- Jul 2, 2024
- 12
- 4
- Houston, TX, USA
- C?ID=590186
First, thank you to the VCDS team for developing such an amazing tool. I'm new to VCDS and CAN-based systems (carburetors are more my thing) so I'm hoping for help to determine whether the problem below is a simple misfire problem (plugs/coils), something worse, or whether I should run from this car as a maintenance money pit.
I just accepted delivery of a 2014 Flying Spur W12 Base. The car has been driven (by me) fewer than 25 miles. The car has 32K miles and has not had its 30K maintenance, which would include new spark plugs and coils. The car is single-owner with clean, single-dealer maintenance history from 0 to ~18K miles (unable to get maintenance records beyond that).
History:
Question 2: The car was involved in a minor collision a few years ago and there was a repair on the door. Are the 46-Central Conv. instrument failures and one-wire CAN warning potential electrical gremlins? Are these reasonable to trace/solve?
According to the Bentley service manual the diagnostic steps for Cylinder Misfire P0304 code is:
FULL SCAN
I am in the process of gathering realtime log data related to misfires and it appears that Cylinders 4,9, and 11 (mostly Cyl 4) have intermittent failures while running.
Total misfire count shows that Cylinder 4 is *maxed out* on misfire count.
MISFIRE TOTAL COUNT REPORT
History:
- Had a reputable European-specialist shop do a Pre-Purchase Inspection where they supposedly scanned the car and it passed with 'no issues' (suspect).
- Car delivered to me (trailered), next morning I drove it to a state inspection station. While sitting in line the "check engine" light came on.
- Car failed inspection because of the check engine code P0304: Cylinder 4 Misfire Detected.
- VCDS scan done (below); cylinder misfires identified.
- Realtime monitoring shows mostly low-RPM misfires (few or no misfires under hard acceleration or highway driving)
- I only have ~10 miles of data on this right now.
- Check fuel injectors.
- Check ignition coil with power output.
- Check spark plugs.
- Check for engine mechanical fault by performing a cylinder pressure test.
FULL SCAN
Monday,01,July,2024,16:04:46:46110
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.5
VIN: License Plate: 14FLYINGSPUR
Mileage: 51360km-31913mi Repair Order: INITIAL-SCAN
Chassis Type: ZA-BY62 (6N0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 28 2E 34 36 37 38
46 47 48 53 56 5D 65 66 68 6C 6D 71 76 77
VIN: Mileage: 51360km-31913miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
48-Seat, Rear, DS -- Status: OK 0000
5D-Operations -- Status: OK 0000
66-Seat, Rear -- Status: OK 0000
68-Wiper Electr. -- Status: OK 0000
71-Battery Charger -- Status: OK 0000
Address 01: Engine (J623-CKHF) Labels: None
Part No SW: 07C 906 023 K HW: 07C 907 309
Component: ME17.1.6 H16 6514
Revision: MHH16--- Serial number: VWX3Z0M7015417 CVN: 25C7EB5B
Coding: 0D2A0032432E00020001
Shop #: WSC 60290 001 1048576
ASAM Dataset: EV_ECM60TMP11107C906023K 001004
ROD: EV_ECM60TMP07C906023K.rod
VCID: 290824D0297263A220D-807C
VINID: 8D34954C9A911554C0241149103A31ABBB
16672 - Please Check DTC Memory of ECU Number 2
P1923 00 [00101111] - -
Mileage: 51358 km
Date: 2024.07.01
Time: 13:30:00
Engine RPM: 587.50 /min
Normed load value: 18.0 %
Coolant temperature: 101 °C
Intake air temperature: 81 °C
Voltage terminal 30: 14.512 V
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [01100001] - -
10594 - ROD - Unknown Error Code
- 00 [01100001]
Readiness: 0010 0001
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 4W0 927 158 A HW: 0CU 927 760 A
Component: OBL 60 MPIUSA H16 0005
Revision: --H16--- Serial number: VWX3Z0M7015417 CVN: AEB9E0B9
Coding: 000002
ASAM Dataset: EV_TCMAL450211 002010
ROD: EV_TCMAL450211_BY62.rod
VCID: 3C26ED84D6E0E60A4BB-8068
Address 03: ABS Brakes Labels: None
Part No SW: 4W0 614 517 A HW: 4W0 614 517 A
Component: ESP 8.1 4WD H01 1100
Coding: 0002543
Shop #: WSC 00083 790 00197
VCID: 3436C5A4F2702E4A83B-8060
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 G HW: 3D0 909 137 G
Component: C0 Kessy 6850
Revision: 00H24072 Serial number: VWX3Z0M7015417
Coding: 0405741
Shop #: WSC 00083 790 00190
VCID: 2B04DED82F4E71B2D21-807E
Component: ELV XXXX
Part No SW: 4W0 959 760 HW: 4W0 959 760
Component: MEM-BFS H04 0600
Revision: AA000000 Serial number: 00000077608911
Coding: D0081F0085070090090001010101002100012727000000
Shop #: WSC 00083 790 00242
VCID: 7F5CDA8887B63D122E9-802A
Address 07: Control Head Labels: 3D0-907-048.clb
Part No SW: 3D0 907 048 HW: 3D0 907 048
Component: J127 KBT vorn 0100
Revision: ABH30001 Serial number: VWZ6Z7U0044003
VCID: 639476F8071EF9F22A1-8036
Address 08: Auto HVAC Labels: None
Part No: 3W5 907 040 J
Component: Climatronic BY621 3029
Coding: 0000101
VCID: 3D20E080C13AEF027C5-8068
Address 09: Cent. Elect. Labels:. 3D0-937-049-V2.clb
Part No SW: 3D0 937 049 Q HW: 3D0 937 049 Q
Component: J519 7700
Revision: -4007--- Serial number: --------------
Coding: 40820000AB2A11C02508030000000000
VCID: 382EF194EE18CA2AAF3-806C
Address 11: Engine II (J624) Labels: None
ASAM Dataset: EV_ECM60TMP21107C906023K 001004
ROD: EV_ECM60TMP07C906023S.rod
12646 - Random/Multiple Cylinder Misfire Detected
P0300 00 [11101101] - -
Mileage: 51358 km
Date: 2024.07.01
Time: 13:28:26
Engine RPM: 598.00 /min
Normed load value: 17.6 %
Intake air temperature: 77 °C
Voltage terminal 30: 14.277 V
10594 - Cylinder 4
P0304 00 [11101101] - Misfire Detected
Mileage: 51358 km
Date: 2024.07.01
Time: 13:30:00
Address 15: Airbags Labels: None
Part No SW: 3W3 959 655 HW: 3W3 959 655
Component: 27 Airbag 9.43 H04 0050
Revision: 93H04005 Serial number: 003FV000HH1+
Coding: 0012855
VCID: 04565564E2505ECA73B-8050
Subsystem 1 - Part No: 4W0 959 339
Component: BF-Gewichtsens. H03 0102
Subsystem 2 - Serial number: 02T65
Subsystem 3 - Serial number: 0001.01.0000H0300000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB40F3E4E2C4ÿ†63
Subsystem 5 - Serial number: E4E2C4ÿ†6342DRB40F340F16Sÿ†63
Subsystem 6 - Serial number: 40F16Sÿ†63528RB406FEB45C4ÿ†63
Subsystem 7 - Serial number: EB45C4ÿ†63628RB406FEA481$ÿ†63
Subsystem 8 - Serial number: EA481$ÿ†63747RB40702A570Eÿ†63
Subsystem 9 - Serial number: 2A570Eÿ†63847RB40702A373Gÿ
Subsystem 10 - Serial number: 2A373Gÿ
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 K
Component: J527 3601
Coding: 0000032
VCID: 47CC826893E6B5D2D69-8012
No Faults Found
Address 17: Instruments Labels: 3Wx-920-xxx-17.clb
Part No SW: 3W0 920 851 L HW: 3W0 920 851 L
Component: J285 KOMBI-INST. 3925
Revision: KPH10V02
Coding: 0034214
Shop #: WSC 19178 004 1048576
VCID: 3FDC9A88CB76FD126E9-806A
Fault Status: 00101011
Reset counter: 16
Mileage: 51334 km
Date: 2024.06.20
Time: 00:00:05
Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 3W0 920 851 L
Component: J533 GW-K-CAN TP20 3925
Coding: 5FFAFFFFEB551702
VCID: 70BE09B4C6A8526AA73-8024
Reset counter: 16
Mileage: 51334 km
Date: 2024.06.20
Time: 00:00:05
Address 28: HVAC, Rear (J524) Labels: None
Part No SW: 4W0 035 008 HW: 4W0 035 008
Component: CLIMATE ECU H06 0062
Revision: P1H06004 Serial number: 51300129127001
Coding: 00000000010102
VCID: 6B841ED8E3CEB1B2921-803E
Subsystem 1 - Part No SW: 4W0 907 042 A HW: 4W0 907 042
Component: RBM-BY621 H09 0055
Serial number: WA107362000004944476
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Revision: A1001003 Serial number: 7665317695
Coding: 030100
Shop #: WSC 00083 790 00191
VCID: 2B04DED8230E71B2D21-807E
Address 34: Level Control Labels: None
Part No: 4W0 907 553
Component: LUFTFDR.-CDC- 3C3V0 7705
Coding: 0005541
Shop #: WSC 00083 790 00171
VCID: 78AE3194AE980A2A6F3-802C
Component: MEM-FS H04 0600
Revision: AA000000 Serial number: 00000077600982
Coding: D0081F0085870090090001010101012100012727000000
Shop #: WSC 00083 790 00236
03341 - Ventilator for Back Rest
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 227
Mileage: 51344 km
Date: 2024.06.24
Time: 13:45:23
Address 37: Navigation (J0506) Labels:. 3D0-035-680.clb
Part No SW: 3W0 035 017 Q HW: 3W0 035 017 Q
Component: RNS-MID H32 0584
Revision: AB001001 Serial number: VWZ6Z7U0044003
Coding: 06010002000000044000
Shop #: WSC 53978 001 1048576
VCID: 3B24EE98D36EE132421-806E
Subsystem 1 - Part No: 3W0 919 859 BN
Component: NAR V4 7963
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 H
Component: Dachmodul 0910
Coding: 0020493
VCID: 3B24EE98DF2EE132421-806E
Address 46: Central Conv. Labels: 3D0-959-933.clb
Part No: 4W0 959 794
Component: TSG HR D26
Coding: 0000040
Shop #: WSC 00000 790 00190
VCID: 06524F6CD43C6CDA6DF-4B30
Subsystem 1 - Part No: 4W0 959 107 A
Component: 11 HDSG 0806
Subsystem 2 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
00122 - Outside Warning Light/Door Exit Light; Rear Left
Address 47: Sound System Labels: None
Part No SW: 4W0 035 465 HW: 4W0 035 465
Component: DSP 10 Kanal 0010
Revision: 00H07001 Serial number: 75824010584903
VCID: 72BA03BCC8A4607A517-8026
Address 48: Seat, Rear, DS
Address 53: Parking Brake Labels: 3W0-907-801.clb
Part No SW: 3W0 907 801 H HW: 3W0 907 801 H
Component: EPB BC7H0300 HC7 0300
Coding: 0022513
VCID: 3B24EE98DF7EE132421-5160
Address 56: Radio (J0506) Labels:. 3D0-035-680.clb
Address 5D: Operations
Address 65: Tire Pressure Labels: None
Part No SW: 3W7 907 273 C HW: 3W7 907 273 C
Component: J0502 RDK 0006
Revision: 0004 006 Serial number: 00000600003270
Coding: 0000E03175CA4286EB75B9FD52EB0097FC004B6E4B6E4B6E4B6E4B64
Shop #: WSC 00083 790 00170
VCID: 40DE9974B6C882EA173-8014
Address 66: Seat, Rear (J877) Labels: None
Component: MEM-BFS-Fond H04 0600
Revision: AA000000 Serial number: 00000077591139
Coding: C0081E8085810000090021000001000000002727000000
Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W5 955 023 M
Component: Wischermodul ª0401
Shop #: WSC 00000 725 65552
VCID: 44D69564A2D09ECA33B-8010
Address 6C: Back-up Cam. Labels: None
Part No SW: 4W0 907 441 HW: 4W0 907 441
Component: J772__Rearview 0030
Revision: 00H13000 Serial number: 525 PA8J390256
Coding: 2020003
VCID: 74B605A4B2B06E4A43B-8020
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 4W0 959 107 A HW: 4W0 959 107 A
Component: HDSG-Modul H04 0806
Revision: 00000000 Serial number: 282300145 Dataset Number: V03935176YS 0002
Coding: 170206C120
ASAM Dataset: EV_HDSGBY621 001002
ROD: EV_HDSGBY621.rod
VCID: 3B24EE98D3EEE132421-806E
Address 71: Battery Charger (J367) Labels:* None
Part No SW: 3W3 915 181 B HW: 3W3 915 181 B
Component: EMM Batt Man H05 0570
Serial number: 0000000001
Coding: 5E0100
Shop #: WSC 00083 790 00211
ASAM Dataset: EV_BatteChargVaria1 002019
ROD: EV_BatteChargVaria1_002.rod
VCID: 382EF194E2D8CA2AAF3-806C
Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
Component: J367-BDM H07 0141
Serial number: 40278911091041200900
Address 76: Park Assist Labels: 3W0-919-283-V3.clb
Part No SW: 3W0 919 283 G HW: 3W0 919 283 E
Component: J446 ST Parkhilfe 0111
Revision: 11H02001 Serial number: 58131326600692
Coding: 0300066
VCID: 41D89C70BDC28BE218D-8014
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3D0 035 730 B HW: 3D0 035 730 B
Component: Telefon 012 0825
Revision: -------- Serial number: 35909603571978
Coding: 020106010100010000000000
ASAM Dataset: EV_UHVPremi A02705
ROD: EV_UHVPremi_A02.rod
VCID: 1B640E18732E8132A21-804E
End----------(Elapsed Time: 03:16, VBatt start/end: 12.2V/12.2V)-----------
Monday,01,July,2024,16:30:16:46110
Mileage: Repair Order: INITIAL-TEST
Address 11: Engine II (07C 906 023 K)
16:30:00
IDE01975 Numb.of misfir.: cylinder 1 3288
IDE01976 Numb.of misfir.: cylinder 2 541
IDE01977 Numb.of misfir.: cylinder 3 290
IDE01978 Numb.of misfir.: cylinder 4 65535
IDE03363 Numb.of misfir.: cylinder 5 902
IDE03364 Numb.of misfir.: cylinder 6 7980
IDE03365 Numb.of misfir.: cylinder 7 2745
IDE03366 Numb.of misfir.: cylinder 8 1011
IDE03367 Numb.of misfir.: cylinder 9 12537
IDE03368 Numb.of misfir.: cylinder 10 230
IDE03369 Numb.of misfir.: cylinder 11 2660
IDE03370 Numb.of misfir.: cylinder 12 852
