My alarm went off last night for no apparent reason, so I scanned to see if I could figure out what tripped it.
No dice, but several other things I did notice:
Several times the ASAM data attempted to update and failed.
When it does this, you either get kicked out of VCDS-Mobile and have to log back in, or it goes back to the main menu.
Ultimately this ends up with a 'lost' scan and you have to start from square one.
Is it possible to have HEX-NET auto-save Autoscans ?
The modules that failed comms are accessible individually as per screenshots below.
Looking at a previous version scan, it also missed 09.
Unfortunately I forgot the Winders tablet so I couldn't get a USB attached scan.
What do you guys think, and what else do you need from me? THanks-Jake
Versions / Info
2012 A8L
CodeBlock V0.41
FW version: 0.176
Dataset: 00000026
Infra mode tethered to iPhone 5s on T-Mobile
Version 0.41.0.4
Version 0.4009.0.4
- Hung on 09 the first try
- 09 is consistently missing - see below about several lost scans
- 62 failed to respond the second time
- 72 failed to respond the 4th or 5th time
Versions / Info
2012 A8L
CodeBlock V0.41
FW version: 0.176
Dataset: 00000026
Version 0.41.0.4
#hndoc:?docid=00000312&xt=hnh:B78F1B8A8EA3DBC96B0A408C3338E796B2FD70156AB09432F7529F072DA08FAA
VCDS Mobile 0.41.0.4
Gateway Installation list:
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
8F-Pretension. Front Left -- Status: OK 0000
90-Pretension. Front Right -- Status: OK 0000
Address 01: Engine (CDRA
-----) Labels:4H-01.lbl
Part Number SW: 4H0-907-560-C HW: 4H0-907-560
Component: 4.2l V8/4V H07 0004
Revision: N5H07---
Coding: 0106000A290F0268
Shop #: WSC 02313 785 00200
ASAM Dataset: EV_ECM42FSI0114H0907560C 001005
ROD: EV_ECM42FSI0114H0907560C.rod
VCID: 2A1791ABD54FA1429D8E-807F
No fault codes found.
Address 02: Auto Trans (J217) Labels:None
Part Number SW: 4H1-927-158-BR HW: 0BK-927-156-K
Component: 0BK 42 FSIUSA H08 1001
Revision: --H08---
Coding: 000002
ROD: EV_TCMALX51011_AU64.rod
VCID: 8145960788B9021A6C24-80D4
Address 03: ABS Brakes (J104) Labels:4H0-907-379.clb
Part Number SW: 4H0-907-379-C HW: 4H0-907-379-C
Component: ESP PREMIUM H10 0273
Revision: --------
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ESPPremi 005006
ROD: EV_ESPPremi_AU64.rod
VCID: 322789CBFD9FE98225DE-8067
Address 05: Acc/Start Auth. (J393) Labels:8K0-907-064-05.clb
Part Number SW: 4H0-907-064-BD HW: 4H0-907-064-BD
Component: BCM2 2.0 H31 0330
Coding: 0D872000000000000000
VCID: 6C9B57B31F3B67722F12-8039
Subsystem 1 -
Subsystem 2 - Part Number: 4H0-905-852-C
Component: J764 ELV MLB H39 0046
Address 06: Seat Mem. Pass (J521) Labels:None
Part Number SW: 4H0-959-760-E HW: 4H0-959-760-E
Component: MEM-BFS H08 0153
Revision: AA000000
Coding: C018B60085043201010001010101112131313333283333
VCID: 352DB2D70CF1E6BA003C-8060
Address 08: Auto HVAC (J255) Labels:None
Part Number SW: 4H0-820-043-H HW: 4H0-820-043-H
Component: Klima 4 Zonen H20 0072
ROD: EV_AirCondiFront_AU64.rod
VCID: 250D6297BC518E3AB05C-8070
Address 0E: Media Player 1 (R161) Labels:None
Part Number SW: 4H0-035-108-E HW: 4H0-035-108
Component: DVDCAlpine H42 0190
Revision: AA001001
VCID: 2207798BAD7F6102D57E-8077
Address 10: Park/Steer Assist (J446) Labels:4H0-919-475-7X2.clb
Part Number SW: 4H0-919-475-L HW: 4H0-919-475-C
Revision: 11001001
Coding: 280902
ROD: EV_EPHVA18AU57X0000.rod
VCID: 3B39A4EF2AD528CAF678-806E
Address 13: Auto Dist. Reg (J428) Labels:None
Part Number SW: 4H0-907-561-A HW: 4H0-907-561
Component: ACC3 H15 0160
Coding: 3601020201
ASAM Dataset: EV_AdaptCruisContrAU64X 001012
ROD: EV_AdaptCruisContrAU64X.rod
VCID: 29156EA7D049AA5A94B4-807C
Address 15: Airbags (J234) Labels:None
Part Number SW: 4H0-959-655-D HW: 4H0-959-655-D
Component: Airbag10.43 H41 0041
Revision: --------
Coding: 303143303230303030314A55304C34483053
VCID: 3731B8DF16FD0CAA1200-8062
Subsystem 1 - Part Number: 4H0-959-339
Component: BF-Gewichtss.H02 0040
Serial Number: 5850000R1190801Y2Nªª
Subsystem 2 - Serial Number: 3575HRB405D0NI366PV.
Subsystem 3 - Serial Number: 3585HRB40550Q3SK39JQ
Subsystem 4 - Serial Number: 3515JRB404R0Q8K4FOSG
Subsystem 5 - Serial Number: 3525JRB404R0Q8K46G6L
Subsystem 6 - Serial Number: 3554VRB40610M5SO0H1M
Subsystem 7 - Serial Number: 3564VRB40610M5SO493L
Address 16: Steering wheel (J527) Labels:None
Part Number SW: 4H0-953-568-G HW: 4H0-953-568-G
Revision: --------
Coding: 0000BC
VCID: 3731B8DF16FD14AA1200-8062
Subsystem 1 - Part Number: 4H0-951-528-L
Component: E221 - MFL H04 0009
Address 17: Instruments (J285) Labels:4H0-920-xxx-17.clb
Part Number SW: 4H0-920-980-H HW: 4H0-920-980-H
Component: TBenUSAACC--- H38 0373
Revision: 32480030
Coding: 0B4F08015700D705020000
ASAM Dataset: EV_RBD4K 004040
ROD: EV_RBD4K.rod
VCID: 302383C3F393DB9253CA-8065
Address 19: CAN Gateway (J533) Labels:None
Part Number SW: 4H0-907-468-F HW: 4H0-907-468-C
Component: J533--Gateway H08 0213
Revision: --------
Coding: 00C1034A00
ROD: EV_GatewUDS_AU57.rod
VCID: 342B8FD3078BE7B23722-8061
Subsystem 1 - Part Number: 4H0-915-181
Component: J367-BDM H07 0140
Serial Number: 00000000005650628220
Address 28: HVAC, Rear (E265) Labels:None
Part Number SW: 4H0-919-158-D HW: 4H0-919-158-D
Component: Klima Fond H15 0062
ROD: EV_AirCondiHeck_AU64.rod
VCID: 312586C7F899D29A5CC4-8064
Address 34: Level Control (J197) Labels:None
Part Number SW: 4H0-907-553-C HW: 4H0-907-553
Component: LUFE-DAEMPFER H17 0096
Coding: 008002
VCID: 2C1B97B3DFBBBF726F92-8079
Address 36: Seat Mem. Drvr (J136) Labels:None
Component: MEM-FS H08 0153
Revision: AA000000
Coding: C018BF8085853201030001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels:None
Part Number SW: 4H0-907-637 HW: 4H0-907-637
Component: SARA 6D H02 0015
Revision: --------
ASAM Dataset: EV_SARA 006014
VCID: EC9BD7B39F3BFF72AF12-80B9
3801346 - ROD - Unknown faultcode
Address 3C: Lane Change Labels:None
Part Number SW: 4H0-907-566-A HW: 4G0907568
Component: J769 SWA MasterH01 0030
Revision: 00H01000 Serial Number: 6PZ 010 287-07
VCID: 2E1F9DBBE9A7556241E6-807B
Subsystem 1 - Part Number: 4H0-907-568-A
Component: J770 SWA Slave H02 0030
Serial Number: 6PZ 010 287-27
Address 42: Door Elect, Driver (J386) Labels:None
Part Number SW: 4H0-959-793-M HW: 4H0-959-793-E
Component: TSG FA H02 0166
Revision: --------
Coding: 011F1F205E0062C202000017
Shop #: WSC 02312 785 00200
VCID: 43C9DC0F5225480ABE88-8016
Address 46: Central Conv. (J393) Labels:4H0-907-064-46.clb
Coding: 0106023A00FA759FB0B0C780020100000000000000000000000000000000
Subsystem 1 - Part Number: 4H0-959-719
Component: GTO BF H01 0070
Subsystem 2 - Part Number: 1K0-951-605-C
Component: LIN BACKUP HOH05 1501
Subsystem 3 - Part Number: 4H4-959-591
Component: J245 007C H06 0005
Coding: 020200
Subsystem 4 - Part Number: 4H0-947-135-BR‘>8
Component: DachelektroniH11 0080
Coding: 070000
Subsystem 5 - Part Number: 4H4-959-591
Component: J394 0014 H06 0005
Coding: 020200
Subsystem 6 - Part Number: 4H4-959-591
Component: J392 006A H06 0005
Coding: 020200
Subsystem 7 - Part Number: 4H4-959-591
Component: J867 00E0 H06 0005
Coding: 020200
Address 47: Sound System Labels:None
Part Number SW: 4G0-035-223-B HW: 4G0-035-223-A
Component: 0130H07
Revision: CJ007000
Coding: 030000
VCID: 1C7B47738F1B57F21F32-8049
Address 48: Seat, Rear, DS (J876) Labels:None
Part Number SW: 4H0-959-860 HW: 4H0-959-860
Component: MEM-FS-Fond H06 0153
Revision: AA000000
Coding: 001892800000300D0A00392038193A2039203B3B202020
VCID: F1A5C6C7B8190A9A9C44-80A4
Address 52: Door Elect, Pass. (J387) Labels:None
Part Number SW: 4H0-959-792-E HW: 4H0-959-792-E
Component: TSG BF H02 0166
Revision: --------
Coding: 011F1F205E0062C202000007
VCID: 3A37A1EB25EF09C2ED6E-806F
Address 53: Parking Brake (----) Labels:4H0-907-801.clb
Part Number SW: 4H0-907-801-E HW: 4H0-907-801-A
Component: EPB-4 H03 0012
Revision: --------
Shop #: WSC 00000 000
Address 56: Radio (R) Labels:None
Part Number SW: 4H0-035-082-B HW: 4H0-035-082
Component: Radio U SIRIU H52 0076
Revision: AB001007
Coding: 020007010000000001
VCID: 20037383A3737312C36A-8075
Address 5B: Seat,Rear,PS (J877) Labels:None
Component: MEM-BFS-Fond H06 0153
Revision: AA000000
Coding: 001896800000300D0A00392038193A2039203B3B382020
Address 5F: Information Electr. (J794) Labels:4E0-035-6xx-5F.clb
Part Number SW: 4H0-035-746-D HW: 4H0-035-746
Component: H-BNT-NA H48 0423
Revision: --------
Coding: 020200000001F9EF7D128B0E00000003140001000000000000
VCID: 29156EA7D049B25A94B4-807C
Subsystem 1 - Part Number: 8R0-060-884-AD‘>8
Component: NAR 2011 0505
Subsystem 2 - Part Number: 4H0-919-604-D
Component: DU8 D4 SV NB H47 0021
Subsystem 3 - Part Number: 4H1-919-600-F
Component: E380 BDT D4 H09 0064
Subsystem 4 - Part Number: 8R0-060-961-B
Component: CD-Database
Address 62: Door, Rear Left (J388) Labels:None
Part Number SW: 4H0-959-795-A HW: 4H0-959-795-A
Component: TSG HL H04 0167
Revision: --------
Coding: 010F1F20420062C202000007
VCID: 3935BEE720E902DAE414-806C
Address 6C: Back-up Cam. Labels:4H0-907-441.clb
Part Number SW: 4H0-907-441-A HW: 4H0907441
Revision: --H04--- Serial Number: 525 PA8J17D1M2
Coding: 1080003
Shop #: WSC 02391 785 00200
VCID: 260F659BC1571D22B956-8073
Address 6D: Trunk Elect. (----) Labels:None
Part Number SW: 4H0-959-107-R HW: 4H0-959-107-M
Component: HDSG-Modul H11 0039
Revision: 10011001
Coding: 0210044100
VCID: 3D3DAAF734C126FAC84C-8068
Address 6F: Centr. Conv. II (J773) Labels:None
Part Number SW: 4H0-907-412 HW: 4H0-907-412
Component: ALM H05 0004
Revision: --------
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: E389BC8F72E5B00A1EC8-80B6
Address 72: Failed to respond
Address 81: Gear Shift (J587) Labels:None
Part Number SW: 4H1-927-731-A HW: 4H1-927-731-A
Component: GSM-LL H07 0083
Revision: 0L0D5012
ROD: EV_GSM2x3Mono.rod
VCID: 2B1994AFDAB5B84A6698-807E
Address 85: On Board Cam. (J852) Labels:None
Part Number SW: 4G0-907-217 HW: 4H0-907-217-A
Component: DPC-SG H24 0036
Revision: --------
ROD: EV_OnBoardCamerDPC.rod
VCID: E58DA2977CD1CE3AF0DC-80B0
Address 88: Multicont. Seat Driver (J873) Labels:None
Part Number SW: 4H0-907-182-H HW: 4H0-907-182-H
Component: IVB H07 0042
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F2180BFEEADC46A4AF0-807A
Address 89: Multicont. Seat Pass. (J872) Labels:None
Address 8A: Multicont. Seat Rear,DS (J875) Labels:None
Part Number SW: 4H0-907-182-G HW: 4H0-907-182-G
Component: IVB H08 0042
ASAM Dataset: EV_IVBDriveSideRear 001003
VCID: 2E1F9DBBE9A7CD6241E6-807B
Address 8B: Adaptive Cruise 2 (J428) Labels:None
Part Number SW: 4H0-907-541-A HW: 4H0-907-541
Coding: 3601020201
ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
ROD: EV_AdaptCruisContr2AU57X.rod
VCID: 2711689FC65D9C2A82A0-8072
Address 8D: Multicont. Seat Rear,PS (J874) Labels:None
ASAM Dataset: EV_IVBPasseSideRear 001003
Address 8E: Image Processing (J851) Labels:4G0-907-107.clb
Part Number SW: 4G0-907-107-C HW: 4H0-907-107
Component: BV-SG H29 0036
ASAM Dataset: EV_BC7 001001
VCID: 260F659BC1578522B956-8073
Address 8F: Pretension. Front Left (J854) Labels:4H0-980-94x-RGS.clb
Part Number SW: 4H0-980-945-B HW: 4H0-980-945-B
Component: RGS-VL H13 0080
ASAM Dataset: EV_RGS_L 002004
Address 90: Pretension. Front Right (J855) Labels:4H0-980-94x-RGS.clb
Part Number SW: 4H0-980-946-B HW: 4H0-980-946-B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Version 0.4009.0.4
#hndoc:?docid=00000143&xt=hnh:E9C81AC9DC7CB65E2DD768F480A86F66024B43276FD134208489DBCCAB086361
VCDS Mobile 0.4009.0.4
VIN: WAURVAFD6CN014370
Revision: N5H07---
VCID: 2A1791ABD5B2A1427A5D8
Revision: --H08---
Coding: 000002
VCID: 814596078844021A8BF77
Revision: --------
Coding:
VCID: 322789CBFD62E982C20D0
VCID: 6C9B57B31FC66772C8C1E
Subsystem 1 - Shop #: WSC 02313 785
Revision: AA000000
VCID: 352DB2D70C0CE6BAE7EF3
Coding:
VCID: 250D6297BCAC8E3A578F3
Address 0e: Media Player 1 (R161)
Revision: AA001001
VCID: 2207798BAD82610232AD0
Revision: 11001001
Coding: 280902
VCID: 3B39A4EF2A2828CA11AB5
Coding: 3601020201
VCID: 29156EA7D0B4AA5A7367F
16896 - Function Restricted due to Exessive Voltage
U1401 00 [008] -
Fault Status: 01000010
Fault Frequency: 8
Reset Counter: 1
Mileage: 66215 km
Time: 00:00:00
140288 - Function Restriction due to Received Malfunction Value
U1113 00 [008] -
Fault Frequency: 8
Reset Counter: 1
Mileage: 66215 km
Time: 00:00:00
Revision: --------
VCID: 3731B8DF16000CAAF5D39
Revision: --------
Coding: 0000BC
VCID: 3731B8DF160014AAF5D39
Revision: 32480030
VCID: 302383C3F36EDB92B419A
Revision: --------
Coding: 00C1034A00
VCID: 342B8FD30776E7B2D0F16
Coding:
VCID: 312586C7F864D29ABB177
Coding: 008002
VCID: 2C1B97B3DF46BF728841E
Revision: AA000000
Address 3b: Sensor Elect. (J849)
Revision: --------
Coding:
VCID: EC9BD7B39FC6FF7248C1E
Address 3c: Lane Change
VCID: 2E1F9DBBE95A5562A6354
Revision: --------
VCID: 43C9DC0F52D8480A595BD
Coding: 020200
Subsystem 4 - Part Number: 4H0-947-135-BR5;Ô
Coding: 070000
Coding: 020200
Coding: 020200
Coding: 020200
Component: 0130H07
Revision: CJ007000
Coding: 030000
VCID: 1C7B47738FE657F2F8E1E
Revision: AA000000
VCID: F1A5C6C7B8E40A9A7B977
Revision: --------
VCID: 3A37A1EB251209C20ABD8
Revision: --------
Coding:
Revision: AB001007
VCID: 20037383A38E731224B9A
Address 5b: Seat,Rear,PS (J877)
Revision: AA000000
Address 5f: Information Electr. (J794) Labels:4E0-035-6xx-5F.clb
Revision: --------
VCID: 29156EA7D0B4B25A7367F
Subsystem 1 - Part Number: 8R0-060-884-AD5;Ô
Component: CD-Database 3371
Revision: --------
VCID: 3935BEE7201402DA03C7F
02111 - Motor for Window Regulator
Fault Status: 00100101
Reset Counter: 154
Mileage: 13138 km
Date: 2014.01.19
Time: 13:08:53
Address 6c: Back-up Cam. Labels:4H0-907-441.clb
Coding: 1080003
VCID: 260F659BC1AA1D225E85C
Address 6d: Trunk Elect. (----)
Revision: 10011001
Coding: 0210044100
VCID: 3D3DAAF7343C26FA2F9FB
Address 6f: Centr. Conv. II (J773)
Revision: --------
Coding:
VCID: E389BC8F7218B00AF91BD
Address 72: Door, Rear Right (J389)
Component: TSG HR H04 0167
Revision: --------
Revision: 0L0D5012
Coding:
VCID: 2B1994AFDA48B84A814B5
Revision: --------
Coding:
VCID: E58DA2977C2CCE3A170F3
Coding:
VCID: 2F2180BFEE50C46AAD231
Coding:
Address 8a: Multicont. Seat Rear,DS (J875)
Coding:
VCID: 2E1F9DBBE95ACD62A6354
Address 8b: Adaptive Cruise 2 (J428)
Coding: 3601020201
VCID: 2711689FC6A09C2A65739
016896 - ROD - Unknown faultcode
Fault Frequency: 8
Reset Counter: 1
Mileage: 66215 km
Time: 00:00:00
Address 8d: Multicont. Seat Rear,PS (J874)
Coding:
Address 8e: Image Processing (J851) Labels:4G0-907-107.clb
Coding:
VCID: 260F659BC1AA85225E85C
Address 8f: Pretension. Front Left (J854) Labels:4H0-980-94x-RGS.clb
Coding:
Coding:
