Afternoon!
I prefix this with I know its not recommended to swap out part numbers for those that dont match however I was able to pickup a unit that is very close to my original. I referenced THIS thread and its within the same "range"
Original scan;
New scan (with new unit connected electrically but not connected to brake lines;
Is there coding I can use on the new unit to make it passable? I've tried my original but it just resets to all zero.
Do I need to connect the pipe work and follow the basic settings? http://wiki.ross-tech.com/wiki/index.php/VW_Tiguan_(5N)_Brake_Electronics#Basic_Setting
Appreciate the unit may not work for my needs as there are small differences but if I can it would be amazing.
Rob
Original scan;
Saturday,01,June,2024,12:58:01:47896
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WV1ZZZ2KZBX223902 License Plate:
Mileage: 344810km-214255mi Repair Order:
Chassis Type: 2K-VN35 (7N0)
VIN: WV1ZZZ2KZBX223902 Mileage: 344810km-214255miles
Address 01: Engine (J623-CAYD) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 DB HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9978
Revision: --H43--- Serial number: 00000000000000 CVN: D0EF36E6
Coding: 00114014032500080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023DB 003011
ROD: EV_ECM16TDI02103L997557M.rod
VCID: 698FAA1309F253C2E0D-803C
VINID: 9E606AAAA09BA92A02083240083D1CB9BD
Part No SW: 1K0 907 379 BD HW: 1K0 907 379 BD
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 633C400D092403FDC61402E4901BC081300000
Shop #: WSC 35110 377 00154
VCID: 75B7F66355CA8722745-8020
ba
Part No SW: 7N0 907 426 F HW: 7N0 907 426 F
Component: AC Manuell H15 0101
Revision: 00010001
Coding: 0000000002
ROD: EV_ClimaBasis_VW32.rod
VCID: 372B3C6B0FC63532A69-8062
B10AB F0 [00001001] - Too Low
Reset counter: 115
Mileage: 344551 km
Date: 2024.06.01
Time: 02:20:23
Part No SW: 2K5 937 085 HW: 2K5 937 085
Component: BCM PQ35 B+ 011 1044
Revision: BB011001
Coding: 401A581A8025186B08800082900000644301728852028060648000000040
VCID: 72BDCD7F24A4901A517-8026
Subsystem 1 - Part No: 1T2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 05101 26 0512
Coding: 009795
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 115
Mileage: 344551 km
Date: 2018.10.23
Time: 02:20:28
Voltage: 12.05 V
Reset counter: 115
Mileage: 344551 km
Date: 2018.10.23
Time: 02:20:52
Voltage: 12.15 V
Reset counter: 115
Mileage: 344551 km
Date: 2018.10.23
Time: 02:20:52
Voltage: 12.10 V
Reset counter: 115
Mileage: 344551 km
Date: 2018.10.23
Time: 02:20:54
Voltage: 12.10 V
Reset counter: 115
Mileage: 344551 km
Date: 2018.10.23
Time: 02:20:54
Voltage: 12.10 V
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag00U H06 0013
Revision: -------- Serial number: 003HL001UZ6R Dataset Number: 2KC003v____ 0221
Coding: 000000000000000000000000000000003055
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3537366315CAC722B45-8060
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Revision: -------- Serial number: 90422KCO0002X Dataset Number: 5K0953507AH D005
Coding: 008A160000
Shop #: WSC 00028 028 00025
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76B5F16F484C8C3A7DF-8022
Component: E221__MFL-TK6 H06 0022
Serial number: 30000000000000335235
Coding: E20000
267264 - Control Module Incorrectly Coded
U1014 00 [00001000] - -
Reset counter: 158
Part No SW: 2K0 920 965 A HW: 2K0 920 965 A
Component: KOMBI H04 0404
Coding: 480000
VCID: 2D071E03FD9A8FE2CC5-8078
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 290910F2002012
Coding: E9801F0600020200007401
VCID: 6D87DE03319A4FE28C5-8038
Component: IMMO H04 0404
ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
VCID: 6A8DD51F0CF458DAE97-803E
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2110
Coding: 0000624
VCID: 48C94F977EB84ACADF3-801C
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 140 3001
Revision: 00H17000
VCID: 313F0273ED22EB02E8D-8064
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000624
VCID: 47CB4CAB73A645B2D69-8012
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5814
Revision: -------- Serial number: VWZZZ4H6290655
Coding: 16000440040005
Shop #: WSC 127395 840 08317
VCID: 46D541AF78AC5CBA2DF-8012
9 Faults Found:
Reset counter: 115
Mileage: 344551 km
Date: 2018.10.23
Time: 02:20:25
00871 - Bass Speaker Front Right (R23)
Reset counter: 115
Mileage: 344551 km
Date: 2018.10.23
Time: 02:20:25
Reset counter: 115
Mileage: 344551 km
Date: 2018.10.23
Time: 02:20:25
Reset counter: 115
Mileage: 344551 km
Date: 2018.10.23
Time: 02:20:25
Fault Status: 00111011
Reset counter: 115
Mileage: 344551 km
Date: 2018.10.23
Time: 02:20:25
00875 - Treble Speaker Front Right (R22)
Reset counter: 115
Mileage: 344551 km
Date: 2018.10.23
Time: 02:20:25
Reset counter: 115
Mileage: 344551 km
Date: 2018.10.23
Time: 02:20:25
00877 - Treble Speaker Rear Right (R16)
Reset counter: 115
Mileage: 344551 km
Date: 2018.10.23
Time: 02:20:25
00856 - Radio Antenna
Reset counter: 115
Mileage: 344551 km
Date: 2018.10.23
Time: 02:20:23
End----------(Elapsed Time: 00:53, VBatt start/end: 12.2V/12.2V)-----------
Thursday,27,June,2024,12:13:45:47896
Mileage: 345210km-214503mi Repair Order:
VIN: WV1ZZZ2KZBX223902 Mileage: 345210km-214503miles
7332 - Mass Air Flow Sensor (G70)
P0103 00 [10100101] - Signal too High
Mileage: 345211 km
Date: 2024.06.27
Time: 00:10:31
Engine RPM: 0.00 /min
Coolant temperature: 16 °C
Intake air temperature: 16 °C
Voltage terminal 30: 12.198 V
Engine RPM: 0 /min
Battery voltage: 11.2 V
EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
Throttle_actuator_commanded_value-ANG_SP_THR[0]: 96.001 %
Air mass: specified value-MAF_SP_MMV: 239.95 mg/stroke
Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Revision: 00H31001
Shop #: WSC 04941 123 12345
VCID: 76B5F16F48CC8C3A7DF-8022
10 Faults Found:
Reset counter: 164
Mileage: 228006 km
Date: 2018.11.18
Time: 16:31:21
Count: 17472
Count: 40960
Count: 12800
Count: 8225
Count: 41985
Count: 64761
Count: 55765
Count: 51200
01164 - ESP Operation
Reset counter: 164
Mileage: 228006 km
Date: 2018.11.18
Time: 16:31:22
Count: 21568
Count: 41216
Count: 13824
Count: 263
Count: 39424
Count: 63497
Count: 16032
Count: 41984
Reset counter: 164
Mileage: 228006 km
Date: 2018.11.18
Time: 16:31:32
Count: 66
Count: 32768
Count: 20992
Count: 294
Count: 44288
Count: 255
Reset counter: 164
Mileage: 228006 km
Date: 2018.11.18
Time: 19:09:38
Count: 7
Count: 32771
Count: 4608
Count: 128
Count: 33792
Count: 254
Fault Status: 00101101
Reset counter: 163
Mileage: 228007 km
Date: 2018.11.18
Time: 00:07:08
Count: 2
Count: 2
Count: 29440
Count: 8196
Count: 38656
Count: 65535
Fault Status: 00100101
Reset counter: 135
Mileage: 345211 km
Date: 2018.11.18
Time: 00:00:17
Count: 2
Count: 2
Count: 4608
Count: 212
Count: 40704
Count: 768
Reset counter: 135
Mileage: 345211 km
Count: 3
Count: 2
Count: 4608
Count: 195
Count: 40960
Count: 768
Fault Status: 01100101
Reset counter: 135
Mileage: 459010 km
Date: 2001.00.02
Time: 16:40:09
Count: 2057
Count: 211
Count: 34560
Count: 279
Count: 256
Count: 49921
Count: 8225
Count: 41985
Reset counter: 135
Mileage: 2162944 km
Date: 2041.00.00
Time: 16:06:18
Count: 257
Count: 9908
Count: 256
Count: 295
Count: 294
Count: 256
Count: 32932
Count: 256
Reset counter: 135
Mileage: 345211 km
Date: 2018.11.18
Time: 00:00:17
Count: 2
Count: 2
Count: 4608
Count: 270
Count: 40704
Count: 768
Revision: 00010001
Coding: 0000000002
Reset counter: 135
Mileage: 345211 km
Date: 2024.06.27
Time: 00:10:33
Revision: BB011001
Coding: 009795
Reset counter: 135
Mileage: 345211 km
Date: 2018.11.18
Time: 00:10:54
Voltage: 12.00 V
Reset counter: 135
Mileage: 345211 km
Date: 2018.11.18
Time: 00:10:52
Voltage: 11.85 V
Reset counter: 135
Mileage: 345211 km
Date: 2018.11.18
Time: 00:10:52
Voltage: 12.00 V
Reset counter: 135
Mileage: 345211 km
Date: 2018.11.18
Time: 00:10:35
Voltage: 12.15 V
Reset counter: 135
Mileage: 345211 km
Date: 2018.11.18
Time: 00:10:35
Voltage: 12.15 V
Coding: 008A160000
Coding: E20000
Coding: 480000
Coding: 0000624
Revision: 00H17000
000 - - - MIL ON
Fault Status: 11100000
Mileage: 345211 km
Date: 2018.11.18
Time: 00:10:30
Battery Volts: 12.1 V
DD
Temperature: 18.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Coding: 0000624
9 Faults Found:
Reset counter: 135
Mileage: 345211 km
Date: 2018.11.18
Time: 00:10:32
Reset counter: 135
Mileage: 345211 km
Date: 2018.11.18
Time: 00:10:32
Reset counter: 135
Mileage: 345211 km
Date: 2018.11.18
Time: 00:10:32
Reset counter: 135
Mileage: 345211 km
Date: 2018.11.18
Time: 00:10:32
Reset counter: 135
Mileage: 345211 km
Date: 2018.11.18
Time: 00:10:32
Reset counter: 135
Mileage: 345211 km
Date: 2018.11.18
Time: 00:10:32
Reset counter: 135
Mileage: 345211 km
Date: 2018.11.18
Time: 00:10:32
Reset counter: 135
Mileage: 345211 km
Date: 2018.11.18
Time: 00:10:32
Reset counter: 135
Mileage: 345211 km
Date: 2018.11.18
Time: 00:10:30
End----------(Elapsed Time: 00:55, VBatt start/end: 12.1V/12.1V)-----------
Rob
