Missing ASAM dataset Fabia III 2015 BCM
nitroCZ
Czech Republic
C?ID=126264
Today I found some missing dataset for Fabia III BCM?
Address 09: Cent. Elect. (J519) Labels:. 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 C HW: 6C0 937 089
Component: BCM PQ26 Hi4R 0084
Serial number: 001378066385
Coding: 0C00085042150AFB43804000402703080000D900D30A3500000000000000
Shop #: WSC 73430 790 00063
VCID: 3038E11C0AABC39AE73-8064
Subsystem 1 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S3Y15M07D02H07M16S38
Coding: 03185E
Subsystem 2 - Part No SW: 6V1 959 801 B HW: 6V1 959 801 B
Component: FHSG DRV 007 0001
Serial number: 00000000000001711465
Coding: 011200
No ASAM data for: "" (SK26)
Monday,01,July,2024,18:26:31:35073
VIN: TMBJN6NJ6GZxxxxxx   License Plate:
Mileage: 128918km-80105mi   Repair Order:
Chassis Type: NJ-SK26 (6C0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F
VIN: TMBJN6NJ6GZ035321   Mileage: 128918km-80105miles
Address 01: Engine (J623-CJZD)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BC    HW: 04E 907 309 AF
   Component: R4 1.2l TFS   H22 9086
   Revision: R4H22---    CVN: 2DF50523
   Coding: 01190032232415080000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ECM12TFS01104E906027BC 001009
   ROD: EV_ECM12TFS011_VW26.rod
   VCID: 66944744F8EF5D2ACDF-8032
   VINID: 91D49A78679A197A800C50C2046E5A3A7A
4714 - Steering Column Control Module
          U0212 00 [00100100] - No Communications
                    Mileage: 128903 km
                    Date: 2024.05.17
                    Time: 04:19:16
                    Engine RPM: 1937.00 /min
                    Normed load value: 27.5 %
                    Vehicle speed: 43 km/h
                    Coolant temperature: 88 °C
                    Intake air temperature: 43 °C
                    Voltage terminal 30: 14.347 V
                    selected gear-Bits 0-7: 3
4720 - Body Control Module (Central Electric 2)
          U0141 00 [00100100] - No Communications
                    Mileage: 128903 km
                    Date: 2024.05.17
                    Time: 04:19:17
                    Engine RPM: 1984.50 /min
                    Normed load value: 35.7 %
                    Voltage terminal 30: 14.277 V
15356 - Oxygen (Lambda) Sensor Signal B1 S2
          P2270 00 [01100101] - too Lean
                    Mileage: 128918 km
                    Date: 2024.05.17
                    Time: 06:02:39
                    Engine RPM: 1988.50 /min
                    Normed load value: 38.8 %
                    Coolant temperature: 87 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 14.229 V
                    O2 sensor 2: B1: internal resistance limit: 700 Ohm
                    Mass flow through throttle valve: 54.2 kg/h
Readiness: 0010 0001
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08503672150624
   Coding: 41F5487D492633C50917106B0052821292CC9008000DCBF98F00
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26_SK26.rod
   VCID: 372ADA00EFC514A2A69-8062
Address 08: Auto HVAC (J255)       Labels:| 6C0-907-044.clb
   Part No SW: 6V0 907 044     HW: 6V0 907 044
   Component: Climatronic   H01 0201
   Serial number:  1506243A-0233
   Coding: 100000001011100001
   ASAM Dataset: EV_ACClimaValeoPQ26 003001
   ROD: EV_ACClimaValeoPQ26_001_SK25.rod
   VCID: 74B02D0CBE33BFBA43B-8020
459014 - Databus
          U1121 00 [00001100] - Missing Message
                    Reset counter: 3
                    Mileage: 128903 km
                    Date: 2024.05.17
                    Time: 04:19:17
   Coding: 03185E
   Coding: 011200
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 7K  H03 0048
   Revision: --------    Serial number: 39391516005535 Dataset Number: 6V0039t____ 0001
   Coding: 0011051041
   ROD: EV_EPHVA18AU3700000_SK26.rod
   VCID: 3D26C828CDF93EF27C5-8068
12665088 - Databus
          [Bodycomputer 2 / Zentralmodul Komfortsystem / ZKE - Klemmen_Status_01 - kein Signal/keine Kommunikation]
                    Reset counter: 3
                    Mileage: 128903 km
                    Date: 2024.05.17
                    Time: 04:19:16
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 02061503210926 Dataset Number: 6V0114t____ 0006
   Coding: 00000000FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3A2CC334DCD709CA597-806E
0262 - Databus
          [FAULT_CIM_TIMEOUT_ESP_02]
                    Reset counter: 3
                    Mileage: 128903 km
                    Date: 2024.05.17
                    Time: 04:19:17
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 14.2 V
                    Vehicle speed: 12.03 m/s
                    Acceleration: 0.49 m/s²
0263 - Databus
          [FAULT_CIM_TIMEOUT_ESP_05]
                    Reset counter: 3
                    Mileage: 128903 km
                    Date: 2024.05.17
                    Time: 04:19:17
0264 - Databus
          [FAULT_CIM_TIMEOUT_ESP_08]
                    Reset counter: 3
                    Mileage: 128903 km
                    Date: 2024.05.17
                    Time: 04:19:17
0265 - Databus
          [FAULT_CIM_TIMEOUT_ESP_10]
                    Reset counter: 3
                    Mileage: 128903 km
                    Date: 2024.05.17
                    Time: 04:19:17
0268 - Databus
          [FAULT_CIM_TIMEOUT_ESP_21]
                    Reset counter: 3
                    Mileage: 128903 km
                    Date: 2024.05.17
                    Time: 04:19:17
0275 - Databus
          [FAULT_CIM_TIMEOUT_LWI_01]
                    Reset counter: 3
                    Mileage: 128903 km
                    Date: 2024.05.17
                    Time: 04:19:17
                    Vehicle speed: 12.00 m/s
                    Acceleration: 0.47 m/s²
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 F    HW: 6C0 959 655 F
   Component: VW20Airbag733 001 0360
   Revision: --------    Serial number: 003RJ003YWSH Dataset Number: 6VA003T____ 0115
   Coding: 88CCC000000000005C5400CF000800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3634D704E8CFEDAABDF-8062
   Subsystem 1 - Part No SW: -----------    HW: 410 822 006 15
   Component: SideSensor_Df  151 0800
   Serial number: 3575H009B1BC2382803L
   Subsystem 2 - Part No SW: -----------    HW: 410 822 106 15
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H009D1BC2383B2C$
   Subsystem 3 - Part No SW: -----------    HW: 442 152 606 15
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A009F19D6A6462F-
   Subsystem 4 - Part No SW: -----------    HW: 442 152 606 15
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A009F19D6A61439R
1054208 - Databus
          [NWD: 0x3C0 Klemmen_Status_01 Timeout]
                    Reset counter: 3
                    Mileage: 128903 km
                    Date: 2024.05.17
                    Time: 04:19:17
   Part No SW: 6V0 920 746 A    HW: 6V0 920 746 A
   Component: KOMBI         205 1420
   Coding: 072D09002180000801883A011000000000000000
   ROD: EV_DashBoardVDDMQBAB_SK26.rod
   VCID: 392EDC38D9D102D250D-806C
16776964 - Databus
          [BCM_01 keine Kommunikation]
                    Reset counter: 3
                    Mileage: 128903 km
                    Date: 2024.05.17
                    Time: 04:19:17
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     0084
   Revision: --------    Serial number: 001378066385
   Coding: 030100042F0A640000000000000000010001050000000000000000000000
   GVL: 01443C0000000000400080000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_SK25.rod
   VCID: 6596404805E95632C45-8030
   Subsystem 1 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000A0445200615
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 22169429432821273384
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AG    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3232
   Serial number: CF750069 Dataset Number: 6V0074t____ 0017
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 6D863868DD196E728C5-8038
1063424 - Databus
          [DEM_MGATE_KOMF_MSG_INVALID_FAULT]
                    Reset counter: 3
                    Mileage: 128903 km
                    Date: 2024.05.17
                    Time: 04:19:17
                    Engine RPM: 2014 /min
                    Vehicle speed: 43.91 km/h
                    System status: Driving mode
                    Terminal 15 status: Terminal 15 on
                    Voltage terminal 30: 14.48 V
                    Power steering current consumption: 0.60 A
                    max.value: 36.64 A
                    End stage temperature: 39 °C
                    Steering assistance: engine output: 100.00 %
                    Engine angle: 276 °
                    Electric motor speed: 48 /min
                    Steering assistance: target engine torque: -0.10 Nm
                    Steering torque: -1.78 Nm
                    Status: OK
1052160 - Databus
          [DEM_KLEMMEN_MESSAGE_ABSENT_FAULT]
                    Reset counter: 3
                    Mileage: 128903 km
                    Date: 2024.05.17
                    Time: 04:19:17
                    Engine RPM: 2004 /min
                    Vehicle speed: 43.47 km/h
                    Voltage terminal 30: 14.33 V
                    Power steering current consumption: 0.69 A
                    max.value: 36.64 A
                    Engine angle: 225 °
                    Electric motor speed: 4 /min
                    Steering assistance: target engine torque: -0.18 Nm
                    Steering torque: -1.96 Nm
                    Status: OK
   Part No SW: 5Q0 035 840 A    HW: 5Q0 035 840 A
   Component: MU-S--ER      H24 0241
   Serial number: SKZAZ2R8684466 Dataset Number: 6V0CV1t____ 0040
   Coding: 03620200BE0000001111000400080A002F0107C40120010000
   ROD: EV_MUStd4CTSAT_SK26.rod
   VCID: 2B02F670238DA042D21-807E
   Subsystem 1 - Part No SW: 6V0 919 604     HW: 6V0 919 604
   Component: ABTm_Std2  H40 1022
   Serial number: SKZ8Z9RH300W4U
End----------(Elapsed Time: 00:46, VBatt start/end: 12.1V/12.1V)-----------
Yet this is a mode year 2016 car..?
And the problem is that the module isn't reporting an ASAM ID, and without an ASAM ID from the module, VCDS has no idea what data to load. The module's ID data should look something like this:
Rich (BB code):
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Component: BCM PQ26 Hi4R H08 0087
   Serial number: [Redacted]
   Coding: 0F0008404205005B03A04080B10703080000D800D6013500000000000000
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005.rod
   VCID: 303917D02AA3E81BE23-8064
So what's the back-story with this module?
nitroCZ
Czech Republic
C?ID=126264
Backstory of this module is that car randomly goes to micro shut-down during drive.It seems as CAN comm issue from faulty BCM. After replacment BCM has correct ASAM data but gateway...
   Component: BCM PQ26 Hi4R H08 0084
   Serial number:  Dataset Number: 6V0063t____ 0110
   Coding: 0C00085042150AFB43804000402703080000D900D900D30A350000000000
   Shop #: WSC 00078 790 12345
12307 - License Plate Light
          B12CA 01 [00001001] - Electrical Failure
                    Reset counter: 143
                    Mileage: 128948 km
                    Date: 2024.05.18
                    Time: 04:03:05
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: operated
                    Stoerschutzzaehler: 0
                    Voltage: 11.7 V
                    Outside temperature: 19.5 °C
528140 - Local Databus 6
          U1501 00 [00001001] - Electrical malfunction
          [Lokaler Datenbus 6 (LIN)->elektrischer Fehler im Stromkreis]
                    Reset counter: 143
                    Mileage: 128948 km
                    Date: 2024.05.18
                    Time: 04:02:56
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 11.7 V
934148 - No Communications with Rain/Light Sensor
          U10F6 00 [00001001] - -
          [Sensor für Regen- und Lichterkennung->kein Signal/ Kommunikation]
                    Reset counter: 143
                    Mileage: 128948 km
                    Date: 2024.05.18
                    Time: 04:02:56
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 11.7 V
939524 - No Communications with Humidity Sensor
          U10F5 00 [00001001] - -
          [Sensor für Feuchteerkennung->kein Signal/ Kommunikation]
                    Reset counter: 143
                    Mileage: 128948 km
                    Date: 2024.05.18
                    Time: 04:02:56
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 11.7 V
          U1101 00 [00001001] - Active
                    Mileage: 128948 km
                    Date: 2024.05.18
                    Time: 04:02:56
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 11.7 V
Address 19: CAN Gateway (J533)       Labels:. 6C0-909-901-V1.clb
   Component: GW MQB A0     H08 0084
   Coding: 030000342F0A640000000000000000010001050000000000000000000000
   Subsystem 1 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
67072 - ROD - Unknown Error Code
          - 00 [00001001]
                    Reset counter: 143
                    Mileage: 128948 km
                    Date: 2024.05.18
                    Time: 04:09:02
15360512 - ROD - Unknown Error Code
          - 00 [00001001]
                    Reset counter: 143
                    Mileage: 128948 km
                    Date: 2024.05.18
                    Time: 04:09:02
15360768 - ROD - Unknown Error Code
          - 00 [00001001]
                    Reset counter: 143
                    Mileage: 128948 km
                    Date: 2024.05.18
                    Time: 04:09:02
Well, GW and BCM are both in the same package. Both are "HW: 6C0 937 089"
