HELP: Audi Q5 (UK) High Beam Assist Module Coding
allisong
York, UK
C?ID=224503
Hi,
I have retrofitted the high beam assist module to a new (September 2015) Audi Q5 3.0 TDI (engine CTBA). All is working fine and I have coded the module, but VCDS only has information on the Byte 0 (coded for Bi-Xenon) and Byte 1 (Steering Type: Right-Hand-Drive). This makes 0202, it is Byte 2 that I have no information on, (Bytes 3 through to 12 are the same in all Q5 modules I have send scans for.
The options for Byte 2 seems to be either 20 or 91 (from all the scans I have seen), however I have no idea what mine should be set to!
If anyone know what Byte 2 should be please let me know!
Many thanks...
Here is a scan of my car:
VCDS Version: Release 15.7.1 Running on Windows 7 x86
Data version: 20150904
PeersMono
Saturday,24,October,2015,15:57:12:22933
Chassis Type: 8R (8R0)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 1B 20 36 42 44 46 47 52
          53 56 5C 5F 62 6C 6D 72 AC
VIN: WAUZZZ8R4GA033914   Mileage: 4350km-2702miles
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (J623-CTBA)       Labels: None
   Part No SW: 8K5 907 401 AD    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  H14 0001
   Revision: 58H14---
   Coding: 2A254012056703030000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TDI0118K5907401AD 001001
   ROD: EV_ECM30TDI0118K5907401AA.rod
   VCID: F2A8900225F634AEDB-80A6
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 8R2 927 156 P    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0007
   Revision: --H03---
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: CAD828E26DE61C6E43-809E
   Part No SW: 8R0 907 379 BA    HW: 8R0 907 379 BA
   Component: ESP8 quattro  H09 0020
   Coding: 2F6DCC01
   VCID: 804CCACA135A163EDD-80D4
   Part No SW: 8K0 907 064 KH    HW: 8K0 907 064 KH
   Component: BCM2 2.0      H15 0711
   Coding: 05B54040000000000000
   Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
   Revision: D1000000    Serial number: 01200720150799
   Coding: 3625028080
   VCID: F8BCA22A4B8A5EFEE5-80AC
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00001124118402
   Coding: 260000118074AFF21981408300001D0D4F9DC608A7090221000008004400070200020034000000
   VCID: FAB8B82275864CEE93-80AE
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 150626  H12 0050
   Coding: 01DD13
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Subsystem 4 - Part No SW: 4G0 907 410     HW: 4H0 907 410
   Component: EHL2 V07.03  H30 0030
   Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
   Component: ACC3          H11 0110
   Coding: 008172
   VCID: B73E6116061491862C-80E2
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8R0 907 364 C    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H09 0054
   Revision: 00000000    Serial number: 04051503500002
   Coding: 070181
   VCID: BA38782235068CEED3-80EE
Address 15: Airbags (J234)       Labels: 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H49 0610
   Serial number: 003JPDD0B5KN
   Coding: 304A3531313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: C8DC12EA73EAEE7E55-809C
   Serial number: 6334MSME532D2C40E
   Serial number: 6344MSME532C671EO
   Serial number: 6352QSME49594872P
   Serial number: 6362QSME6559457AT
   Serial number: 63732SME56591654/
   Serial number: 63832SME52592C6EC
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372OE4000N2
   Coding: 0000FF
   VCID: C4C406DA47C2CA1EB9-8090
Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 981 S    HW: 8R0 920 981 S
   Component: KOMBIINSTR.   H35 0567
   Revision: 00200000    Serial number: 03D398F7G
   Coding: 33EF22007F012600010000
   VCID: CAD828E265E61C6E43-809E
   Part No SW: 8R0 907 468 AA    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0070
   Revision: 1Z130032    Serial number: 3241Z156160A67
   Coding: 80CF07FF00
   VCID: FEB0B43269AE60CEAF-80AA
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Revision: 52001005    Serial number: --------------
   Coding: 020100
   VCID: B93A672E300087F6DA-80EC
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 02020064747464545425363E00
   VCID: FCB4BE3A7FB272DE81-80A8
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000157479742
   Coding: 01781B00000000000000
   VCID: C2C800C25DD6C42E8B-8096
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Component: TSG FA        H02 0511
   Revision:             Serial number: 0000158275464
   Coding: 011D12215E01440004
   VCID: CFEE39F69E84394614-809A
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Part No SW: 8R0 909 144 P    HW: 8R0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0003897468
   Coding: 010001010001
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X.rod
   VCID: C5C21BDE44F8F316AE-8090
   Revision: 00002001    Serial number: 0374755641
   Coding: 013B0E22A0B970818720053680040047
   Component: GTO BF  H01 0080
   Subsystem 2 - Part No: 8K0 951 177
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Revision: 00005001    Serial number: 94813047097807
   VCID: AD12437EF4482B5646-80F8
   Component: TSG BF        H02 0511
   Revision:             Serial number: 0000158663940
   VCID: CED024F2998E304E1F-809A
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 10000000567405
   ROD: EV_ParkiBrake_AU48.rod
   VCID: BA3878223D068CEED3-80EE
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109G-0F8055316
   Coding: 010103010000000001
   VCID: AB164D66CA5C256658-80FE
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08006    Serial number: 60021572000008
   Coding: 0033204
   VCID: B73E6116C61491862C-80E2
   Part No SW: 8R2 035 666 J    HW: 8R2 035 666 H
   Component: H-BN-EU       H49 0941
   Revision: --------    Serial number: 515G/0F7545244
   Coding: 160101060005E9EF6D82CB5E00000403E40000020000000000
   VCID: C0CC0ACA53DAD63E9D-8094
   Subsystem 1 - Part No: 8R0 060 884 CR
   Component: EUR 2015  2102
   Component: DU7 High  H42 0104
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Component: CD-Database  6208
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000157706101
   Coding: 010C12204001240004
   VCID: C6C01CD271FEF80EA7-8092
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-JA5A3OV
   Coding: 1021010
   VCID: B424561AD7627A9E09-80E0
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: BD32733E2428BBD6F6-80E8
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000158548167
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 151841244
   ROD: EV_RDCMA00100.rod
   VCID: AF2E5976F644594674-80FA
End-------------------------(Elapsed Time: 03:35)--------------------------
Moving to Retrofits...
Mrclopec
Nipomo, CA, USA
C?ID=149231
Its the vertical offset based on model. Sebastion, please correct me if I am wrong...
Byte 2
A4 (Pre and Post Facelift) - 91
A5 (Pre Facelift) - 98
A5 (Post Facelift) - 8A
A6 - 82
A7 - 8E
Q5 - 20
Q7 - 90
Ps. It would appear that I need to update the coding on my own FLA mirror to reflect this. I don't think it will make much of a difference in operation though.
allisong
York, UK
C?ID=224503
aaaah, that makes sense when you know it, thanks, I will try 20
langers2k
C?ID=224085
Good to know, does it also take into account windscreen angle?
Do you know what any of the other bytes do? Just collected a few examples and it appears bytes 03, 06 and 09 are linked to each other as they are either 6B 5D 20 or 64 64 25.
Where as byte 12 is either empty, 00 or 01.
Mostly wondering which is closest to a 1Z Octavia as I've retrofitted HBA which was never an option and is sometimes slow to react.
allisong
York, UK
C?ID=224503
I really don't know! I do know that all of the Q5 coding's that I have seen ( about six ) have had the same coding for all the other bytes. The coding used for the rest of the bytes is also the same as it came from the factory ( ordered the mirror as new ) the only bytes not coded were byte 0, 1 and 2 all set to 00 hex ( uncoded ).
