2017 Q7 Steering angle sensor needs calibration after clock spring replacement - what is the procedure
Turbo Boost Leak Testers
California, USA
C?ID=580615
i have searched and cannot find a step by step procedure to recalibrate the steering angle sensor on my 2017 Audi Q7 - Im only finding procedures for older models and the options are not available with this new chassis.
Issue started after i pulled the engine for an oil consumption issue finding the exhaust valves needed replacement. During that the steering shaft was spun and clock spring ribbon was damaged. I purchased the clock spring/steering module off eBay (exact PN as my original unit). I had tried first just to swap the clock spring module, thought it would be an easy fix, took it to the dealer and they couldn't communicate with it, so since, i put the ebay clockspring/steering module together and have that installed now. Purchased VCDS and hoping to get this done myself
Is there a detailed complete procedure i can follow to get the steering angle sensor calibrated?
Are there any data logs that i can look at to verify if my new steering module is functional?
Any help is appreciated
full auto scan below
Saturday,22,June,2024,15:21:22:34318
VCDS Version: 24.5.0.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WA1LAAF74HD029911   License Plate:
Mileage: 148772km-92442mi   Repair Order:
Chassis Type: F7-AU73 (8W6)
Scan: 01 02 03 06 08 09 15 16 17 19 29 36 39 3C 42 44 46 50 52 5F
          69 6C 6D 81 A5 BB BC CA CF D6 D7
VIN: WA1LAAF74HD029911   Mileage: 148772km-92442miles
39-Right Light -- Status: Malfunction 0010
50-Seat Adj. 3rd row -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CREC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4M0 907 551 A    HW: 06E 907 425
   Component: 3.0l V6 TFSI  H10 0003
   Revision: --H10---    CVN: 8E921FE7
   Coding: 2A2A00320536010D74280000000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TFS0214M0907551A 001005
   ROD: EV_ECM30TFS021_AU73.rod
   VCID: 2D0C6506BDE95E82CC5-8178
   VINID: 9D105C451587118500089241044BB2CCC9
20639 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
          P0056 00 [10101111] - Malfunction / Open Circuit
30959 - Engine Oil Level Sensing
          P15A5 00 [00100000] - Implausible Signal
17178 - Databus
          U1123 00 [00101111] - Received Error Message
23081 - Implausible Data Received from Steering Column Control Module
          U0429 00 [00101111] - -
24194 - PCV Valve Malfunction
          P052E 00 [01100101] - -
Readiness: 0010 0001
Address 02: Auto Trans        Labels:| 0BK-927-156.clb
   Part No SW: 4M0 927 158 L    HW: 0D5 927 156 H
   Component: 0D5  30TSIUSA H03 1006
   Revision: --H03---    CVN: 228D7428
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 3D2C55466D89CE027C5-8168
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-V1.clb
   Part No SW: 4M0 907 379 Q    HW: 4M0 907 379 N
   Component: ESP9 Premium  H09 0657
   Dataset Number: 4M0909504M  0002 CVN: ACFBEF4F
   Coding: 28AA149C30A40A9F91A75892007E5292E6269A14280C50891A004A49676459
   ASAM Dataset: EV_ESP9BOSCHAU536K 012013
   ROD: EV_ESP9BOSCHAU536K_AU73.rod
   VCID: 45DC3DA6055986C2245-8110
6293504 - Steering Angle Sensor
          C2008 00 [10101111] - Signal Qualification
   Part No SW: 4M1 959 760     HW: 4M1 959 760
   Component: MEM-BFS       008 0031
   Serial number: 00000217805240 Dataset Number: 4M0909866C  0016
   Coding: 001410000000B0010000010101010000000000000000000000000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   VCID: 76BE8A6A083F5D5A7DF-8122
   Part No SW: 4M0 820 043 R    HW: 4M0 820 043 R
   Component: Klima Zone 3  H52 0093
   Coding: 6608090C5144000D10200280000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 343A70625EC30F4A83B-8160
   Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000001033984
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4G0 907 658 B    HW: 4G0 907 658 B
   Component: Humidity_Sens  H01 0005
   Serial number: 1FB8884800PAG0FSA002
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: Klima Heck  H40 0073
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0266
   Dataset Number: 4M0909514P  0050
   Coding: 07500363E0081CCD010D871458BE9CB911033D01900000000000000020001A0108690122025709
   VCID: 0256E6BA54F771FA417-8156
   Subsystem 1 - Part No SW: 4M1 955 119 A    HW: 4H2 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 160712  043 0893
   Serial number: 89555300401619400504
   Coding: 1BC7F7
   Serial number: 62207148
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 27 06 2016  00449103
   Garage door opener control head:
   Subsystem 4 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20160810104130 00389
   Subsystem 5 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE113061612010127
   Coding: 030000
   Interior Light Module:
   Subsystem 6 - Part No SW: 4M0 947 135 CP    HW: 4M0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: Q00188016
   Subsystem 7 - Part No SW: 4M0 907 705 A    HW: 4M0 907 705 A
   Component: J866-EVLS-SG  H03 0080
   Serial number: WA125105000024653807
   Coding: 020100
   Subsystem 8 - Part No SW: 4M0 925 301 A    HW: 4M0 925 301 A
   Component: SL-Q7NF/AU736  H10 0013
   Serial number: 00000000000000070690
65689 - Heated Seat Backrest; Front Left
          B14E1 15 [00001001] - Open or Short to Plus
66088 - Garage Door Opener Transmitter
          U1135 00 [00001001] - No Communications
66952 - Databus
          [Right LCM: side marker faulty]
196758 - Databus
          [Brake control module: received error value in signal ESP system status]
   Part No SW: 4M0 959 655 A    HW: 4M0 959 655 A
   Component: Airbag10.44   H71 0086
   Serial number: 003M500115TN Dataset Number: 4M0909602T  0001
   Coding: AECCFCC000800000A0F00033C24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005.rod
   VCID: 3924415679A1F22250D-816C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 4M0857705E0246Q01796
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 4M0857706E0247Q01645
   Coding: 88001B
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J160005SD1Q0G
   Subsystem 4 - Part No SW: -----------    HW: 442 060 209 16
   Serial number: 3577Y00AF1F9D0F0E29U
   Subsystem 5 - Part No SW: -----------    HW: 442 063 008 16
   Serial number: 3587Y009B1F9D0F2C25M
   Subsystem 6 - Part No SW: -----------    HW: 442 0B1 706 16
   Serial number: 3517700AD20A0002D1E2
   Subsystem 7 - Part No SW: -----------    HW: 442 0B1 706 16
   Serial number: 3527700AD20D8174919F
   Subsystem 8 - Part No SW: -----------    HW: 442 0C0 808 16
   Serial number: 3557500C92139CC3B1AO
   Subsystem 9 - Part No SW: -----------    HW: 442 0C0 808 16
   Serial number: 3567500C92139CC641CN
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 410 201 508 16
   Component: CentrSensorXY  1C8 0108
   Serial number: I0O7800BB20D7DC22067
          B13BC F2 [10001001] - No function
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
   Part No SW: 4M0 907 129 GD    HW: 4M0 907 129 GD
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 78A28452022B2B2A6F3-812C
5586944 - Steering angle sensor
          B1168 04 [00001001] - Internal System Fault
   Part No SW: 4M0 920 890 B    HW: 4M0 920 890 B
   Component: FBenUSA       H15 0302
   Coding: 08E600C12888CF050223E9601800200008000000
   ASAM Dataset: EV_DashBoardAU736 001022
   ROD: EV_DashBoardAU736_AU73.rod
   VCID: 2F307F0EB7E52C92FE9-817A
   Part No SW: 8W6 907 468 C    HW: 8W6 907 468 C
   Component: Gateway       H27 2299
   Revision: 4P060005    Serial number: 0584P304416904 Dataset Number: 4M0909515F  0069
   Coding: 0301000100000E4054070000005900304C120007000000000175078E00000000
   GVL: 01503C0008000000C0FC08000002C800100C2000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 002060
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 4AC60E9A2C4769BAC97-811E
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0002
   Serial number: 20160816092724 01006
   Serial number: 1548631304
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0023
   Component: MEM-FS        008 0031
   Serial number: 00000217815202 Dataset Number: 4M0909856C  0018
   Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
0308 - Bulb for side marker light
          C11A6 15 [00001000] - Open or Short to Plus
Address 3C: Lane Change (J769)       Labels:| 4M0-907-566.clb
   Part No SW: 4M0 907 566 B    HW: 4M0 907 566
   Component: MRR1Rear      H13 0230
   Revision: --------    Dataset Number: 4M0909535K  0014
   Coding: 1E8002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001015
1192234 - Databus
          [databus error value received - EPS_Zahnstangen_Pos]
1192210 - Databus
          [databus error value received - ESP_Systemstatus]
267010 - Databus
          [FAULT_SLAVE]
   Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
   Component: TSG FS        009 0052
   Serial number: 0000216920675  Dataset Number: 4M0909872F  0027
   Coding: 001F9B005E001080000120B0
   VCID: 42D626BA1477B1FA017-8116
   Part No SW: 4M0 909 144 G    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H20 0004
   Serial number: 0000176880 Dataset Number: 4M0909852L  0025
   Coding: 90000001000100
   ASAM Dataset: EV_EPSVWBSAU736 008020
   ROD: EV_EPSVWBSAU736_008.rod
   VCID: 3338737E5BCD08729A1-8166
5258753 - Steering End Stops Not Learned
          C10AC F0 [10001001] - Unknown Error Elaboration
          [End_stop_not_learned]
3156996 - Databus
          [Message_LWI_01_Error_Value]
4205828 - Steering angle sensor
          B1168 54 [10001001] - Missing Calibration / Basic Setting
   Part No SW: 8W0 907 064 BD    HW: 8W0 907 064 D
   Component: BCM2 MLBevo   018 0328
   Dataset Number: 4M0909501G  0060
   Coding: 01341E00490100C0650BA0006E01580203024000010005502F0400000F04803F001E0001000000
   ASAM Dataset: EV_BCM2HellaAU736 011012
   ROD: EV_BCM2HellaAU736_011_AU73.rod
   VCID: 7F506F4E27051C122E9-812A
   ID - sensor:
   Subsystem 1 - Part No SW: 4M0 959 754 AA    HW: 4M0 959 754 AA
   Component: ID-Geber  H40 0105
   Serial number: 3616000156116014
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000036312682
   Subsystem 3 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0816
   Serial number: 94153575
648705 - Bulb for Rear Left Side Marker Lamp
          B12BC 13 [00001000] - Open Circuit
648707 - Bulb for Rear Left Side Marker Lamp
          B12BC 12 [00001000] - Short to Plus
131123 - Remote key 2
          B147A 18 [00001001] - Current Too Low
Address 50: Seat Adj. 3rd row (J857)       Labels:* None
   Part No SW: 4M0 959 760 G    HW: 4M0 959 760 G
   Component: MEM-SR3       008 0015
   Serial number: 00000216987167 Dataset Number: 4M0909467B  0014
   Coding: FF041020F1000000000F000000000900000021210900000000000000440000
   ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
   ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
   VCID: 3C2A58427693C70A4BB-8168
   Part No SW: 4M0 959 792 G    HW: 4M0 959 792 C
   Component: TSG BFS       009 0052
   Serial number: 0000216005832  Dataset Number: 4M0909873F  0027
   VCID: 41D429B61171AAE218D-8114
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M0 035 880 B    HW: 4M0 035 880
   Component: MU-P-LNS-US   052 0692
   Serial number: A289I0G7519338 Dataset Number: 4M0909545J  0034
   Coding: 01370602FF0A000053220001041A00102F001BE501700904FE
   VCID: 2B086B1E83FD50B2D21-817E
   Subsystem 1 - Part No SW: V03 959 802 DL    HW: -----------
   Component: NAR 2019  --- 0069
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9GJ402SE2
   Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
   Component: ControlUnit_P  H15 0209
   Serial number: 02091600000000000494
   Compact disc data bank:
   Component: Gracenote2---  --- 3009
7188 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Garage door opener (0x14) - function restriction due to communication error - BapErr_retry not successful]
7223 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
   Part No SW: 4M0 907 383 C    HW: 4M0 907 383
   Component: Anhaenger     H20 0214
   Revision: 9C001003    Serial number: 0415450302 Dataset Number: 4M0909527C  0024
   Coding: 0210000200000000
   VCID: 3236767AA4D7017A917-8166
   Part No SW: 4M0 907 428 D    HW: 4M0 907 428
   Component: Areaview 2    H12 0311
   Serial number: C854607JG003295 Dataset Number: 4M1909460F  0018
   Coding: 02350602BB0FA10008404004
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: 30919561600000 Dataset Number: 4M0909541G  0025
   Coding: 00B0
   ROD: EV_DeckLidCONTIAU736_VW41.rod
   VCID: 48C23492324B9BAADF3-811C
   Part No SW: 4M1 713 041 D    HW: 4M1 713 041 D
   Component: GSM-LL        H08 0068
   Revision: 0L0D5012    Serial number: 20160823000566
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 261E9A2A981F6DDA0DF-8172
   Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
   Component: BVS           H14 0042
   Dataset Number: 4M0909466K  0041
   Coding: 0407030600000201022023A3A50000B400F0C020C000
   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
10 Faults Found:
1123080 - Databus
          [LWI_01_LWI_QBit_Lenkradwinkel]
1123714 - Databus
          [Airbag_01_AB_Systemfehler]
1123173 - Databus
          [ESP_21_ESP_Systemstatus]
1123186 - Databus
          [LWI_01_LWI_Lenkradwinkel]
1123188 - Databus
          [LWI_01_LWI_Lenkradw_Geschw]
1123733 - Databus
          [SWA_01_SWA_rel_Fehler]
1123600 - Predictive Route Data
          B1630 02 [00001000] - Signal Failure
1123601 - Predictive Route Data
4096 - Module for Camera
          C110A F3 [00001001] - Restricted Visibility due to Interference Windshield Inside
          [Clean_windshield]
1123986 - Dynamic Calibration
          C1106 F1 [00001000] - Function Restriction due to Limitation Exceeded
          [Online_calibration_safe-state_active]
   Part No SW: 4M0 959 795 G    HW: 4M0 959 795 C
   Component: TSG HFS       009 0052
   Serial number: 0000216974152  Dataset Number: 4M0909897F  0028
   Coding: 000F9B0000001080400020A0
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 44DA20A20E63BFCA33B-8110
   Component: TSG HBFS      009 0052
   Serial number: 0000216974153  Dataset Number: 4M0909896F  0028
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
          B1487 54 [00001000] - Missing Calibration / Basic Setting
   Part No SW: 4M0 907 594 G    HW: 4M0 907 594
   Component: SAD_STG_1     013 0005
   Dataset Number: 4M0909469F  0014
   Coding: 2A8000053602
   ROD: EV_SunRoofCONTIAU736_006_VW37.rod
   VCID: 3A265E5A7CA7F93A597-816E
Address CF: Lane Chge Asst 2 (J770)       Labels:. 4M0-907-566.clb
   Part No SW: 4M0 907 590 B    HW: 4M0 907 590
   Revision: --------
   Coding: 1E8002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001015
   VCID: 31347976A1D13A62E8D-8164
1192234 - Databus
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   Dataset Number: 4M0909471D  0012
   ROD: EV_LEDModLeftMELCOAU736_AU73.rod
   VCID: 167EAAEA287FFD5A9DF-8142
   Component: LED1R         H09 0003
   Dataset Number: 4M0909472D  0012
End----------(Elapsed Time: 02:36, VBatt start/end: 12.1V/12.1V)-----------
You should be able to look see readings from the Steering Angle Sensor at this Measuring Value in the ABS:
IDE00326 -- Steering wheel angle
There are also a whole bunch of Steering Angle Sensor Measuring Values in 16-Steering Wheel. Type angle into the search/filter box on the Advanced Measuring Values screen in that module and you'll find them all. I would probably start with:
IDE08696-MAS02983 -- Steerg. wheel angle sens. - Steering wheel angle
See what those angle readings show with the front wheels straight ahead and the steering wheel centered. Then move the steering wheel some to the left and some to the right and see what happens to the readings.
But the fact is, you have this fault in the 16-Steering Wheel:
I do not think you can fix that with any kind of calibration.
eBay is not a reputable source for modern VW/Audi parts. ;)
California, USA
C?ID=580615
Thanks for the Reply, finally able to get back into it for some data. I went into module 16, steering wheel. Seems the steering wheel angle is locked at 819 degrees, and the internal value of the steering wheel angle is reading numbers but fluctuating,and doesnt seem right.
What is the "steering wheel angle internal value" represent with respect to the regular "steering wheel angle?"
should the correct readings be something near 0 degrees with the wheels pointing forward, straight?
see photo, shows the internal value all over the place.
@Uwe - the ebay module was a genuine part, but used, not aftermarket. I guess to your point it still proved to not work, but now im not sure if its because tampered with it, swapping the ribbon clockspring out and back in.
Ill have to re-inspect the "new" ribbon, but if the ribbon is good, and currently all other steering stalk controls work, turn signals, wipers, etc, what else could be failed causing the internal system fault B1168 04?
