The first two sets of debugs you sent had ignition OFF and DoIP ON.
The third set you sent still had DoIP ON (but ignition ON, progress!). The third set appears to have communicated correctly with most controllers that were detected in the very short gateway installation list, with the exception of 01-Engine.
Would you like to try a 4th time, this time with ignition ON and DoIP OFF?
I see some amount of network packets concatenation, but not to the extent that it should impair . If you feel this is network related, you may want to try disabling some of your (diagnostic-wise) superfluous network adapters:
MAC0: xxx Intel(R) Ethernet Connection (3) I218-LM204747C1CBE7 Intel(R) Ethernet Connection (3) I218-LM
MAC1: xxx VMware Virtual Ethernet Adapter for VMnet1005056C00001 VMware Virtual Ethernet Adapter for VMnet1
MAC2: xxx VMware Virtual Ethernet Adapter for VMnet8005056C00008 VMware Virtual Ethernet Adapter for VMnet8
MAC3: xxx Bluetooth Device (Personal Area Network) xxx Bluetooth Device (Personal Area Network)
MAC4: xxx Intel(R) Dual Band Wireless-AC xxx Intel(R) Dual Band Wireless-AC 7265
MAC5: xxx Microsoft Wi-Fi Direct Virtual Adapter xxx Microsoft Wi-Fi Direct Virtual Adapter
MAC6: xxx Microsoft Wi-Fi Direct Virtual Adapter #xxx Microsoft Wi-Fi Direct Virtual Adapter #2
MAC7: xxx Dell Wireless 5809e Gobi(TM) 4G LTE Mobile Broadband Card xxx Dell Wireless 5809e Gobi(TM) 4G LTE Mobile Broadband Card
as needs to send a broadcast on every network when you are auto-detecting the interface.
There may be more network adapters on your PC but I only coded for 8 broadcasts/network adapters. This might be an issue with your current setup.
And/or you could enter the interface's IP directly in Options: currently it's at 192.168.88.110 .
