Resolved 2011 VW Jetta 1.6 TDI DQ200 P177D
Resolved
PK87
Denmark
C?ID=582095
Hi all,
I have replaced the TCU due to intermittent communication errors. The car ran but shifted funny - it made errors when shifting to fourth gear, but a basic setting procedure fixed that issue. After a few short trips and some other brake and wheel suspension fixed the transmission started to make some really rough shifts to first gear when putting the gear selector into D. I get P177D abnormal torque detected and flashing D symbol. R runs fine.
I took out the mechatronic and found a broken o-ring on the accumulator and swapped it for a upgraded version with steel female threading. Didn't help on my issue.
I realized the software on the TCU, which I got from a donor mechatronic, was running another software compared to the original one (donor was 0AM 300 048 N and the old one is 0AM 300 054 D). I had the TCU flashed with correct software but without any luck.
I tried putting back the old TCU and the car shifted into D and R perfectly again - but while getting the car ready for a test drive I lost communication again. Do you have any suggestions for fixing or maybe adjusting the the donor TCU?
Thanks in advance!
OLD TCU AUTO SCAN:
Friday,28,June,2024,13:36:24:14720
VCDS -- Windows based VAG/VAS emulator - Runs on Windows 10 x64
VCDS Version: NEZ 23.11.0.1 HEX-V2 CB: 0.4643.4
Data version: 20240311 DS351.0
www.vcds.dk
Dealer no.: 204 01234 023456
Frame number: WVWZZZ16ZCM052346 Registration no.:
Model Type: 16-VW32 (7N0)
Search: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 61 62 69 72
Chassis number: WVWZZZ16ZCM052346 Mileage: 410260km
02-Automatic -- Status: Periodic communication error 1000
03-ABS brakes -- Status: Ok 0000
04-Steering angle -- Status: Ok 0000
08-Air conditioning -- Status: Ok 0000
09-Central electr. BCM1 -- Status: Malfunction 0010
15-Airbags -- Status: Ok 0000
16-Steering wheel electronics -- Status: Ok 0000
17-Instrument -- Status: Ok 0000
25-Immobilizer -- Status: Ok 0000
42-Door electr. V for -- Status: Malfunction 0010
44-Power steering -- Status: Malfunction 0010
46-Comfort electronics -- Status: Ok 0000
52-Door electr. H for -- Status: Ok 0000
56-Radio -- Status: Ok 0000
61-Battery regulation -- Status: Ok 0000
62-Door electr. V behind -- Status: Ok 0000
69-Towbar -- Status: Ok 0000
72-Door electr. H back -- Status: Ok 0000
Control Unit 01: Engine (J623-CAYC) Explanation File:. NEZ\03L-906-023-CAY.clb
   Control unit number: SW: 03L 906 023 MQ HW: 03L 907 425 C
   Component: R4 1.6l TDI H43 9977
   Revision : --H43--- Serial number : 00000000000000 CVN: 214DB367
   Coding : 10254016032401080000
   Dealer: WSC 00066 000 00086
   ASAM data set : EV_ECM16TDI02103L906023MQ 003012
   ROOT: EV_ECM16TDI02103L997557T.root
   VCID: 015F92E9E18A920220C-8054
   VINID: 9E69EAAAA046A937401420C418082A174E
2 fault codes found:
6088 - Gearbox control unit
          U0101 00 [10100101] - No communication
          Fault light activated - Not confirmed - Tested since memory wipe
             Freezer frame data:
                    Error priority: 2
                    Error rate: 2
                    Mileage: 410265 km
                    Date: 2024.06.28
                    Time: 00:03:33
                    Engine speed: 0.00 /min
                    Normalized load value: 0.0%
                    Driving speed: 0 km/h
                    Coolant temperature: 22 °C
                    Intake air temperature: 22 °C
                    Barometric air pressure: 1000 mbar
                    At 30 voltage: 12.536 V
                    Reset counter for EOBD: 40
                    Driver's torque requirement-TQI_DRIV_SUB: 0.00 Nm
                    Control unit temperature-TECU: 27 °C
6408 - Immobilizer signal (P/N)
          P0850 00 [01101100] - Short to plus/break
          Periodic - Confirmed - Tested since memory wipe
             Freezer frame data:
                    Error priority: 2
                    Error rate: 16
                    Mileage: 410264 km
                    Date: 2024.06.28
                    Time: 00:50:00
                    Coolant temperature: 50 °C
                    Intake air temperature: 21 °C
                    Barometric air pressure: 1010 mbar
                    At 30 voltage: 12.311 V
                    Engine speed: 0 /min
                    Driving speed: 255 km/h
                    Accelerator setting: normalized-Accelerator setting: 0.00 %
                    Battery voltage: 12.2 V
Control unit 02: Automation Explanation file: NEZ\0AM-927-769.clb
   Control unit number: SW: 0AM 300 054 D HW: 0AM 927 769 D
   Component : GSG DSG AG7 431 3640
   Revision : 00043014 Serial number : CU501602287844
   Coding : 0000020
   Dealer: WSC 04940 001 00001
   VCID: 2E0519550C14DD7A8DE-807A
No error codes found.
Control unit 03: ABS brakes (J104) Explanation file: NEZ\1K0-907-379-60EC1F.clb
   Control unit number: SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
   Component : ESP MK60EC1 H31 0121
   Revision : 00H31001
   Coding : A13B20F8092700FC850E04E8901F0051210000
   Dealer: WSC 00066 000 00000
   VCID: 7BA3E00183E6F8D27A0-802E
Control unit 08: Air conditioning (J255) Explanation file:| NEZ\5K0-907-044.clb
   Control unit number: SW: 5K0 907 044 ES HW: 5K0 907 044 ES
   Component: Climatronic H18 1112
   Revision : 00001003
   Coding : 0000004003
   Dealer: WSC 00066 000 00121
   ASAM dataset : EV_Climatronic A01010
   ROOT: EV_ClimaAutoBasis_VW32.root
   VCID: 005997EDEA809B0A2F2-8054
Control unit 09: Central electr. BCM1 (J519) Explanation File:. NEZ\1K0-937-08x-09.clb
   Control unit number: SW: 5K0 937 086 J HW: 5K0 937 086 J
   Component : BCM PQ35 M 011 0048
   Revision : BC011001
   Coding : 06000A3A902D02C040080080110081E403010088608085625CC087000041
   Dealer: WSC 00066 123 12345
   VCID: 3B232001C36638D23A0-806E
1 error found:
01315 - Gearbox control unit
            004 - No signal/communication - Intermittent
             Freezer frame data:
                    Error status : 00100100
                    Error priority: 6
                    Error frequency: 1
                    Reset counter: 75
                    Mileage: 410265 km
                    Time indication: 0
                    Date: 2018.11.19
                    Time: 00:04:22
             Freezer frame data:
                        At 15 MORE
                    Volts: 12.40 V
                        To
                        To
                        To
                        From
                        From
Control unit 15: Airbags (J234) Explanation file:* NEZ\5K0-959-655.clb
   Control unit number: SW: 5C0 959 655 C HW: 5C0 959 655 C
   Component : AirbagVW10 013 0613
   Serial number: 003G6M00VT0L Data set number: 160003v____ 0131
   Coding : 00003242
   ASAM dataset : EV_AirbaVW10SMEVW360 A01014
   ROOT: EV_AirbaVW10SMEVW360.root
   VCID: 323D0D2514ACF99AE96-8066
   Crash sensor for side airbag on the driver's side:
   Subsystem 1 - Control unit no: SW: 5K0 959 354 HW: 5K0 959 354
   Component : S.Sens.Fahr.V H01 ----
   Serial number : 3572MSME5B5A7061ZZZ
   Crash sensor for passenger side airbag:
   Subsystem 2 - Control unit no: SW: 5K0 959 354 HW: 5K0 959 354
   Component : S.Sens.Beif.V H01 ----
   Serial number : 3582MSME65140562ZZZN
   Crash sensor for side airbag in the rear on the driver's side:
   Subsystem 3 - Control unit no: SW: 5K0 959 351 A HW: 5K0 959 351 A
   Component : S.Sens.Fahr.H H02 ----
   Serial number : 3516KSME2D541D13ZZZV
   Crash sensor for side airbag in the rear on the passenger side:
   Subsystem 4 - Control unit no: SW: 5K0 959 351 A HW: 5K0 959 351 A
   Component : S.Sens.Beif.H H02 ----
   Serial number : 3526KSME1B151A13ZZZN
Control unit 16: Steering wheel electronics (J527) Explanation file:| NEZ\5K0-953-569.clb
   Control unit number: SW: 1K5 953 521 AG HW: 5K0 953 569
   Component : LENKS.MODULE 014 0140
   Revision : FF010040 Serial number : 20110803301857
   Coding: 4880140000
   Dealer: WSC 00066 000 00185
   ASAM dataset : EV_SMLSNGVOLWSXS A01004
   ROOT: EV_SMLSNGVOLWS.root
   VCID: 72BDCD25D42CB99A296-8026
Controller 17: Instrument (J285) Explanation file:| NEZ\5K0-920-xxx-17.clb-SRI1
   Control unit number: SW: 5C6 920 871 A HW: 5C6 920 871 A
   Component: KOMBI H04 0617
   Coding : 171E00
   ASAM dataset : EV_Kombi_UDS_VDD_RM09 A04114
   ROOT: EV_Kombi_UDS_VDD_RM09_004_VW32.root
   VCID: 2A0D15453C7CB15A516-807E
Control unit 19: CAN Gateway (J533) Explanation file:. NEZ\7N0-907-530-V2.clb
   Control unit number: SW: 7N0 907 530 J HW: 1K0 907 951
   Component : J533 Gateway H43 1620
   Revision : H43 Serial number : 23091101280629
   Coding: 351002
   VCID: 372B3C31FF4E1CB2DE8-8062
             Freezer frame data:
                    Error priority: 2
                    Error rate: 2
                    Reset counter: 75
                    Mileage: 410265 km
                    Time indication: 0
                    Date: 2018.11.19
                    Time: 00:03:34
01305 - Databus: Infotainment
             Freezer frame data:
                    Error status : 01100100
                    Error priority: 1
                    Error frequency: 1
                    Reset counter: 35
                    Mileage: 410264 km
                    Time indication: 0
                    Date: 2018.11.19
                    Time: 00:14:29
Control unit 25: Immobilizer (J334) Explanation file:| NEZ\5K0-920-xxx-25.clb
   Control unit number: SW: 5K0 953 234 HW: 5K0 953 234
   Component : IMMO H04 0617
   Serial number    :
   Coding : 000000
   Dealer : WSC 00000 000 00000
   ASAM dataset : EV_Immo_UDS_VDD_RM09 A03009
   ROOT: EV_Immo_UDS_VDD_RM09_VW21.root
   VCID: 6A8DD545FCFC715A916-803E
Control unit 42: Door electr. V for (J386) Explanation file:| NEZ\3C0-959-70X-GEN4.clb
   Control unit number: SW: 561 959 701 HW: 3C0 959 793 B
   Component : TUER-SG FT 002 0515
   Revision : 13110009 Serial number : 0003396292
   Coding : 0200B5
   Dealer: WSC 01383 790 50316
   ASAM dataset : EV_TSGFPQ35BRFVW46X A04001
   ROOT: EV_TSGFPQ35BRFVW46X_VW32.root
   VCID: 5BE3808123A618D21A0-800E
   Driving Sub-Unit:
   Subsystem 1 - Control unit no: SW: 3C0 959 703 B HW: 3C0 959 795 C Explanation file: NEZ\1K0-959-70X-GEN4.CLB
   Component : J388__TSG-HL 006 1508
   Serial number : 00000006040718
   Coding : 000090
1 error found:
66048 - Motor for front window winder
          B11EC 54 [00001001] - no default setting
             Freezer frame data:
                    Error priority: 7
                    Error frequency: 1
                    Reset counter: 35
Control unit 44: Power steering Explanation file: NEZ\1K0-909-14x-GEN3.clb
   Control unit number:: 1K0 909 144 M
   Component: EPS_ZFLS At 70 3201
   Revision : 00H20000
   Dealer: WSC 02069 000 90108
   VCID: 34310B3DE238F7AAFBA-8060
1 error found:
03803 - Power steering steering wheel angle sensor
            000 - - - Fault lamp activated
             Freezer frame data:
                    Error status : 11100000
                    Error priority: 2
                    Error frequency: 1
                    Time indication: 0
             Freezer frame data:
                    Battery volt: 12.8 V
                        PD
                    Temperature: 22.0°C
                    Counter: 2
                    Steering angle: 0.00°
                    Counter: 0
                        Ratwink.ik.ini
Control unit 52: Door electr. H for (J387) Explanation file:| NEZ\3C0-959-70X-GEN4.clb
   Control unit number: SW: 561 959 702 HW: 3C0 959 792 B
   Component : TUER-SG BT 002 0515
   Revision : 15110009 Serial number : 0003392656
   Coding : 0200B4
   ASAM dataset : EV_TSGBPQ35BRFVW46X A04001
   ROOT: EV_TSGBPQ35BRFVW46X_VW32.root
   VCID: 5CE1839D26A81FEA13A-8008
   Passenger Subunit:
   Subsystem 1 - Control unit no: SW: 3C0 959 704 B HW: 3C0 959 794 C Explanation file: NEZ\1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR 006 1508
   Serial number : 00000006060449
   Coding : 000090
Control unit 56: Radio
Cannot be contacted
Control unit 61: Battery regulation (J840) Explanation file:. NEZ\1K0-907-534.clb
   Control unit number: SW: 7N0 907 534 HW: 1K0 907 951
   Component : Batt.regelung H43 1620
   Serial number: 23091101280629
   Coding : 030B185A
   VCID: 71BFC229D1AA8282D0C-8024
Subsystem 1 - Control unit no: SW: 5C0 915 181 A HW: 5C0 915 181
   Component : J367-BDM H07 0180
   Serial number : 00000000008900138874
Control unit 69: Trailer hitch (J345) Explanation file:. NEZ\1K0-907-383-V2.lbl
   Control unit number: SW: 1K0 907 383 F HW: 1K0 907 383 F
   Component: Trailer H09 0100
   Revision : 3A001001 Serial number : 00000145837916
   Coding: 410D000100000000
   Dealer: WSC 00772 204 174347
   VCID: 3039072D1A20CB8A9F2-8064
End------(Elapsed time: 01:03, VBat. start/end: 12.4V/12.5V)--------
DONOR TCU AUTO SCAN:
Sunday,30,June,2024,22:14:44:14720
www.vcds.dk
02-Automatic -- Status: Ok 0000
09-Central electr. BCM1 -- Status: Ok 0000
7332 - Air mass meter (G70)
          P0103 00 [10100101] - Signal too strong
             Freezer frame data:
                    Error priority: 2
                    Error frequency: 1
                    Mileage: 410265 km
                    Date: 2024.06.30
                    Time: 01:17:59
                    Coolant temperature: 18 °C
                    Intake air temperature: 19 °C
                    At 30 voltage: 12,198 V
                    EGR valve: activation-ANG_SP_EGRV[0]: 0.000%
                    Throttle_actuator_commanded_value-ANG_SP_THR[0]: 3.999%
                    Air mass prescribed value-MAF_SP_MMV: 239.95 mg/stroke
                    Air mass actual value (mg/stroke)-MAF_MES: 0 mg/stroke
          P0850 00 [00100101] - Short circuit to plus/break
             Freezer frame data:
                    Error priority: 2
                    Error frequency: 1
                    Mileage: 410265 km
                    Date: 2024.06.30
                    Time: 01:17:58
                    At 30 voltage: 12.085 V
                    Battery voltage: 12.1 V
   Component : GSG DSG AG7 441 3640
   Revision : 00044014 Serial number : CU501707275610
   Coding : 0000020
   Revision : 00H31001
   Revision : 00001003
   Coding : 0000004003
   Revision : BC011001
   Coding : 00003242
   Coding: 4880140000
   Coding : 171E00
   Coding: 351002
1 error found:
             Freezer frame data:
                    Error priority: 1
                    Error frequency: 1
                    Reset counter: 35
                    Mileage: 410265 km
                    Time indication: 0
                    Date: 2018.11.21
                    Time: 01:17:56
   Serial number    :
   Coding : 000000
   Coding : 0200B5
   Driving Sub-Unit:
   Coding : 000090
1 error found:
             Freezer frame data:
                    Error priority: 7
                    Error frequency: 1
                    Reset counter: 35
                    Mileage: 410265 km
                    Date: 2024.06.30
                    Time: 01:17:56
-------------------------------------------------- -----------------------------4
   Revision : 00H20000
1 error found:
             Freezer frame data:
                    Error priority: 2
                    Error frequency: 1
                    Mileage: 410265 km
                    Time indication: 0
                    Date: 2018.11.21
                    Time: 01:17:55
             Freezer frame data:
                    Battery volt: 12.1 V
                        DD
                    Temperature: 21.0°C
                    Counter: 2
                    Counter: 0
                        Ratwink.ik.ini
   Coding : 0200B4
   Passenger Subunit:
   Coding : 000090
Cannot be contacted
   Coding : 030B185A
End-------(Elapsed time: 01:02, VBat. start/end: 12.1V/12.1V)--------
Dr Sheldon
Windsor UK
C?ID=334979
First it seems that you go on the right path - I think you are telling us that the donor is not dropping Comms ??
and then
Why open this can of worms trying to wedge Square pegs into Round holes.
I'm not as brave as you I wouldn't entertain that method of fixing cars - I Think VCDS can help you with coding the Donor - If it can be coded but for dodge software i dont think it will ??
Wrong Part Number - Wrong Software - Wrong Ending
You have no clue if the Donor is good or faulty ??
Why not repair the old one properly - get it done properly or buy one with the correct part number ?
PK87
Denmark
C?ID=582095
The donor was supposed to come from a 1.6 TDI Golf - and should be running fine. I guess I can not believe any of that after all after the findings of the wrong software version. Part number is all same though - and software got flashed without any kind of errors. So shouldn't it work as this?
Donor TCU has no problems with communication no.
Old TCU has snapped wires which needs to be resoldered/welded inside sealed housing. It could have other issues also, hence I am looking to get the donor TCU up and running.
Hardware is the same in both: 0AM 927 769 D
Software is the same in both: 0AM 300 054 D 3640
Coding is the same in both: 0000020
I think they should be interchangeable now, however there are slight differences in the Component field:
GSG DSG AG7 431 vs GSG DSG AG7 441
and the Revision:
Revision : 00043014 vs 00044014.
I'm no Dumb Stupid Gearbox expert so I don't know for a fact whether this is significant or not.
PK87
Denmark
C?ID=582095
Fixed the issue! Cloned the TCU and mechatronic now drives like a charm.
siLc
Tallinn, Estonia
C?ID=330192
The installed software is still pretty old. You can have it updated to about SW 62xx, which lowers the maximum working pressure from 60 to 52bar, preventing cracking of the accumulator housing.
  • Informative
