02:36, VBatt start/end: 12.1V/12.0V)-----------
------------------------------52 Faults Found------------------------------
   #102
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
00576 - Terminal 15 008 - Implausible Signal
Several of these seem to be related to fuses in a certain area: Fuse Panel C, Fuse Panel 1 fuses 1-6 have power. Fuses 7-12 don't have power and those are Steering Column Electronic Systems Control Module -J527-, Headlamp range control module -J431-, Right Headlamp Power Output Stage -J668- 2
Seems like more than a coincidence. My question is, where or how does power pass through these fuses because in wiring diagram I see this:
This only shows a few wires coming into and out to a couple components. There is that line above each that looks to be some sort of connection between each fuse location on carrier. Any idea where power/ground for Fuses 7-12 comes from?
   #103
Ziddywerks
Northern NJ USA
C?ID=208579
Main feed looks like it's coming from track 323. Are we sure we have the correct wiring diagram up for that model year? Mine is showing otherwise.
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
This is coming from the Main ERWIN wiring diagram based on my VIN, but maybe it's not correct. Some items like "through model year 2014" and "from model year 2015", but this is section "Fuse Positions , (L0L)" doesn't have separate areas based on Model Year.
Ziddywerks
Northern NJ USA
C?ID=208579
Mine shows otherwise:
   #106
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Interesting! Mine doesn't match as far as colors of wires either. I can clearly see black/blue and red/yellow which my wiring diagram doesn't even have. I guess they packaged the wrong one up for me. I'll check my AllData and see if I have the same as yours
EDIT: AllData has the right one, but I ERWIN didn't. Apparently there are two (2) Fuse positions in doc. One is 074 -Fuse Positions , (L0L) (this one is wrong for my car) and 022 - Fuse Positions , (L0L) (this one is right for my car). Mystery solved!
Ziddywerks
Northern NJ USA
C?ID=208579
Mine is based on Vin, from what I know from 2010 to 2014 fuse layout is the same based on options.
   #108
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Thought I figured out the problem already (but I didn't)! Traced Panel C1 Fuses back to Panel B1, Fuses 13 & 14. 13 is fine and has power, but 14 didn't. Checked fuse and it's fine, but when probing, I got power on Fuse 14 slot. Looked inside to see that one of prongs to make contact with fuse blade is bent back slightly so it's not making contact on 1 side of fuse. Worked to find something small enough to gently push back out so then those other modules would come online hopefully, but I am still getting no power to other fuse block. Going to have to take that Panel C1 carrier apart and see why blue/black wire isn't providing power on Fuse Panel C to those 6 fuses
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Fixed with making sure connections were snug in Fuse Box B. Going to run and post another scan if this works to bring other modules back online
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Fixed most everything that I have been trying to except one very pesky thing that that is the screen not popping out when car is powered on or switch is pressed. Also, buttons in center console don't work. I do see the screen is lit up and trying to connect to some old bluetooth device, but since center console buttons don't work, I can't do anything like back out, change media sources, etc.
Tuesday,13,May,2025,21:50:57:10725
VIN: WAU2GAFC4DN072644   License Plate: SMALLS
Mileage: 146276km-90891mi   Repair Order: 6969
   Coding: 000002
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:27
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 28
                    Uz: 96
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:27
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 2C
                    Uz: 96
   Coding: 6601207A0C
13 Faults Found:
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:27
                    Voltage terminal 30: 11.65 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:27
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:27
0198 - Position Sensor in Right Side Vent
          B10E4 15 [00001001] - Open or Short to Plus
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:27
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:27
                    Outside temperature: 22.0 °C
                    Inside temperature: 21.48 °C
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:27
                    Temperature downstream of evaporator: 18.30 °C
          P150A 00 [00001001] - -
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:27
                    Voltage terminal 30: 11.67 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:27
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:27
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:27
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:27
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:27
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:27
   Coding: 0045F7
   Coding: 02006E
   Coding: 853000
   Coding: 020300
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:00
            014 - Defective
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:00
   Coding: A8C304
   Coding: 000034
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:27
   Coding: 00CD073000
   Voltage stabilizer:
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:27
                    Voltage terminal 30: 11.6 V
                    Voltage terminal 15: 11.6 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:27
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   ROD: EV_SARA2.rod
   Coding: 0000007
   Coding: 101F00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:29
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:29
            014 - Defective
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:29
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:29
   Coding: 030000
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 C    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0020
   Serial number: 121008-0004-011
   Coding: 1223A633701AA500
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU57.rod
H01 0031
   Coding: 3A0000
H01 0031
   Coding: 3A0000
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:35
                    Voltage: 11.60 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:32
                    Voltage: 11.50 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:38
                    Voltage: 11.50 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 01:26:39
                    Voltage: 11.50 V
   Coding: 1080013
   Coding: 0A3305C102
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
End----(Elapsed Time: 02:26, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
------------------------------29 Faults Found------------------------------
   Coding: 000002
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:07
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 28
                    Uz: 97
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:07
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 2C
                    Uz: 97
   Coding: 6601207A0C
13 Faults Found:
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:06
                    Voltage terminal 30: 11.73 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:06
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:06
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:06
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:06
                    Inside temperature: 19.18 °C
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:06
                    Temperature downstream of evaporator: 17.81 °C
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:06
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:06
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:06
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:06
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:06
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:06
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:06
   Coding: 0045F7
   Coding: 02006E
   Coding: 853000
   Coding: 020300
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:00
            014 - Defective
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:00
   Coding: A8C304
   Coding: 000034
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:13
   Coding: 00CD073000
   Voltage stabilizer:
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:07
                    Control Module temperature: 27 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:06
                    Voltage terminal 30: 11.7 V
                    Voltage terminal 15: 11.7 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   ROD: EV_SARA2.rod
   Coding: 0000007
   Coding: 101F00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:08
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:08
            014 - Defective
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:07
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:08
   Coding: 030000
H01 0031
   Coding: 3A0000
H01 0031
   Coding: 3A0000
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:15
                    Voltage: 11.70 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:13
                    Voltage: 11.50 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.29
                    Time: 02:05:18
                    Voltage: 11.50 V
   Coding: 1080013
   Coding: 0A3305C102
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
End----(Elapsed Time: 02:39, VBatt start/end: 11.7V/11.6V. VIgn 11.7V)-----
------------------------------28 Faults Found------------------------------
Ziddywerks
Northern NJ USA
C?ID=208579
Cycle headlight switch to on position to check if the mmi buttons light up or not. If not then I woudl say no power supply to mmi buttons. Check fuses and all connection to mmi button panel E380 IIRC.
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Ok, the issue was behind the Control Module for Information Electronics 1 -J794-. The previous owner had some sort of piggyback cable plugged into original harness that wasn't plugged into anything else. I checked all fuses, power and grounds going to screen and buttons, and pulled apart Center Console control head to check board for damage or blown capacitors and then cleaned and reinstalled. Buttons work much better and aren't sticky, but the issue was found after removing -J794- and removing all the aftermarket wiring behind it. Screen pops out now and MMI is 100% fully functional! Going to plug in all modules that I have purchased and rescan so we can get an accurate count of errors still remaining, but we're looking MUCH better. Last error count was 28, but it should be less than that now!
Only major thing left before I can actually drive is replacing vent hose from expansion tank to radiator that was broken and then I can pressure test cooling system and add coolant.
Also, ordered assortment of fuses and will be going through every fuse panel in the car to place correct fuse amperage in slots since some are not correct and have a 20 where should be 15, 10 where should be 7.5, etc
   #114
Hopefully not from Amazon?
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
They are Bussmann fuses from Grainger, but that's pretty scary. Also, Louis Rossmann is the man! His fight for Right to Repair is well-documented
nugentp
C?ID=6386
Thats crazy alright.
   #118
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Posting latest scan after installing every module I currently possess for the car. Still looking at rear lights not having power and rear AC vent short to ground, but 60 faults has been reduced to 18 now after all this time. Need someone to remove CP on front climatronic module now, so that's the next thing since it's hot a hell here in AZ so I'll cook if I try to drive it without that!
Sunday,18,May,2025,16:02:52:10725
Mileage: 146317km-90917mi   Repair Order: 051825
VIN: WAU2GAFC4DN072644   Mileage: 146317km-90917miles
   Coding: 000002
   Coding: 6601207A0C
7 Faults Found:
                    Reset counter: 0
                    Mileage: 146317 km
                    Date: 2023.05.18
                    Time: 15:58:08
                    Voltage terminal 30: 12.38 V
                    Inside temperature: 22.32 °C
                    Reset counter: 0
                    Mileage: 146317 km
                    Date: 2023.05.18
                    Time: 15:58:08
                    Temperature downstream of evaporator: 19.26 °C
                    Reset counter: 0
                    Mileage: 146317 km
                    Date: 2023.05.18
                    Time: 15:58:08
                    Voltage terminal 30: 12.36 V
                    Reset counter: 0
                    Mileage: 146317 km
                    Date: 2023.05.18
                    Time: 15:58:08
                    Reset counter: 0
                    Mileage: 146317 km
                    Date: 2023.05.18
                    Time: 15:58:08
                    Reset counter: 0
                    Mileage: 146317 km
                    Date: 2023.05.18
                    Time: 15:58:08
                    Reset counter: 0
                    Mileage: 146317 km
                    Date: 2023.05.18
                    Time: 15:58:08
   Coding: 0045F7
   Coding: 02006E
   Coding: 853000
   Coding: 020300
                    Reset counter: 0
                    Mileage: 146317 km
                    Date: 2023.05.18
                    Time: 15:58:00
                    Reset counter: 0
                    Mileage: 146317 km
                    Date: 2023.05.18
                    Time: 15:58:00
            014 - Defective
                    Reset counter: 0
                    Mileage: 146317 km
                    Date: 2023.05.18
                    Time: 15:58:00
   Coding: A8C304
   Coding: 000034
   Coding: 00CD073000
   Voltage stabilizer:
                    Reset counter: 0
                    Mileage: 146317 km
                    Date: 2023.05.18
                    Time: 15:58:08
                    Voltage terminal 30: 12.3 V
                    Voltage terminal 15: 12.3 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0064
   Serial number: 16011200040875
   Coding: 00
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
   VCID: 2F3B1EE8E79FD222260-807A
0070 - Position Sensor in Rear Right Upper Body Vent
          B10E6 15 [00001001] - Open or Short to Plus
                    Reset counter: 0
                    Mileage: 146317 km
                    Date: 2023.05.18
                    Time: 15:58:08
                    Voltage terminal 30: 12.44 V
   ROD: EV_SARA2.rod
   Coding: 0000007
   Coding: 101F00
                    Reset counter: 0
                    Mileage: 146317 km
                    Date: 2023.05.18
                    Time: 15:58:10
                    Reset counter: 0
                    Mileage: 146317 km
                    Date: 2023.05.18
                    Time: 15:58:10
            014 - Defective
                    Reset counter: 0
                    Mileage: 146317 km
                    Date: 2023.05.18
                    Time: 15:58:10
                    Reset counter: 0
                    Mileage: 146317 km
                    Date: 2023.05.18
                    Time: 15:58:10
   Coding: 030000
H01 0031
   Coding: 3A0000
H01 0031
   Coding: 3A0000
Address 56: Radio
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349LJA0009P
   Subsystem 4 - Part No: 8R0 060 961 D
                    Reset counter: 0
                    Mileage: 146317 km
                    Date: 2023.05.18
                    Time: 15:58:20
                    Voltage: 12.20 V
                    Reset counter: 0
                    Mileage: 146317 km
                    Date: 2023.05.18
                    Time: 15:58:20
                    Voltage: 12.20 V
   Coding: 1080013
   Coding: 0A3305C102
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:52, VBatt start/end: 12.4V/12.3V)-----------
------------------------------18 Faults Found------------------------------
Now that I have it running again and oil changed and fluids checked, I gave it a wash and took it out for a drive.
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
New fault code to address after paying the dealership $250 to remove Component Protection from the Auto HVAC (J255) module. They also tried to do Basic Setting even though I told them to only remove CP, so before I could manually trigger compressor to turn on and cool air flowed from the vents. Now, I get a message from IDE00965 -- Compressor shut-off condition that says, "Basic Setting not Performed" and something like "Request denied from module" when I try to do tests in module for "Max cooling"
Reset counter: 5
Mileage: 146519 km
Date: 2023.05.30
Time: 08:06:01
Outside temperature: 32.0 °C
Temperature downstream of evaporator: 50.88 °C
Engine speed: 790 /min
I tested at the sensor and am seeing 12v on power, 12v when going from Bat+ to Ground pin and 12v on LIN wire. Would this mean either it's actually low pressure in the HVAC lines or just that the sensor is faulty? I can see if Auto Zone has Loan-A-Tool to test pressures, but curious if this is the right path or if there is another way to see refrigerant pressures being reported to the car.
VIN: WAU2GAFC4DN072644   Mileage: 146595km-91089miles
   Coding: 000002
   Coding: 6601207A0C
7 Faults Found:
                    Reset counter: 5
                    Mileage: 146595 km
                    Date: 2023.05.30
                    Time: 11:24:30
                    Voltage terminal 30: 12.71 V
                    Outside temperature: 29.0 °C
                    Inside temperature: 30.16 °C
                    Reset counter: 5
                    Mileage: 146595 km
                    Date: 2023.05.30
                    Time: 11:24:29
                    Temperature downstream of evaporator: 51.77 °C
0292 - Running-in regulation
          B10C6 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 5
                    Mileage: 146595 km
                    Date: 2023.05.30
                    Time: 11:24:29
                    Reset counter: 5
                    Mileage: 146595 km
                    Date: 2023.05.30
                    Time: 11:24:29
                    Reset counter: 5
                    Mileage: 146595 km
                    Date: 2023.05.30
                    Time: 11:24:30
                    Reset counter: 5
                    Mileage: 146595 km
                    Date: 2023.05.30
                    Time: 11:24:30
                    Reset counter: 5
                    Mileage: 146595 km
                    Date: 2023.05.30
                    Time: 11:24:30
   Coding: 0045F7
   Coding: 02006E
   Coding: 853000
   Coding: 020300
                    Reset counter: 5
                    Mileage: 146595 km
                    Date: 2023.05.30
                    Time: 11:24:00
            014 - Defective
                    Reset counter: 5
                    Mileage: 146595 km
                    Date: 2023.05.30
                    Time: 11:24:00
   Coding: A8C304
   Coding: 000034
   Coding: 00CD073000
   Voltage stabilizer:
   Coding: 00
   ROD: EV_SARA2.rod
   Coding: 0000007
   Component: GTO BF  H01 0080
   Serial number: 00000000000000124659
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
                    Reset counter: 5
                    Mileage: 146595 km
                    Date: 2023.05.30
                    Time: 11:24:31
                    Reset counter: 5
                    Mileage: 146595 km
                    Date: 2023.05.30
                    Time: 11:24:31
            014 - Defective
                    Reset counter: 5
                    Mileage: 146595 km
                    Date: 2023.05.30
                    Time: 11:24:31
   Coding: 030000
H01 0031
   Coding: 3A0000
H01 0031
   Coding: 3A0000
                    Reset counter: 5
                    Mileage: 146595 km
                    Date: 2023.05.30
                    Time: 11:24:37
                    Voltage: 12.60 V
   Coding: 090200040303E1EF55128B3E00000003100001000000000000
                    Reset counter: 5
                    Mileage: 146595 km
                    Date: 2023.05.30
                    Time: 11:24:41
                    Voltage: 12.50 V
                    Reset counter: 5
                    Mileage: 146595 km
                    Date: 2023.05.30
                    Time: 11:24:41
                    Voltage: 12.50 V
   Coding: 1080013
   Coding: 0A3305C102
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:34, VBatt start/end: 12.6V/12.6V)-----------
------------------------------15 Faults Found------------------------------
Ziddywerks
Northern NJ USA
C?ID=208579
Perhaps the system is empty? or the signal being sent is not a good signal. That fault usually means the module does not like the signal its seeing.
