Help with mk6 jetta retrofit mfsw
MK6KETTNER
Delaware, USA
H11-2H
I retrofitted a beetle turbo steering wheel with mfsw buttons and paddle shifters onto my 2013 jetta se 2.5L without buttons or paddles from factory, i had to add the repair wire and splice it into section 8 on the steering module and section 17 on the bcm and now im throwing new codes and i’ve checked fuses and wiring is all good but still lost, any help would be greatly appreciated, ill drop my full auto scan below thank you in advance.
Saturday,29,June,2024,23:10:06:65383
VIN: 3VWDP7AJ8DM308028   License Plate: KETTNER
Mileage: 136180km-84618mi   Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25
VIN: 3VWDP7AJ8DM308028   Mileage: 136180km-84618miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 CP    HW: 07K 907 309 B
   Component: 2,5l R5/4V      G01 5872
   Revision: T4H06---    Serial number:
   Coding: 0000075
   Shop #: WSC 13622 410 403014
   VCID: 7EA5F5855CF8838A25F-802A
   VINID: 0E69D480745A214743008002200BCFFED4
005699 - Please check DTC Memory of Electric Load Controller
               P1643 - 000 -
                    Mileage: 136183 km
                    Date: 2018.11.20
                    Time: 09:39:44
                    RPM: 671 /min
                    Load: 28.2 %
                    Temperature: 85.0°C
                    Temperature: 55.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.716 V
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
               P0036 - 000 - Malfunction / Open Circuit
                    Mileage: 136183 km
                    Date: 2018.11.20
                    Time: 09:39:44
                    RPM: 662 /min
                    Load: 27.8 %
                    Temperature: 85.0°C
                    Temperature: 55.0°C
                    Voltage: 13.843 V
000066 - Oxygen (Lambda) Sensor B1 S3: Heating Circuit
               P0042 - 000 - Malfunction /Open Circuit
                    Mileage: 136183 km
                    Date: 2018.11.20
                    Time: 09:39:44
                    RPM: 662 /min
                    Load: 27.8 %
                    Temperature: 85.0°C
                    Temperature: 55.0°C
                    Voltage: 13.843 V
   Part No SW: 09G 927 750 LF    HW: 09G 927 750 LF
   Component: AQ 250 6F           2246
   Revision: 00H97000    Serial number:
   Coding: 0000840
   Shop #: WSC 00066 000 00000
   VCID: 00598B7D260CF57A573-8054
   Revision: 00H31001
   Coding: B14B400C492208028D0B02E692211061A61400
   Shop #: WSC 00066 123 12345
   VCID: 7DA7F2895DFE98923C5-8028
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 AT    HW: 5C0 820 047 AT
   Component: J301  Klimaanlage   0204
   Revision: 2001012S    Serial number: 00000001582345
   VCID: 72BDD1B518A0D7EA517-8026
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0256
   Revision: B2066001    Serial number: 04371138131852
   Coding: 7B994B3808AB0B0000382000240884D500C2502E60000000300000000000
   VCID: 2F3B18C1C712BA02FE9-807A
   Subsystem 1 - Part No SW: 6R0 959 801 AF    HW: 6R0 959 801 AF  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  004 3465
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AF    HW: 6R0 959 802 AF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  004 3465
   Coding: 820000
   Subsystem 3 - Part No SW: 6R0 959 811 H    HW: 6R0 959 811 H
   Component: J388__TSG_HL  004 3464
   Coding: 800000
   Subsystem 4 - Part No SW: 6R0 959 812 H    HW: 6R0 959 812 H
   Component: J389__TSG_HR  004 3464
   Coding: 800000
                    Fault Status: 00101011
                    Reset counter: 12
01326 - Control Module for Multi-Function Steering Wheel (J453)
                    Reset counter: 228
                    Mileage: 136183 km
                    Date: 2018.11.20
                    Time: 09:39:04
   Part No SW: 5C0 959 655 Q    HW: 5C0 959 655 Q
   Component: AirbagVW10G   013 0851
   Serial number: 003LKM04RB6S   Dataset Number: 160003v____ 0202
   Coding: 00004A33
   Shop #: WSC 00066 000 00185
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 40D94B7D6A0C357A173-8014
   Serial number: 6940000Y130000U9320F
   Coding: 303037
   Serial number: 3572MSME2F4F247AZZZ9
   Serial number: 3582MSME324F247AZZZ+
   Serial number: 3516KSME37386E23ZZZZ
   Serial number: 3526KSME721A1D24ZZZU
   Serial number: 3556LSME67077321ZZZR
   Serial number: 3566LSME01655823ZZZP
   Part No SW: 5C6 920 952 B    HW: 5C6 920 952 B
   Component: KOMBI         H06 0705
   Coding: 270A01
   Shop #: WSC 00066 123 00185
   VCID: 2B030CD1F38AC622D21-807E
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0256
   Revision: B2066001
   Coding: 102200
   VCID: 70B9DBBD1AACE5FAA73-8024
   Component: IMMO          H06 0705
   ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
   VCID: 6A8DC9D53CF01F2AE97-803E
End----------(Elapsed Time: 00:55, VBatt start/end: 12.3V/12.3V)-----------
Sunday,30,June,2024,11:14:27:65383
   Coding: 0000075
               P1643 - 000 -
                    Mileage: 136183 km
                    Date: 2018.11.20
                    Time: 09:39:44
                    RPM: 671 /min
                    Load: 28.2 %
                    Temperature: 85.0°C
                    Temperature: 55.0°C
                    Voltage: 13.716 V
               P0036 - 000 - Malfunction / Open Circuit - MIL ON
                    Fault Status: 11100000
                    Mileage: 136183 km
                    Date: 2018.11.20
                    Time: 09:39:44
                    RPM: 662 /min
                    Load: 27.8 %
                    Temperature: 85.0°C
                    Temperature: 55.0°C
                    Voltage: 13.843 V
               P0042 - 000 - Malfunction /Open Circuit - MIL ON
                    Mileage: 136183 km
                    Date: 2018.11.20
                    Time: 09:39:44
                    RPM: 662 /min
                    Load: 27.8 %
                    Temperature: 85.0°C
                    Temperature: 55.0°C
                    Voltage: 13.843 V
   Coding: 0000840
   Revision: 00H31001
   Coding: 820000
   Coding: 820000
   Coding: 800000
   Coding: 800000
                    Reset counter: 12
00538 - Reference Voltage
                    Reset counter: 12
                    Reset counter: 228
                    Mileage: 136183 km
                    Date: 2018.11.20
                    Time: 09:39:04
   Coding: 00004A33
   Coding: 303037
   Coding: 270A01
   Revision: B2066001
   Coding: 102200
End----------(Elapsed Time: 00:56, VBatt start/end: 13.6V/13.5V)-----------
hi, It sounds like you received some information from another forum ; locations of overlay wires. That's fine and I'm sure that post was trying to be helpful..... but unfortunately there are most likely Dozens of configurations regarding your Jetta. That is, what worked on one Jetta, doesn't necessarily transfer to another. The fault above implies no power or your mfsw is not being recognized. (ie need to check for power and ground(s)).
There are many retrofitters here on the forum, but I'm not one of them. Many of us started this way with VCDS only to be derailed with component protection and other obstacles. I'm not saying your retro-fit can't be done; its just that some are much more difficult than others.
At this point I don't think you should be attaching or jumping Any wires unless you are pretty sure what pins/functions they are going to! I think you should detach the ones you have connected also. You can easily "let the smoke out of something" and then you will have a whole different set of problems. (and they will be expensive!).
At the very least, your going to need a wiring diagram so that if a member replies, you will be able to communicate with one another. See Blue tool bar at the top of this page "HOW TO" and click on that for directions to a subscription for Official vw/audi WD's. Others may be available else where as well.
Be patient, I'm sure you will get some comments or more accurate advice ; and perhaps some wiring diagrams from a jetta With a mfsw and a WD of yours without a standard steering wheel. (I think).
