In a Kessy car, with the ECU off-line?Does the starter click? or make any noise?
hatSorry didnt scroll through the log. Log showed malfunction but then when i scroll down it said cannot be reached. I didn't see that. In this case start with basics powers and grounds at module.In a Kessy car, with the ECU off-line?
Sorry, I debated posting in thread or messaging you, but checking the IDE connect to ECM and TCM from gateway would involve probing the pin at gateway with scope and checking for activity, yes? Then, If I'm getting it there, you're saying to check at ECM and TCM for power and, if none, then follow diagram to see where power is coming from?I would be checking can communication status to ecm and tcm via gateway ide channel. 0 is no good 1 is ok. IF no comms I would be checking power and ground to ecm and tcm or following diagram to see where 15 power comes from. I will assume most likely comfort module, access start or central electrics. This is where I would start this would be easier in my opinion.
No viewing IDE channel in the gateway module the module can tell you if the module your looking for is talking to the gateway or not. No probing involved just a laptop and VCDS and a few key strokes. IF IDE channel shows 0 then module is not talking to gateway if 1 is show communication is ok. If zero then you need to check power and ground at affected module or find where power is coming from then looking at fuses and so on.Sorry, I debated posting in thread or messaging you, but checking the IDE connect to ECM and TCM from gateway would involve probing the pin at gateway with scope and checking for activity, yes? Then, If I'm getting it there, you're saying to check at ECM and TCM for power and, if none, then follow diagram to see where power is coming from?
Sorry for some many questions, but I am trying to make sure I'm doing things right and not testing the wrong thing and getting a false positive.
In the wiring diagram, they are listed as J217 and J623 and are both Orange and Brown wires that look to be a welded connection down the line, but both come off Pin 5, so that would be your first spot to check?
Ah, IDE. Not sure what IDE I'm looking for or how to get there. Did I do this correctly?No viewing IDE channel in the gateway module the module can tell you if the module your looking for is talking to the gateway or not. No probing involved just a laptop and VCDS and a few key strokes. IF IDE channel shows 0 then module is not talking to gateway if 1 is show communication is ok. If zero then you need to check power and ground at affected module or find where power is coming from then looking at fuses and so on.
;SW:4G0-907-468-AC HW:4G0-907-468-AC --- CAN Gateway
;Component:J533--Gateway H12 0037, Coding:00CD073000
;EV_GatewPkoUDS,001018,EV_GatewPkoUDS_001_AU57.rod
;Tuesday,09,July,2024,19:21:36:10725
;VCDS Version: Release 24.5.0 (x64) Data version: 20240429 DS355.0
;VCID: 71BFD890312B84D2A8D-8024
Group,Description,Actual
IDE00018,Voltage terminal 15,12.3, V
IDE00019,Voltage terminal 30,12.3, V
IDE00056,History data 1,||2024-06-13-03:44*00.2*02*02853***
2024-06-12-15:08*03.7*02**
2024-06-12-04:44*01.8*02**
2024-06-12-02:05*04.7*02**
2024-06-07-19:41*09.2*02**
2024-06-06-19:22*01.6*02**
2024-06-06-16:58*18.2*02**
2024-06-12-15:08*00.0*02*00797***
2024-06-12-02:05*00.3*02**
2024-06-11-20:21*00.5*02**
2024-06-11-16:16*17.5*02**
2024-06-10-22:46*01.9*02**
2024-06-10-20:47*02.3*02**
2024-06-10-18:07*21.3*02**
2024-04-05-16:29*00.5*02*00946***
2024-04-05-15:33*15.4*02**
2024-03-19-07:19*00.0*02**
2024-03-19-07:13*00.0*02**
2024-03-19-07:08*00.0*02**
2024-03-19-07:03*00.0*02**
2024-03-19-06:58*00.0*02**|,
IDE00057,History data 2,||2024-03-18-17:20*0016*049*-00.19*0-0-0-0-0-0*0*02*00028**
2024-01-29-23:24*0009*000*-00.21*0-0-0-0-0-0*0*02**
2023-03-24-18:36*0001*025*-01.84*0-0-0-0-0-0*0*02**
2012-12-15-10:29*0002*019*-00.33*0-0-1-0-0-0*0*02**
2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00**
2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00**|,
IDE00058,History data 3,||2024-04-05-16:48*3*0*000*000*-07.22*0-0-0-0-0-0*0*0*00.3*00.4**
2024-04-05-16:39*2*0*001*000*-14.96*0-0-1-0-0-0*0*0*00.2*00.3**
2024-04-05-16:36*1*0*002*000*-15.04*0-0-1-0-0-0*0*0*00.1*00.2**
2024-04-05-16:32*3*0*003*000*-08.95*0-0-0-0-0-0*0*0*00.1*00.2**
2024-04-05-16:30*1*0*003*000*-14.46*0-0-1-0-0-0*0*0*00.1*00.1**
2024-04-05-15:54*3*0*004*000*-07.79*0-0-0-0-0-0*0*0*00.1*00.1**
2024-04-05-15:50*2*0*005*000*-14.34*0-0-1-0-0-0*0*0*00.0*00.0**
2024-04-05-15:47*1*0*006*000*-14.61*0-0-1-0-0-0*0*0*00.0*00.0**
2024-04-05-15:45*3*0*006*000*-07.75*0-0-0-0-0-0*0*0*00.0*00.0**
2024-04-05-15:45*1*0*007*000*-09.15*0-0-0-0-0-0*0*0*00.0*00.0**
2024-04-05-15:43*1*0*007*000*-14.38*0-0-1-0-0-0*0*0*00.8*00.9**
2024-04-05-15:35*3*0*008*000*-06.79*0-0-0-0-0-0*1*0*00.8*00.9**
2024-04-05-15:34*1*0*008*000*-08.89*0-0-0-0-0-0*0*0*00.8*00.9**
2024-04-04-23:19*3*0*009*000*-08.29*0-0-0-0-0-0*0*0*00.8*00.8**
2024-04-04-23:19*1*0*009*000*-09.47*0-0-0-0-0-0*0*0*00.8*00.8**|,
IDE00059,History data 4,||2020-03-12-00:07*02*105*VAO*AO12345678*09500*05689*0020*0000*0000**
2012-10-22-21:34*01*105*JCB*221016G0BX*09500*11233*0023*0000*0000**
2000-01-01-00:00*00*---*---*----------*09999*00000*0000*0000*0000**
2000-01-01-00:00*00*---*---*----------*00000*00000*0000*0000*0000**
2000-01-01-00:00*00*---*---*----------*00000*00000*0000*0000*0000**|,
IDE00060,History data 5,||2024-01-30-19:26*-00.21*-02.32*-09.56*11.54*001*07*-22.6*05380*09500*146277*0-0-0-0-0-0*0*00.9*01.4*008.9*33*02*05**
2023-08-02-00:00*+00.00*-05.33*-09.53*12.55*100*02*+00.2*03640*09592*137506*0-0-0-0-0-0*0*00.0*00.0*000.0*01*00*04**
2023-01-05-00:00*-00.25*-00.62*-09.43*12.16*100*02*-01.4*01945*09701*125204*0-0-0-0-0-0*0*00.0*00.0*001.4*03*00*03**
2022-12-18-00:00*-00.02*-00.05*-10.69*11.94*100*02*-02.6*01917*09701*125140*0-0-0-0-0-0*0*00.0*00.0*047.5*06*01*02**
2022-11-29-00:00*-00.08*-00.22*-09.19*11.98*100*02*-00.8*01883*09703*125098*0-0-0-0-0-0*0*00.0*00.0*005.4*05*00*01**|,
IDE00061,History data 6,||2024-06-14-00:01*051*+21*-000.1*00.00**
2024-06-14-00:00*044*+24*-000.1*00.00**
2024-06-14-00:00*045*+25*-000.1*00.00**
2024-06-14-14:40*058*+23*-000.1*00.00**
2024-06-12-22:23*038*+24*-000.1*00.00**
2024-06-12-22:22*038*+24*-000.1*00.00**
2024-06-12-20:47*051*+24*-000.1*00.00**
2024-06-12-20:46*050*+24*-000.1*00.00**
2024-06-12-18:49*044*+25*-000.1*00.00**
2024-06-12-18:48*047*+25*-000.1*00.00**
2024-06-12-18:11*045*+25*-000.3*00.00**
2024-06-12-18:11*047*+25*-000.1*00.00**
2024-06-12-15:15*044*+27*-000.1*00.00**
2024-06-12-15:14*045*+27*-000.1*00.00**
2024-06-12-06:12*032*+40*-000.1*00.00**
2024-06-12-06:11*033*+40*-000.1*00.00**
2024-06-12-06:11*034*+40*-000.1*00.00**
2024-06-12-05:03*037*+40*-000.1*00.00**
2024-06-12-05:00*041*+40*-000.1*00.00**
2024-06-12-04:58*042*+40*-000.1*00.00**|,
IDE00062,History data 7,||2024-06-14-19:24*058*-006.7*003.2*00.3*00.2**
2024-06-14-00:01*059*-002.5*019.5*00.0*00.0**
2024-06-14-01:04*050*+002.2*000.4*00.0*00.0**
2024-06-14-00:01*057*-002.1*001.0*00.1*00.0**
2024-06-14-22:23*042*+002.0*000.5*00.0*00.0**
2024-06-14-00:01*057*-010.6*022.4*00.6*00.1**
2024-06-14-14:41*039*-008.5*007.5*00.3*00.1**
2024-06-12-22:23*058*-040.6*040.8*02.0*00.8**
2024-06-12-21:12*038*-008.6*001.1*00.5*00.4**
2024-06-12-20:47*049*-000.9*000.3*00.0*00.0**
2024-06-12-20:46*050*-000.1*000.0*00.0*00.0**
2024-06-12-18:49*050*-003.3*001.9*00.1*00.1**
2024-06-12-18:12*047*-001.8*000.6*00.0*00.0**
2024-06-12-18:11*047*-000.1*000.0*00.0*00.0**
2024-06-12-15:15*050*-002.5*002.9*00.1*00.0**
2024-06-12-15:14*046*-000.1*000.0*00.0*00.0**
2024-06-12-06:12*046*-004.8*009.0*00.3*00.0**
2024-06-12-05:04*033*-003.7*001.1*00.3*00.0**
2024-06-12-05:03*037*-000.1*000.0*00.0*00.0**
2024-06-12-05:00*036*-001.1*000.0*00.0*00.0**|,
IDE00063,History data 8,||2024-06-15-21:54*1*51*00*00*20*25*2000-01-01-00:00*02**
2024-06-15-18:06*1*50*00*00*20*25*2000-01-01-00:00*02**
2024-06-15-15:42*1*49*00*00*20*25*2000-01-01-00:00*02**
2024-06-14-23:11*1*48*00*00*20*25*2000-01-01-00:00*02**
2024-06-14-21:43*1*47*00*00*20*25*2000-01-01-00:00*02**|,
IDE00064,History data 9,||2020-03-12-00:07*043*019*082*027*00000*12.50*+21*02*12.70*00000*00000**
2024-05-24-16:57*070*080*069*039*05523*12.40*+29*02*12.70*00263*00565**
2024-04-15-20:09*070*080*090*054*05502*12.70*+26*02*12.70*00263*00565**
2024-03-14-10:39*070*080*000*000*05402*11.40*+08*02*03.05*00258*00565**
2024-01-25-09:06*062*072*057*026*05091*12.20*+21*02*03.05*00253*00549**
2023-12-29-09:04*064*073*071*031*04835*12.40*+08*02*02.95*00251*00549**
2023-12-01-00:29*066*074*078*040*04678*12.50*+15*02*03.00*00248*00549**
2023-11-04-15:58*070*081*080*047*04334*12.50*+27*02*02.85*00197*00407**
2023-10-07-15:36*074*081*076*047*04101*12.50*+41*02*02.85*00187*00381**
2023-09-11-15:25*077*080*072*045*03939*12.40*+34*02*02.85*00185*00381**
2023-08-14-09:08*079*082*058*036*03766*12.20*+33*02*02.70*00182*00381**
2023-07-18-09:01*078*082*073*047*03492*12.40*+35*02*02.75*00177*00381**|,
IDE00065,History data 10,||2023-08-14-11:39*1*000.5*0*000.0*0*000.0*00.00**
2023-08-11-18:37*1*000.1*1*004.8*0*000.0*00.15**
2022-04-05-22:20*0*000.4*0*000.0*0*000.0*00.46**
2022-04-05-22:20*0*000.5*0*000.0*0*000.0*00.45**
2022-04-05-22:18*0*001.2*0*000.0*0*000.0*00.43**
2000-01-01-00:00*0*0*0*00.00**
2023-08-11-18:42*2*004.8*00.15**
2000-01-01-00:00*0*000.0*00.00**
2023-03-23-12:14*02*15.00*14.85*12.80**
2023-01-05-00:11*01*15.00*14.89*10.00**
2000-01-01-00:00*00*00.00*00.00*00.00**
2000-01-01-00:00*00*00.00*00.00*00.00**|,
IDE00066,History data 11,||2024-01-29-09:58*000*000*013*000*0097*053*00.2*00.5*081*046*090*054*01*00131*00269*00139*00390*00802**
2024-01-28-23:16*000*000*013*000*0075*042*00.2*00.4*084*049*091*055*01**
2024-01-28-17:06*000*000*000*000*0000*000*00.0*00.1*091*052*091*052*01**
2024-01-28-17:03*000*000*001*000*0001*001*00.0*00.3*092*052*092*052*01**
2024-01-28-16:21*000*000*026*000*0132*084*00.3*00.9*085*048*093*053*01**
2024-01-28-12:34*000*000*004*000*0030*046*00.0*00.4*064*035*091*051*01**
2024-01-28-07:31*000*000*064*000*0831*104*01.1*02.0*087*050*094*055*01**
2024-01-27-21:39*000*000*072*000*1027*149*00.9*04.2*093*060*095*059*03**
2024-01-26-19:21*000*000*000*000*0000*000*00.0*00.0*089*054*089*054*00**
2024-01-26-19:04*000*000*010*001*0116*037*00.4*01.3*089*054*089*054*06**|,
IDE00067,History data 12,||2024-03-18-08:54*2*060*029*+16*01*+30.0*-01.2*11.9*0**
2023-09-26-17:56*2*059*028*+34*02*+30.0*+07.5*12.8*1**
2023-09-23-17:24*2*060*032*+33*01*+30.0*-05.4*11.9*1**
2023-08-07-20:05*2*059*034*+53*01*+30.0*+03.8*12.7*1**
2023-06-24-11:49*2*059*023*+35*02*+30.0*+02.2*12.2*1**
00000*00031*00000**|,
IDE00068,History data 13,||2023-08-11-18:40*0-1-0-0-0*000.1*00001**
2000-01-01-00:00*0-0-0-0-0*000.0**
2000-01-01-00:00*0-0-0-0-0*000.0**|,
IDE00069,History data 14,||2000-01-01-00:00*00*---*---*----------*00000*00000**
2000-01-01-00:00*0*00*00*00*00*00**
00000*00000*00000**
2024-01-28-13:07*0-0-0-0-1-0-0-0**
2024-01-27-21:39*0-0-0-0-1-0-0-0**
00000*00000*00000*00094*00000*00000*00000*00000**
2000-01-01-00:00*0*000*000*00*00000*00000**
00000*00000*00000**|,
IDE00070,History data 15,||2000-01-01-00:00*000*00*00*000*00*00*000*00*00**
2000-01-01-00:00*000*00*00*000*00*00*000*00*00**|,
IDE00071,History data 16,||146276**
00094*00886*02971*00287*00029**
01188*00082*00041*00006**
10762*00298*00201*00002**
01283*01608*00711*00880**
02775*01286*00421**
03293*00267*00112*00008**
02390*00047*00006**
00000*00000*00000**
00055*00006*00003**
00177*00099*00072*00051*00045*00038*00057*00039*00031*00079**|,
IDE00102,Control Module temperature,34, °C
IDE00276,Position in MOST Ring,04,
IDE01807,History data 21,||11647*2016-05-31-16:27*0000.4*53*0000.4*00*0000.0*00*0000.0*00*0000.0*00*0000.0**
05601*2014-04-08-12:03*0001.1*3b*0001.1*00*0000.0*00*0000.0*00*0000.0*00*0000.0**
00000*2000-00-00-00:00*0000.0*00*0000.0*00*0000.0*00*0000.0*00*0000.0*00*0000.0**
00000*2000-00-00-00:00*0000.0*00*0000.0*00*0000.0*00*0000.0*00*0000.0*00*0000.0**|,
IDE01808,History data 22,||19*00001*01*00001*02*00001*17*00001*53*00001*09*00001*05*00001*42*00001*52*00001*36*00001**|,
IDE01809,History data 23,||25534*2024-01-30-11:46*0021.3*K*00041*06e0*0*06e0*0*06e0*0*06c7*0*06f8*0**
00000*2000-00-00-00:00*0000.0*0*00000*0000*0*0000*0*0000*0*0000*0*0000*0**
00000*2000-00-00-00:00*0000.0*0*00000*0000*0*0000*0*0000*0*0000*0*0000*0**|,
IDE01810,History data 24,||25691*2024-06-13-05:55*0003.8*K*00023*000006e2*002*000006e0*002*000006e3*001*00000000*000*00000000*000**
25672*2024-06-12-06:06*0000.9*K*00024*000006e1*011*000006e0*004*000000ff*003*000006e3*002*000006e2*001**
25534*2024-01-29-23:28*0010.5*K*00056*000006e0*004*000006e6*003*000006e2*002*000006e1*002*000006ea*001**
25534*2024-01-29-15:56*0003.1*K*00029*000006e3*003*000006f8*002*000006e2*002*000006e0*001*00000000*000**
25522*2024-01-29-04:26*0000.9*K*00019*000006e6*007*000006e2*002*000006e3*001*000006f8*001*000006e0*001**|,
IDE01811,History data 25,||25644*2024-04-05-00:02*0000.0**
25643*2024-04-05-16:36*0000.0**
25643*2024-04-05-16:32*0000.0**
25643*2024-04-05-16:30*0000.0**
25642*2024-04-05-16:29*0000.5**|,
IDE01812,History data 26,||36271*04309*00005*00017*28072*00000*01259*02609**|,
IDE01813,History data 27,||30010*04410*03459*20318*00000*00000*01823**|,
IDE01814,History data 28,||16885*00000*00000*16885*00000**|,
IDE01815,History data 29,||00001*00000*00000*00000*00001*00000*00000*00000**|,
IDE01816,History data 30,||00001*00000*00000*00001*00000*00000*00000**|,
IDE01817,History data 31,||00000*00000*00000*00000*00000**|,
IDE01818,History data 32,||25720*2024-06-16-00:17*0000.0*06e0*0**
25719*2024-06-15-20:55*0000.0*06e0*0**
25715*2024-06-14-22:40*0000.0*06e0*0**
25714*2024-06-14-19:48*0000.0*06e0*0**
25713*2024-06-14-19:32*0000.0*06c7*0**|,
IDE01819,History data 33,||25719*2024-06-15-22:08*0001.1*000006c0*L**
25719*2024-06-15-21:54*0000.9*000006c0*L**
25719*2024-06-15-21:05*0000.1*000000ff*M**
25715*2024-06-15-18:23*0019.7*000006c0*L**
25715*2024-06-15-18:06*0019.4*000006c0*L**|,
IDE01820,History data 34,||25713*2024-06-14-19:31*0000.0*06e1**
25712*2024-06-14-19:26*0000.0*06e1**
25711*2024-06-14-19:26*0019.4*06e1**
25711*2024-06-14-17:19*0017.3*06e3**
25711*2024-06-14-00:03*0000.0*06e2**|,
IDE01821,History data 35,||00000*00001*00050*00000*00004*00002*00000*01269*00170**|,
IDE01822,History data 36,||25695*2024-06-13-23:30*0000.3*00000*00000*00030*00000*00000*00000*00000**
25691*2024-06-13-05:55*0003.8*00000*00000*00030*00000*00000*00000*00000**
25680*2024-06-12-18:38*0000.4*00000*00000*00033*00000*00000*00000*00000**
25672*2024-06-12-06:06*0000.9*00000*00000*00031*00000*00000*00000*00000**
25658*2024-06-04-14:42*0158.0*00000*00000*00030*00000*00000*00000*00000**|,
IDE01823,History data 37,25721*2012-10-24-15:24*0000.0*0000.0**,
IDE01827,Specified generator voltage,10.6, V
IDE01828,Generator DF Signal,0.025, %
IDE01829,Generator exciter current,0.000, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,electrically OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Hitachi,
IDE01831-MAS04490,Generator variant-Size,---,
IDE01831-ENG113380,Generator variant-alternator identification_regulator,4,
IDE01831-ENG113379,Generator variant-alternator manufacture_regulator,Infineon Technologies AG,
IDE01833-MAS03159,Battery version-Manufacturer,Varta,
IDE01833-MAS04490,Battery version-Size,105 Ah,
IDE01834,Battery voltage,12.396, V
IDE01835,Battery current filtered,-14.600, A
IDE01836,Battery current,-14.679, A
IDE01837,Temperature of battery sensor,27, °
IDE01838,Battery temperature,25, °
IDE01839,Battery charge level,90, %
IDE01840,Battery condition for display,90, %
IDE01841,Battery internal resistance,3.6, mOhm
IDE01842,Usable battery charge,51, Ah
IDE01843,Battery voltage at rest,12.7, V
IDE01844,Increase idle speed request,not active,
IDE01845,Reduce internal fan request,not active,
IDE01846,Static current shut-off stage,not active,
IDE01847,Auxiliary heater activation restriction request,-,
IDE01847-ENG100234,Auxiliary heater activation restriction request-park_heater_target_time,not active,
IDE01848,Energy balance of last driving cycle,0.0, Ah
IDE01849,Previous journey duration,0.00, H
IDE01850,Overall energy balance,9500.0, Ah
IDE01851,Entire energy throughput,5689.3, Ah
IDE01852,Static current measurement: result,0.03, A
IDE01853,Static current measurement: status,Measurement end,
IDE01854,Energy reclamation request,not active,
IDE01855,Generator current,0.0, A
IDE01856,Battery acid stratification,0, %
IDE01864-MAS03173,Status of current bus communication-Powertrain data bus,active,
IDE01864-MAS03174,Status of current bus communication-Comfort data bus,active: local wakeup event,
IDE01864-MAS03175,Status of current bus communication-Extended data bus,active,
IDE01864-MAS03176,Status of current bus communication-Display and control head databus,active,
IDE01864-MAS03177,Status of current bus communication-Infotainment data bus,active,
IDE01864-MAS03178,Status of current bus communication-Suspension data bus,not installed,
IDE01864-MAS03179,Status of current bus communication-Local data bus 2,not installed,
IDE01864-MAS03180,Status of current bus communication-Local data bus,active,
IDE01864-MAS03181,Status of current bus communication-Flexray databus,active,
IDE01864-MAS07380,Status of current bus communication-Data bus Sensor/Hybrid,Bus sleep mode,
IDE01865-MAS03182,Status flex ray communication-Branch 1,active,
IDE01865-MAS03183,Status flex ray communication-Branch 2,active,
IDE01865-MAS03184,Status flex ray communication-Branch 3,active,
IDE01865-MAS03185,Status flex ray communication-Branch 4,active,
IDE01865-MAS03186,Status flex ray communication-Branch 5,not installed,
IDE01865-MAS03187,Status flex ray communication-Branch 6,not installed,
IDE01865-MAS03188,Status flex ray communication-Branch 7,not installed,
IDE01865-MAS03189,Status flex ray communication-Branch 8,not installed,
IDE01866,MOST system condition,Configuration OK,
IDE01867-IDE01863,MOST hardware parameter-MOST light performance,Decrease 0 dB,
IDE01867-MAS03121,MOST hardware parameter-Ring break diagnostic line status,1,
IDE01867-MAS03122,MOST hardware parameter-Ring break diagnostic line voltage,25.5, V
IDE01867-ENG100178,MOST hardware parameter-HW Instance (MP1-4)_MOST hardware value,0,
IDE01868,Ring break diagnostic result,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE01948,Battery internal resistance not normed,3.0, mOhm
IDE01979,Stored key for component protection participants,05 81 48 08 22 40 00 0C 00 00,
IDE01980,Component protection participant currently wrongly authent.,00 00 00 00 00 00 00 00 00 00,
IDE01981,Comp. protect participant occasionally wrongly authent.,00 00 00 00 00 00 00 00 00 00,
IDE01982,Transport protocol used for component protection,01 01 40 00 00 00 00 0C 00 00,
IDE01983,Number of successfully repaired keys,0,
IDE01984,Number of successful key downloads,0,
IDE01985-ENG101043,FAZIT identification test sum-Checksum,D6 D3 9F D7,
IDE01985-ENG99027,FAZIT identification test sum-Version,1,
IDE01992-ENG100904,Installation list: current installations-ECUs present,|ECU present Bit 0,ECU present Bit 1,ECU present Bit 2,ECU present Bit 3,ECU present Bit 4,ECU present Bit 5,ECU present Bit 6,ECU present Bit 7|not attainable,not attainable,can be reached,not attainable,can be reached,can be reached,can be reached,can be reached|can be reached,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,can be reached|not attainable,not attainable,not attainable,can be reached,not attainable,can be reached,can be reached,can be reached|not attainable,not attainable,not attainable,can be reached,not attainable,not attainable,not attainable,not attainable|not attainable,can be reached,not attainable,can be reached,can be reached,can be reached,can be reached,can be reached|can be reached,can be reached,not attainable,not attainable,not attainable,can be reached,can be reached,not attainable|not attainable,not attainable,not attainable,not attainable,not attainable,can be reached,can be reached,not attainable|can be reached,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable|not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable|not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable|,
IDE01993-ENG103664,Control module reference number-ECU IDs,|ECU ID,ECM name|01,Engine Electronics|02,Transmission Electronics|03,Brake electronics|03,Brake electronics|04,Steering angle sensor|05,Access/start authorization|06,Seat adjustment: passenger's side|08,Climate Control Module|09,Electronic central electric|0E,Media Player 1|10,Parallel parking 2|11,Engine electronics 2|13,Distance Regulation|8B,Distance regulation 2|34,Level control system|15,Airbag|16,Steering column electronics systems|17,Instrument cluster|17,Instrument cluster|18,Auxiliary/parking heating|19,Data Bus OBD Interface|1B,Active Steering|1E,Media Player 2|20,High beam assistant|22,All-wheel drive electronics|28,Rear A/C control head|2E,Media Player 3|30,Special Function 2|36,Seat adjustment: driver side|3C,Lane change assistance|3D,Special Function|3E,Media Player 4|42,Driver's door electronics|46,Comfort system central control module|47,Sound System|52,Passenger's door electronics|53,Parking Brake|55,Headlamp range control|56,Radio|57,TV Tuner|85,Camera control module|5F,Information electronics 1|62,Left rear door electronics|26,Convertible top operation|65,Tire Pressure Monitoring System (TPMS)|69,Trailer Function|6C,Rear view camera system|6D,Rear lid electronics|6F,Comfort system central control module 2|72,Right rear door electronics|3B,Sensor Electronics|7F,Information electronics 2|82,Head-Up-Display|84,Night vision system|48,Seat adjustment: rear driver's side|5B,Seat adjustment: rear passenger side|88,Multi contour seat driver's side|89,Multicontour seat passenger side|8A,Multi contour seat rear driver's side|8D,Multi contour seat rear passenger's side|8F,Left front seat belt tensioner|90,Right front seat belt tensioner|AC,Reducing Agent Metering System|44,Power steering|81,Selector lever|8E,Image processing control module|C0,Actuator For Exterior Noise|A9,Structure-borne sound actuator|40,A/C compressor|51,Electric drive|8C,Hybrid Battery Management|BA,Subframe mount|14,Wheel Damping Electronics|00,Unknown (0)|00,Unknown (0)|00,Unknown (0)|00,Unknown (0)|00,Unknown (0)|00,Unknown (0)|00,Unknown (0)|,
IDE01995-ENG103538,Control module protocol information-ECUs DiagProt,|ISO-TP,TP 2.0,TP 1.6,K Line,Ethernet|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,No,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|No,No,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|Yes,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|,
IDE01996-ENG99724,Installation list: specified installations-ECU coded,|ECU coded Bit 0,ECU coded Bit 1,ECU coded Bit 2,ECU coded Bit 3,ECU coded Bit 4,ECU coded Bit 5,ECU coded Bit 6,ECU coded Bit 7|Yes,No,Yes,Yes,Yes,Yes,Yes,Yes|Yes,No,No,No,No,Yes,No,Yes|No,No,No,Yes,No,Yes,Yes,Yes|No,No,Yes,Yes,No,No,Yes,No|No,Yes,Yes,Yes,Yes,Yes,Yes,Yes|Yes,Yes,No,No,No,Yes,Yes,No|No,No,No,No,No,Yes,Yes,No|Yes,No,Yes,Yes,No,No,No,No|No,No,No,No,No,No,No,No|No,No,No,No,No,No,No,No|,
IDE02384-ENG102478,Status of event memory-ECU Dtcs,|ECU Dtc Bit 0,ECU Dtc Bit 1,ECU Dtc Bit 2,ECU Dtc Bit 3,ECU Dtc Bit 4,ECU Dtc Bit 5,ECU Dtc Bit 6,ECU Dtc Bit 7|OK,OK,Malfunction,OK,Malfunction,Malfunction,Malfunction,Malfunction|Malfunction,OK,OK,OK,OK,OK,OK,Malfunction|OK,OK,OK,Malfunction,OK,Malfunction,Malfunction,Malfunction|OK,OK,OK,Malfunction,OK,OK,OK,OK|OK,Malfunction,OK,Malfunction,Malfunction,Malfunction,Malfunction,Malfunction|Malfunction,Malfunction,OK,OK,OK,OK,Malfunction,OK|OK,OK,OK,OK,OK,OK,OK,OK|Malfunction,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|,
IDE03008-ENG98388,Stop process prevented-Battery state of charge too low,0,
IDE03008-ENG98389,Stop process prevented-Battery temperature,0,
IDE03008-ENG99012,Stop process prevented-Consumer/component current too high,0,
IDE03008-ENG103231,Stop process prevented-Entnehmbare Ladung zu gering,0,
IDE03008-ENG98719,Stop process prevented-Idle increase active,0,
IDE03008-ENG122800,Stop process prevented-Intermittierender Betrieb aktiv,0,
IDE03008-ENG98746,Stop process prevented-Possible standing time too short,0,
IDE03008-ENG103267,Stop process prevented-Sonderveto aktiv,0,
IDE03008-ENG104139,Stop process prevented-Veto DC/DC Wandler,0,
IDE03009-ENG98388,Start process requested-Battery state of charge too low,0,
IDE03009-ENG104067,Start process requested-Charge contingency,0,
IDE03009-ENG99104,Start process requested-Entnehmbare Ladung,0,
IDE03009-ENG99021,Start process requested-insufficient voltage,0,
IDE03009-ENG101118,Start process requested-Stromverbrauch,0,
IDE03009-ENG102869,Start process requested-Zielzeit abgelaufen,0,
IDE03127,Prevented stop processes (ring memory),||2024-01-24-23:08*1-0-0-0-1-0-0-0**
2024-01-24-23:06*1-0-0-0-1-0-0-0**
2024-01-24-23:05*1-0-0-0-1-0-0-0**
2023-11-15-01:29*1-0-0-0-0-0-0-0**
2023-11-15-01:28*1-0-0-0-0-0-0-0**
00197*00000*00000*00000*00069*00000*00000*00000**|,
IDE03128,Requested start processes (ring memory),||2021-01-28-16:55*0-0-0-0-1-0-0-0**
2018-02-09-19:02*0-0-1-0-0-0-0-0**
2017-12-29-12:02*0-0-1-0-0-0-0-0**
2017-12-17-09:57*0-0-1-0-0-0-0-0**
2017-12-13-20:23*0-0-1-0-0-0-0-0**
00000*00000*00000*00000*00001*00000*00000*00000**|,
IDE03150-ENG113353,Readiness for bus sleep mode-ECU Sleepready New,|ECU SleepReady Bit0,ECU SleepReady Bit1,ECU SleepReady Bit2,ECU SleepReady Bit3,ECU SleepReady Bit4,ECU SleepReady Bit5,ECU SleepReady Bit6,ECU SleepReady Bit7|can be reached,can be reached,not attainable,not attainable,not attainable,can be reached,not attainable,can be reached|not attainable,can be reached,not attainable,not attainable,can be reached,not attainable,can be reached,not attainable|not attainable,can be reached,not attainable,can be reached,can be reached,not attainable,not attainable,not attainable|can be reached,can be reached,not attainable,not attainable,can be reached,can be reached,can be reached,not attainable|can be reached,not attainable,not attainable,not attainable,not attainable,not attainable,can be reached,not attainable|not attainable,not attainable,can be reached,can be reached,can be reached,can be reached,not attainable,not attainable|can be reached,can be reached,not attainable,can be reached,can be reached,can be reached,can be reached,can be reached|can be reached,can be reached,not attainable,not attainable,can be reached,can be reached,can be reached,can be reached|not attainable,can be reached,can be reached,not attainable,not attainable,not attainable,not attainable,not attainable|not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable|,
IDE03151,TP CAN identifier,|TP CAN identifier|00 00|00 00|07 13|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|07 57|07 56|07 55|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|07 1D|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|07 21|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|07 12|00 00|07 58|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,Not available,
IDE03897,Generator: status communication,active,
IDE03898,Voltage stabilizer: status communication,active,
IDE03899,Battery monitoring control module: status communication,active,
IDE06747-IDE01834,Battery Monitoring Control Module 2-Battery voltage,4.000, V
IDE06747-IDE01836,Battery Monitoring Control Module 2-Battery current,-32.768, A
IDE06747-IDE01838,Battery Monitoring Control Module 2-Battery temperature,-40, °
IDE06747-IDE01839,Battery Monitoring Control Module 2-Battery charge level,0, %
IDE06747-IDE01841,Battery Monitoring Control Module 2-Battery internal resistance,0.0, mOhm
IDE06747-IDE01948,Battery Monitoring Control Module 2-Battery internal resistance not normed,0.0, mOhm
IDE06747,Battery Monitoring Control Module 2,not active,
IDE06747-ENG113366,Battery Monitoring Control Module 2-battery current puls,0,
IDE06747-ENG113365,Battery Monitoring Control Module 2-battery voltage puls,9.000, V
IDE06747-ENG113367,Battery Monitoring Control Module 2-BZE_Min_puls_duration,0, ms
IDE06747-ENG113368,Battery Monitoring Control Module 2-BZE_Min_trigger,0,
IDE06747-ENG101157,Battery Monitoring Control Module 2-BZE_Q_Elad,0.0, Ah
IDE06747-ENG100159,Battery Monitoring Control Module 2-BZE_Q_Lad,0.0, Ah
IDE06747-ENG106125,Battery Monitoring Control Module 2-EM_blBatteryDisconnected,connected,
IDE06747-ENG98970,Battery Monitoring Control Module 2-Temperature of battery sensor,-40, °
ENG107689-IDE01868,Automatic loop break diagnosis-Ring break diagnostic result,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG107689-MAS00043,Automatic loop break diagnosis-Terminal 30 power supply,0.0, V
ENG107689-MAS00711,Automatic loop break diagnosis-Odometer reading,0, km
ENG107689-MAS01230,Automatic loop break diagnosis-Date,00.00.2000,
ENG107689-MAS02957,Automatic loop break diagnosis-Time,00:00,
ENG105315-ENG103971,BCmE_Versionnumber-Patch,2,
ENG105315-ENG98889,BCmE_Versionnumber-Release,5,
ENG111625-MAS00106,Break recommendation-Year,2000,
ENG111625-MAS00107,Break recommendation-Month,0,
ENG111625-MAS00108,Break recommendation-Day,0,
ENG111625-MAS00109,Break recommendation-Hours,0,
ENG111625-MAS00110,Break recommendation-Minutes,0,
ENG111625-ENG151621,Break recommendation-Deaktiviert durch EEPROM-Wert,No,
ENG111625-ENG151620,Break recommendation-Deaktiviert durch falschen Datensatz,Yes,
ENG111625-ENG113361,Break recommendation-PE_Art_der_Meldung,Initialization,
ENG111625-ENG113357,Break recommendation-PE_Einstellung,active,
ENG111625-ENG113359,Break recommendation-PE_Fehlercode,not installed,
ENG111625-ENG113362,Break recommendation-PE_Index_HFC_TP,1.000,
ENG111625-ENG113358,Break recommendation-PE_Stufe,0,
ENG105771-ENG102240,DCDC_First_Branch-DC_STST1_Bypassrelais_defekt_TW1,0,
ENG105771-ENG102373,DCDC_First_Branch-DC_STST1_El_Fehler_Ausgang_KS_TW1,0,
ENG105771-ENG104027,DCDC_First_Branch-DC_STST1_Lastabschaltung_TW1,0,
ENG105771-ENG101272,DCDC_First_Branch-DC_STST1_Uebertemperatur_TW1,0,
ENG105771-ENG100694,DCDC_First_Branch-DC_STST1_Unterspannung_Eingang_TW1,0,
ENG105772-ENG102945,DCDC_Second_Branch-DC_STST1_Bypassrelais_defekt_TW2,0,
ENG105772-ENG99327,DCDC_Second_Branch-DC_STST1_El_Fehler_Ausgang_KS_TW2,0,
ENG105772-ENG100692,DCDC_Second_Branch-DC_STST1_Lastabschaltung_TW2,0,
ENG105772-ENG100445,DCDC_Second_Branch-DC_STST1_Uebertemperatur_TW2,0,
ENG105772-ENG101117,DCDC_Second_Branch-DC_STST1_Unterspannung_Eingang_TW2,0,
ENG105773-ENG100371,DCDC_STST_Status-DC_STST1_Boost,0,
ENG105773-ENG101192,DCDC_STST_Status-DC_STST1_Defekt,0,
ENG105773-ENG101605,DCDC_STST_Status-DC_STST1_ErrorGueltigkeit,1,
ENG105773-ENG103583,DCDC_STST_Status-DC_STST1_Fail,0,
ENG105773-ENG103918,DCDC_STST_Status-DC_STST1_Fktbereit,0,
ENG105773-ENG102020,DCDC_STST_Status-DC_STST1_Lokalaktiv,0,
ENG105773-ENG103598,DCDC_STST_Status-DC_STST1_Stromgrenze,0,
ENG105773-ENG99195,DCDC_STST_Status-DC_STST1_Uebertemperatur,0,
ENG113398,EM Produktionsmodus Freigabe,1,
ENG113397,EM RSM Freigabe,1,
ENG106120,EM_battery identification known,known,
ENG106121-ENG101157,EM_Battery_charge_discharge-BZE_Q_Elad,5659.8, Ah
ENG106121-ENG100159,EM_Battery_charge_discharge-BZE_Q_Lad,4816.2, Ah
ENG106122,EM_battery_identification,13,
ENG106123,EM_blAlternator On,OFF,
ENG106124,EM_blAlternator Valid,Yes,
ENG106125,EM_blBatteryDisconnected,connected,
ENG106126,EM_blBemSleepRdy,0,
ENG106127,EM_blBoostRecognised,detected,
ENG106128,EM_blCanMostActive,1,
ENG106129,EM_blControlKFan,0,
ENG106130,EM_blDisconnectionAdeptChannel,0,
ENG106131,EM_blMmi Advance Warning,0,
ENG106132,EM_blMmi Advance Warning Diag,0,
ENG106133,EM_blParkHeatingEncoded,Not coded,
ENG106134,EM_blRecuperation Encoded,coded,
ENG106135,EM_blRecuperation Enforce,Not coded,
ENG106136,EM_blSleepIndication,1,
ENG106137,EM_blStabilisation EBalance,0,
ENG106138,EM_blStabilisation EPowerSystem,0,
ENG106139,EM_blVnaActive,0,
ENG106140,EM_Current_Control_Recu,not active,
ENG121181,EM_Energiebilanz_2,10000.0, Ah
ENG106141,EM_errEBalanceDiag,0,
ENG106142,EM_errEPowerSystem,0,
ENG106143,EM_errOverVoltage,0,
ENG113400-ENG113369,EM_Hybrid_Info-Hybrid_Info,Motorstart_ueber_12V_Starter_nur_bei_0kmh_moeglich,
ENG106144,EM_IAlternator L1,0.0, A
ENG106145,EM_IAlternator Reserve,0.0, A
ENG106146,EM_IInternalFan,0.25, A
ENG106147,EM_IKmStandTm Active,0, km
ENG106148,EM_IKmStandTmActiveIn,68, km
ENG106149,EM_INeutralBem,-4.072, A
ENG106150,EM_IParkHeatingRequirements,10, A
ENG121178,EM_Ladestrombegrenzung,not active,
ENG106151,EM_Load Response Time,6.00, s
ENG106160-ENG102785,EM_loss_of_voltage / param_specified_capacity-Battery technology,Batterietechnologie unbekannt,
ENG106160-ENG100745,EM_loss_of_voltage / param_specified_capacity-BZE_DeltaUStart_Aktuell,12.70, V
ENG106160-ENG101482,EM_loss_of_voltage / param_specified_capacity-BZE_DeltaUStart_Mittel,12.70, V
ENG106160-ENG102509,EM_loss_of_voltage / param_specified_capacity-BZE_DeltaUStart_Trigger,1,
ENG106160-ENG102743,EM_loss_of_voltage / param_specified_capacity-BZE_MinUStart,14.70, V
ENG106160-ENG101108,EM_loss_of_voltage / param_specified_capacity-BZE_MinUStart_Trigger,1,
ENG106160-ENG100156,EM_loss_of_voltage / param_specified_capacity-BZE_Q_Nom,100, Ah
ENG106160-ENG100059,EM_loss_of_voltage / param_specified_capacity-Nenn Kapazität,Init,
ENG106152,EM_MAlternator,0.0, Nm
ENG106153,EM_NDisconnectionEngineSpeed,5990, /min
ENG106154,EM_PAltMechanical,0, W
ENG106155-ENG99338,EM_prcSoh-prc SohP,80, %
ENG106155-ENG101494,EM_prcSoh-prc SohQ,70, %
ENG106156,EM_PReserveFilter,0, W
ENG106157-ENG101729,EM_RecuMode_Engine-Modus Rekuperation (Motor),Acceleration limited,
ENG106159-ENG102920,EM_Recuperation_Prerequisite-Auslastung des Generators,1,
ENG106159-ENG100983,EM_Recuperation_Prerequisite-Batteriealterung (Ladung),1,
ENG106159-ENG99619,EM_Recuperation_Prerequisite-Batteriealterung (Leistung),1,
ENG106159-ENG102670,EM_Recuperation_Prerequisite-Batterieregeneration,1,
ENG106159-ENG103895,EM_Recuperation_Prerequisite-Energie Netz,1,
ENG106159-ENG99263,EM_Recuperation_Prerequisite-Energiedurchsatz,1,
ENG106159-ENG99104,EM_Recuperation_Prerequisite-Entnehmbare Ladung,1,
ENG106159-ENG99756,EM_Recuperation_Prerequisite-Generatordiagnose,1,
ENG106159-ENG103581,EM_Recuperation_Prerequisite-Ladezustand der Batterie,1,
ENG106159-ENG100106,EM_Recuperation_Prerequisite-Leerlaufanhebung,1,
ENG106159-ENG104009,EM_Recuperation_Prerequisite-LIN-Kommunikation,1,
ENG106159-ENG98425,EM_Recuperation_Prerequisite-Outside temperature,1,
ENG106159-ENG102570,EM_Recuperation_Prerequisite-Säureschichtung,1,
ENG106159-ENG101873,EM_Recuperation_Prerequisite-Sonderveto,1,
ENG106159-ENG103261,EM_Recuperation_Prerequisite-Spannung der Batterie,1,
ENG106159-ENG103394,EM_Recuperation_Prerequisite-Temperatur der Batterie,1,
ENG106158-ENG104224,EM_Recuperation_Restriction-Abblendlicht Aktiv,0,
ENG106158-ENG99969,EM_Recuperation_Restriction-Auslastung Innegeblaese Hoch,0,
ENG106158-ENG103587,EM_Recuperation_Restriction-Bauteilschutz BDM,0,
ENG106158-ENG102567,EM_Recuperation_Restriction-Bauteilschutz Fernlicht,0,
ENG106158-ENG101156,EM_Recuperation_Restriction-Blinker links Aktiv,0,
ENG106158-ENG101146,EM_Recuperation_Restriction-Blinker rechts Aktiv,0,
ENG106158-ENG113355,EM_Recuperation_Restriction-EPS Leistunsanforderung,0,
ENG106158-ENG101898,EM_Recuperation_Restriction-ESP-Anforderung,0,
ENG106158-ENG99511,EM_Recuperation_Restriction-Innenlicht Aktiv,1,
ENG106158-ENG102650,EM_Recuperation_Restriction-Motor-Anforderung,0,
ENG121180-ENG121171,EM_Rekuperation_Sonderveto-Sonderveto_Anhaenger,No,
ENG121180-ENG121172,EM_Rekuperation_Sonderveto-Sonderveto_Klima,No,
ENG121180-ENG121174,EM_Rekuperation_Sonderveto-Sonderveto_Motor_Spannungsanforderung,No,
ENG121180-ENG121170,EM_Rekuperation_Sonderveto-Sonderveto_Produktion,No,
ENG121180-ENG121169,EM_Rekuperation_Sonderveto-Sonderveto_Transportmodus,No,
ENG121180-ENG121173,EM_Rekuperation_Sonderveto-Sonderveto_Zustart_Batterie,No,
ENG106161-ENG102992,EM_Start_Stop_State-Mögliche Stoppzeit,13,
ENG106161-ENG100942,EM_Start_Stop_State-Start Stopp Phase,Phase 1,
ENG106161-ENG103632,EM_Start_Stop_State-Status Motorstopp,not active,
ENG106161-ENG102878,EM_Start_Stop_State-Status Wiederstart,not active,
ENG106161-ENG100005,EM_Start_Stop_State-Stromverbrauchsschätzung Stoppphase,30, A
ENG106162-ENG101997,EM_Start_Stop_System_Error / system fault DC-Batterie zyklisch verbraucht,0,
ENG106162-ENG103373,EM_Start_Stop_System_Error / system fault DC-Battery fault,0,
ENG106162-ENG99392,EM_Start_Stop_System_Error / system fault DC-Fehler Diagnosesignal DC/DC-Wandler,0,
ENG106162-ENG102635,EM_Start_Stop_System_Error / system fault DC-Generator malfunction,0,
ENG106162-ENG101407,EM_Start_Stop_System_Error / system fault DC-Start/Stopp-Koordinator unplausibel,0,
ENG106162-ENG122799,EM_Start_Stop_System_Error / system fault DC-Systemfehler BDM Defekt,0,
ENG106162-ENG100042,EM_Start_Stop_System_Error / system fault DC-Systemfehler DC/DC-Wandler,0,
ENG106163-ENG99559,EM_tSgErrors-tSgError IO Duration tSgErrors,0, min
ENG106163-ENG100405,EM_tSgErrors-tSgError NIO Duration tSgErrors,2, min
ENG106163-ENG100563,EM_tSgErrors-tSgErrorDuration In tSgErrors,0, s
ENG106163-ENG103494,EM_tSgErrors-tSgErrorDuration tSgErrors,0, s
ENG106164,EM_UControlUnit,12.320, V
ENG106165,EM_Ustart,6.5, V
ENG106166,EM_valBdm LinTableSwitch,Terminal 15 on,
ENG106167,EM_valBdm WakeUpReason,0,
ENG106168,EM_valEngineId,4,
ENG106169,EM_valHlkLevelRequirement,1,
ENG106170,EM_valStatusHlk,0,
ENG106171-ENG103971,EM_Versionnumber-Patch,6,
ENG106171-ENG98889,EM_Versionnumber-Release,12,
ENG113401-ENG113374,EM_Zustart Freigabe-Freigabe Aussentemperatur,Yes,
ENG113401-ENG113370,EM_Zustart Freigabe-Freigabe Batterietemperatur (Bat1),Yes,
ENG113401-ENG113372,EM_Zustart Freigabe-Freigabe Batterietemperatur (Bat2),Yes,
ENG113401-ENG113371,EM_Zustart Freigabe-Freigabe Entnehmbare Ladung (Bat1),Yes,
ENG113401-ENG113373,EM_Zustart Freigabe-Freigabe Leistungsfähigkeit Zustart,No,
ENG121179-ENG121165,EM_Zustart_Systemfehler-EM_BatterieAb_BDM1,No,
ENG121179-ENG121166,EM_Zustart_Systemfehler-EM_BatterieAb_BDM2,No,
ENG121179-ENG121167,EM_Zustart_Systemfehler-EM_LIN1_ungueltig,No,
ENG121179-ENG121168,EM_Zustart_Systemfehler-EM_LIN2_ungueltig,No,
ENG113402-ENG113377,GW_Bap_Status-Lifecycle,run,
ENG113402-ENG99775,GW_Bap_Status-MOST,On,
ENG113402-ENG113378,GW_Bap_Status-PE_Freigabe,0,
ENG106825,GW_SYS_BEM_SleepReady,EM active,
ENG106826,GW_SYS_BM_Run-on,60, s
ENG106827-ENG100038,GW_SYS_CPU_Load-CPU Load,0, %
ENG106827-ENG113384,GW_SYS_CPU_Load-Task Level 1,0, %
ENG106827-ENG113383,GW_SYS_CPU_Load-Task Level 2,0, %
ENG106827-ENG113382,GW_SYS_CPU_Load-Task Level 3,0, %
ENG106827-ENG113381,GW_SYS_CPU_Load-Task Level 4,0, %
ENG106828,GW_SYS_EEPROM Repair,0,
ENG106832-ENG100323,GW_SYS_LastWakeupReason-Car WakeUp Reason,Comfort data bus,
ENG106832-ENG99403,GW_SYS_LastWakeupReason-Gateway WakeUp Reason,Comfort data bus,
ENG106833,GW_SYS_Reset_Count,0,
ENG106834,GW_SYS_ResetReason,Power On Reset,
ENG100548-MAS00049,GW_SYS_State-Component protection,not active,
ENG100548-MAS00795,GW_SYS_State-Data Bus On Board Diagnostic Interface,active,
ENG100548-MAS01468,GW_SYS_State-Terminal 15,active,
ENG100548-MAS01490,GW_SYS_State-Energy management,not active,
ENG100548-MAS03173,GW_SYS_State-Powertrain data bus,not active,
ENG100548-MAS03174,GW_SYS_State-Comfort data bus,not active,
ENG100548-MAS03175,GW_SYS_State-Extended data bus,active,
ENG100548-MAS03176,GW_SYS_State-Display and control head databus,not active,
ENG100548-MAS03177,GW_SYS_State-Infotainment data bus,active,
ENG100548-MAS03178,GW_SYS_State-Suspension data bus,not active,
ENG100548-MAS03180,GW_SYS_State-Local data bus,active,
ENG100548-MAS03181,GW_SYS_State-Flexray databus,not active,
ENG100548-ENG102839,GW_SYS_State-A-Can Flexray F-Can SubMaster,active,
ENG100548-ENG100518,GW_SYS_State-Busmonitor,active,
ENG100548-ENG98571,GW_SYS_State-EEPROM,active,
ENG100548-ENG99046,GW_SYS_State-Emergency signal flashing,not active,
ENG100548-ENG100049,GW_SYS_State-K-Can Dash-Can SubMaster,active,
ENG100548-ENG102799,GW_SYS_State-Mindestaktivzeit,active,
ENG106837,GW_SYS_TP20_Counter,0,
ENG110999,GW_Watchdog_Version,0,
ENG100189,IN ESP_standstill flag,1,
ENG100411,IN ESP_v_Signal,0, km/h
ENG100786,IN HW terminal 15,1,
ENG101017,IN KBI_odometer_reading,146276,
ENG101398,IN MO_engine_speed_01,0.00, /min
ENG103286,IN MO_Motor_running,0,
ENG106958-MAS00106,IN time_01-Year,2024,
ENG106958-MAS00107,IN time_01-Month,6,
ENG106958-MAS00108,IN time_01-Day,16,
ENG106958-MAS00109,IN time_01-Hours,0,
ENG106958-MAS00110,IN time_01-Minutes,24,
ENG106958-MAS00111,IN time_01-Seconds,17,
ENG106958-MAS00690,IN time_01-Daylight saving time,Winter time,
ENG106958-ENG103328,IN time_01-type of clock,Quartz_crystal,
ENG101569,IN ZAS_Te_15,1,
ENG103048,IN ZAS_Te_X,1,
ENG107685-ENG103912,MOST Deattaches-deatatch counter_MOST Deatatches,0,
ENG107685-ENG99643,MOST Deattaches-present deatatch counter_MOST Deatatches,0,
ENG107685-ENG100756,MOST Deattaches-present status_MOST Deatatches,connected,
ENG102460,MOST Notifications,|Function ID,Target Adress 1,Target Adress 2,Target Adress 3|00 00,00 00,00 00,00 00|00 00,00 00,00 00,00 01|00 00,00 00,00 00,00 00|00 00,00 00,00 02,00 00|00 00,00 00,00 00,00 00|00 00,0C FE,00 00,00 00|00 00,00 00,00 00,00 00|0C FF,00 00,00 00,00 00|00 00,00 00,00 00,0E 02|01 00,00 00,00 00,00 00|00 00,00 00,0E 03,03 FF|00 00,00 00,00 00,00 00|00 00,0E 04,03 FF,00 00|00 00,00 00,00 00,00 00|0E 05,01 00,00 00,00 00|00 00,00 00,00 00,0E 06|03 FF,00 00,00 00,00 00|00 00,00 00,0E 10,03 FF|00 00,00 00,00 00,00 00|00 00,0E 24,03 FF,00 00|00 00,00 00,00 00,00 00|0E 30,03 FF,00 00,00 00|00 00,00 00,00 00,0E 31|03 FF,00 00,00 00,00 00|00 00,00 00,0E 32,03 FF|00 00,00 00,00 00,00 00|00 00,0E 33,00 00,00 00|00 00,00 00,00 00,00 00|0E 34,00 00,00 00,00 00|00 00,00 00,00 00,0E 36|00 00,00 00,00 00,00 00|00 00,00 00,0E 38,00 00|00 00,00 00,00 00,00 00|00 00,0E 3C,00 00,00 00|00 00,00 00,00 00,00 00|0E 3E,00 00,00 00,00 00|00 00,00 00,00 00,0E 3F|00 00,00 00,00 00,00 00|00 00,00 00,0E 40,00 00|00 00,00 00,00 00,00 00|00 00,0E A0,01 00,00 00|00 00,00 00,00 00,00 00|0E A1,01 00,00 00,00 00|00 00,00 00,00 00,0E A2|,
ENG107869-ENG102318,NW_MOST Addressing-diag inst-id,19,
ENG107869-ENG101908,NW_MOST Addressing-groupadress,03 FF,
ENG107869-ENG101657,NW_MOST Addressing-logical adress,05 19,
ENG107869-ENG99161,NW_MOST Addressing-vehicle inst-id,01,
ENG107870-ENG100752,NW_MOST net mngmt status-Configuration_NW_MOST Networkmanagment.Status,New,
ENG107870-ENG99305,NW_MOST net mngmt status-MMI_State_NW_MOST Networkmanagment.Status,MMI_On,
ENG107870-ENG103488,NW_MOST net mngmt status-ShutDownState_NW_MOST Networkmanagment.Status,normal operation,
ENG107870-ENG104176,NW_MOST net mngmt status-Systemstate_NW_MOST Networkmanagment.Status,normal operation,
ENG107948,OUT_Alternator_reference_voltage_value,10.6, V
ENG107949,OUT_GW_Aging_counter_DIAG_01_message,251,
ENG102605,outside_temperature,26.0, °C
ENG113399-ENG113364,PE_Version-DS_Version,.,
ENG113399-ENG109174,PE_Version-SW_VERSION,5.0,
ENG107686-IDE00317,Reset date for counter: sporadic loop breaks-Date,00.00.2000,
ENG110089,Warm-Up-Cycle Counter (zVZ),0,
Elapsed Time: 00:38
Still chasing this one down. I was able to verify power to the ECU, but am still trying to determine how to view the IDE channel. I posted a reply, but I was hoping someone would be able to jump in and tell me if I am even looking at the right area?No viewing IDE channel in the gateway module the module can tell you if the module your looking for is talking to the gateway or not. No probing involved just a laptop and VCDS and a few key strokes. IF IDE channel shows 0 then module is not talking to gateway if 1 is show communication is ok. If zero then you need to check power and ground at affected module or find where power is coming from then looking at fuses and so on.
I think this is the part you were talking about :
Code:;SW:4G0-907-468-AC HW:4G0-907-468-AC --- CAN Gateway ;Component:J533--Gateway H12 0037, Coding:00CD073000 ;EV_GatewPkoUDS,001018,EV_GatewPkoUDS_001_AU57.rod ;Tuesday,09,July,2024,19:21:36:10725 ;VCDS Version: Release 24.5.0 (x64) Data version: 20240429 DS355.0 ;VCID: 71BFD890312B84D2A8D-8024 Group,Description,Actual IDE00018,Voltage terminal 15,12.3, V IDE00019,Voltage terminal 30,12.3, V IDE00030,Status of actuator test,not active, IDE00056,History data 1,||2024-06-13-03:44*00.2*02*02853*** 2024-06-12-15:08*03.7*02** 2024-06-12-04:44*01.8*02** 2024-06-12-02:05*04.7*02** 2024-06-07-19:41*09.2*02** 2024-06-06-19:22*01.6*02** 2024-06-06-16:58*18.2*02** 2024-06-12-15:08*00.0*02*00797*** 2024-06-12-02:05*00.3*02** 2024-06-11-20:21*00.5*02** 2024-06-11-16:16*17.5*02** 2024-06-10-22:46*01.9*02** 2024-06-10-20:47*02.3*02** 2024-06-10-18:07*21.3*02** 2024-04-05-16:29*00.5*02*00946*** 2024-04-05-15:33*15.4*02** 2024-03-19-07:19*00.0*02** 2024-03-19-07:13*00.0*02** 2024-03-19-07:08*00.0*02** 2024-03-19-07:03*00.0*02** 2024-03-19-06:58*00.0*02**|, IDE00057,History data 2,||2024-03-18-17:20*0016*049*-00.19*0-0-0-0-0-0*0*02*00028** 2024-01-29-23:24*0009*000*-00.21*0-0-0-0-0-0*0*02** 2023-03-24-18:36*0001*025*-01.84*0-0-0-0-0-0*0*02** 2012-12-15-10:29*0002*019*-00.33*0-0-1-0-0-0*0*02** 2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00** 2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00** 2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00** 2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00** 2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00** 2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00**|, IDE00058,History data 3,||2024-04-05-16:48*3*0*000*000*-07.22*0-0-0-0-0-0*0*0*00.3*00.4** 2024-04-05-16:39*2*0*001*000*-14.96*0-0-1-0-0-0*0*0*00.2*00.3** 2024-04-05-16:36*1*0*002*000*-15.04*0-0-1-0-0-0*0*0*00.1*00.2** 2024-04-05-16:32*3*0*003*000*-08.95*0-0-0-0-0-0*0*0*00.1*00.2** 2024-04-05-16:30*1*0*003*000*-14.46*0-0-1-0-0-0*0*0*00.1*00.1** 2024-04-05-15:54*3*0*004*000*-07.79*0-0-0-0-0-0*0*0*00.1*00.1** 2024-04-05-15:50*2*0*005*000*-14.34*0-0-1-0-0-0*0*0*00.0*00.0** 2024-04-05-15:47*1*0*006*000*-14.61*0-0-1-0-0-0*0*0*00.0*00.0** 2024-04-05-15:45*3*0*006*000*-07.75*0-0-0-0-0-0*0*0*00.0*00.0** 2024-04-05-15:45*1*0*007*000*-09.15*0-0-0-0-0-0*0*0*00.0*00.0** 2024-04-05-15:43*1*0*007*000*-14.38*0-0-1-0-0-0*0*0*00.8*00.9** 2024-04-05-15:35*3*0*008*000*-06.79*0-0-0-0-0-0*1*0*00.8*00.9** 2024-04-05-15:34*1*0*008*000*-08.89*0-0-0-0-0-0*0*0*00.8*00.9** 2024-04-04-23:19*3*0*009*000*-08.29*0-0-0-0-0-0*0*0*00.8*00.8** 2024-04-04-23:19*1*0*009*000*-09.47*0-0-0-0-0-0*0*0*00.8*00.8**|, IDE00059,History data 4,||2020-03-12-00:07*02*105*VAO*AO12345678*09500*05689*0020*0000*0000** 2012-10-22-21:34*01*105*JCB*221016G0BX*09500*11233*0023*0000*0000** 2000-01-01-00:00*00*---*---*----------*09999*00000*0000*0000*0000** 2000-01-01-00:00*00*---*---*----------*00000*00000*0000*0000*0000** 2000-01-01-00:00*00*---*---*----------*00000*00000*0000*0000*0000**|, IDE00060,History data 5,||2024-01-30-19:26*-00.21*-02.32*-09.56*11.54*001*07*-22.6*05380*09500*146277*0-0-0-0-0-0*0*00.9*01.4*008.9*33*02*05** 2023-08-02-00:00*+00.00*-05.33*-09.53*12.55*100*02*+00.2*03640*09592*137506*0-0-0-0-0-0*0*00.0*00.0*000.0*01*00*04** 2023-01-05-00:00*-00.25*-00.62*-09.43*12.16*100*02*-01.4*01945*09701*125204*0-0-0-0-0-0*0*00.0*00.0*001.4*03*00*03** 2022-12-18-00:00*-00.02*-00.05*-10.69*11.94*100*02*-02.6*01917*09701*125140*0-0-0-0-0-0*0*00.0*00.0*047.5*06*01*02** 2022-11-29-00:00*-00.08*-00.22*-09.19*11.98*100*02*-00.8*01883*09703*125098*0-0-0-0-0-0*0*00.0*00.0*005.4*05*00*01**|, IDE00061,History data 6,||2024-06-14-00:01*051*+21*-000.1*00.00** 2024-06-14-00:00*044*+24*-000.1*00.00** 2024-06-14-00:00*045*+25*-000.1*00.00** 2024-06-14-14:40*058*+23*-000.1*00.00** 2024-06-12-22:23*038*+24*-000.1*00.00** 2024-06-12-22:22*038*+24*-000.1*00.00** 2024-06-12-20:47*051*+24*-000.1*00.00** 2024-06-12-20:46*050*+24*-000.1*00.00** 2024-06-12-18:49*044*+25*-000.1*00.00** 2024-06-12-18:48*047*+25*-000.1*00.00** 2024-06-12-18:11*045*+25*-000.3*00.00** 2024-06-12-18:11*047*+25*-000.1*00.00** 2024-06-12-15:15*044*+27*-000.1*00.00** 2024-06-12-15:14*045*+27*-000.1*00.00** 2024-06-12-06:12*032*+40*-000.1*00.00** 2024-06-12-06:11*033*+40*-000.1*00.00** 2024-06-12-06:11*034*+40*-000.1*00.00** 2024-06-12-05:03*037*+40*-000.1*00.00** 2024-06-12-05:00*041*+40*-000.1*00.00** 2024-06-12-04:58*042*+40*-000.1*00.00**|, IDE00062,History data 7,||2024-06-14-19:24*058*-006.7*003.2*00.3*00.2** 2024-06-14-00:01*059*-002.5*019.5*00.0*00.0** 2024-06-14-01:04*050*+002.2*000.4*00.0*00.0** 2024-06-14-00:01*057*-002.1*001.0*00.1*00.0** 2024-06-14-22:23*042*+002.0*000.5*00.0*00.0** 2024-06-14-00:01*057*-010.6*022.4*00.6*00.1** 2024-06-14-14:41*039*-008.5*007.5*00.3*00.1** 2024-06-12-22:23*058*-040.6*040.8*02.0*00.8** 2024-06-12-21:12*038*-008.6*001.1*00.5*00.4** 2024-06-12-20:47*049*-000.9*000.3*00.0*00.0** 2024-06-12-20:46*050*-000.1*000.0*00.0*00.0** 2024-06-12-18:49*050*-003.3*001.9*00.1*00.1** 2024-06-12-18:12*047*-001.8*000.6*00.0*00.0** 2024-06-12-18:11*047*-000.1*000.0*00.0*00.0** 2024-06-12-15:15*050*-002.5*002.9*00.1*00.0** 2024-06-12-15:14*046*-000.1*000.0*00.0*00.0** 2024-06-12-06:12*046*-004.8*009.0*00.3*00.0** 2024-06-12-05:04*033*-003.7*001.1*00.3*00.0** 2024-06-12-05:03*037*-000.1*000.0*00.0*00.0** 2024-06-12-05:00*036*-001.1*000.0*00.0*00.0**|, IDE00063,History data 8,||2024-06-15-21:54*1*51*00*00*20*25*2000-01-01-00:00*02** 2024-06-15-18:06*1*50*00*00*20*25*2000-01-01-00:00*02** 2024-06-15-15:42*1*49*00*00*20*25*2000-01-01-00:00*02** 2024-06-14-23:11*1*48*00*00*20*25*2000-01-01-00:00*02** 2024-06-14-21:43*1*47*00*00*20*25*2000-01-01-00:00*02**|, IDE00064,History data 9,||2020-03-12-00:07*043*019*082*027*00000*12.50*+21*02*12.70*00000*00000** 2024-05-24-16:57*070*080*069*039*05523*12.40*+29*02*12.70*00263*00565** 2024-04-15-20:09*070*080*090*054*05502*12.70*+26*02*12.70*00263*00565** 2024-03-14-10:39*070*080*000*000*05402*11.40*+08*02*03.05*00258*00565** 2024-01-25-09:06*062*072*057*026*05091*12.20*+21*02*03.05*00253*00549** 2023-12-29-09:04*064*073*071*031*04835*12.40*+08*02*02.95*00251*00549** 2023-12-01-00:29*066*074*078*040*04678*12.50*+15*02*03.00*00248*00549** 2023-11-04-15:58*070*081*080*047*04334*12.50*+27*02*02.85*00197*00407** 2023-10-07-15:36*074*081*076*047*04101*12.50*+41*02*02.85*00187*00381** 2023-09-11-15:25*077*080*072*045*03939*12.40*+34*02*02.85*00185*00381** 2023-08-14-09:08*079*082*058*036*03766*12.20*+33*02*02.70*00182*00381** 2023-07-18-09:01*078*082*073*047*03492*12.40*+35*02*02.75*00177*00381**|, IDE00065,History data 10,||2023-08-14-11:39*1*000.5*0*000.0*0*000.0*00.00** 2023-08-11-18:37*1*000.1*1*004.8*0*000.0*00.15** 2022-04-05-22:20*0*000.4*0*000.0*0*000.0*00.46** 2022-04-05-22:20*0*000.5*0*000.0*0*000.0*00.45** 2022-04-05-22:18*0*001.2*0*000.0*0*000.0*00.43** 2000-01-01-00:00*0*0*0*00.00** 2000-01-01-00:00*0*0*0*00.00** 2000-01-01-00:00*0*0*0*00.00** 2000-01-01-00:00*0*0*0*00.00** 2000-01-01-00:00*0*0*0*00.00** 2023-08-11-18:42*2*004.8*00.15** 2000-01-01-00:00*0*000.0*00.00** 2000-01-01-00:00*0*000.0*00.00** 2000-01-01-00:00*0*000.0*00.00** 2000-01-01-00:00*0*000.0*00.00** 2023-03-23-12:14*02*15.00*14.85*12.80** 2023-01-05-00:11*01*15.00*14.89*10.00** 2000-01-01-00:00*00*00.00*00.00*00.00** 2000-01-01-00:00*00*00.00*00.00*00.00** 2000-01-01-00:00*00*00.00*00.00*00.00**|, IDE00066,History data 11,||2024-01-29-09:58*000*000*013*000*0097*053*00.2*00.5*081*046*090*054*01*00131*00269*00139*00390*00802** 2024-01-28-23:16*000*000*013*000*0075*042*00.2*00.4*084*049*091*055*01** 2024-01-28-17:06*000*000*000*000*0000*000*00.0*00.1*091*052*091*052*01** 2024-01-28-17:03*000*000*001*000*0001*001*00.0*00.3*092*052*092*052*01** 2024-01-28-16:21*000*000*026*000*0132*084*00.3*00.9*085*048*093*053*01** 2024-01-28-12:34*000*000*004*000*0030*046*00.0*00.4*064*035*091*051*01** 2024-01-28-07:31*000*000*064*000*0831*104*01.1*02.0*087*050*094*055*01** 2024-01-27-21:39*000*000*072*000*1027*149*00.9*04.2*093*060*095*059*03** 2024-01-26-19:21*000*000*000*000*0000*000*00.0*00.0*089*054*089*054*00** 2024-01-26-19:04*000*000*010*001*0116*037*00.4*01.3*089*054*089*054*06**|, IDE00067,History data 12,||2024-03-18-08:54*2*060*029*+16*01*+30.0*-01.2*11.9*0** 2023-09-26-17:56*2*059*028*+34*02*+30.0*+07.5*12.8*1** 2023-09-23-17:24*2*060*032*+33*01*+30.0*-05.4*11.9*1** 2023-08-07-20:05*2*059*034*+53*01*+30.0*+03.8*12.7*1** 2023-06-24-11:49*2*059*023*+35*02*+30.0*+02.2*12.2*1** 00000*00031*00000**|, IDE00068,History data 13,||2023-08-11-18:40*0-1-0-0-0*000.1*00001** 2000-01-01-00:00*0-0-0-0-0*000.0** 2000-01-01-00:00*0-0-0-0-0*000.0** 2000-01-01-00:00*0-0-0-0-0*000.0** 2000-01-01-00:00*0-0-0-0-0*000.0**|, IDE00069,History data 14,||2000-01-01-00:00*00*---*---*----------*00000*00000** 2000-01-01-00:00*00*---*---*----------*00000*00000** 2000-01-01-00:00*0*00*00*00*00*00** 2000-01-01-00:00*0*00*00*00*00*00** 00000*00000*00000** 2024-01-28-13:07*0-0-0-0-1-0-0-0** 2024-01-27-21:39*0-0-0-0-1-0-0-0** 00000*00000*00000*00094*00000*00000*00000*00000** 2000-01-01-00:00*0*000*000*00*00000*00000** 2000-01-01-00:00*0*000*000*00*00000*00000** 00000*00000*00000**|, IDE00070,History data 15,||2000-01-01-00:00*000*00*00*000*00*00*000*00*00** 2000-01-01-00:00*000*00*00*000*00*00*000*00*00** 2000-01-01-00:00*000*00*00*000*00*00*000*00*00** 2000-01-01-00:00*000*00*00*000*00*00*000*00*00** 2000-01-01-00:00*000*00*00*000*00*00*000*00*00** 2000-01-01-00:00*000*00*00*000*00*00*000*00*00** 2000-01-01-00:00*000*00*00*000*00*00*000*00*00** 2000-01-01-00:00*000*00*00*000*00*00*000*00*00** 2000-01-01-00:00*000*00*00*000*00*00*000*00*00** 2000-01-01-00:00*000*00*00*000*00*00*000*00*00**|, IDE00071,History data 16,||146276** 00094*00886*02971*00287*00029** 01188*00082*00041*00006** 10762*00298*00201*00002** 01283*01608*00711*00880** 02775*01286*00421** 00000*00000*00000*00000** 03293*00267*00112*00008** 02390*00047*00006** 00000*00000*00000** 00055*00006*00003** 00177*00099*00072*00051*00045*00038*00057*00039*00031*00079**|, IDE00102,Control Module temperature,34, °C IDE00276,Position in MOST Ring,04, IDE01807,History data 21,||11647*2016-05-31-16:27*0000.4*53*0000.4*00*0000.0*00*0000.0*00*0000.0*00*0000.0** 05601*2014-04-08-12:03*0001.1*3b*0001.1*00*0000.0*00*0000.0*00*0000.0*00*0000.0** 00000*2000-00-00-00:00*0000.0*00*0000.0*00*0000.0*00*0000.0*00*0000.0*00*0000.0** 00000*2000-00-00-00:00*0000.0*00*0000.0*00*0000.0*00*0000.0*00*0000.0*00*0000.0** 00000*2000-00-00-00:00*0000.0*00*0000.0*00*0000.0*00*0000.0*00*0000.0*00*0000.0**|, IDE01808,History data 22,||19*00001*01*00001*02*00001*17*00001*53*00001*09*00001*05*00001*42*00001*52*00001*36*00001**|, IDE01809,History data 23,||25534*2024-01-30-11:46*0021.3*K*00041*06e0*0*06e0*0*06e0*0*06c7*0*06f8*0** 00000*2000-00-00-00:00*0000.0*0*00000*0000*0*0000*0*0000*0*0000*0*0000*0** 00000*2000-00-00-00:00*0000.0*0*00000*0000*0*0000*0*0000*0*0000*0*0000*0** 00000*2000-00-00-00:00*0000.0*0*00000*0000*0*0000*0*0000*0*0000*0*0000*0** 00000*2000-00-00-00:00*0000.0*0*00000*0000*0*0000*0*0000*0*0000*0*0000*0**|, IDE01810,History data 24,||25691*2024-06-13-05:55*0003.8*K*00023*000006e2*002*000006e0*002*000006e3*001*00000000*000*00000000*000** 25672*2024-06-12-06:06*0000.9*K*00024*000006e1*011*000006e0*004*000000ff*003*000006e3*002*000006e2*001** 25534*2024-01-29-23:28*0010.5*K*00056*000006e0*004*000006e6*003*000006e2*002*000006e1*002*000006ea*001** 25534*2024-01-29-15:56*0003.1*K*00029*000006e3*003*000006f8*002*000006e2*002*000006e0*001*00000000*000** 25522*2024-01-29-04:26*0000.9*K*00019*000006e6*007*000006e2*002*000006e3*001*000006f8*001*000006e0*001**|, IDE01811,History data 25,||25644*2024-04-05-00:02*0000.0** 25643*2024-04-05-16:36*0000.0** 25643*2024-04-05-16:32*0000.0** 25643*2024-04-05-16:30*0000.0** 25642*2024-04-05-16:29*0000.5**|, IDE01812,History data 26,||36271*04309*00005*00017*28072*00000*01259*02609**|, IDE01813,History data 27,||30010*04410*03459*20318*00000*00000*01823**|, IDE01814,History data 28,||16885*00000*00000*16885*00000**|, IDE01815,History data 29,||00001*00000*00000*00000*00001*00000*00000*00000**|, IDE01816,History data 30,||00001*00000*00000*00001*00000*00000*00000**|, IDE01817,History data 31,||00000*00000*00000*00000*00000**|, IDE01818,History data 32,||25720*2024-06-16-00:17*0000.0*06e0*0** 25719*2024-06-15-20:55*0000.0*06e0*0** 25715*2024-06-14-22:40*0000.0*06e0*0** 25714*2024-06-14-19:48*0000.0*06e0*0** 25713*2024-06-14-19:32*0000.0*06c7*0**|, IDE01819,History data 33,||25719*2024-06-15-22:08*0001.1*000006c0*L** 25719*2024-06-15-21:54*0000.9*000006c0*L** 25719*2024-06-15-21:05*0000.1*000000ff*M** 25715*2024-06-15-18:23*0019.7*000006c0*L** 25715*2024-06-15-18:06*0019.4*000006c0*L**|, IDE01820,History data 34,||25713*2024-06-14-19:31*0000.0*06e1** 25712*2024-06-14-19:26*0000.0*06e1** 25711*2024-06-14-19:26*0019.4*06e1** 25711*2024-06-14-17:19*0017.3*06e3** 25711*2024-06-14-00:03*0000.0*06e2**|, IDE01821,History data 35,||00000*00001*00050*00000*00004*00002*00000*01269*00170**|, IDE01822,History data 36,||25695*2024-06-13-23:30*0000.3*00000*00000*00030*00000*00000*00000*00000** 25691*2024-06-13-05:55*0003.8*00000*00000*00030*00000*00000*00000*00000** 25680*2024-06-12-18:38*0000.4*00000*00000*00033*00000*00000*00000*00000** 25672*2024-06-12-06:06*0000.9*00000*00000*00031*00000*00000*00000*00000** 25658*2024-06-04-14:42*0158.0*00000*00000*00030*00000*00000*00000*00000**|, IDE01823,History data 37,25721*2012-10-24-15:24*0000.0*0000.0**, IDE01827,Specified generator voltage,10.6, V IDE01828,Generator DF Signal,0.025, % IDE01829,Generator exciter current,0.000, A IDE01830-MAS01632,Generator Status-Status,Thermal OK, IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK, IDE01830-MAS02971,Generator Status-Status 3:,electrically OK, IDE01831-MAS03159,Generator variant-Manufacturer,Hitachi, IDE01831-MAS04490,Generator variant-Size,---, IDE01831-ENG113380,Generator variant-alternator identification_regulator,4, IDE01831-ENG113379,Generator variant-alternator manufacture_regulator,Infineon Technologies AG, IDE01833-MAS03159,Battery version-Manufacturer,Varta, IDE01833-MAS04490,Battery version-Size,105 Ah, IDE01834,Battery voltage,12.396, V IDE01835,Battery current filtered,-14.600, A IDE01836,Battery current,-14.679, A IDE01837,Temperature of battery sensor,27, ° IDE01838,Battery temperature,25, ° IDE01839,Battery charge level,90, % IDE01840,Battery condition for display,90, % IDE01841,Battery internal resistance,3.6, mOhm IDE01842,Usable battery charge,51, Ah IDE01843,Battery voltage at rest,12.7, V IDE01844,Increase idle speed request,not active, IDE01845,Reduce internal fan request,not active, IDE01846,Static current shut-off stage,not active, IDE01847,Auxiliary heater activation restriction request,-, IDE01847-ENG100234,Auxiliary heater activation restriction request-park_heater_target_time,not active, IDE01848,Energy balance of last driving cycle,0.0, Ah IDE01849,Previous journey duration,0.00, H IDE01850,Overall energy balance,9500.0, Ah IDE01851,Entire energy throughput,5689.3, Ah IDE01852,Static current measurement: result,0.03, A IDE01853,Static current measurement: status,Measurement end, IDE01854,Energy reclamation request,not active, IDE01855,Generator current,0.0, A IDE01856,Battery acid stratification,0, % IDE01864-MAS03173,Status of current bus communication-Powertrain data bus,active, IDE01864-MAS03174,Status of current bus communication-Comfort data bus,active: local wakeup event, IDE01864-MAS03175,Status of current bus communication-Extended data bus,active, IDE01864-MAS03176,Status of current bus communication-Display and control head databus,active, IDE01864-MAS03177,Status of current bus communication-Infotainment data bus,active, IDE01864-MAS03178,Status of current bus communication-Suspension data bus,not installed, IDE01864-MAS03179,Status of current bus communication-Local data bus 2,not installed, IDE01864-MAS03180,Status of current bus communication-Local data bus,active, IDE01864-MAS03181,Status of current bus communication-Flexray databus,active, IDE01864-MAS07380,Status of current bus communication-Data bus Sensor/Hybrid,Bus sleep mode, IDE01865-MAS03182,Status flex ray communication-Branch 1,active, IDE01865-MAS03183,Status flex ray communication-Branch 2,active, IDE01865-MAS03184,Status flex ray communication-Branch 3,active, IDE01865-MAS03185,Status flex ray communication-Branch 4,active, IDE01865-MAS03186,Status flex ray communication-Branch 5,not installed, IDE01865-MAS03187,Status flex ray communication-Branch 6,not installed, IDE01865-MAS03188,Status flex ray communication-Branch 7,not installed, IDE01865-MAS03189,Status flex ray communication-Branch 8,not installed, IDE01866,MOST system condition,Configuration OK, IDE01867-IDE01863,MOST hardware parameter-MOST light performance,Decrease 0 dB, IDE01867-MAS03121,MOST hardware parameter-Ring break diagnostic line status,1, IDE01867-MAS03122,MOST hardware parameter-Ring break diagnostic line voltage,25.5, V IDE01867-ENG100178,MOST hardware parameter-HW Instance (MP1-4)_MOST hardware value,0, IDE01868,Ring break diagnostic result,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00, IDE01948,Battery internal resistance not normed,3.0, mOhm IDE01979,Stored key for component protection participants,05 81 48 08 22 40 00 0C 00 00, IDE01980,Component protection participant currently wrongly authent.,00 00 00 00 00 00 00 00 00 00, IDE01981,Comp. protect participant occasionally wrongly authent.,00 00 00 00 00 00 00 00 00 00, IDE01982,Transport protocol used for component protection,01 01 40 00 00 00 00 0C 00 00, IDE01983,Number of successfully repaired keys,0, IDE01984,Number of successful key downloads,0, IDE01985-ENG101043,FAZIT identification test sum-Checksum,D6 D3 9F D7, IDE01985-ENG99027,FAZIT identification test sum-Version,1, IDE01992-ENG100904,Installation list: current installations-ECUs present,|ECU present Bit 0,ECU present Bit 1,ECU present Bit 2,ECU present Bit 3,ECU present Bit 4,ECU present Bit 5,ECU present Bit 6,ECU present Bit 7|not attainable,not attainable,can be reached,not attainable,can be reached,can be reached,can be reached,can be reached|can be reached,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,can be reached|not attainable,not attainable,not attainable,can be reached,not attainable,can be reached,can be reached,can be reached|not attainable,not attainable,not attainable,can be reached,not attainable,not attainable,not attainable,not attainable|not attainable,can be reached,not attainable,can be reached,can be reached,can be reached,can be reached,can be reached|can be reached,can be reached,not attainable,not attainable,not attainable,can be reached,can be reached,not attainable|not attainable,not attainable,not attainable,not attainable,not attainable,can be reached,can be reached,not attainable|can be reached,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable|not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable|not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable|, IDE01993-ENG103664,Control module reference number-ECU IDs,|ECU ID,ECM name|01,Engine Electronics|02,Transmission Electronics|03,Brake electronics|03,Brake electronics|04,Steering angle sensor|05,Access/start authorization|06,Seat adjustment: passenger's side|08,Climate Control Module|09,Electronic central electric|0E,Media Player 1|10,Parallel parking 2|11,Engine electronics 2|13,Distance Regulation|8B,Distance regulation 2|34,Level control system|15,Airbag|16,Steering column electronics systems|17,Instrument cluster|17,Instrument cluster|18,Auxiliary/parking heating|19,Data Bus OBD Interface|1B,Active Steering|1E,Media Player 2|20,High beam assistant|22,All-wheel drive electronics|28,Rear A/C control head|2E,Media Player 3|30,Special Function 2|36,Seat adjustment: driver side|3C,Lane change assistance|3D,Special Function|3E,Media Player 4|42,Driver's door electronics|46,Comfort system central control module|47,Sound System|52,Passenger's door electronics|53,Parking Brake|55,Headlamp range control|56,Radio|57,TV Tuner|85,Camera control module|5F,Information electronics 1|62,Left rear door electronics|26,Convertible top operation|65,Tire Pressure Monitoring System (TPMS)|69,Trailer Function|6C,Rear view camera system|6D,Rear lid electronics|6F,Comfort system central control module 2|72,Right rear door electronics|3B,Sensor Electronics|7F,Information electronics 2|82,Head-Up-Display|84,Night vision system|48,Seat adjustment: rear driver's side|5B,Seat adjustment: rear passenger side|88,Multi contour seat driver's side|89,Multicontour seat passenger side|8A,Multi contour seat rear driver's side|8D,Multi contour seat rear passenger's side|8F,Left front seat belt tensioner|90,Right front seat belt tensioner|AC,Reducing Agent Metering System|44,Power steering|81,Selector lever|8E,Image processing control module|C0,Actuator For Exterior Noise|A9,Structure-borne sound actuator|40,A/C compressor|51,Electric drive|8C,Hybrid Battery Management|BA,Subframe mount|14,Wheel Damping Electronics|00,Unknown (0)|00,Unknown (0)|00,Unknown (0)|00,Unknown (0)|00,Unknown (0)|00,Unknown (0)|00,Unknown (0)|, IDE01995-ENG103538,Control module protocol information-ECUs DiagProt,|ISO-TP,TP 2.0,TP 1.6,K Line,Ethernet|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,No,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|No,No,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|Yes,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|, IDE01996-ENG99724,Installation list: specified installations-ECU coded,|ECU coded Bit 0,ECU coded Bit 1,ECU coded Bit 2,ECU coded Bit 3,ECU coded Bit 4,ECU coded Bit 5,ECU coded Bit 6,ECU coded Bit 7|Yes,No,Yes,Yes,Yes,Yes,Yes,Yes|Yes,No,No,No,No,Yes,No,Yes|No,No,No,Yes,No,Yes,Yes,Yes|No,No,Yes,Yes,No,No,Yes,No|No,Yes,Yes,Yes,Yes,Yes,Yes,Yes|Yes,Yes,No,No,No,Yes,Yes,No|No,No,No,No,No,Yes,Yes,No|Yes,No,Yes,Yes,No,No,No,No|No,No,No,No,No,No,No,No|No,No,No,No,No,No,No,No|, IDE02384-ENG102478,Status of event memory-ECU Dtcs,|ECU Dtc Bit 0,ECU Dtc Bit 1,ECU Dtc Bit 2,ECU Dtc Bit 3,ECU Dtc Bit 4,ECU Dtc Bit 5,ECU Dtc Bit 6,ECU Dtc Bit 7|OK,OK,Malfunction,OK,Malfunction,Malfunction,Malfunction,Malfunction|Malfunction,OK,OK,OK,OK,OK,OK,Malfunction|OK,OK,OK,Malfunction,OK,Malfunction,Malfunction,Malfunction|OK,OK,OK,Malfunction,OK,OK,OK,OK|OK,Malfunction,OK,Malfunction,Malfunction,Malfunction,Malfunction,Malfunction|Malfunction,Malfunction,OK,OK,OK,OK,Malfunction,OK|OK,OK,OK,OK,OK,OK,OK,OK|Malfunction,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|, IDE03008-ENG98388,Stop process prevented-Battery state of charge too low,0, IDE03008-ENG98389,Stop process prevented-Battery temperature,0, IDE03008-ENG99012,Stop process prevented-Consumer/component current too high,0, IDE03008-ENG103231,Stop process prevented-Entnehmbare Ladung zu gering,0, IDE03008-ENG98719,Stop process prevented-Idle increase active,0, IDE03008-ENG122800,Stop process prevented-Intermittierender Betrieb aktiv,0, IDE03008-ENG98746,Stop process prevented-Possible standing time too short,0, IDE03008-ENG103267,Stop process prevented-Sonderveto aktiv,0, IDE03008-ENG104139,Stop process prevented-Veto DC/DC Wandler,0, IDE03009-ENG98388,Start process requested-Battery state of charge too low,0, IDE03009-ENG104067,Start process requested-Charge contingency,0, IDE03009-ENG99104,Start process requested-Entnehmbare Ladung,0, IDE03009-ENG99021,Start process requested-insufficient voltage,0, IDE03009-ENG101118,Start process requested-Stromverbrauch,0, IDE03009-ENG102869,Start process requested-Zielzeit abgelaufen,0, IDE03127,Prevented stop processes (ring memory),||2024-01-24-23:08*1-0-0-0-1-0-0-0** 2024-01-24-23:06*1-0-0-0-1-0-0-0** 2024-01-24-23:05*1-0-0-0-1-0-0-0** 2023-11-15-01:29*1-0-0-0-0-0-0-0** 2023-11-15-01:28*1-0-0-0-0-0-0-0** 00197*00000*00000*00000*00069*00000*00000*00000**|, IDE03128,Requested start processes (ring memory),||2021-01-28-16:55*0-0-0-0-1-0-0-0** 2018-02-09-19:02*0-0-1-0-0-0-0-0** 2017-12-29-12:02*0-0-1-0-0-0-0-0** 2017-12-17-09:57*0-0-1-0-0-0-0-0** 2017-12-13-20:23*0-0-1-0-0-0-0-0** 00000*00000*00000*00000*00001*00000*00000*00000**|, IDE03150-ENG113353,Readiness for bus sleep mode-ECU Sleepready New,|ECU SleepReady Bit0,ECU SleepReady Bit1,ECU SleepReady Bit2,ECU SleepReady Bit3,ECU SleepReady Bit4,ECU SleepReady Bit5,ECU SleepReady Bit6,ECU SleepReady Bit7|can be reached,can be reached,not attainable,not attainable,not attainable,can be reached,not attainable,can be reached|not attainable,can be reached,not attainable,not attainable,can be reached,not attainable,can be reached,not attainable|not attainable,can be reached,not attainable,can be reached,can be reached,not attainable,not attainable,not attainable|can be reached,can be reached,not attainable,not attainable,can be reached,can be reached,can be reached,not attainable|can be reached,not attainable,not attainable,not attainable,not attainable,not attainable,can be reached,not attainable|not attainable,not attainable,can be reached,can be reached,can be reached,can be reached,not attainable,not attainable|can be reached,can be reached,not attainable,can be reached,can be reached,can be reached,can be reached,can be reached|can be reached,can be reached,not attainable,not attainable,can be reached,can be reached,can be reached,can be reached|not attainable,can be reached,can be reached,not attainable,not attainable,not attainable,not attainable,not attainable|not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable|, IDE03151,TP CAN identifier,|TP CAN identifier|00 00|00 00|07 13|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|07 57|07 56|07 55|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|07 1D|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|07 21|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|07 12|00 00|07 58|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|, IDE03212,Start/stop conditions,Stop release, IDE03213,Start/stop enable,Not available, IDE03897,Generator: status communication,active, IDE03898,Voltage stabilizer: status communication,active, IDE03899,Battery monitoring control module: status communication,active, IDE06747-IDE01834,Battery Monitoring Control Module 2-Battery voltage,4.000, V IDE06747-IDE01836,Battery Monitoring Control Module 2-Battery current,-32.768, A IDE06747-IDE01838,Battery Monitoring Control Module 2-Battery temperature,-40, ° IDE06747-IDE01839,Battery Monitoring Control Module 2-Battery charge level,0, % IDE06747-IDE01841,Battery Monitoring Control Module 2-Battery internal resistance,0.0, mOhm IDE06747-IDE01948,Battery Monitoring Control Module 2-Battery internal resistance not normed,0.0, mOhm IDE06747,Battery Monitoring Control Module 2,not active, IDE06747-ENG113366,Battery Monitoring Control Module 2-battery current puls,0, IDE06747-ENG113365,Battery Monitoring Control Module 2-battery voltage puls,9.000, V IDE06747-ENG113367,Battery Monitoring Control Module 2-BZE_Min_puls_duration,0, ms IDE06747-ENG113368,Battery Monitoring Control Module 2-BZE_Min_trigger,0, IDE06747-ENG101157,Battery Monitoring Control Module 2-BZE_Q_Elad,0.0, Ah IDE06747-ENG100159,Battery Monitoring Control Module 2-BZE_Q_Lad,0.0, Ah IDE06747-ENG106125,Battery Monitoring Control Module 2-EM_blBatteryDisconnected,connected, IDE06747-ENG98970,Battery Monitoring Control Module 2-Temperature of battery sensor,-40, ° ENG107689-IDE01868,Automatic loop break diagnosis-Ring break diagnostic result,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00, ENG107689-MAS00043,Automatic loop break diagnosis-Terminal 30 power supply,0.0, V ENG107689-MAS00711,Automatic loop break diagnosis-Odometer reading,0, km ENG107689-MAS01230,Automatic loop break diagnosis-Date,00.00.2000, ENG107689-MAS02957,Automatic loop break diagnosis-Time,00:00, ENG105315-ENG103971,BCmE_Versionnumber-Patch,2, ENG105315-ENG98889,BCmE_Versionnumber-Release,5, ENG111625-MAS00106,Break recommendation-Year,2000, ENG111625-MAS00107,Break recommendation-Month,0, ENG111625-MAS00108,Break recommendation-Day,0, ENG111625-MAS00109,Break recommendation-Hours,0, ENG111625-MAS00110,Break recommendation-Minutes,0, ENG111625-ENG151621,Break recommendation-Deaktiviert durch EEPROM-Wert,No, ENG111625-ENG151620,Break recommendation-Deaktiviert durch falschen Datensatz,Yes, ENG111625-ENG113361,Break recommendation-PE_Art_der_Meldung,Initialization, ENG111625-ENG113357,Break recommendation-PE_Einstellung,active, ENG111625-ENG113359,Break recommendation-PE_Fehlercode,not installed, ENG111625-ENG113362,Break recommendation-PE_Index_HFC_TP,1.000, ENG111625-ENG113358,Break recommendation-PE_Stufe,0, ENG105771-ENG102240,DCDC_First_Branch-DC_STST1_Bypassrelais_defekt_TW1,0, ENG105771-ENG102373,DCDC_First_Branch-DC_STST1_El_Fehler_Ausgang_KS_TW1,0, ENG105771-ENG104027,DCDC_First_Branch-DC_STST1_Lastabschaltung_TW1,0, ENG105771-ENG101272,DCDC_First_Branch-DC_STST1_Uebertemperatur_TW1,0, ENG105771-ENG100694,DCDC_First_Branch-DC_STST1_Unterspannung_Eingang_TW1,0, ENG105772-ENG102945,DCDC_Second_Branch-DC_STST1_Bypassrelais_defekt_TW2,0, ENG105772-ENG99327,DCDC_Second_Branch-DC_STST1_El_Fehler_Ausgang_KS_TW2,0, ENG105772-ENG100692,DCDC_Second_Branch-DC_STST1_Lastabschaltung_TW2,0, ENG105772-ENG100445,DCDC_Second_Branch-DC_STST1_Uebertemperatur_TW2,0, ENG105772-ENG101117,DCDC_Second_Branch-DC_STST1_Unterspannung_Eingang_TW2,0, ENG105773-ENG100371,DCDC_STST_Status-DC_STST1_Boost,0, ENG105773-ENG101192,DCDC_STST_Status-DC_STST1_Defekt,0, ENG105773-ENG101605,DCDC_STST_Status-DC_STST1_ErrorGueltigkeit,1, ENG105773-ENG103583,DCDC_STST_Status-DC_STST1_Fail,0, ENG105773-ENG103918,DCDC_STST_Status-DC_STST1_Fktbereit,0, ENG105773-ENG102020,DCDC_STST_Status-DC_STST1_Lokalaktiv,0, ENG105773-ENG103598,DCDC_STST_Status-DC_STST1_Stromgrenze,0, ENG105773-ENG99195,DCDC_STST_Status-DC_STST1_Uebertemperatur,0, ENG113398,EM Produktionsmodus Freigabe,1, ENG113397,EM RSM Freigabe,1, ENG106120,EM_battery identification known,known, ENG106121-ENG101157,EM_Battery_charge_discharge-BZE_Q_Elad,5659.8, Ah ENG106121-ENG100159,EM_Battery_charge_discharge-BZE_Q_Lad,4816.2, Ah ENG106122,EM_battery_identification,13, ENG106123,EM_blAlternator On,OFF, ENG106124,EM_blAlternator Valid,Yes, ENG106125,EM_blBatteryDisconnected,connected, ENG106126,EM_blBemSleepRdy,0, ENG106127,EM_blBoostRecognised,detected, ENG106128,EM_blCanMostActive,1, ENG106129,EM_blControlKFan,0, ENG106130,EM_blDisconnectionAdeptChannel,0, ENG106131,EM_blMmi Advance Warning,0, ENG106132,EM_blMmi Advance Warning Diag,0, ENG106133,EM_blParkHeatingEncoded,Not coded, ENG106134,EM_blRecuperation Encoded,coded, ENG106135,EM_blRecuperation Enforce,Not coded, ENG106136,EM_blSleepIndication,1, ENG106137,EM_blStabilisation EBalance,0, ENG106138,EM_blStabilisation EPowerSystem,0, ENG106139,EM_blVnaActive,0, ENG106140,EM_Current_Control_Recu,not active, ENG121181,EM_Energiebilanz_2,10000.0, Ah ENG106141,EM_errEBalanceDiag,0, ENG106142,EM_errEPowerSystem,0, ENG106143,EM_errOverVoltage,0, ENG113400-ENG113369,EM_Hybrid_Info-Hybrid_Info,Motorstart_ueber_12V_Starter_nur_bei_0kmh_moeglich, ENG106144,EM_IAlternator L1,0.0, A ENG106145,EM_IAlternator Reserve,0.0, A ENG106146,EM_IInternalFan,0.25, A ENG106147,EM_IKmStandTm Active,0, km ENG106148,EM_IKmStandTmActiveIn,68, km ENG106149,EM_INeutralBem,-4.072, A ENG106150,EM_IParkHeatingRequirements,10, A ENG121178,EM_Ladestrombegrenzung,not active, ENG106151,EM_Load Response Time,6.00, s ENG106160-ENG102785,EM_loss_of_voltage / param_specified_capacity-Battery technology,Batterietechnologie unbekannt, ENG106160-ENG100745,EM_loss_of_voltage / param_specified_capacity-BZE_DeltaUStart_Aktuell,12.70, V ENG106160-ENG101482,EM_loss_of_voltage / param_specified_capacity-BZE_DeltaUStart_Mittel,12.70, V ENG106160-ENG102509,EM_loss_of_voltage / param_specified_capacity-BZE_DeltaUStart_Trigger,1, ENG106160-ENG102743,EM_loss_of_voltage / param_specified_capacity-BZE_MinUStart,14.70, V ENG106160-ENG101108,EM_loss_of_voltage / param_specified_capacity-BZE_MinUStart_Trigger,1, ENG106160-ENG100156,EM_loss_of_voltage / param_specified_capacity-BZE_Q_Nom,100, Ah ENG106160-ENG100059,EM_loss_of_voltage / param_specified_capacity-Nenn Kapazität,Init, ENG106152,EM_MAlternator,0.0, Nm ENG106153,EM_NDisconnectionEngineSpeed,5990, /min ENG106154,EM_PAltMechanical,0, W ENG106155-ENG99338,EM_prcSoh-prc SohP,80, % ENG106155-ENG101494,EM_prcSoh-prc SohQ,70, % ENG106156,EM_PReserveFilter,0, W ENG106157-ENG101729,EM_RecuMode_Engine-Modus Rekuperation (Motor),Acceleration limited, ENG106159-ENG102920,EM_Recuperation_Prerequisite-Auslastung des Generators,1, ENG106159-ENG100983,EM_Recuperation_Prerequisite-Batteriealterung (Ladung),1, ENG106159-ENG99619,EM_Recuperation_Prerequisite-Batteriealterung (Leistung),1, ENG106159-ENG102670,EM_Recuperation_Prerequisite-Batterieregeneration,1, ENG106159-ENG103895,EM_Recuperation_Prerequisite-Energie Netz,1, ENG106159-ENG99263,EM_Recuperation_Prerequisite-Energiedurchsatz,1, ENG106159-ENG99104,EM_Recuperation_Prerequisite-Entnehmbare Ladung,1, ENG106159-ENG99756,EM_Recuperation_Prerequisite-Generatordiagnose,1, ENG106159-ENG103581,EM_Recuperation_Prerequisite-Ladezustand der Batterie,1, ENG106159-ENG100106,EM_Recuperation_Prerequisite-Leerlaufanhebung,1, ENG106159-ENG104009,EM_Recuperation_Prerequisite-LIN-Kommunikation,1, ENG106159-ENG98425,EM_Recuperation_Prerequisite-Outside temperature,1, ENG106159-ENG102570,EM_Recuperation_Prerequisite-Säureschichtung,1, ENG106159-ENG101873,EM_Recuperation_Prerequisite-Sonderveto,1, ENG106159-ENG103261,EM_Recuperation_Prerequisite-Spannung der Batterie,1, ENG106159-ENG103394,EM_Recuperation_Prerequisite-Temperatur der Batterie,1, ENG106158-ENG104224,EM_Recuperation_Restriction-Abblendlicht Aktiv,0, ENG106158-ENG99969,EM_Recuperation_Restriction-Auslastung Innegeblaese Hoch,0, ENG106158-ENG103587,EM_Recuperation_Restriction-Bauteilschutz BDM,0, ENG106158-ENG102567,EM_Recuperation_Restriction-Bauteilschutz Fernlicht,0, ENG106158-ENG101156,EM_Recuperation_Restriction-Blinker links Aktiv,0, ENG106158-ENG101146,EM_Recuperation_Restriction-Blinker rechts Aktiv,0, ENG106158-ENG113355,EM_Recuperation_Restriction-EPS Leistunsanforderung,0, ENG106158-ENG101898,EM_Recuperation_Restriction-ESP-Anforderung,0, ENG106158-ENG99511,EM_Recuperation_Restriction-Innenlicht Aktiv,1, ENG106158-ENG102650,EM_Recuperation_Restriction-Motor-Anforderung,0, ENG121180-ENG121171,EM_Rekuperation_Sonderveto-Sonderveto_Anhaenger,No, ENG121180-ENG121172,EM_Rekuperation_Sonderveto-Sonderveto_Klima,No, ENG121180-ENG121174,EM_Rekuperation_Sonderveto-Sonderveto_Motor_Spannungsanforderung,No, ENG121180-ENG121170,EM_Rekuperation_Sonderveto-Sonderveto_Produktion,No, ENG121180-ENG121169,EM_Rekuperation_Sonderveto-Sonderveto_Transportmodus,No, ENG121180-ENG121173,EM_Rekuperation_Sonderveto-Sonderveto_Zustart_Batterie,No, ENG106161-ENG102992,EM_Start_Stop_State-Mögliche Stoppzeit,13, ENG106161-ENG100942,EM_Start_Stop_State-Start Stopp Phase,Phase 1, ENG106161-ENG103632,EM_Start_Stop_State-Status Motorstopp,not active, ENG106161-ENG102878,EM_Start_Stop_State-Status Wiederstart,not active, ENG106161-ENG100005,EM_Start_Stop_State-Stromverbrauchsschätzung Stoppphase,30, A ENG106162-ENG101997,EM_Start_Stop_System_Error / system fault DC-Batterie zyklisch verbraucht,0, ENG106162-ENG103373,EM_Start_Stop_System_Error / system fault DC-Battery fault,0, ENG106162-ENG99392,EM_Start_Stop_System_Error / system fault DC-Fehler Diagnosesignal DC/DC-Wandler,0, ENG106162-ENG102635,EM_Start_Stop_System_Error / system fault DC-Generator malfunction,0, ENG106162-ENG101407,EM_Start_Stop_System_Error / system fault DC-Start/Stopp-Koordinator unplausibel,0, ENG106162-ENG122799,EM_Start_Stop_System_Error / system fault DC-Systemfehler BDM Defekt,0, ENG106162-ENG100042,EM_Start_Stop_System_Error / system fault DC-Systemfehler DC/DC-Wandler,0, ENG106163-ENG99559,EM_tSgErrors-tSgError IO Duration tSgErrors,0, min ENG106163-ENG100405,EM_tSgErrors-tSgError NIO Duration tSgErrors,2, min ENG106163-ENG100563,EM_tSgErrors-tSgErrorDuration In tSgErrors,0, s ENG106163-ENG103494,EM_tSgErrors-tSgErrorDuration tSgErrors,0, s ENG106164,EM_UControlUnit,12.320, V ENG106165,EM_Ustart,6.5, V ENG106166,EM_valBdm LinTableSwitch,Terminal 15 on, ENG106167,EM_valBdm WakeUpReason,0, ENG106168,EM_valEngineId,4, ENG106169,EM_valHlkLevelRequirement,1, ENG106170,EM_valStatusHlk,0, ENG106171-ENG103971,EM_Versionnumber-Patch,6, ENG106171-ENG98889,EM_Versionnumber-Release,12, ENG113401-ENG113374,EM_Zustart Freigabe-Freigabe Aussentemperatur,Yes, ENG113401-ENG113370,EM_Zustart Freigabe-Freigabe Batterietemperatur (Bat1),Yes, ENG113401-ENG113372,EM_Zustart Freigabe-Freigabe Batterietemperatur (Bat2),Yes, ENG113401-ENG113371,EM_Zustart Freigabe-Freigabe Entnehmbare Ladung (Bat1),Yes, ENG113401-ENG113373,EM_Zustart Freigabe-Freigabe Leistungsfähigkeit Zustart,No, ENG121179-ENG121165,EM_Zustart_Systemfehler-EM_BatterieAb_BDM1,No, ENG121179-ENG121166,EM_Zustart_Systemfehler-EM_BatterieAb_BDM2,No, ENG121179-ENG121167,EM_Zustart_Systemfehler-EM_LIN1_ungueltig,No, ENG121179-ENG121168,EM_Zustart_Systemfehler-EM_LIN2_ungueltig,No, ENG113402-ENG113377,GW_Bap_Status-Lifecycle,run, ENG113402-ENG99775,GW_Bap_Status-MOST,On, ENG113402-ENG113378,GW_Bap_Status-PE_Freigabe,0, ENG106825,GW_SYS_BEM_SleepReady,EM active, ENG106826,GW_SYS_BM_Run-on,60, s ENG106827-ENG100038,GW_SYS_CPU_Load-CPU Load,0, % ENG106827-ENG113384,GW_SYS_CPU_Load-Task Level 1,0, % ENG106827-ENG113383,GW_SYS_CPU_Load-Task Level 2,0, % ENG106827-ENG113382,GW_SYS_CPU_Load-Task Level 3,0, % ENG106827-ENG113381,GW_SYS_CPU_Load-Task Level 4,0, % ENG106828,GW_SYS_EEPROM Repair,0, ENG106832-ENG100323,GW_SYS_LastWakeupReason-Car WakeUp Reason,Comfort data bus, ENG106832-ENG99403,GW_SYS_LastWakeupReason-Gateway WakeUp Reason,Comfort data bus, ENG106833,GW_SYS_Reset_Count,0, ENG106834,GW_SYS_ResetReason,Power On Reset, ENG100548-MAS00049,GW_SYS_State-Component protection,not active, ENG100548-MAS00795,GW_SYS_State-Data Bus On Board Diagnostic Interface,active, ENG100548-MAS01468,GW_SYS_State-Terminal 15,active, ENG100548-MAS01490,GW_SYS_State-Energy management,not active, ENG100548-MAS03173,GW_SYS_State-Powertrain data bus,not active, ENG100548-MAS03174,GW_SYS_State-Comfort data bus,not active, ENG100548-MAS03175,GW_SYS_State-Extended data bus,active, ENG100548-MAS03176,GW_SYS_State-Display and control head databus,not active, ENG100548-MAS03177,GW_SYS_State-Infotainment data bus,active, ENG100548-MAS03178,GW_SYS_State-Suspension data bus,not active, ENG100548-MAS03180,GW_SYS_State-Local data bus,active, ENG100548-MAS03181,GW_SYS_State-Flexray databus,not active, ENG100548-ENG102839,GW_SYS_State-A-Can Flexray F-Can SubMaster,active, ENG100548-ENG100518,GW_SYS_State-Busmonitor,active, ENG100548-ENG98571,GW_SYS_State-EEPROM,active, ENG100548-ENG99046,GW_SYS_State-Emergency signal flashing,not active, ENG100548-ENG100049,GW_SYS_State-K-Can Dash-Can SubMaster,active, ENG100548-ENG102799,GW_SYS_State-Mindestaktivzeit,active, ENG106837,GW_SYS_TP20_Counter,0, ENG110999,GW_Watchdog_Version,0, ENG100189,IN ESP_standstill flag,1, ENG100411,IN ESP_v_Signal,0, km/h ENG100786,IN HW terminal 15,1, ENG101017,IN KBI_odometer_reading,146276, ENG101398,IN MO_engine_speed_01,0.00, /min ENG103286,IN MO_Motor_running,0, ENG106958-MAS00106,IN time_01-Year,2024, ENG106958-MAS00107,IN time_01-Month,6, ENG106958-MAS00108,IN time_01-Day,16, ENG106958-MAS00109,IN time_01-Hours,0, ENG106958-MAS00110,IN time_01-Minutes,24, ENG106958-MAS00111,IN time_01-Seconds,17, ENG106958-MAS00690,IN time_01-Daylight saving time,Winter time, ENG106958-ENG103328,IN time_01-type of clock,Quartz_crystal, ENG101569,IN ZAS_Te_15,1, ENG103048,IN ZAS_Te_X,1, ENG107685-ENG103912,MOST Deattaches-deatatch counter_MOST Deatatches,0, ENG107685-ENG99643,MOST Deattaches-present deatatch counter_MOST Deatatches,0, ENG107685-ENG100756,MOST Deattaches-present status_MOST Deatatches,connected, ENG102460,MOST Notifications,|Function ID,Target Adress 1,Target Adress 2,Target Adress 3|00 00,00 00,00 00,00 00|00 00,00 00,00 00,00 01|00 00,00 00,00 00,00 00|00 00,00 00,00 02,00 00|00 00,00 00,00 00,00 00|00 00,0C FE,00 00,00 00|00 00,00 00,00 00,00 00|0C FF,00 00,00 00,00 00|00 00,00 00,00 00,0E 02|01 00,00 00,00 00,00 00|00 00,00 00,0E 03,03 FF|00 00,00 00,00 00,00 00|00 00,0E 04,03 FF,00 00|00 00,00 00,00 00,00 00|0E 05,01 00,00 00,00 00|00 00,00 00,00 00,0E 06|03 FF,00 00,00 00,00 00|00 00,00 00,0E 10,03 FF|00 00,00 00,00 00,00 00|00 00,0E 24,03 FF,00 00|00 00,00 00,00 00,00 00|0E 30,03 FF,00 00,00 00|00 00,00 00,00 00,0E 31|03 FF,00 00,00 00,00 00|00 00,00 00,0E 32,03 FF|00 00,00 00,00 00,00 00|00 00,0E 33,00 00,00 00|00 00,00 00,00 00,00 00|0E 34,00 00,00 00,00 00|00 00,00 00,00 00,0E 36|00 00,00 00,00 00,00 00|00 00,00 00,0E 38,00 00|00 00,00 00,00 00,00 00|00 00,0E 3C,00 00,00 00|00 00,00 00,00 00,00 00|0E 3E,00 00,00 00,00 00|00 00,00 00,00 00,0E 3F|00 00,00 00,00 00,00 00|00 00,00 00,0E 40,00 00|00 00,00 00,00 00,00 00|00 00,0E A0,01 00,00 00|00 00,00 00,00 00,00 00|0E A1,01 00,00 00,00 00|00 00,00 00,00 00,0E A2|, ENG107869-ENG102318,NW_MOST Addressing-diag inst-id,19, ENG107869-ENG101908,NW_MOST Addressing-groupadress,03 FF, ENG107869-ENG101657,NW_MOST Addressing-logical adress,05 19, ENG107869-ENG99161,NW_MOST Addressing-vehicle inst-id,01, ENG107870-ENG100752,NW_MOST net mngmt status-Configuration_NW_MOST Networkmanagment.Status,New, ENG107870-ENG99305,NW_MOST net mngmt status-MMI_State_NW_MOST Networkmanagment.Status,MMI_On, ENG107870-ENG103488,NW_MOST net mngmt status-ShutDownState_NW_MOST Networkmanagment.Status,normal operation, ENG107870-ENG104176,NW_MOST net mngmt status-Systemstate_NW_MOST Networkmanagment.Status,normal operation, ENG107948,OUT_Alternator_reference_voltage_value,10.6, V ENG107949,OUT_GW_Aging_counter_DIAG_01_message,251, ENG102605,outside_temperature,26.0, °C ENG113399-ENG113364,PE_Version-DS_Version,., ENG113399-ENG109174,PE_Version-SW_VERSION,5.0, ENG107686-IDE00317,Reset date for counter: sporadic loop breaks-Date,00.00.2000, ENG110089,Warm-Up-Cycle Counter (zVZ),0, Elapsed Time: 00:38
That is your starting point !!
ERWIN. Wiring Diagrams, Powers, Grounds, CAN Lines with a Scope !! And a Micro Amp Clamp to confirm the Direction of CAN Transmissions - Bi Directional is a Must !!!
Not sure what waffle is.You made my Eyes hurt !!
You have over complicated this to the point that you will quite likely destroy the car !!
Have you done that successfully ?
Hard to tell with the thread populated with so much waffle
Are you allowed to drive ?![]()
I was told by EuroX to check IDE channel which didn't require any scope
Pretty sure I'm allowed to drive and not sure how that relates to my question. Maybe I was asking about IDE because I was told by EuroX to check IDE channel which didn't require any scope or additional testing components so I figured I'd start there.
I did check wiring diagrams and follow power from battery to ECU. I am relatively certain now that issue is with communication on Can Bus, so I'm working on learning how to test with my scope.
Again, this is all new to me as, up until now, I've never used VCDS for anything other than making my gauges sweep or roll down windows with unlock button. I have never used scope or anything like that so I'm learning as I go, bro!
Well, I am realizing that as well! Thanks for the guidance. I don't mean to bite the hand that feeds me so I appreciate the advice.There is nothing in Automotive Electronics on this planet that can replace the eyes of a scope for non Intrusive analysis !!
I stand to be corrected !!
Stand alone or with BNC or 4mm Banana ?Micro amp clamps are in the process of being ordered
Looking for ones with BNC connector for my Rigol scope. Not sure which would be best. I see ones varying in price from $69 to $500Stand alone or with BNC or 4mm Banana ?
I would disagree, in this field quick and dirty method always wins. NO ONE will whip out a scope for a no start on EVERY single vehicle. Quick and dirty always wins. Scope only comes in useful if you think you have a dirty signal or a sensor that's on the frits. Rule number one is always check the basics. Power, ground and comms. It looks like gateway see terminal 15 and terminal 30. Question is if your getting terminal 15 and terminal 30 at the pin at the ecm?There is nothing in Automotive Electronics on this planet that can replace the eyes of a scope for non Intrusive analysis !!
No comms with ECU does not need this level of Complication or Drama
I have a pico scope pwm box and signal generator. I only deal with vw and audi vehicles at the shop and the occasional high end garbage like ferrari, maserati and a few others. Scope comes out as a last resort as I can check just about everything with my powerprobe 5. Plus my ODIS has a scope attached to it for checking signals and such. Again unless I have some oddball faults It ain't coming out. Bypassing a relay is a few seconds rather than setting up a scope. Just my opinion. Everyone does things differently.I do
I have a Pico set up in the workshop on a trolley which I switch on with the kettle It is ready to go !
Then I have 2x Handheld 2 channel Scopes
Snap On M2 https://www.techshopmag.com/tool-of-the-month-new-verdict-m2-two-channel-scope-meter/
and the Fluke 123
Then a couple of Power probes
And an assortment of bulbs wired up for load testing
A decade box
A Signal Generator
PWM controller
With those few items I can test and prove 90% of the work thrown at me.
For example I had a intermittent Cooling Fan Failure on a MINI. Using a break out lead I put the scope on each of the 4 relay pins and the 5th on Temp Sensor so I could see what 30, 85, 86, 87 were doing Set a slow timebase on the scope and let it run. Left the car in the corner to run. It took best part 3 hours and god knows how many times the fan switched correctly to catch the failure !!
10 minute set up time !!
I could monitor that with Teamviewer from the other side of the world !!
The scope works !!
Perhaps I should rephrase and say "it works for me"
