audi A4 It does not turn on
caliche1275
Columbia
C?ID=160533
Hi,
Now I have a problem with A4 2014, cold star after (2 minutes) goes out and not back on, checking is no supply voltage to the spark plugs.
:thanks::banghead:
VCDS Version: Release 15.7.1 Running on Windows 7 x86
Data version: 20150904
Tuesday,27,October,2015,18:13:08:49232
Chassis Type: 8K (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 72
          77
VIN: WAUZZZ8K4EA073510   Mileage: 25440km-15807miles
Address 01: Engine (B8-PA-CDHA)       Labels: 06H-907-115-CAB.clb
   Part No SW: 8K1 907 115 N    HW: 8K1 907 115 N
   Component: 1.8l R4/4V TF H04 0003
   Revision: PBH04---
   Coding: 0A031013040400002000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM18TFS0118K1907115N 001005
   ROD: EV_ECM18TFS011.rod
   VCID: 39790C7FB899C2F65A-806C
Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
   Part No SW: 8K5 927 155 D    HW: 0AW 927 156 K
   Component: 0AW 18TFSIRdW H05 0002
   Revision: --H05---    Serial number: 0000000087
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMVL381 A02433
   ROD: EV_TCMVL381_AU48.rod
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 8K0 907 379 CN    HW: 8K0 907 379 CN
   Component: ESP8 front    H09 0020
   Coding: 02554801
   VCID: 071DBA87B6ED64061C-8052
                    Fault Status: 11101100
                    Reset counter: 220
                    Mileage: 25446 km
                    Date: 2015.08.16
                    Time: 08:09:04
                    Hex Value: 0x00C0
                    Hex Value: 0x0782
                    Hex Value: 0x004A
                    Hex Value: 0xB080
                    Hex Value: 0x0000
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 220
                    Mileage: 25446 km
                    Date: 2015.08.16
                    Time: 08:09:04
                    Hex Value: 0x00C0
                    Hex Value: 0x0782
                    Hex Value: 0x001A
                    Hex Value: 0x0280
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 HQ    HW: 8K0 907 064 GQ
   Component: BCM2 2.0      H13 0641
   Coding: 01814000000000000000
   VCID: 0603B783B1E77D0E67-8052
   Subsystem 1 - Part No SW: 8K0 959 754 E    HW: 8K0 959 754 E
   Part No SW: 8K1 820 043 Q    HW: 8K1 820 043 Q
   Component: KLIMA 1 ZONE  H02 0121
   Revision: A0000000    Serial number: 01211020132048
   Coding: 640022C000
   VCID: 3663074381872D8EB7-8062
00457 - Control Module for Network (J519)
                    Reset counter: 220
                    Mileage: 25446 km
                    Date: 2015.08.16
                    Time: 08:05:07
   Part No SW: 8K0 907 063 DG    HW: 8K0 907 063 DG
   Revision: 07016001    Serial number: 00000054395802
   Coding: 2600C0108034AFC00081400000001D0D0F1C430802010201000004004401020100000020000000
   VCID: 77FDCA47C60D14866C-8022
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B
   Component: MITSUBA250913  H18 0461
   Coding: 004577
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
01229 - A/C Humidity Sensor (G260)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 220
                    Mileage: 25446 km
                    Date: 2015.08.16
                    Time: 08:05:11
                    Reset counter: 220
                    Mileage: 25446 km
                    Date: 2015.08.16
                    Time: 08:05:12
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003KFDB2JVD+
   Coding: 30514435363030303030554A304C384B3053
   Shop #: WSC 42811 001 1048576
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 489F79BBF373AB7ED5-801C
   Serial number: 6334MSME7F521832G
   Serial number: 6344MSME7F26185EW
   Serial number: 6352QSME6E382670N
   Serial number: 6362QSME6842567EU
   Serial number: 63732SME67390B50/
   Serial number: 63832SME5B370E76A
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862MJT000LZ
   Coding: 000012
   VCID: 489F79BBFB73AB7ED5-801C
                    Reset counter: 220
                    Mileage: 25446 km
                    Date: 2015.08.16
                    Time: 08:05:42
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 901 K    HW: 8K0 920 901 K
   Component: KOMBIINSTR.   H09 0564
   Revision: 00000000    Serial number: Z9Y71HUAE
   Coding: 1386080002010008050000
   VCID: 33653E5792F538A690-8066
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0056
   Revision: 1V080027    Serial number: 2741V13A0107AA
   Coding: 80C303FF00
            000 -  -
                    Reset counter: 220
                    Mileage: 25446 km
                    Date: 2015.08.16
                    Time: 08:07:18
                    Bin. Bits:    10111
                    Voltage: 11.60 V
                    Count: 6
Address 2E: Media Player 3 (R199)       Labels: 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020202
   VCID: 39790C7FB099C2F65A-806C
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011C02204100410001
   VCID: 56A3A7C321C70D8E57-8002
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Component: RCEPS         H39 0507
   Revision: 00001000    Serial number: 0024986599
   Coding: 100000000001
   Shop #: WSC 06324 000 00000
   ROD: EV_RCEPSAU48X.rod
   VCID: 34673D4B9FFB3F9E89-8060
3164944 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 220
                    Mileage: 25446 km
                    Date: 2015.08.16
                    Time: 08:05:07
   Revision: 00002001    Serial number: 0317438707
   Coding: 011A062280B900048330013280000000
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
   Part No SW: 8R1 035 223 A    HW: 8R1 035 223
   Component: DSP STD       H08 0230
   Revision: 26S00000
   Coding: 0203010102
   VCID: 2B5526374AC56066D8-807E
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   VCID: 55A1A0CF3CC106965E-8000
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 30000000120706
   ROD: EV_ParkiBrake_AU48.rod
460032 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
                    Reset counter: 220
                    Mileage: 25446 km
                    Date: 2015.08.16
                    Time: 08:05:07
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8R1 035 195 H    HW: 8R1 035 195 H
   Component: Symphony3 US  H04 0461
   Revision: 00000002    Serial number: AUZ5Z4M1777637
   Coding: 0402008201018500015B071800
   VCID: 3A7B1373B59FC9EE53-806E
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0305
   Coding: 010C02204000210001
   VCID: 59B9ACFF50D922F67A-800C
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
   Component: TSG HR        H07 0305
   Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005685786
   Coding: 0010390
   VCID: 3D71186F64B1FED676-8068
End-------------------------(Elapsed Time: 03:15)--------------------------
auto-scan
Gone But Not Forgotten
Could be an over heated or bad terminal 30 or 15 relay from possible bad ground connection.
