2013 Audi A7 doesn't crank/start.
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
So a little bit of history. Picked this car up a few days ago from a local auction. Key "works" to open doors, turn on car via start/stop button, open trunk, sense proximity to unlock, but will not start the engine. I am posting logs where you see "No Communication with module" numerous times. Some of the modules show "Open circuit" because someone decided to rob the car of some items. There include, but are not limited to: front HVAC module, front vent with hazards and screen button, Rear HVAC control module, rear power outlet. Watched a few videos where people were testing continuity of modules from ODB port and various other things, but I'm wondering if there is anything in this log that shows why the car would refused to crank?
Any and all ideas will be considered and I appreciate anyone who takes the time to give an answer, even if it's something you think I've already tried.
Saturday,06,July,2024,13:54:35:10725
Mileage: 146276km-90891mi   Repair Order:
Chassis Type: 4G0
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 47 52
          53 55 56 5F 62 6C 6D 72 8F 90
   Mileage: 146276km-90891miles
04-Steering Angle -- Status: Cannot be reached 0100
08-Auto HVAC -- Status: Cannot be reached 0100
10-Park/Steer Assist -- Status: Cannot be reached 0100
28-HVAC, Rear -- Status: Cannot be reached 0100
3C-Lane Change -- Status: Cannot be reached 0100
55-Headlight Range -- Status: Cannot be reached 0100
8F-Pretens. Frt Left -- Status: Cannot be reached 0100
90-Pretens. Frt Right -- Status: Cannot be reached 0100
Address 01: Engine
   Part No SW: 4G1 927 158 A    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H16 1006
   Revision: --H16---    CVN: 06AF4385
   Coding: 000002
   ROD: EV_TCMAL551211_002_AU48.rod (VIN: N/A)
   VCID: 2D0704E0ED93A032CC5-8078
12544 - Power Supply Terminal 15
          P3325 00 [00100111] - Implausible
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:27
                    Voltage terminal 30: 12.502 V
                    Transmission input speed: 0.00 /min
                    Transmission output speed: 0.00 /min
                    Engine torque: 0 Nm
                    ATF temperature: 24 °C
                    Accelerator pedal position: 14.9 %
                    M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
                    M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
                    M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Coasting
                    Engine RPM: 0 /min
                    Transfer speed from ESP: 0.00 km/h
                    Transfer speed from ESP: valid
12561 - No Communications with Steering Angle Sender (G85)
          U0126 00 [00100111] - -
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:25
                    Engine RPM: 0 /min
                    Status data bus communication diagnostic interface-State Deashboard received: not received
                    Status data bus communication diagnostic interface-State ECM received: not received
                    Status data bus communication diagnostic interface-State ESP received: not received
                    Status data bus communication diagnostic interface-State Gateway received: not received
                    Status data bus communication diagnostic interface-State Parking Brake received: not received
                    Status data bus communication diagnostic interface-State Steering Angle received: not received
                    Status data bus communication diagnostic interface-State Steering Assist received: not received
12626 - No Communications with HVAC Control Module (J301)
          U0164 00 [00100111] - -
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:25
                    Engine RPM: 0 /min
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 44A78F0322E5F1C05B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004028
   ROD: EV_ESPPremiAU57X_004_AU57.rod (VIN: N/A)
   VCID: 36352B8C18C5E3EABDF-8062
9 Faults Found:
0067 - Function Restricted due to Missing Message(s)
          U1111 00 [10001001] - -
          [ComScl_PDU_LWI_01_Timeout]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:24
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DB
                    Uz: A0
0781 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [ComScl_PDU_LWR_AFS_01_Timeout]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:24
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DE
                    Uz: A0
0604 - Tire Pressure Warning
          C102D 00 [00001001] - -
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:24
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 28
                    Uz: A0
0629 - Tire Pressure Warning
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:24
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 2C
                    Uz: A0
0838 - Function Restriction due to Faults in Other Modules
          U1113 00 [10000001] - -
          [SCL_MO_Mom_Begrenzung_Invalid]
0727 - Function Restriction due to Implausible Message(s)
          U1112 00 [10000001] - -
          [SCL_MO_Mom_Fahrerwunsch_Invalid]
0729 - Function Restriction due to Implausible Message(s)
          [SCL_MO_Mom_Verlust_Invalid]
0731 - Function Restriction due to Implausible Message(s)
          [SCL_MO_Mom_m_ex_Invalid]
0787 - Function Restriction due to Implausible Message(s)
          U1112 00 [10001001] - -
          [SCL_MO_Motormomente_Invalid]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:24
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: E6
                    Uz: A0
   Part No SW: 4H0 907 064 CR    HW: 4H0 907 064 CR
   Component: BCM2 2.0      H32 0421
   Coding: 0DAA2046000000000000
   VCID: 7BA3FAB863E7FE82021-802E
   Serial number: 2312000188284001
Address 08: Auto HVAC
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001455986
   Coding: 0200E011163C9FE0C1008884A0003928CF9CD208A6080225800008406000
   Shop #: WSC 12345 123 61029
   VCID: 6FBBDEE8279F9222BE9-803A
   Component: WWS57X 120912  H36 0080
   Serial number:         120924234600
   Coding: 0045F7
   Serial number: 20651292
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 02 10 2012  00000362
   Subsystem 4 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0040535061
   Coding: 853000
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA104148000001943496
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 44580E46000000000001
9 Faults Found:
00576 - Terminal 15
                    Fault Status: 01101000
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:00
00910 - Indicator Lamp for Emergency Flashers (K6)
                    Fault Status: 01101100
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:00
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:00
02258 - Door Opener Transmitter
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:00
01229 - A/C Humidity Sensor (G260)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:00
03725 - Control Module for Seat Belt Tensioner; Left Front
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:00
Address 10: Park/Steer Assist
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D8002FL1K Dataset Number: 4G8909602D  0004
   Coding: 303145313131303030314A55304C34473853
   ROD: EV_AirbaAU10BPAAU64X_VW51.rod (VIN: N/A)
   VCID: 333312980BB7F6C29A1-8066
   Serial number: 6940000Y150001ER7M01
   Serial number: 3575HRB405D1HGMQ915M
   Serial number: 3585HRB40571HGMQCP1/
   Serial number: 3515JRB401C4UN9OI1VD
   Serial number: 3525JRB405D1MFU46GQ%
   Serial number: 3554VRB400K4UNK88PR/
   Serial number: 3564VRB400G4UNK86H55
1050112 - Databus
          [CAN: 0x086 LWI_01 Timeout]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:25
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20121012001065
   Coding: 000034
   VCID: 30391D94FA21CDDAE73-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
00576 - Terminal 15
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
   Part No SW: 4G8 920 983 E    HW: 4G8 920 983 E
   Component: TBenUsa       H79 0515
   Revision: 28460207    Serial number: 658111012592017
   Coding: 03E701060B43D705020100
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod (VIN: N/A)
   VCID: 372B26881FCF1AE2A69-8062
16776970 - Function Restricted due to Missing Message(s)
          [LWR_AFS_01 keine Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
1048580 - Button for Trip Odometer Reset
          B11FE 13 [00001001] - Open Circuit
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000719062 Dataset Number: 4G8909515D  0059
   Coding: 00CD073000
   GVL: FDA1E84CFE63600D0000
   ASAM Dataset: EV_GatewPkoUDS 001018
   ROD: EV_GatewPkoUDS_001_AU57.rod (VIN: N/A)
   VCID: 71BFD890312B84D2A8D-8024
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790310195
   Voltage stabilizer:
   Serial number: 180417000000000000CC
9 Faults Found:
5055 - No Communications with HVAC Control Module (J301)
          U0164 00 [00001001] - -
          [No signal/communication to Aircondition- ECU (Climatronic)]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Voltage terminal 30: 12.4 V
                    Voltage terminal 15: 12.4 V
                    Control Module temperature: 29 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
5088 - Rear A/C control module
          U1072 00 [00001001] - No communication
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
4230 - No Communications with Steering Angle Sender (G85)
          U0126 00 [00001001] - -
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5013 - Headlight Range Control Module
          U101E 00 [00001001] - No Communication
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5271 - No Communications with Parking Assist Control Module A
          U0159 00 [00001001] - -
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
4879 - Lane change assistant control module
          U1045 00 [00001001] - No communication
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5080 - Front Left belt tensioner control module
          U107C 00 [00001001] - No communication
          [Steuergerät für RGS Links Keine Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5081 - Front Right belt tensioner control module
          U107D 00 [00001001] - No communication
          [Steuergerät für RGS Rechts Keine Kommunikation]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0259 - Extended CAN Bus (SAE Bus C)
          U0047 00 [00001001] - Performance
          [Vehicle Communication Bus C Bus Performance]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
Address 28: HVAC, Rear
   Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000039194743
   Coding: C0581B008F006001000001010101102030303232203232
   VCID: 382925B41251159AAF3-806C
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:26
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H02 0053
   Revision: --------    Serial number: EJ1BPA8201GNLM Dataset Number: 4G8909573A  0001
   ASAM Dataset: EV_SARA2 005011
   ROD: EV_SARA2.rod (VIN: N/A)
Address 3C: Lane Change
   Component: TSG FA        H03 0506
   Coding: 011F57025E00628002000412
   VCID: 47CB56486FAF6A62D69-8012
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
01340 - Mirror Adjustment Switch
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:55
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0007945176 Dataset Number: 4G8909852J  0028
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod (VIN: N/A)
   VCID: 323D179CF4ADFFCA917-8066
3158276 - Function Restricted due to Missing Message(s)
          [Ausfall Botschaft "PDU_LWI_01"]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:24
                    Write only channel
   Revision: 00002001    Serial number: 0185437806
   Coding: 0126063A20FAF08580B00A84020102070000000000000000000000000000
   Subsystem 2 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO1853955A
   Coding: 101F00
   Subsystem 3 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0028
   Serial number: WA104224000002081655
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
            014 - Defective
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:25
01308 - Control Module for Roof Electronics (J528)
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:25
03233 - Controls for Garage Door Opener (E284)
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:25
   Revision: CJ007001    Serial number: 00000000009943
   Coding: 030000
   Shop #: WSC 06745 128 28888
   VCID: 1D67D4209DB350B25C5-8048
02753 - Inside Microphone (R74)
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:26
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:41
                    Bin. Bits: 00000100
   Component: TSG BF        H03 0506
   Coding: 011F57025E00628002000402
   VCID: 46D55B4C68A5736A2DF-8012
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000504125 Dataset Number: 4G8909522A  0002
   ROD: EV_ParkiBrake_VW51.rod (VIN: N/A)
   VCID: 2B030AF8D387AE02D21-807E
10613248 - Terminal 15
          U1405 00 [10001001] - Implausible signal
          [FC_IGNITION_CROSS_CHECK_FAULT]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Voltage terminal 30: 12.5 V
                    Internal Fault ID: 44
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: applied
                    Status ParkingBrake right: applied
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
          [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:24
                    Internal Fault ID: 188
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
Address 55: Headlight Range
   Part No SW: 4G0 035 082 E    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0121
   Revision: AB001007    Serial number: 156J/0C7645431
   Coding: 020007010000000001
   VCID: 221DE7DCA4CD6F4A617-8076
02617 - Satellite Antenna (R170)
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:31
                    Voltage: 12.50 V
   Part No SW: 4G0 035 746 D    HW: 4G0 035 746 B
   Component: H-BNT-NA      H49 0622
   Revision: --------    Serial number: 194J 0C7515071
   Coding: 090200040003E1EF55128B3E00000003100001000000000000
   VCID: 2809F5F4C2F1851A3F3-807C
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDC9402R0KX
   Subsystem 3 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
7 Faults Found:
00658 - Control Head
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:27
                    Voltage: 12.40 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:29
                    Bin. Bits: 00000100 00000010
                    Bin. Bits: 10000100 00000000
                    Bin. Bits: 00000000 00000000
02168 - Left Front Microphone (R140)
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:26
                    Voltage: 12.40 V
02169 - Front Right Microphone (R141)
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:26
                    Voltage: 12.40 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:34
                    Voltage: 12.40 V
01524 - Antenna for Telephone
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:35
                    Voltage: 12.40 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:29
                    Bin. Bits: 00001000 00000000
   Component: TSG HL        H03 0506
   Coding: 010F17024000628002000002
   VCID: 49CF507079BB9C12C0D-801C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H06---    Serial number: 525 PA8J28G9CC
   Coding: 1080013
   VCID: 2615FBCCC4E5936A0DF-8072
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
                        Reverse OFF
                    Count: 3
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
                        Reverse OFF
                    Count: 3
   Part No SW: 4G8 959 107 R    HW: 4G8 959 107 G
   Component: HDSG-Modul    H13 0043
   Revision: 12013001    Serial number: 262200497 Dataset Number: 4G8909541F  0022
   Coding: 0A3305C102
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571_AU57.rod (VIN: N/A)
   VCID: 44D141445E19417A33B-8010
   Component: TSG HR        H03 0506
Address 8F: Pretens. Frt Left
Address 90: Pretens. Frt Right
End----(Elapsed Time: 02:40, VBatt start/end: 12.5V/12.5V. VIgn 0.0V)------
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
I should have stated that most of the modules are on order and will need to be coded to my car on arrival (or taken to shop to have CP removed, if they contain), but I was hoping the no-start issue isn't related to a HVAC module being absent
"VIgn 0.0V" combined with "Power Supply Terminal 15 - Implausible" in several modules makes me think this car has (switched) power distribution issues. I would get a wiring diagram and follow back pin 1 of the diagnostic socket toward the battery to see where (switched) power isn't making it through.
Ziddywerks
Northern NJ USA
C?ID=208579
I would be looking at 09 module or 46. What is the back story to this vehicle? Flood car? Please post unedited auto scan with vin.
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Thanks, Ewe. I will try that. Got a new oscilloscope to try now!
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Sorry, this is literally my first post here so I’ll look up how to get an unedited dump with my VIN. As far as the history, I’m not quite sure because I pulled a carVertical check before buying, and there was nothing of note on there.
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Backstory is, car was Abandoned Vehicle that owner never claimed. Not sure how that occurred, but I suspect car was not running and then cannibalized and left somewhere for city to tow away
  • Informative
Dr Sheldon
Windsor UK
C?ID=334979
If you got that at auction for $0 - Will it be worthwhile ??
Thanks, Ewe.
-Uwe- (Starts with a 'U' as in "Uniform")
  • Haha
Reactions: JMR
I’ll blame autocorrect for that one!
Auto-Correct is the work of the devil! Turn that crap off! I'm entirely fine with software that flags possible errors and makes suggestions if I ask for them, but I'll be damned if I let any software correct what I've typed without my explicit consent.
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
@EuroX Here is the unedited log. I added VIN number when saving. Did I do it right?
Wednesday,03,July,2024,14:55:33:10725
VIN: WAU2GAFC4DN072644   License Plate:
Chassis Type: 4G0
Address 01: Engine
   Coding: 000002
                    Fault Frequency: 51
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:26
                    Voltage terminal 30: 11.390 V
                    Engine torque: 0 Nm
                    ATF temperature: 31 °C
                    Engine RPM: 0 /min
12551 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [00100110] - -
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:54
                    Voltage terminal 30: 10.988 V
                    Engine RPM: 0 /min
12554 - No Communication with Engine Control Module (SAE ECM/PCM)
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:54
                    Engine RPM: 0 /min
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:24
                    Voltage terminal 30: 11.388 V
                    Engine RPM: 0 /min
12562 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [10101110] - -
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:55
                    Voltage terminal 30: 11.336 V
                    Engine RPM: 0 /min
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:24
                    Engine RPM: 0 /min
16 Faults Found:
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:24
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DB
                    Uz: 93
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:25
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DE
                    Uz: 93
0069 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [ComScl_PDU_Motor_01_Timeout]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:55
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 2F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: E3
                    Uz: 92
0071 - Function Restricted due to Missing Message(s)
          [ComScl_PDU_Motor_02_Timeout]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:55
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 2F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: F0
                    Uz: 92
0073 - Function Restricted due to Missing Message(s)
          [ComScl_PDU_Motor_03_Timeout]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:55
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 2F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: F5
                    Uz: 92
0075 - Function Restricted due to Missing Message(s)
          [ComScl_PDU_Motor_10_Timeout]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:55
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 2F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: F8
                    Uz: 92
0091 - Function Restricted due to Missing Message(s)
          [ComScl_PDU_TSK_05_Timeout]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:55
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 2F
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 0C
                    Uz: 92
0486 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001000] - -
          [Ldm_ApbFailureState]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:55
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 2F
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 04
                    Uz: 91
                    Fault Frequency: 51
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:24
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 28
                    Uz: 93
                    Fault Frequency: 51
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:24
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 2C
                    Uz: 93
0854 - Function Restriction due to Faults in Other Modules
          [SCL_GE_Uefkt_Error]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:55
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 2F
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: C9
                    Uz: 91
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:24
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: E6
                    Uz: 93
   Coding: 0045F7
   Subsystem 2 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Subsystem 3 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Coding: 853000
   Coding: 020300
9 Faults Found:
00576 - Terminal 15
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:00
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:00
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [10001001] - Resistance Too High
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:30
1050112 - Databus
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:26
   Coding: 000034
00576 - Terminal 15
                    Fault Frequency: 51
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:23
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:57
16776971 - Function Restricted due to Missing Message(s)
          [Motor_03 keine Kommunikation]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:57
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:24
   Coding: 00CD073000
   Voltage stabilizer:
9 Faults Found:
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.12
                    Time: 21:43:35
                    Voltage terminal 30: 12.2 V
                    Voltage terminal 15: 12.2 V
                    Control Module temperature: 24 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.12
                    Time: 21:43:35
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.12
                    Time: 21:43:35
                    Voltage terminal 30: 12.3 V
                    Voltage terminal 15: 12.3 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.12
                    Time: 21:43:35
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.12
                    Time: 21:43:35
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.12
                    Time: 21:43:35
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.12
                    Time: 21:43:35
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.12
                    Time: 21:43:35
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.12
                    Time: 21:43:35
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:28
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:57
                    Fault Frequency: 61
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:23
                    Fault Frequency: 61
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:23
                    Fault Frequency: 13
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:23
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:59
3158274 - Function Restricted due to Missing Message(s)
          [Ausfall Botschaft "PDU_Motor_03"]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:57
                    Write only channel
                    Fault Frequency: 50
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:24
                    Write only channel
4208000 - Steering Angle Sensor
          B1168 F1 [00001000] - Synchronization Failed
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:56
                    Write only channel
   Coding: 101F00
9 Faults Found:
                    Fault Frequency: 39
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:23
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:23
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:23
            014 - Defective
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:27
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:27
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:27
                    Reset counter: 35
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:55
                    Reset counter: 35
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:10:26
                    Reset counter: 35
                    Mileage: 146276 km
                    Date: 2024.05.25
                    Time: 00:50:01
   Coding: 030000
                    Fault Frequency: 118
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:28
                    Fault Frequency: 22
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:43
                    Bin. Bits: 00000100
                    Fault Frequency: 61
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:23
                    Fault Frequency: 61
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:23
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:59
8 Faults Found:
                    Fault Frequency: 51
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:24
                    Voltage terminal 30: 11.4 V
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
333568 - Function Restricted due to Missing Message(s)
          [FC_TSK_05_MESSAGE_TIMEOUT]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:54
                    Voltage terminal 30: 11.1 V
                    Internal Fault ID: 49
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
334080 - Function Restricted due to Missing Message(s)
          [FC_MOTOR_02_MESSAGE_TIMEOUT]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:54
                    Internal Fault ID: 51
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
331264 - Function Restricted due to Missing Message(s)
          [FC_MOTOR_01_MESSAGE_TIMEOUT]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:54
                    Internal Fault ID: 99
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
331520 - Function Restricted due to Missing Message(s)
          [FC_MOTOR_03_MESSAGE_TIMEOUT]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:54
                    Internal Fault ID: 100
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
331776 - Function Restricted due to Missing Message(s)
          [FC_MOTOR_CODE_01_MESSAGE_TIMEOUT]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:54
                    Internal Fault ID: 101
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
460800 - Function Restriction due to Faults in Other Modules
          [FC_SIGNAL_GE_UEFKT_ERROR_VALUE]
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:06:55
                    Internal Fault ID: 144
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:24
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:33
                    Voltage: 11.30 V
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:11:40
                    Bin. Bits: 00000000 00001000
8 Faults Found:
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:32
                    Voltage: 11.10 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 21:08:02
                    Voltage: 11.10 V
                    Bin. Bits:      001
                    Fault Frequency: 17
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.12
                    Time: 21:43:45
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:31
                    Voltage: 11.10 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:31
                    Voltage: 11.10 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:39
                    Voltage: 11.10 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:39
                    Voltage: 11.10 V
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 23:11:45
                    Bin. Bits: 00011000 00000000
                    Bin. Bits: 00000000 00010000
   Coding: 1080013
                    Fault Frequency: 95
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:23
                        Reverse OFF
                    Count: 3
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.04.04
                    Time: 20:52:23
                        Reverse OFF
                    Count: 3
   Coding: 0A3305C102
End----(Elapsed Time: 02:40, VBatt start/end: 12.1V/12.1V. VIgn 0.0V)------
Monday,08,July,2024,14:35:52:10725
Chassis Type: 4G0
Address 01: Engine
   Coding: 000002
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:27
                    Engine torque: 0 Nm
                    Engine RPM: 0 /min
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:25
                    Engine RPM: 0 /min
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:25
                    Engine RPM: 0 /min
9 Faults Found:
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:24
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DB
                    Uz: A0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:24
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DE
                    Uz: A0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:24
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 28
                    Uz: A0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:24
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 2C
                    Uz: A0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:24
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 22
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: E6
                    Uz: A0
   Coding: 0045F7
   Coding: 02006E
   Coding: 853000
   Coding: 020300
9 Faults Found:
00576 - Terminal 15
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:00
            014 - Defective
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:00
1050112 - Databus
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:25
   Coding: 000034
00576 - Terminal 15
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
   Coding: 00CD073000
   Voltage stabilizer:
9 Faults Found:
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:26
                    Fault Frequency: 8
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
                    Reset counter: 36
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:55
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:24
                    Write only channel
   Coding: 101F00
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
            014 - Defective
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:25
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:25
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:25
   Coding: 030000
                    Fault Frequency: 16
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:26
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:41
                    Bin. Bits: 00000100
                    Fault Frequency: 8
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
                    Fault Frequency: 8
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:23
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:24
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:31
                    Voltage: 12.50 V
8 Faults Found:
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:27
                    Voltage: 12.40 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:28:36
                    Voltage: 13.10 V
                    Bin. Bits:      001
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 19:31:55
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:26
                    Voltage: 12.40 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:26
                    Voltage: 12.40 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:34
                    Voltage: 12.40 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:35
                    Voltage: 12.40 V
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:29
   Coding: 1080013
                    Fault Frequency: 12
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
                        Reverse OFF
                    Count: 3
                    Reset counter: 251
                    Mileage: 146276 km
                    Date: 2024.06.14
                    Time: 22:22:21
                        Reverse OFF
                    Count: 3
   Coding: 0A3305C102
End----(Elapsed Time: 02:40, VBatt start/end: 12.4V/12.4V. VIgn 0.0V)------
Dr Sheldon
Windsor UK
C?ID=334979
Address 01: Engine Cannot be reached
That is your starting point !!
ERWIN. Wiring Diagrams, Powers, Grounds, CAN Lines with a Scope !! And a Micro Amp Clamp to confirm the Direction of CAN Transmissions - Bi Directional is a Must !!!
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Got Erwin files. Got a scope (RIGOL 1150z) that I'm learning to use now. Got a breakout box to easily access diagnostic pins, got a test light to check for power! I think I'm on the right path, yeah?
Also, watching some training videos on electrical diagram explanation and reading the Audi specific one from Erwin. If nothing else, Im going to learn a lot and hopefully help someone else at that point!
Ziddywerks
Northern NJ USA
C?ID=208579
Currently does the ignition turn on? Does the cluster come to life and so on? Also is terminal 15 temporarily jumped? I would check can communication status via gateway to see if its talking to all installed modules. If it's talking to ecm and tcm it should crank. However based on the log seen it look like many are either offline or not connected.
Dr Sheldon
Windsor UK
C?ID=334979
Good
But test at component and gateway NOT at OBD socket - Nothing of value there for you !!
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Good
Thank you. I'm realizing that now. Wonder of the breakout box was needed since the components seem to be where all the action's at!
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
Ignition turns on, cluster comes to life. I'm in the process of looking through wiring diagram to find location of gateway. Pulled out glove box based on video I saw and Im not seeing it! Ha!
hangtenboy
Cave Creek, AZ, USA
C?ID=522321
I was thinking that as well that if at least ECU and TCM communicate with gateway it "should" start. I'll find the gateway this evening
Ziddywerks
Northern NJ USA
C?ID=208579
Does the starter click? or make any noise? Have you tried spinning the engine by hand with a rachet? maybe theres a good reason why it was abandoned?
