2013 Audi A7 doesn't crank/start.
   #41
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Thursday,01,May,2025,12:59:08:10725
VCDS Version: 25.3.1.1 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250415 DS365.0
VIN: WAU2GAFC4DN072644   License Plate:
Mileage: 146276km-90891mi   Repair Order:
Chassis Type: 4G0
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 47 52
          53 55 56 5F 62 6C 6D 72 8F 90
   Mileage: 146276km-90891miles
04-Steering Angle -- Status: Cannot be reached 0100
10-Park/Steer Assist -- Status: Cannot be reached 0100
28-HVAC, Rear -- Status: Cannot be reached 0100
3B-Sensor Elect. -- Status: Malfunction 0010
3C-Lane Change -- Status: Cannot be reached 0100
55-Headlight Range -- Status: Cannot be reached 0100
8F-Pretens. Frt Left -- Status: Cannot be reached 0100
90-Pretens. Frt Right -- Status: Cannot be reached 0100
Address 01: Engine
   Part No SW: 4G1 927 158 A    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H16 1006
   Revision: --H16---    CVN: 06AF4385
   Coding: 000002
   ROD: EV_TCMAL551211_002_AU48.rod (VIN: N/A)
   VCID: 2D0704E0ED93A03214C-8078
12544 - Power Supply Terminal 15
          P3325 00 [00100111] - Implausible
                    Fault Frequency: 25
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:34
                    Voltage terminal 30: 12.737 V
                    Transmission input speed: 0.00 /min
                    Transmission output speed: 0.00 /min
                    Engine torque: 0 Nm
                    ATF temperature: 24 °C
                    Accelerator pedal position: 14.9 %
                    M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
                    M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
                    M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Coasting
                    Engine speed: 0 /min
                    Transfer speed from ESP: 0.00 km/h
                    Transfer speed from ESP: valid
12551 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [00100110] - -
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:00
                    Voltage terminal 30: 12.830 V
                    Status data bus communication diagnostic interface-State Deashboard received: not received
                    Status data bus communication diagnostic interface-State ECM received: not received
                    Status data bus communication diagnostic interface-State ESP received: not received
                    Status data bus communication diagnostic interface-State Gateway received: not received
                    Status data bus communication diagnostic interface-State Parking Brake received: not received
                    Status data bus communication diagnostic interface-State Steering Angle received: not received
                    Status data bus communication diagnostic interface-State Steering Assist received: not received
12554 - No Communication with Engine Control Module (SAE ECM/PCM)
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:00
12561 - No Communications with Steering Angle Sender (G85)
          U0126 00 [00100111] - -
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:33
                    Voltage terminal 30: 12.740 V
12562 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [10101110] - -
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:01
                    Voltage terminal 30: 13.008 V
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 44A78F0322E5F1C05B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004028
   ROD: EV_ESPPremiAU57X_004_AU57.rod (VIN: N/A)
   VCID: 36352B8C18C5E3EA656-8062
16 Faults Found:
0067 - Function Restricted due to Missing Message(s)
          U1111 00 [10001001] - -
          [ComScl_PDU_LWI_01_Timeout]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:32
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DB
                    Uz: A3
0781 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [ComScl_PDU_LWR_AFS_01_Timeout]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:32
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DE
                    Uz: A3
0069 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [ComScl_PDU_Motor_01_Timeout]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:01
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 2F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: E3
                    Uz: A7
0071 - Function Restricted due to Missing Message(s)
          [ComScl_PDU_Motor_02_Timeout]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:01
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 2F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: F0
                    Uz: A7
0073 - Function Restricted due to Missing Message(s)
          [ComScl_PDU_Motor_03_Timeout]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:01
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 2F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: F5
                    Uz: A7
0075 - Function Restricted due to Missing Message(s)
          [ComScl_PDU_Motor_10_Timeout]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:01
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 2F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: F8
                    Uz: A7
0091 - Function Restricted due to Missing Message(s)
          [ComScl_PDU_TSK_05_Timeout]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:01
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 2F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 0C
                    Uz: A7
0486 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001000] - -
          [Ldm_ApbFailureState]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:01
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 2F
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 04
                    Uz: A7
0604 - Tire Pressure Warning
          C102D 00 [00001001] - -
                    Fault Frequency: 26
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:32
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 28
                    Uz: A3
0629 - Tire Pressure Warning
                    Fault Frequency: 26
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:32
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 2C
                    Uz: A3
0854 - Function Restriction due to Faults in Other Modules
          [SCL_GE_Uefkt_Error]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:01
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 2F
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: C9
                    Uz: A6
0838 - Function Restriction due to Faults in Other Modules
          U1113 00 [10000001] - -
          [SCL_MO_Mom_Begrenzung_Invalid]
0727 - Function Restriction due to Implausible Message(s)
          U1112 00 [10000001] - -
          [SCL_MO_Mom_Fahrerwunsch_Invalid]
0729 - Function Restriction due to Implausible Message(s)
          [SCL_MO_Mom_Verlust_Invalid]
0731 - Function Restriction due to Implausible Message(s)
          [SCL_MO_Mom_m_ex_Invalid]
0787 - Function Restriction due to Implausible Message(s)
          U1112 00 [10001001] - -
          [SCL_MO_Motormomente_Invalid]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:32
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: E6
                    Uz: A3
   Part No SW: 4H0 907 064 CR    HW: 4H0 907 064 CR
   Component: BCM2 2.0      H32 0421
   Coding: 0DAA2046000000000000
   VCID: 7BA3FAB863E7FE82DA8-802E
   Serial number: 2312000188284001
                    Fault Status: 00101101
                    Reset counter: 35
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:01
03026 - Enabling Terminal 15:
                    Fault Status: 00101001
                    Reset counter: 35
                    Mileage: 146276 km
                    Date: 2025.03.14
                    Time: 19:21:22
   Part No SW: 4G0 820 043 L    HW: 4G0 820 043 L
   Component: KLIMA 4 ZONEN H11 0062
   Serial number: 04081100040879
   Coding: 6601207A0C
   ASAM Dataset: EV_AirCondiComfoUDS 002033
   ROD: EV_AirCondiComfoUDS_002.rod (VIN: N/A)
   VCID: 2809F5F4C271851AE7A-807C
19 Faults Found:
0050 - Motor for Left Side Vent Flap
          B10C9 21 [00001000] - Signal Amplitude Too Low
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:31
                    Voltage terminal 30: 12.57 V
                    Outside temperature: 21.5 °C
                    Inside temperature: 21.21 °C
                    Left side vent motor-Act.val.: 9894
                    Left side vent motor-Specified value: 9894
                    Left side vent motor-Stop open: 11346
                    Left side vent motor-Stop closed: 10000
0194 - Position Sensor in Left Center Vent
          B10E1 15 [00001001] - Open or Short to Plus
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 23:22:35
                    Voltage terminal 30: 12.41 V
                    Terminal 15 status: Terminal 15 on
                    Supply voltage for external components: 5.00 V
0196 - Position Sensor in Right Center Vent
          B10E2 15 [00001001] - Open or Short to Plus
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 23:22:35
0243 - Function Restriction due to Faults in Other Modules
          [Steuergerät für Bordnetz: Bitte Fehlerspeicher auslesen]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:05:24
                    Voltage terminal 30: 12.08 V
                    Outside temperature: 22.0 °C
0245 - Function Restriction due to Faults in Other Modules
          [Sensor für Luftfeuchte innen: unplausibles Signal]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 00:05:14
                    Voltage terminal 30: 12.88 V
                    Outside temperature: 23.0 °C
                    Inside temperature: 25.69 °C
0260 - Function Restricted due to Missing Message(s)
          [Steuergerät für Airbag: kein Signal/keine Kommunikation]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:05:27
                    Voltage terminal 30: 12.10 V
0267 - Sensor for Refrigerant Pressure and Temperature
          B10C2 21 [00001001] - Signal Amplitude Too Low
                    Fault Frequency: 8
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 23:22:35
                    Compressor current: actual value: 0 mA
                    Outside temperature: 23.5 °C
                    Temperature downstream of evaporator: 20.94 °C
0276 - Engine Off Timer Performance
          P150A 00 [00001001] - -
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 23:22:35
0291 - Function Restricted due to Missing Message(s)
          [Sensor für Luftgüte: kein Signal / Kommunikation]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:05:26
0314 - Function Restricted due to Missing Message(s)
          [Sensor für Luftfeuchte aussen: kein Signal / Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 23:22:35
0315 - Function Restricted due to Missing Message(s)
          [Sensor für Luftfeuchte innen: kein Signal / Kommunikation]
                    Fault Frequency: 19
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 23:22:35
0317 - Function Restricted due to Missing Message(s)
          [Steuergerät für Klima hinten: kein Signal / Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 23:22:35
0331 - Function Restricted due to Missing Message(s)
          [Motorsteuergerät: kein Signal/Kommunikation]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:03
                    Voltage terminal 30: 12.92 V
0369 - Function Restricted due to Missing Message(s)
          [Steuergerät für Spurhalteassistent: kein Signal / Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 23:22:35
0387 - Function Restriction due to Faults in Other Modules
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:05:24
0392 - Function Restriction due to Faults in Other Modules
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 00:05:14
0400 - Function Restriction due to Faults in Other Modules
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 00:05:14
0401 - Function Restriction due to Faults in Other Modules
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 00:05:14
15360768 - Component Protection
          U1101 00 [00001001] - Active
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 23:22:35
                    Component protection: 33
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001455986
   Coding: 0200E011163C9FE0C1008884A0003928CF9CD208A6080225800008406000
   Shop #: WSC 12345 123 61029
   VCID: 6FBBDEE8279F9222660-803A
   Component: WWS57X 120912  H36 0080
   Serial number:         120924234600
   Coding: 0045F7
   Serial number: 20651292
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 02 10 2012  00000362
   Subsystem 4 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0040535061
   Coding: 853000
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA104148000001943496
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 44580E46000000000001
9 Faults Found:
00576 - Terminal 15
                    Fault Status: 01101000
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:00
                    Fault Status: 01101101
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:06:00
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:05:00
02258 - Door Opener Transmitter
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:00
01229 - A/C Humidity Sensor (G260)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:00
03608 - Humidity Sensor in Fresh Air Intake Duct
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:05:00
                    Fault Status: 00100101
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:05:00
03725 - Control Module for Seat Belt Tensioner; Left Front
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:00
Address 10: Park/Steer Assist
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D8002FL1K Dataset Number: 4G8909602D  0004
   Coding: 303145313131303030314A55304C34473853
   ROD: EV_AirbaAU10BPAAU64X_VW51.rod (VIN: N/A)
   VCID: 333312980BB7F6C2428-8066
   Serial number: 6940000Y150001ER7M01
   Serial number: 3575HRB405D1HGMQ915M
   Serial number: 3585HRB40571HGMQCP1/
   Serial number: 3515JRB401C4UN9OI1VD
   Serial number: 3525JRB405D1MFU46GQ%
   Serial number: 3554VRB400K4UNK88PR/
   Serial number: 3564VRB400G4UNK86H55
1050112 - Databus
          [CAN: 0x086 LWI_01 Timeout]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:33
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20121012001065
   Coding: 000034
   VCID: 30391D94FA21CDDA3FA-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
00576 - Terminal 15
                    Fault Frequency: 25
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:29
   Part No SW: 4G8 920 983 E    HW: 4G8 920 983 E
   Component: TBenUsa       H79 0515
   Revision: 28460207    Serial number: 658111012592017
   Coding: 03E701060B43D705020100
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod (VIN: N/A)
   VCID: 372B26881FCF1AE27E0-8062
16776970 - Function Restricted due to Missing Message(s)
          [LWR_AFS_01 keine Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:31
16776971 - Function Restricted due to Missing Message(s)
          [Motor_03 keine Kommunikation]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:03
1048580 - Button for Trip Odometer Reset
          B11FE 13 [00001001] - Open Circuit
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:31
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000719062 Dataset Number: 4G8909515D  0059
   Coding: 00CD073000
   GVL: FDA1E84CFE63600D0000
   ASAM Dataset: EV_GatewPkoUDS 001018
   ROD: EV_GatewPkoUDS_001_AU57.rod (VIN: N/A)
   VCID: 71BFD890312B84D2704-8024
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790310195
   Voltage stabilizer:
   Serial number: 180417000000000000CC
13 Faults Found:
5088 - Rear A/C control module
          U1072 00 [00001001] - No communication
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:31
                    Voltage terminal 30: 12.6 V
                    Voltage terminal 15: 12.6 V
                    Control Module temperature: 27 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [00001000] - -
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:00
                    Voltage terminal 30: 13.0 V
                    Voltage terminal 15: 13.0 V
                    Control Module temperature: 20 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
4230 - No Communications with Steering Angle Sender (G85)
          U0126 00 [00001001] - -
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:31
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
4160 - No Communications with Airbag Control Module
          U0151 00 [00001000] - -
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:05:21
                    Voltage terminal 30: 12.0 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 26 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: OFF
                    Datenfeld: 0
5013 - Headlight Range Control Module
          U101E 00 [00001001] - No Communication
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:31
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5271 - No Communications with Parking Assist Control Module A
          U0159 00 [00001001] - -
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:31
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
4228 - No Communication with ABS Brake Control Module
          U0121 00 [00001000] - -
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:05:20
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
4879 - Lane change assistant control module
          U1045 00 [00001001] - No communication
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:31
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5080 - Front Left belt tensioner control module
          U107C 00 [00001001] - No communication
          [Steuergerät für RGS Links Keine Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:31
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5081 - Front Right belt tensioner control module
          U107D 00 [00001001] - No communication
          [Steuergerät für RGS Rechts Keine Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:31
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0259 - Extended CAN Bus (SAE Bus C)
          U0047 00 [00001001] - Performance
          [Vehicle Communication Bus C Bus Performance]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:31
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Fault Frequency: 11
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:31
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0019 - Terminal 15
          U1405 00 [00001000] - Implausible signal
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:05:21
                    Voltage terminal 30: 12.1 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
Address 28: HVAC, Rear
   Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000039194743
   Coding: C0581B008F006001000001010101102030303232203232
   VCID: 382925B41251159A77A-806C
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:03
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:05:22
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H02 0053
   Revision: --------    Serial number: EJ1BPA8201GNLM Dataset Number: 4G8909573A  0001
   ASAM Dataset: EV_SARA2 005011
   ROD: EV_SARA2.rod (VIN: N/A)
3801600 - Terminal 15
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:05:20
                    DCU_Internal_DTC: 3A 02 00
                    Ignition Cycle Count: 32571
                    DCU Temperature: 22 °C
                    Voltage VBG 22: 2.5 V
                    Debug Data: 00 00 00 00 00 00 00 00
Address 3C: Lane Change
   Component: TSG FA        H03 0506
   Coding: 011F57025E00628002000412
   VCID: 47CB56486FAF6A620E0-8012
                    Fault Frequency: 25
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:29
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:05
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0007945176 Dataset Number: 4G8909852J  0028
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod (VIN: N/A)
   VCID: 323D179CF4ADFFCA49E-8066
3158274 - Function Restricted due to Missing Message(s)
          [Ausfall Botschaft "PDU_Motor_03"]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:03
                    2.42 V
3158276 - Function Restricted due to Missing Message(s)
          [Ausfall Botschaft "PDU_LWI_01"]
                    Fault Frequency: 25
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:32
                    2.42 V
4208000 - Steering Angle Sensor
          B1168 F1 [00001000] - Synchronization Failed
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:02
                    112.50 °
15888 - Terminal 15
          [Unplausibles Klemme 15 (Zündungssignal)]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:05:24
   Revision: 00002001    Serial number: 0185437806
   Coding: 0126063A20FAF08580B00A84020102070000000000000000000000000000
   Subsystem 2 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO1853955A
   Coding: 101F00
   Subsystem 3 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00002421657
   Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0028
   Serial number: WA104224000002081655
12 Faults Found:
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 23:20:16
                    Fault Frequency: 26
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 23:20:16
03616 - Rear Left Reading Light
                    Fault Status: 01101100
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 23:20:20
03615 - Rear Right Reading Light
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 23:20:20
            014 - Defective
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 23:20:20
03233 - Controls for Garage Door Opener (E284)
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 23:20:20
                    Reset counter: 35
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:05:22
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
                    Fault Status: 00101011
                    Reset counter: 35
                    Mileage: 146276 km
                    Date: 2025.03.14
                    Time: 19:14:27
01403 - Glass-Break Sensors; Rear
                    Reset counter: 35
                    Mileage: 146276 km
                    Date: 2025.03.14
                    Time: 19:14:27
                    Reset counter: 35
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:05:20
01503 - Bulb for 3rd Brake Light (M25)
                    Fault Status: 00101100
                    Reset counter: 35
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:05:21
00165 - Switch for Transmission Position P/N
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:05:21
   Revision: CJ007001    Serial number: 00000000009943
   Coding: 030000
   Shop #: WSC 06745 128 28888
   VCID: 1D67D4209DB350B284C-8048
   Component: TSG BF        H03 0506
   Coding: 011F57025E00628002000402
   VCID: 46D55B4C68A5736AF56-8012
                    Fault Frequency: 25
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:29
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:05
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000504125 Dataset Number: 4G8909522A  0002
   ROD: EV_ParkiBrake_VW51.rod (VIN: N/A)
   VCID: 2B030AF8D387AE020A8-807E
9 Faults Found:
10613248 - Terminal 15
          U1405 00 [10001001] - Implausible signal
          [FC_IGNITION_CROSS_CHECK_FAULT]
                    Fault Frequency: 25
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:31
                    Voltage terminal 30: 12.7 V
                    Internal Fault ID: 44
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: applied
                    Status ParkingBrake right: applied
333568 - Function Restricted due to Missing Message(s)
          [FC_TSK_05_MESSAGE_TIMEOUT]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:00
                    Voltage terminal 30: 12.9 V
                    Internal Fault ID: 49
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
334080 - Function Restricted due to Missing Message(s)
          [FC_MOTOR_02_MESSAGE_TIMEOUT]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:00
                    Internal Fault ID: 51
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
333312 - Function Restricted due to Missing Message(s)
          [FC_AIRBAG_02_MESSAGE_TIMEOUT]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:05:21
                    Internal Fault ID: 87
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
331264 - Function Restricted due to Missing Message(s)
          [FC_MOTOR_01_MESSAGE_TIMEOUT]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:00
                    Internal Fault ID: 99
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
331520 - Function Restricted due to Missing Message(s)
          [FC_MOTOR_03_MESSAGE_TIMEOUT]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:00
                    Internal Fault ID: 100
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
331776 - Function Restricted due to Missing Message(s)
          [FC_MOTOR_CODE_01_MESSAGE_TIMEOUT]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:00
                    Internal Fault ID: 101
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
460800 - Function Restriction due to Faults in Other Modules
          [FC_SIGNAL_GE_UEFKT_ERROR_VALUE]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:01
                    Internal Fault ID: 144
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
          [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:31
                    Internal Fault ID: 188
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
Address 55: Headlight Range
   Part No SW: 4G0 035 082 E    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0121
   Revision: AB001007    Serial number: 156J/0C7645431
   Coding: 020007010000000001
   VCID: 221DE7DCA4CD6F4AB9E-8076
02617 - Satellite Antenna (R170)
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:39
                    Voltage: 12.70 V
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:16
                    Bin. Bits: 00000000 00001000
   Part No SW: 4G0 035 746 D    HW: 4G0 035 746 B
   Component: H-BNT-NA      H49 0622
   Revision: --------    Serial number: 194J 0C7515071
   Coding: 090200040003E1EF55128B3E00000003100001000000000000
   VCID: 2809F5F4C2F1851AE7A-807C
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDC9402R0KX
   Subsystem 3 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
00658 - Control Head
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:32
                    Voltage: 12.60 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 23:33:51
                    Voltage: 13.00 V
                    Bin. Bits:      001
                    Fault Frequency: 9
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.17
                    Time: 19:01:33
                    Bin. Bits: 00000100 00000000
                    Bin. Bits: 10000100 00000000
                    Bin. Bits: 00000000 00000000
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:42
                    Voltage: 12.60 V
01524 - Antenna for Telephone
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:42
                    Voltage: 12.60 V
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2025.03.13
                    Time: 20:09:22
                    Bin. Bits: 00011000 00000000
                    Bin. Bits: 00000000 00010000
   Component: TSG HL        H03 0506
   Coding: 010F17024000628002000002
   VCID: 49CF507079BB9C12184-801C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H06---    Serial number: 525 PA8J28G9CC
   Coding: 1080013
   VCID: 2615FBCCC4E5936AD56-8072
01327 - Control Module for Parking Aid (J446)
                    Fault Frequency: 29
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:29
                        Reverse OFF
                    Count: 3
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.12
                    Time: 22:57:29
                        Reverse OFF
                    Count: 3
   Part No SW: 4G8 959 107 R    HW: 4G8 959 107 G
   Component: HDSG-Modul    H13 0043
   Revision: 12013001    Serial number: 262200497 Dataset Number: 4G8909541F  0022
   Coding: 0A3305C102
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571_AU57.rod (VIN: N/A)
   VCID: 44D141445E19417AEB2-8010
Address 72: Door, Rear Right
Address 8F: Pretens. Frt Left
Address 90: Pretens. Frt Right
End----(Elapsed Time: 02:55, VBatt start/end: 12.1V/12.1V. VIgn 0.0V)------
-----------------------------111 Faults Found------------------------------
   #42
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Posting new scan after removing 12v to Pin 10 of ECM and clearing faults in Acc/Start Auth. (J393) related to "Open or Short to ground"
Saturday,03,May,2025,14:19:00:10725
Mileage: 146276km-90891mi   Repair Order: 5
Chassis Type: 4G0
Address 01: Engine
   Coding: 000002
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:22
                    Voltage terminal 30: 12.101 V
                    Engine torque: 0 Nm
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:20
9 Faults Found:
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:19
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DB
                    Uz: 9B
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:19
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DE
                    Uz: 9B
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:19
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 28
                    Uz: 9B
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:19
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 2C
                    Uz: 9B
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:19
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: E6
                    Uz: 9B
   Coding: 6601207A0C
9 Faults Found:
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:18
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:18
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:18
                    Outside temperature: 24.0 °C
                    Temperature downstream of evaporator: 20.49 °C
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:18
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:18
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:18
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:18
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:18
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:18
   Coding: 0045F7
   Coding: 02006E
   Coding: 853000
   Coding: 020300
7 Faults Found:
00576 - Terminal 15
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:00
            014 - Defective
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:00
1050112 - Databus
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:20
   Coding: 000034
00576 - Terminal 15
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:16
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:18
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:18
   Coding: 00CD073000
   Voltage stabilizer:
9 Faults Found:
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:19
                    Voltage terminal 15: 12.0 V
                    Control Module temperature: 32 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:19
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:19
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:19
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:19
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:19
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:19
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:19
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:19
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:16
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:19
                    2.42 V
   Coding: 101F00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:16
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:16
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:20
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:20
            014 - Defective
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:20
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:20
   Coding: 030000
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:16
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:18
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:19
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:26
                    Voltage: 12.00 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:21
                    Voltage: 11.90 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:24
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:29
                    Voltage: 11.90 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:23
                    Bin. Bits: 00001000 00000000
   Coding: 1080013
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:16
                        Reverse OFF
                    Count: 3
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:28:16
                        Reverse OFF
                    Count: 3
   Coding: 0A3305C102
   Component: TSG HR        H03 0506
End----(Elapsed Time: 02:45, VBatt start/end: 12.1V/12.1V. VIgn 0.0V)------
------------------------------58 Faults Found------------------------------
Address 09: DTCs cleared
Address 0x19,4G0 907 468 AC,UDS Selective Output Tests,
Chassis Type: 4G0
Address 01: Engine
   Coding: 000002
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:31
                    Voltage terminal 30: 12.099 V
                    Engine torque: 0 Nm
                    ATF temperature: 25 °C
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:29
                    Voltage terminal 30: 12.103 V
9 Faults Found:
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:28
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DB
                    Uz: 9B
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:28
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DE
                    Uz: 9B
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:28
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 28
                    Uz: 9B
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:28
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 2C
                    Uz: 9B
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:28
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: E6
                    Uz: 9B
   Coding: 6601207A0C
9 Faults Found:
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:28
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:28
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:28
                    Temperature downstream of evaporator: 20.93 °C
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:27
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:27
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:27
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:27
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:27
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:27
   Coding: 0045F7
   Coding: 02006E
   Coding: 853000
   Coding: 020300
7 Faults Found:
00576 - Terminal 15
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:00
            014 - Defective
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:00
1050112 - Databus
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:30
   Coding: 000034
00576 - Terminal 15
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:25
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:28
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:27
   Coding: 00CD073000
   Voltage stabilizer:
9 Faults Found:
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:27
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:27
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:27
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:27
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:27
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:27
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:27
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:27
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:27
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:25
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:28
                    2.42 V
   Coding: 101F00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:29
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:29
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:25
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:25
            014 - Defective
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:29
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:29
   Coding: 030000
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:25
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:27
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:28
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:35
                    Voltage: 12.10 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:32
                    Voltage: 11.90 V
                    Fault Frequency: 17
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:44
                    Bin. Bits: 10111111 10000010
                    Bin. Bits: 10000100 10011111
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:38
                    Voltage: 11.90 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:38
                    Voltage: 11.90 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:32
                    Bin. Bits: 00001000 00010000
   Coding: 1080013
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:25
                        Reverse OFF
                    Count: 3
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2025.03.19
                    Time: 20:57:25
                        Reverse OFF
                    Count: 3
   Coding: 0A3305C102
End----(Elapsed Time: 02:51, VBatt start/end: 12.1V/12.1V. VIgn 0.0V)------
------------------------------59 Faults Found------------------------------
TTT
C?ID=547002
IDE channels and micro probes, wtf, this was a 2h job maximum.
Write text all power feeds and minus, by plug number and pin number, wiring color and cross section that you could find in schematics, for engine computer.
Lets check your works so far. Put all wires back where they belong.
   #44
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Sounds like a plan! I'll start taking measurements now
   #45
TTT
C?ID=547002
Tell me for testing you use test lamp with incandescent lamp. No led, no voltmeter.
   #46
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
I don’t have one of those, but you’re saying I should be testing for any specific voltage to get a measurement then? Just see if it has 12v only. I can pick up a test light with incandescent bulb, but why would I test with that vs multimeter or led test light?
   #47
TTT
C?ID=547002
Because circuits need to be able to carry load (amps). Voltmeters don’t check that. Any green crusty wiring will show perfect volt readings but will be unable to carry amps.
Yoy have to trust me for now! Incandescent test lamp or any form of home made bulb 5-15W on two wires.
   #48
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
I trust you. Heading to store already. I was just curious so I wanted to ask
   #49
Ziddywerks
Northern NJ USA
C?ID=208579
It been verified that BCM2 is not sending out terminal 15 to the ecm. However using a jumper wire still no comms to ecm. So either the test or jumper was not done correctly or there is a communication issue with gateway or wiring in my opinion.
   #50
TTT
C?ID=547002
After about a year, this needs to start from the beginning, especially that testing was not done correctly.
   #51
Dr Sheldon
Windsor UK
C?ID=334979
From what I see, OP seems out of his comfort zone here. Clearly again and again certain tests are suggested and he goes on his merry way doing something different and often irrelevant.
I get the feeling that this, if had any chance of being resolved with OP as the Pilot, would have been resolved by now. However this is going backwards.
So yes !! This needs to start again.
   #52
TTT
C?ID=547002
If anyone was in their comfort zone, this forum would of not existed.
Life is simple, if tests are not done like I say, I move on with life, my time is limited. When I will not know further, I will say so, so I will not waste time of others.
To countercheck, I need to know the engine code and which type of A7 this is.
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
You are 100% correct that I’m out of my comfort zone so this is why I tried to follow the tests suggested to the letter. Just bought Picoscope since I couldn’t trust the used Rigol scope and probes and had difficulty compensating it. Read through countless wiring diagrams and purchase AllData to ease checking of items. Bought Power Probe 3 Master kit that arrived yesterday as well. I have tried and listened to suggestions and what one person might consider as going backwards, another person considers getting back to the basics. I will go back through the thread now that I have scope that I can trust and see what tests I didn’t perform before and attempt them again. This car hasn’t been a high priority since we have other cars so I’m just getting back to it now that my wife needs a vehicle and I’d like to get rid of a couple of our other cars. Trust me when I say that I am TRYING to resolve this and haven’t “gone on my merry way” with anything. I just was overwhelmed at first and over complicated things. Possibly part of my autism, but I am trying hard to focus on single items and slowly getting the tools required so I can do the tests properly 😆
   #54
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Engine code is CTUA and A7 Quattro Sportback Prestige. Also, I’m doing the test you asked for today after work so I am definitely doing what you ask so I’m not wasting your time
Reactions: TTT
   #55
TTT
C?ID=547002
After studying the schematics a bit, I think I am ready with the diagnostics, waiting some feedback from your side, before going straight to the concerned area.
   #56
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
@TTT Just to be clear, you want me to use the test light and check each pin on ECU for power with Ignition on, correct? Pin lights up, mark as "Lights: Yes". Pin doesn't light, "Lights: No". Did i get that right? Each connector, each pin
Here are my findings in a Google Sheets
ECU wires w/ test light
Reactions: TTT
   #57
Ziddywerks
Northern NJ USA
C?ID=208579
I am begining to think this is a communication issue more than anything else.
   #58
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
I am thinking you might be right since I noticed almost zero (0.006) voltage with my multimeter last night on orange wires (pin 67 & 68). Moving to gateway module to see if there is any activity on the pins there for ECU or TCU
   #59
Ziddywerks
Northern NJ USA
C?ID=208579
I wonder if this vehicle has a can break connector on the side of the dash somewhere thats missing.
   #60
TTT
C?ID=547002
Patience :rolleyes:, I'm on a different time zone, looking into it now.
LE: how do I have to read the excel? Columns A and D indicates where the test light has lit? And which one were checked against minus and which one against plus? Because 1, 2 and 4 are minus and there is N indicated, which I would read that it did not turn the test lamp ON, against battery plus. Is this the way to read it?
