2013 Audi A7 doesn't crank/start.
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
I am going to break out my Powerprobe ECT 3000 to try and trace the open wire if I can
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Ok, I have connected PowerProbe up and traced wiring but I'm pretty getting stumped because I am seeing connectivity with multimeter between those two points of CanBus Lines. This is pins 67,68 on ECU connector to 13,14 in T17a which would mean there is no break in wire there, correct? With PowerProbe ECT 3000, I am also seeing tone all the way through to there. Wouldn't I expect there to be no continuity or power flowing through to the T17 connector in picture?
Ziddywerks
Northern NJ USA
C?ID=208579
Up to and including T17a is fine, like I said, gearbox is beyond that point, and gearbox is talking. Concern point is E93 and E94 junctions, but they don't say where that is.
But that does not make sense because if the splices are an issue J217 is after the splice. So If the splices are no good then J217 would not be talking. I would do a dirty overlay to ecm to see if it comes back online. If it does cut and splice and make it permanent.
   #84
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Just out of curiosity, I connected scope to pins 13 and 14 on t17 and I saw CANBUS data activity. Connected to ECU pins 67 & 68 and nothing. So I temporarily connected the correct pins on t17 directly to pins on ECU with solid core copper wire (67 to 13 & 68 to 14). That would be an overlay, right?
Same behavior from car. Did an autoscan and no communication to ECU. Cleared all faults and rescanned. Same results. Even backprobed 67 & 68 with scope and saw activity, but this must be activity to/from TCU.
Saturday,10,May,2025,18:10:09:10725
VCDS Version: 25.3.1.1 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250415 DS365.0
Mileage: 146276km-90891mi   Repair Order: 67
Chassis Type: 4G0
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 47 52
          53 55 56 5F 62 6C 6D 72 8F 90
   Mileage: 146276km-90891miles
04-Steering Angle -- Status: Cannot be reached 0100
10-Park/Steer Assist -- Status: Cannot be reached 0100
28-HVAC, Rear -- Status: Cannot be reached 0100
3C-Lane Change -- Status: Cannot be reached 0100
55-Headlight Range -- Status: Cannot be reached 0100
8F-Pretens. Frt Left -- Status: Cannot be reached 0100
90-Pretens. Frt Right -- Status: Cannot be reached 0100
Address 01: Engine
   Part No SW: 4G1 927 158 A    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H16 1006
   Revision: --H16---    CVN: 06AF4385
   Coding: 000002
   ROD: EV_TCMAL551211_002_AU48.rod (VIN: N/A)
   VCID: 2D0704E0ED93A03214C-8078
12544 - Power Supply Terminal 15
          P3325 00 [00100111] - Implausible
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:51
                    Voltage terminal 30: 12.555 V
                    Transmission input speed: 0.00 /min
                    Transmission output speed: 0.00 /min
                    Engine torque: 0 Nm
                    ATF temperature: 24 °C
                    Accelerator pedal position: 14.9 %
                    M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
                    M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
                    M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Coasting
                    Engine speed: 0 /min
                    Transfer speed from ESP: 0.00 km/h
                    Transfer speed from ESP: valid
12561 - No Communications with Steering Angle Sender (G85)
          U0126 00 [00100111] - -
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:49
                    Voltage terminal 30: 12.556 V
                    Status data bus communication diagnostic interface-State Deashboard received: not received
                    Status data bus communication diagnostic interface-State ECM received: not received
                    Status data bus communication diagnostic interface-State ESP received: not received
                    Status data bus communication diagnostic interface-State Gateway received: not received
                    Status data bus communication diagnostic interface-State Parking Brake received: not received
                    Status data bus communication diagnostic interface-State Steering Angle received: not received
                    Status data bus communication diagnostic interface-State Steering Assist received: not received
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 44A78F0322E5F1C05B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004028
   ROD: EV_ESPPremiAU57X_004_AU57.rod (VIN: N/A)
   VCID: 36352B8C18C5E3EA656-8062
9 Faults Found:
0067 - Function Restricted due to Missing Message(s)
          U1111 00 [10001001] - -
          [ComScl_PDU_LWI_01_Timeout]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:48
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DB
                    Uz: A1
0781 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [ComScl_PDU_LWR_AFS_01_Timeout]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:48
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DE
                    Uz: A1
0604 - Tire Pressure Warning
          C102D 00 [00001001] - -
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:48
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 28
                    Uz: A1
0629 - Tire Pressure Warning
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:48
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 2C
                    Uz: A1
0838 - Function Restriction due to Faults in Other Modules
          U1113 00 [10000001] - -
          [SCL_MO_Mom_Begrenzung_Invalid]
0727 - Function Restriction due to Implausible Message(s)
          U1112 00 [10000001] - -
          [SCL_MO_Mom_Fahrerwunsch_Invalid]
0729 - Function Restriction due to Implausible Message(s)
          [SCL_MO_Mom_Verlust_Invalid]
0731 - Function Restriction due to Implausible Message(s)
          [SCL_MO_Mom_m_ex_Invalid]
0787 - Function Restriction due to Implausible Message(s)
          U1112 00 [10001001] - -
          [SCL_MO_Motormomente_Invalid]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:48
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: E6
                    Uz: A1
   Part No SW: 4H0 907 064 CR    HW: 4H0 907 064 CR
   Component: BCM2 2.0      H32 0421
   Coding: 0DAA2046000000000000
   VCID: 7BA3FAB863E7FE82DA8-802E
   Serial number: 2312000188284001
   Part No SW: 4G0 820 043 L    HW: 4G0 820 043 L
   Component: KLIMA 4 ZONEN H11 0062
   Serial number: 04081100040879
   Coding: 6601207A0C
   ASAM Dataset: EV_AirCondiComfoUDS 002033
   ROD: EV_AirCondiComfoUDS_002.rod (VIN: N/A)
   VCID: 2809F5F4C271851AE7A-807C
10 Faults Found:
0192 - Position Sensor in Left Side Vent
          B10E3 15 [00001001] - Open or Short to Plus
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
                    Voltage terminal 30: 12.55 V
                    Terminal 15 status: Terminal 15 on
                    Supply voltage for external components: 5.00 V
0194 - Position Sensor in Left Center Vent
          B10E1 15 [00001001] - Open or Short to Plus
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
0196 - Position Sensor in Right Center Vent
          B10E2 15 [00001001] - Open or Short to Plus
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
0267 - Sensor for Refrigerant Pressure and Temperature
          B10C2 21 [00001001] - Signal Amplitude Too Low
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
                    Compressor current: actual value: 0 mA
                    Outside temperature: 22.0 °C
                    Temperature downstream of evaporator: 20.54 °C
0276 - Engine Off Timer Performance
          P150A 00 [00001001] - -
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
0314 - Function Restricted due to Missing Message(s)
          [Sensor für Luftfeuchte aussen: kein Signal / Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
0315 - Function Restricted due to Missing Message(s)
          [Sensor für Luftfeuchte innen: kein Signal / Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
0317 - Function Restricted due to Missing Message(s)
          [Steuergerät für Klima hinten: kein Signal / Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
0369 - Function Restricted due to Missing Message(s)
          [Steuergerät für Spurhalteassistent: kein Signal / Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
15360768 - Component Protection
          U1101 00 [00001001] - Active
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
                    Component protection: 33
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001455986
   Coding: 0200E011163C9FE0C1008884A0003928CF9CD208A6080225800008406000
   Shop #: WSC 12345 123 61029
   VCID: 6FBBDEE8279F9222660-803A
   Component: WWS57X 120912  H36 0080
   Serial number:         120924234600
   Coding: 0045F7
   Serial number: 20651292
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 02 10 2012  00000362
   Subsystem 4 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0040535061
   Coding: 853000
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA104148000001943496
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 44580E46000000000001
7 Faults Found:
00576 - Terminal 15
                    Fault Status: 01101000
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:00
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:00
02258 - Door Opener Transmitter
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:00
01229 - A/C Humidity Sensor (G260)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:00
03725 - Control Module for Seat Belt Tensioner; Left Front
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:00
Address 10: Park/Steer Assist
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D8002FL1K Dataset Number: 4G8909602D  0004
   Coding: 303145313131303030314A55304C34473853
   ROD: EV_AirbaAU10BPAAU64X_VW51.rod (VIN: N/A)
   VCID: 333312980BB7F6C2428-8066
   Serial number: 6940000Y150001ER7M01
   Serial number: 3575HRB405D1HGMQ915M
   Serial number: 3585HRB40571HGMQCP1/
   Serial number: 3515JRB401C4UN9OI1VD
   Serial number: 3525JRB405D1MFU46GQ%
   Serial number: 3554VRB400K4UNK88PR/
   Serial number: 3564VRB400G4UNK86H55
1050112 - Databus
          [CAN: 0x086 LWI_01 Timeout]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:50
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20121012001065
   Coding: 000034
   VCID: 30391D94FA21CDDA3FA-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
00576 - Terminal 15
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:45
   Part No SW: 4G8 920 983 E    HW: 4G8 920 983 E
   Component: TBenUsa       H79 0515
   Revision: 28460207    Serial number: 658111012592017
   Coding: 03E701060B43D705020100
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod (VIN: N/A)
   VCID: 372B26881FCF1AE27E0-8062
16776970 - Function Restricted due to Missing Message(s)
          [LWR_AFS_01 keine Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
1048580 - Button for Trip Odometer Reset
          B11FE 13 [00001001] - Open Circuit
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000719062 Dataset Number: 4G8909515D  0059
   Coding: 00CD073000
   GVL: FDA1E84CFE63600D0000
   ASAM Dataset: EV_GatewPkoUDS 001018
   ROD: EV_GatewPkoUDS_001_AU57.rod (VIN: N/A)
   VCID: 71BFD890312B84D2704-8024
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790310195
   Voltage stabilizer:
   Serial number: 180417000000000000CC
9 Faults Found:
5088 - Rear A/C control module
          U1072 00 [00001001] - No communication
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
                    Voltage terminal 30: 12.4 V
                    Voltage terminal 15: 12.5 V
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
4230 - No Communications with Steering Angle Sender (G85)
          U0126 00 [00001001] - -
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5013 - Headlight Range Control Module
          U101E 00 [00001001] - No Communication
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5271 - No Communications with Parking Assist Control Module A
          U0159 00 [00001001] - -
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
4879 - Lane change assistant control module
          U1045 00 [00001001] - No communication
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5080 - Front Left belt tensioner control module
          U107C 00 [00001001] - No communication
          [Steuergerät für RGS Links Keine Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5081 - Front Right belt tensioner control module
          U107D 00 [00001001] - No communication
          [Steuergerät für RGS Rechts Keine Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0259 - Extended CAN Bus (SAE Bus C)
          U0047 00 [00001001] - Performance
          [Vehicle Communication Bus C Bus Performance]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
                    Voltage terminal 30: 12.5 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
Address 28: HVAC, Rear
   Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000039194743
   Coding: C0581B008F006001000001010101102030303232203232
   VCID: 382925B41251159A77A-806C
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H02 0053
   Revision: --------    Serial number: EJ1BPA8201GNLM Dataset Number: 4G8909573A  0001
   ASAM Dataset: EV_SARA2 005011
   ROD: EV_SARA2.rod (VIN: N/A)
Address 3C: Lane Change
   Component: TSG FA        H03 0506
   Coding: 011F57025E00628002000412
   VCID: 47CB56486FAF6A620E0-8012
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:45
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0007945176 Dataset Number: 4G8909852J  0028
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod (VIN: N/A)
   VCID: 323D179CF4ADFFCA49E-8066
3158276 - Function Restricted due to Missing Message(s)
          [Ausfall Botschaft "PDU_LWI_01"]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:48
                    2.42 V
   Revision: 00002001    Serial number: 0185437806
   Coding: 0126063A20FAF08580B00A84020102070000000000000000000000000000
   Subsystem 2 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO1853955A
   Coding: 101F00
   Subsystem 3 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00002421657
   Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0028
   Serial number: WA104224000002081655
03616 - Rear Left Reading Light
                    Fault Status: 01101100
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:49
03615 - Rear Right Reading Light
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:49
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:45
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:45
            014 - Defective
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:49
03233 - Controls for Garage Door Opener (E284)
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:49
   Revision: CJ007001    Serial number: 00000000009943
   Coding: 030000
   Shop #: WSC 06745 128 28888
   VCID: 1D67D4209DB350B284C-8048
   Component: TSG BF        H03 0506
   Coding: 011F57025E00628002000402
   VCID: 46D55B4C68A5736AF56-8012
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:45
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000504125 Dataset Number: 4G8909522A  0002
   ROD: EV_ParkiBrake_VW51.rod (VIN: N/A)
   VCID: 2B030AF8D387AE020A8-807E
10613248 - Terminal 15
          U1405 00 [10001001] - Implausible signal
          [FC_IGNITION_CROSS_CHECK_FAULT]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:47
                    Voltage terminal 30: 12.6 V
                    Internal Fault ID: 44
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: applied
                    Status ParkingBrake right: applied
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
          [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:48
                    Internal Fault ID: 188
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
Address 55: Headlight Range
   Part No SW: 4G0 035 082 E    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0121
   Revision: AB001007    Serial number: 156J/0C7645431
   Coding: 020007010000000001
   VCID: 221DE7DCA4CD6F4AB9E-8076
02617 - Satellite Antenna (R170)
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:55
                    Voltage: 12.50 V
   Part No SW: 4G0 035 746 D    HW: 4G0 035 746 B
   Component: H-BNT-NA      H49 0622
   Revision: --------    Serial number: 194J 0C7515071
   Coding: 090200040003E1EF55128B3E00000003100001000000000000
   VCID: 2809F5F4C2F1851AE7A-807C
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDC9402R0KX
   Subsystem 3 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
00658 - Control Head
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:53
                    Voltage: 12.40 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:53
                    Bin. Bits: 00000100 00000000
                    Bin. Bits: 10000100 00000000
                    Bin. Bits: 00000000 00000000
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:58
                    Voltage: 12.40 V
01524 - Antenna for Telephone
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:59
                    Voltage: 12.40 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:52
                    Bin. Bits: 00001000 00000000
   Component: TSG HL        H03 0506
   Coding: 010F17024000628002000002
   VCID: 49CF507079BB9C12184-801C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H06---    Serial number: 525 PA8J28G9CC
   Coding: 1080013
   VCID: 2615FBCCC4E5936AD56-8072
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:45
                        Reverse OFF
                    Count: 3
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.26
                    Time: 00:30:45
                        Reverse OFF
                    Count: 3
   Part No SW: 4G8 959 107 R    HW: 4G8 959 107 G
   Component: HDSG-Modul    H13 0043
   Revision: 12013001    Serial number: 262200497 Dataset Number: 4G8909541F  0022
   Coding: 0A3305C102
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571_AU57.rod (VIN: N/A)
   VCID: 44D141445E19417AEB2-8010
   Component: TSG HR        H03 0506
Address 8F: Pretens. Frt Left
Address 90: Pretens. Frt Right
End----(Elapsed Time: 03:10, VBatt start/end: 12.5V/12.5V. VIgn 0.0V)------
------------------------------60 Faults Found------------------------------
   #85
TTT
C?ID=547002
My point of view is that you need to stick to the initial plan, which is to find why there is no comm at the ecm plug. A single failure would knock out one wire, but here both are offline, and also some other modules. My thought was that once the failure point(s) is(are) found, that it could reveal more and fix other issues at the same time. Think of water intrusion and corrosion at a harness point or in this lines.
I'm thinking TCM and ECM cannot be that far from each other, I would strip the wiring harness.
If there is continuity between gateway and ECM, it does not explain the lack of canbus activity. Cannot be, either measurements have failed or the wiring failed, one of the two.
   #86
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
I can be on board with that plan. Thank you for sticking with me. I am putting car up on jackstands to be able to get underneath to TCU plug since it’s on Mechatronics unit
   #87
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
@TTT Decided to check connectors for CANBUS on ECM and realized that the probes into back of connector were not making good contact. Swapped over to a slightly longer probe and back-probed again on pin 67,68.
This explains why there is connectivity between ECM and T17a, but also why you mentioned it can't be both, because it is not. So data signals are going TO the ECM, but not FROM the ECM, I looks like. Time for a new ECM?
Alternatively, do you know where I can find the ignition/start process as it relates to the ECM? I am trying to see if the ECM itself isn't receiving/transmitting power to appropriate pins on ECM. For instance, not power coming to Pin 10 from Comfort Control module, but is this required for start? Trying to find steps like, constant power and ground supplied with igniition on, sends 12v single to relay, which pulls to ground, then pin X sends 12 v to TCM, CCM, BCM, etc. Then signal is sent back to ecm on Pin Y and canbus lines are activated. Is there any sort of documentation like this. I have ERWIN files and access to AllData DIY for this car, so maybe there is something in there that I haven't found.
TTT
C?ID=547002
This is a odd one, so ecm has power, grounds, comms, it can close it's power relay, however, it does not talk to diag. This is odd. Unless it is missing some other wakeup canbus signal, but I doubt that. Considering there are more units not communicating, unless battery was connected backwards, I can’t see so many failing.
Are we sure the terminals are not spread, by front probing with too big pins? Such that now there is no proper connection to the ecm pins? You can do a so called drag test to see if the terminals are still tight.
However, this gets me concerned:
Terminal 15<br> 008 - Implausible Signal in multiple modules
0259 - Extended CAN Bus (SAE Bus C)<br> U0047 00 [00001001] - Performance<br> [Vehicle Communication Bus C Bus Performance]
Address 10: Park/Steer Assist<br>Cannot be reached
Address 28: HVAC, Rear<br>Cannot be reached
Address 3C: Lane Change<br>Cannot be reached
Address 55: Headlight Range<br>Cannot be reached
Address 8F: Pretens. Frt Left<br>Cannot be reached
Address 90: Pretens. Frt Right<br>Cannot be reached
I wonder what all these have in common? How do they wake up with ignition on, dedicated terminal 15 wire, or canbus message? If canbus message, which module is responsible to send it?
Ziddywerks
Northern NJ USA
C?ID=208579
I would do a can high and can low overlay and see what happens instead of wasting time trying to find the failure point. Time is money.
   #90
TTT
C?ID=547002
Pre-tensioners, power supply for left and right units it is in the trunk, right side rear fuse box ST2. F1 25A for the left one, F2 25A for the right one, both on terminal 15. Tell me, are these fuses energized with ignition on? Use test light. Could this area be water damaged? Unfortunate I cannot find electrical schematics to find what supplies these 2 fuses, which relay that is.
LE: lane change is from fuse F8 5A terminal 15 in ST4, which is in the same rear right trunk area.
LE2: parking aid is from fuse ST4 F5 5A terminal 15, which is in the same rear right trunk area.
In the rear right area, it is relay 4, J681 which is terminal 15 relay, supplying all above. It's coil has a permanent minus (brown wire) and switched plus on black wire from F1 from ST4, 5A which is supplied from ST1 SB14 which rail is supplied by relay J329 relay terminal 15 which is relay 2 in the relay box below dash.
J329 is one to focus on.
It's control coil has two wires: black/blue which is minus from module 46 Convenience System J393, plus from Fuse 1 holder D under dash panel, same with relay 2 terminal 15, which is supplied from fuse S133 battery fuse box, so this is terminal 30, permanent plus. Long story short, this coil has permanent plus and minus from J393. Is this relay clicking with ignition on??
Power side of it, it takes terminal 30 permanent plus from same fuse S133 and sends it after relay to SB ST1 fuse box.
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
What is an overlay? I temporarily connected the correct pins on t17 directly to pins on ECU with stranded copper wire (67 to 13 & 68 to 14). Would that be an overlay? Not sure what you mean by that term
   #92
Bruce
Near Philadelphia, PA, USA
You have done what he means.
Overlay = lay a wire over the one that is suspect, connecting the same points.
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
What is it's power relay? Is it the J271 Motronic Engine Control Module Power Supply Relay, right? I did notice last night Engine Component Power Supply Relay -J757- and find this relay is functional, but there is 12 v on 85 but no ground on 86, so relay isn't activating and thus no power flowing from 30 to 87. The main relay, J271 Motronic Engine Control Module Power Supply Relay, does activate
I did open up harness and gently pull these two out last night and inspect them and they fit snugly onto pin.
J329 clicks on with ignition and supplies power to SB ST1 fuse box and all fuses in that carrier. Just tested that now.
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Got ya. Yes, I did this on Saturday, but I will try again today, but since I am seeing CAN communication going to ECU pins, I am unsure what this will change.
I am looking through wiring diagrams, but really I am trying to figure out if there is a signal of some sort that triggers CANBUS for ECU to turn on, or if this is something that should be enabled earlier on in sequence like when power is received from J271 Motronic Engine Control Module Power Supply Relay. Could this all be caused by a bad ECU? Or is there another signal being missed from somewhere, possibly? Just trying to see if providing power to a specific pos or gnd feed to wake up ECU is needed.
   #95
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Looking at this now and I'll report back
UPDATE: ST 2, F1 and F2, no power. ST4 F5 or F8, no power either. In the rear right area, it is relay 4, J681 which is terminal 15 relay, is not activating which would explain why no power to LE and LE2. Did also confirm that Seatbelt modules also are supplied power from J681 Terminal 15 Power Supply Relay 2.
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
THIS CAR JUST STARTED FOR THE FIRST TIME IN OVER A YEAR! Yes, I did sh*t myself when it started, but luckily I was wearing my brown pants.
Happened to have another relay that I had bought so I tried replacing relay J681. Also, replaced Fuse in Slot 14 and 16 of Fuse Panel B since 14 looked broken inside and 16 was crusty so I used wire brush. Decided to just replace both so I ran up to Auto Zone and bought some. For anyone just joining, Fuse 16 powers Starter Relay -J53- & Starter Relay 2 -J695-. Fuse 14 powers Fuse Carrier 4 -ST4- in Fuse Panel F -SF-
If anyone wants to kick me in the head, I understand, but tracing back the fault about seatbelt tensioners is what got me to arrive at this point.
There is still plenty more things to me to fix, but this is the first MASSIVE step in a long time. Thank you to everyone that helped me with this and I have learned so very much from all of your assistance.
NOTE: Please ignore the rattle at beginning of video. Had stuff sitting on the car since I didn't actually expect it to start that was rattling. Scared me for a sec until I realized it wasn't the car making that sound!
Ziddywerks
Northern NJ USA
C?ID=208579
Awesome glad to see it running. That was the hard part the rest will be easy.
TTT
C?ID=547002
Well done, can we have another auto-scan please, after clearing all DTCs?
I still don’t understand what rear fuse box with ignition relay 2 had to do with ecm lack of comms, but tbh, I don’t care. It runs. :)
   #100
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Yes, sir! I’ll get one first thing in the morning tomorrow and post. Still got some issues with steering angle sensor, low coolant (there is a break in plastic nipple coming off radiator) and various modules that are missing but we’ll see what else pops up now. Engine didn’t explode (yet) but I also had new oil filters and Audi oil that I changed today before I dared fire it up again! 😅 Also, screen doesn’t pop out and none of the controls in middle console respond (probably related to MMI screen not opening), but that’s small potatoes now!
I’m doing a post-mortum analysis at some point of those wires and fuses to see what else was on them because I have to know or I’ll always wonder, but that’s for another day down the line! She runs!
