Modules missing, failure in comm, ASAM update issues
jakematic
NC USA
C?ID=129085
My alarm went off last night for no apparent reason, so I scanned to see if I could figure out what tripped it.
No dice, but several other things I did notice:
  • Hung on 09 the first try
  • 09 is consistently missing - see below about several lost scans
  • 62 failed to respond the second time
  • 72 failed to respond the 4th or 5th time
Several times the ASAM data attempted to update and failed.
When it does this, you either get kicked out of VCDS-Mobile and have to log back in, or it goes back to the main menu.
Ultimately this ends up with a 'lost' scan and you have to start from square one.
Is it possible to have HEX-NET auto-save Autoscans ?
The modules that failed comms are accessible individually as per screenshots below.
Looking at a previous version scan, it also missed 09.
Unfortunately I forgot the Winders tablet so I couldn't get a USB attached scan.
What do you guys think, and what else do you need from me? THanks-Jake
Versions / Info
2012 A8L
CodeBlock V0.41
FW version: 0.176
Dataset: 00000026
Infra mode tethered to iPhone 5s on T-Mobile
Version 0.41.0.4
#hndoc:?docid=00000312&xt=hnh:B78F1B8A8EA3DBC96B0A408C3338E796B2FD70156AB09432F7529F072DA08FAA
VCDS Mobile 0.41.0.4
Gateway Installation list:
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
8F-Pretension. Front Left -- Status: OK 0000
90-Pretension. Front Right -- Status: OK 0000
Address 01: Engine  (CDRA
 -----)	Labels:4H-01.lbl
	Part Number SW: 4H0-907-560-C	HW: 4H0-907-560
	Component: 4.2l V8/4V    H07 0004
	Revision: N5H07---
	Coding: 0106000A290F0268
	Shop #: WSC 02313 785 00200
	ASAM Dataset: EV_ECM42FSI0114H0907560C 001005
	ROD: EV_ECM42FSI0114H0907560C.rod
	VCID: 2A1791ABD54FA1429D8E-807F
No fault codes found.
Address 02: Auto Trans  (J217)	Labels:None
	Part Number SW: 4H1-927-158-BR	HW: 0BK-927-156-K
	Component: 0BK 42 FSIUSA H08 1001
	Revision: --H08---
	Coding: 000002
	ASAM Dataset: EV_TCMALX51011 002018
	ROD: EV_TCMALX51011_AU64.rod
	VCID: 8145960788B9021A6C24-80D4
Address 03: ABS Brakes  (J104)	Labels:4H0-907-379.clb
	Part Number SW: 4H0-907-379-C	HW: 4H0-907-379-C
	Component: ESP PREMIUM   H10 0273
	Revision: --------
	Shop #: WSC 02311 785 00200
	ASAM Dataset: EV_ESPPremi 005006
	ROD: EV_ESPPremi_AU64.rod
	VCID: 322789CBFD9FE98225DE-8067
Address 05: Acc/Start Auth.  (J393)	Labels:8K0-907-064-05.clb
	Part Number SW: 4H0-907-064-BD	HW: 4H0-907-064-BD
	Component: BCM2 2.0      H31 0330
	Coding: 0D872000000000000000
	VCID: 6C9B57B31F3B67722F12-8039
	Subsystem 1 -
	Subsystem 2 - 	Part Number: 4H0-905-852-C
	Component: J764 ELV MLB H39 0046
Address 06: Seat Mem. Pass  (J521)	Labels:None
	Part Number SW: 4H0-959-760-E	HW: 4H0-959-760-E
	Component: MEM-BFS       H08 0153
	Revision: AA000000
	Coding: C018B60085043201010001010101112131313333283333
	VCID: 352DB2D70CF1E6BA003C-8060
Address 08: Auto HVAC  (J255)	Labels:None
	Part Number SW: 4H0-820-043-H	HW: 4H0-820-043-H
	Component: Klima 4 Zonen H20 0072
	ASAM Dataset: EV_AirCondiFront 001050
	ROD: EV_AirCondiFront_AU64.rod
	VCID: 250D6297BC518E3AB05C-8070
Address 0E: Media Player 1  (R161)	Labels:None
	Part Number SW: 4H0-035-108-E	HW: 4H0-035-108
	Component: DVDCAlpine    H42 0190
	Revision: AA001001
	VCID: 2207798BAD7F6102D57E-8077
Address 10: Park/Steer Assist  (J446)	Labels:4H0-919-475-7X2.clb
	Part Number SW: 4H0-919-475-L	HW: 4H0-919-475-C
	Component: PARKHILFE ACC H07 0043
	Revision: 11001001
	Coding: 280902
	ASAM Dataset: EV_EPHVA18AU57X0000 002005
	ROD: EV_EPHVA18AU57X0000.rod
	VCID: 3B39A4EF2AD528CAF678-806E
Address 13: Auto Dist. Reg  (J428)	Labels:None
	Part Number SW: 4H0-907-561-A	HW: 4H0-907-561
	Component: ACC3          H15 0160
	Coding: 3601020201
	ASAM Dataset: EV_AdaptCruisContrAU64X 001012
	ROD: EV_AdaptCruisContrAU64X.rod
	VCID: 29156EA7D049AA5A94B4-807C
Address 15: Airbags  (J234)	Labels:None
	Part Number SW: 4H0-959-655-D	HW: 4H0-959-655-D
	Component: Airbag10.43   H41 0041
	Revision: --------
	Coding: 303143303230303030314A55304C34483053
	ROD: EV_AirbaAU10BPAAU64X_AU57.rod
	VCID: 3731B8DF16FD0CAA1200-8062
	Subsystem 1 - 	Part Number: 4H0-959-339
	Component: BF-Gewichtss.H02 0040
	Serial Number: 5850000R1190801Y2Nªª
	Subsystem 2 - 	Serial Number: 3575HRB405D0NI366PV.
	Subsystem 3 - 	Serial Number: 3585HRB40550Q3SK39JQ
	Subsystem 4 - 	Serial Number: 3515JRB404R0Q8K4FOSG
	Subsystem 5 - 	Serial Number: 3525JRB404R0Q8K46G6L
	Subsystem 6 - 	Serial Number: 3554VRB40610M5SO0H1M
	Subsystem 7 - 	Serial Number: 3564VRB40610M5SO493L
Address 16: Steering wheel  (J527)	Labels:None
	Part Number SW: 4H0-953-568-G	HW: 4H0-953-568-G
	Revision: --------
	Coding: 0000BC
	VCID: 3731B8DF16FD14AA1200-8062
	Subsystem 1 - 	Part Number: 4H0-951-528-L
	Component: E221 - MFL   H04 0009
Address 17: Instruments  (J285)	Labels:4H0-920-xxx-17.clb
	Part Number SW: 4H0-920-980-H	HW: 4H0-920-980-H
	Component: TBenUSAACC--- H38 0373
	Revision: 32480030
	Coding: 0B4F08015700D705020000
	ASAM Dataset: EV_RBD4K 004040
	ROD: EV_RBD4K.rod
	VCID: 302383C3F393DB9253CA-8065
Address 19: CAN Gateway  (J533)	Labels:None
	Part Number SW: 4H0-907-468-F	HW: 4H0-907-468-C
	Component: J533--Gateway H08 0213
	Revision: --------
	Coding: 00C1034A00
	ROD: EV_GatewUDS_AU57.rod
	VCID: 342B8FD3078BE7B23722-8061
	Subsystem 1 - 	Part Number: 4H0-915-181
	Component: J367-BDM     H07 0140
	Serial Number: 00000000005650628220
Address 28: HVAC, Rear  (E265)	Labels:None
	Part Number SW: 4H0-919-158-D	HW: 4H0-919-158-D
	Component: Klima Fond    H15 0062
	ASAM Dataset: EV_AirCondiHeck 001039
	ROD: EV_AirCondiHeck_AU64.rod
	VCID: 312586C7F899D29A5CC4-8064
Address 34: Level Control  (J197)	Labels:None
	Part Number SW: 4H0-907-553-C	HW: 4H0-907-553
	Component: LUFE-DAEMPFER H17 0096
	Coding: 008002
	ASAM Dataset: EV_AirSuspe 003022
	VCID: 2C1B97B3DFBBBF726F92-8079
Address 36: Seat Mem. Drvr  (J136)	Labels:None
	Component: MEM-FS        H08 0153
	Revision: AA000000
	Coding: C018BF8085853201030001010101112131313333203333
Address 3B: Sensor Elect.  (J849)	Labels:None
	Part Number SW: 4H0-907-637	HW: 4H0-907-637
	Component: SARA 6D       H02 0015
	Revision: --------
	ASAM Dataset: EV_SARA 006014
	VCID: EC9BD7B39F3BFF72AF12-80B9
3801346 - ROD - Unknown faultcode
Address 3C: Lane Change	Labels:None
	Part Number SW: 4H0-907-566-A	HW: 4G0907568
	Component: J769  SWA MasterH01  0030
	Revision: 00H01000	Serial Number: 6PZ 010 287-07
	Coding: 0000002
	VCID: 2E1F9DBBE9A7556241E6-807B
	Subsystem 1 - 	Part Number: 4H0-907-568-A
	Component: J770  SWA Slave H02  0030
	Serial Number: 6PZ 010 287-27
Address 42: Door Elect, Driver  (J386)	Labels:None
	Part Number SW: 4H0-959-793-M	HW: 4H0-959-793-E
	Component: TSG FA        H02 0166
	Revision: --------
	Coding: 011F1F205E0062C202000017
	Shop #: WSC 02312 785 00200
	VCID: 43C9DC0F5225480ABE88-8016
Address 46: Central Conv.  (J393)	Labels:4H0-907-064-46.clb
	Coding: 0106023A00FA759FB0B0C780020100000000000000000000000000000000
	Subsystem 1 - 	Part Number: 4H0-959-719
	Component: GTO BF       H01 0070
	Subsystem 2 - 	Part Number: 1K0-951-605-C
	Component: LIN BACKUP HOH05 1501
	Subsystem 3 - 	Part Number: 4H4-959-591
	Component: J245  007C   H06 0005
	Coding: 020200
	Subsystem 4 - 	Part Number: 4H0-947-135-BR‘>8
	Component: DachelektroniH11 0080
	Coding: 070000
	Subsystem 5 - 	Part Number: 4H4-959-591
	Component: J394  0014   H06 0005
	Coding: 020200
	Subsystem 6 - 	Part Number: 4H4-959-591
	Component: J392  006A   H06 0005
	Coding: 020200
	Subsystem 7 - 	Part Number: 4H4-959-591
	Component: J867  00E0   H06 0005
	Coding: 020200
Address 47: Sound System	Labels:None
	Part Number SW: 4G0-035-223-B	HW: 4G0-035-223-A
	Component: 0130H07
	Revision: CJ007000
	Coding: 030000
	VCID: 1C7B47738F1B57F21F32-8049
Address 48: Seat, Rear, DS  (J876)	Labels:None
	Part Number SW: 4H0-959-860	HW: 4H0-959-860
	Component: MEM-FS-Fond   H06 0153
	Revision: AA000000
	Coding: 001892800000300D0A00392038193A2039203B3B202020
	VCID: F1A5C6C7B8190A9A9C44-80A4
Address 52: Door Elect, Pass.  (J387)	Labels:None
	Part Number SW: 4H0-959-792-E	HW: 4H0-959-792-E
	Component: TSG BF        H02 0166
	Revision: --------
	Coding: 011F1F205E0062C202000007
	VCID: 3A37A1EB25EF09C2ED6E-806F
Address 53: Parking Brake  (----)	Labels:4H0-907-801.clb
	Part Number SW: 4H0-907-801-E	HW: 4H0-907-801-A
	Component: EPB-4         H03 0012
	Revision: --------
	Shop #: WSC 00000 000
Address 56: Radio  (R)	Labels:None
	Part Number SW: 4H0-035-082-B	HW: 4H0-035-082
	Component: Radio U SIRIU H52 0076
	Revision: AB001007
	Coding: 020007010000000001
	VCID: 20037383A3737312C36A-8075
Address 5B: Seat,Rear,PS  (J877)	Labels:None
	Component: MEM-BFS-Fond  H06 0153
	Revision: AA000000
	Coding: 001896800000300D0A00392038193A2039203B3B382020
Address 5F: Information Electr.  (J794)	Labels:4E0-035-6xx-5F.clb
	Part Number SW: 4H0-035-746-D	HW: 4H0-035-746
	Component: H-BNT-NA      H48 0423
	Revision: --------
	Coding: 020200000001F9EF7D128B0E00000003140001000000000000
	VCID: 29156EA7D049B25A94B4-807C
	Subsystem 1 - 	Part Number: 8R0-060-884-AD‘>8
	Component: NAR 2011     0505
	Subsystem 2 - 	Part Number: 4H0-919-604-D
	Component: DU8 D4 SV NB H47 0021
	Subsystem 3 - 	Part Number: 4H1-919-600-F
	Component: E380 BDT D4  H09 0064
	Subsystem 4 - 	Part Number: 8R0-060-961-B
	Component: CD-Database
Address 62: Door, Rear Left  (J388)	Labels:None
	Part Number SW: 4H0-959-795-A	HW: 4H0-959-795-A
	Component: TSG HL        H04 0167
	Revision: --------
	Coding: 010F1F20420062C202000007
	VCID: 3935BEE720E902DAE414-806C
Address 6C: Back-up Cam.	Labels:4H0-907-441.clb
	Part Number SW: 4H0-907-441-A	HW: 4H0907441
	Component: SG Rueckfahrkamera   0061
	Revision: --H04---	Serial Number: 525 PA8J17D1M2
	Coding: 1080003
	Shop #: WSC 02391 785 00200
	VCID: 260F659BC1571D22B956-8073
Address 6D: Trunk Elect.  (----)	Labels:None
	Part Number SW: 4H0-959-107-R	HW: 4H0-959-107-M
	Component: HDSG-Modul    H11 0039
	Revision: 10011001
	Coding: 0210044100
	ASAM Dataset: EV_DeckLidContrUnit 001025
	VCID: 3D3DAAF734C126FAC84C-8068
Address 6F: Centr. Conv. II  (J773)	Labels:None
	Part Number SW: 4H0-907-412	HW: 4H0-907-412
	Component: ALM           H05 0004
	Revision: --------
	ASAM Dataset: EV_Ambie 001008
	ROD: EV_Ambie.rod
	VCID: E389BC8F72E5B00A1EC8-80B6
Address 72: Failed to respond
Address 81: Gear Shift  (J587)	Labels:None
	Part Number SW: 4H1-927-731-A	HW: 4H1-927-731-A
	Component: GSM-LL        H07 0083
	Revision: 0L0D5012
	ROD: EV_GSM2x3Mono.rod
	VCID: 2B1994AFDAB5B84A6698-807E
Address 85: On Board Cam.  (J852)	Labels:None
	Part Number SW: 4G0-907-217	HW: 4H0-907-217-A
	Component: DPC-SG        H24 0036
	Revision: --------
	ROD: EV_OnBoardCamerDPC.rod
	VCID: E58DA2977CD1CE3AF0DC-80B0
Address 88: Multicont. Seat Driver  (J873)	Labels:None
	Part Number SW: 4H0-907-182-H	HW: 4H0-907-182-H
	Component: IVB           H07 0042
	ROD: EV_IVBDriveSideFrnt.rod
	VCID: 2F2180BFEEADC46A4AF0-807A
Address 89: Multicont. Seat Pass.  (J872)	Labels:None
Address 8A: Multicont. Seat Rear,DS  (J875)	Labels:None
	Part Number SW: 4H0-907-182-G	HW: 4H0-907-182-G
	Component: IVB           H08 0042
	ASAM Dataset: EV_IVBDriveSideRear 001003
	VCID: 2E1F9DBBE9A7CD6241E6-807B
Address 8B: Adaptive Cruise 2  (J428)	Labels:None
	Part Number SW: 4H0-907-541-A	HW: 4H0-907-541
	Coding: 3601020201
	ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
	ROD: EV_AdaptCruisContr2AU57X.rod
	VCID: 2711689FC65D9C2A82A0-8072
Address 8D: Multicont. Seat Rear,PS  (J874)	Labels:None
	ASAM Dataset: EV_IVBPasseSideRear 001003
Address 8E: Image Processing  (J851)	Labels:4G0-907-107.clb
	Part Number SW: 4G0-907-107-C	HW: 4H0-907-107
	Component: BV-SG         H29 0036
	ASAM Dataset: EV_BC7 001001
	VCID: 260F659BC1578522B956-8073
Address 8F: Pretension. Front Left  (J854)	Labels:4H0-980-94x-RGS.clb
	Part Number SW: 4H0-980-945-B	HW: 4H0-980-945-B
	ASAM Dataset: EV_RGS_L 002004
Address 90: Pretension. Front Right  (J855)	Labels:4H0-980-94x-RGS.clb
	Part Number SW: 4H0-980-946-B	HW: 4H0-980-946-B
	ASAM Dataset: EV_RGS_R 002004
	ROD: EV_RGS_R.rod
Version 0.4009.0.4
#hndoc:?docid=00000143&xt=hnh:E9C81AC9DC7CB65E2DD768F480A86F66024B43276FD134208489DBCCAB086361
VCDS Mobile 0.4009.0.4
VIN: WAURVAFD6CN014370
	Revision: N5H07---
	VCID: 2A1791ABD5B2A1427A5D8
	Revision: --H08---
	Coding: 000002
	VCID: 814596078844021A8BF77
	Revision: --------
	Coding:
	VCID: 322789CBFD62E982C20D0
	VCID: 6C9B57B31FC66772C8C1E
	Subsystem 1 - 	Shop #: WSC 02313 785
	Revision: AA000000
	VCID: 352DB2D70C0CE6BAE7EF3
	Coding:
	VCID: 250D6297BCAC8E3A578F3
Address 0e: Media Player 1  (R161)
	Revision: AA001001
	VCID: 2207798BAD82610232AD0
	Revision: 11001001
	Coding: 280902
	VCID: 3B39A4EF2A2828CA11AB5
	Coding: 3601020201
	VCID: 29156EA7D0B4AA5A7367F
16896 - Function Restricted due to Exessive Voltage
	U1401 00 [008] -
		Fault Status: 01000010
		Fault Frequency: 8
		Reset Counter: 1
		Mileage: 66215 km
140288 - Function Restriction due to Received Malfunction Value
	U1113 00 [008] -
		Fault Frequency: 8
		Reset Counter: 1
		Mileage: 66215 km
	Revision: --------
	VCID: 3731B8DF16000CAAF5D39
	Revision: --------
	Coding: 0000BC
	VCID: 3731B8DF160014AAF5D39
	Revision: 32480030
	VCID: 302383C3F36EDB92B419A
	Revision: --------
	Coding: 00C1034A00
	VCID: 342B8FD30776E7B2D0F16
	Coding:
	VCID: 312586C7F864D29ABB177
	Coding: 008002
	VCID: 2C1B97B3DF46BF728841E
	Revision: AA000000
Address 3b: Sensor Elect.  (J849)
	Revision: --------
	Coding:
	VCID: EC9BD7B39FC6FF7248C1E
Address 3c: Lane Change
	Coding: 0000002
	VCID: 2E1F9DBBE95A5562A6354
	Revision: --------
	VCID: 43C9DC0F52D8480A595BD
	Coding: 020200
	Subsystem 4 - 	Part Number: 4H0-947-135-BR5;Ô
	Coding: 070000
	Coding: 020200
	Coding: 020200
	Coding: 020200
	Component: 0130H07
	Revision: CJ007000
	Coding: 030000
	VCID: 1C7B47738FE657F2F8E1E
	Revision: AA000000
	VCID: F1A5C6C7B8E40A9A7B977
	Revision: --------
	VCID: 3A37A1EB251209C20ABD8
	Revision: --------
	Coding:
	Revision: AB001007
	VCID: 20037383A38E731224B9A
Address 5b: Seat,Rear,PS  (J877)
	Revision: AA000000
Address 5f: Information Electr.  (J794)	Labels:4E0-035-6xx-5F.clb
	Revision: --------
	VCID: 29156EA7D0B4B25A7367F
	Subsystem 1 - 	Part Number: 8R0-060-884-AD5;Ô
	Component: CD-Database  3371
	Revision: --------
	VCID: 3935BEE7201402DA03C7F
02111 - Motor for Window Regulator
		Fault Status: 00100101
		Reset Counter: 154
		Mileage: 13138 km
		Date: 2014.01.19
		Time: 13:08:53
Address 6c: Back-up Cam.	Labels:4H0-907-441.clb
	Coding: 1080003
	VCID: 260F659BC1AA1D225E85C
Address 6d: Trunk Elect.  (----)
	Revision: 10011001
	Coding: 0210044100
	VCID: 3D3DAAF7343C26FA2F9FB
Address 6f: Centr. Conv. II  (J773)
	Revision: --------
	Coding:
	VCID: E389BC8F7218B00AF91BD
Address 72: Door, Rear Right  (J389)
	Component: TSG HR        H04 0167
	Revision: --------
	Revision: 0L0D5012
	Coding:
	VCID: 2B1994AFDA48B84A814B5
	Revision: --------
	Coding:
	VCID: E58DA2977C2CCE3A170F3
	Coding:
	VCID: 2F2180BFEE50C46AAD231
	Coding:
Address 8a: Multicont. Seat Rear,DS  (J875)
	Coding:
	VCID: 2E1F9DBBE95ACD62A6354
Address 8b: Adaptive Cruise 2  (J428)
	Coding: 3601020201
	VCID: 2711689FC6A09C2A65739
016896 - ROD - Unknown faultcode
		Fault Frequency: 8
		Reset Counter: 1
		Mileage: 66215 km
Address 8d: Multicont. Seat Rear,PS  (J874)
	Coding:
Address 8e: Image Processing  (J851)	Labels:4G0-907-107.clb
	Coding:
	VCID: 260F659BC1AA85225E85C
Address 8f: Pretension. Front Left  (J854)	Labels:4H0-980-94x-RGS.clb
	Coding:
	Coding:
Jake, at your convenience, can you please make a Measuring Block Map of your 46 module please? (You'll need the Windows PC for that). Somewhere in there we're going to find reason your alarm went off, but we don't have it documented yet.
[Applications]
[Controller Channels Map]
Address: 46
Function: Meas. Blocks
Output: Pre-Label File
[Start]
Please e-mail us the resulting file.
Thanks!
jakematic
NC USA
C?ID=129085
Will do.
Good reason to finally try the Dell Venue 8.1 cabled to HEX-NET.
Edit:
PLB emailed to Support
Scan with USB cable worked like a champ, see below.
Switched to AP mode and scanned again using tablet.
Scan hung on module 09, 46. and 62.
After several minutes, hit [Done, Go Back] on 09 and 46 and the scan continued.
On 62 when I did that it locked up VCDS and put Not Responding in the titlebar.
Waited.... waited.... waited... hit X to close dimmed window and VCDS crashed.
Cabled HEX-NET scan
Wednesday,30,April,2014,18:31:28:28071
VCDS Version: 14.4.2.0
Data version: 20140411
VIN: WAURVAFD6CN014370   License Plate:
Mileage: 13611km-8457mi   Repair Order:
Chassis Type: FD (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 28 34 36 3B 3C 42
          46 47 48 52 53 56 5B 5F 62 6C 6D 6F 72 81 85 88 89 8A 8B 8D
          8E 8F 90
VIN: WAURVAFD6CN014370   Mileage: 13611km-8457miles
Address 01: Engine (------CDRA)       Labels: None
   Part No SW: 4H0 907 560 C    HW: 4H0 907 560
   Revision: N5H07---
   VCID: 2A18C35B4D928E6B29-807F
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 4H1 927 158 BR    HW: 0BK 927 156 K
   Revision: --H08---
   Coding: 000002
   VCID: 014A44F79064AD3358-8054
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 C    HW: 4H0 907 379 C
   Coding: 44E6F20022674F00E200
   VCID: 3228DB3B6542C6AB91-8067
   Part No SW: 4H0 907 064 BD    HW: 4H0 907 064 BD
   VCID: 6C9405438FE6505B9B-8039
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Revision: AA000000    Serial number: 00000014753132
   VCID: 3522E0279C2CD193B4-8060
   Part No SW: 4H0 820 043 H    HW: 4H0 820 043 H
   Coding: 480122BECC
   VCID: 25023067248CA11304-8070
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
   Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0100
   Revision: 11012002    Serial number: 00000001073731
   Coding: 09072091073C9FE18B000804A0003800009CD308820001218001085C3B00
   VCID: 6E900F4BB9FAA24BB5-803B
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 110724  H35 0040
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
   Component: E1 - LDS  H07 0044
   Component: USHL4.2  H30 0030
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Coding: 100000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Coding: 100000
   Subsystem 7 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0280
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 E    HW: 4H0 035 108
   Revision: AA001001
   VCID: 22082B7B3DA2562B61-8077
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Revision: 11001001    Serial number: 55901126901403
   Coding: 280902
   VCID: 3B36F61FB20807E342-806E
Address 13: Auto Dist. Reg (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4H0 907 561 A    HW: 4H0 907 561
   Coding: 3601020201
   VCID: 291A3C574894857320-807C
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
   Revision: --------    Serial number: 003JS0016EK5
   VCID: 373EEA2F8E202383A6-8062
   Subsystem 1 - Part No SW: 4H0 959 339     HW: 4H0 959 339
   Serial number: 5850000R1190801Y2N
   Serial number: 3575HRB405D0NI366PV.
   Serial number: 3585HRB40550Q3SK39JQ
   Serial number: 3515JRB404R0Q8K4FOSG
   Serial number: 3525JRB404R0Q8K46G6L
   Serial number: 3554VRB40610M5SO0H1M
   Crash sensor for front airbag; passenger side:
   Serial number: 3564VRB40610M5SO493L
Address 16: Steering wheel (J527)       Labels: None
   Revision: --------    Serial number: 90815KIN0002H
   Coding: 0000BC
   VCID: 373EEA2F86202383A6-8062
   Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4H0 920 980 H    HW: 4H0 920 980 H
   Revision: 32480030    Serial number: 658270911593012
   ROD: EV_RBD4K.rod
   VCID: 302CD1336B4EF4BBE7-8065
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
   Component: Analoguhr D4  H05 0224
   Serial number: 1110824000963
   Part No SW: 4H0 907 468 F    HW: 4H0 907 468 C
   Revision: --------    Serial number: 00000000254143
   Coding: 00C1034A00
   VCID: 3424DD239F56C89B83-8061
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Serial number: 00000000005650628220
Address 28: HVAC, Rear (E265)       Labels: None
   Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
   Coding: 0000000000
   VCID: 312AD4376044FDB3E8-8064
Address 34: Level Control (J197)       Labels: Redir Fail!
   Part No SW: 4H0 907 553 C    HW: 4H0 907 553
   Coding: 008002
   ROD: EV_AirSuspe_AU64.rod
   VCID: 2C14C5434766905BDB-8079
   Revision: AA000000    Serial number: 00000014727766
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637     HW: 4H0 907 637
   Revision: --------    Serial number: EJ1BPA3100XW8S0
   ROD: EV_SARA.rod
   VCID: 6C94054387E6505B9B-8039
3801346 - Function Restricted due to Missing Message(s)
          U1111 00 [032] - -
   Part No SW: 4H0 907 566 A    HW: 4G0 907 566
   Revision: 00H01000    Serial number: 6PZ 010 287-07
   Coding: 0000002
   VCID: 2E10CF4BB97AE24BF5-807B
   Subsystem 1 - Part No: 4H0 907 568 A
   Subsystem 2 - Serial number: 6PZ 010 287-27
   Subsystem 3 - Serial number: 5F22.09.1100H020003CX22488ˇ
   Subsystem 4 - Serial number: X22488ˇ
   Part No SW: 4H0 959 793 M    HW: 4H0 959 793 E
   Revision: --------    Serial number: 0000120547259
   VCID: 43C68EFFC2F87F230A-8016
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0159921986
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
   Component: Dachelektroni  H11 0080
   Coding: 070000
   Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Coding: 020200
   Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Coding: 020200
   Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Coding: 020200
   Part No SW: 4G0 035 223 B    HW: 4G0 035 223 A
   Component: BOSE G3 C7    H07 0130
   Revision: CJ007000    Serial number: 00000000025817
   Coding: 030000
   VCID: 1C7415831FC660DBAB-8049
Address 48: Seat, Rear, DS (J876)       Labels: None
   Part No SW: 4H0 959 860     HW: 4H0 959 860
   Revision: AA000000    Serial number: 00000014816977
   VCID: 71AA1437A8C4BDB3A8-8024
   Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
   Revision: --------    Serial number: 0000120382709
   VCID: 3A38F31BB5323EEB59-806F
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Revision: --------    Serial number: 00000000147982
   ROD: EV_ParkiBrake_AU48.rod
Address 56: Radio (R)       Labels: None
   Part No SW: 4H0 035 082 B    HW: 4H0 035 082
   Revision: AB001007    Serial number: 155HY0B7511356
   VCID: 200C217333AE443B77-8075
Address 5B: Seat,Rear,PS (J877)       Labels: None
   Revision: AA000000    Serial number: 00000014816966
   Part No SW: 4H0 035 746 D    HW: 4H0 035 746
   Revision: --------    Serial number: 035JZ0B7504356
   VCID: 291A3C574094857320-807C
   Subsystem 2 - Part No SW: 4H0 919 604 D    HW: 4H0 919 604 D
   Subsystem 3 - Part No SW: 4H1 919 600 F    HW: 4H1 919 600
   Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
   Revision: --------    Serial number: 0000120482526
   VCID: 393AEC17B03435F350-806C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4H0 907 441 A    HW: 4H0 907 441
   Revision: --H04---    Serial number: 525 PA8J17D1M2
   Coding: 1080003
   VCID: 2600376B918AAA0B0D-8073
Address 6D: Trunk Elect. (----)       Labels: None
   Part No SW: 4H0 959 107 R    HW: 4H0 959 107 M
   Revision: 10011001    Serial number: 256100203
   Coding: 0210044100
   ROD: EV_DeckLidContrUnit.rod
   VCID: 3D32F807AC1C09D37C-8068
Address 6F: Centr. Conv. II (J773)       Labels: None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Revision: --------    Serial number: 000000046400
   ROD: EV_Ambie.rod
   VCID: 63866E7F6A381F232A-8036
   Revision: --------    Serial number: 0000120482529
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Revision: 0L0D5012    Serial number: SN110727  0507
   VCID: 2B16C65F42689763D2-807E
Address 85: On Board Cam. (J852)       Labels: None
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Coding: E9060000
   VCID: 65827067640C6113C4-8030
Address 88: Multicont. Seat Driver (J873)       Labels: None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Serial number: 00001638159702
   Coding: 764FF2
   VCID: 2F2ED24F7670EB43FE-807A
Address 89: Multicont. Seat Pass. (J872)       Labels: None
   Serial number: 00001638160002
   Coding: 364FF2
Address 8A: Multicont. Seat Rear,DS (J875)       Labels: None
   Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
   Serial number: 00001637035802
   Coding: 200F00
   VCID: 2E10CF4B717AE24BF5-807B
Address 8B: Adaptive Cruise 2 (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4H0 907 541 A    HW: 4H0 907 541
   Coding: 3601020201
   VCID: 271E3A6F5E80B30336-8072
Address 8D: Multicont. Seat Rear,PS (J874)       Labels: None
   Serial number: 00001637038001
   Coding: 200F00
Address 8E: Image Processing (J851)       Labels: 4G0-907-107.clb
   Part No SW: 4G0 907 107 C    HW: 4H0 907 107
   Serial number: 000040220709117
   Coding: 02A19A000111
   ROD: EV_BC7.rod
   VCID: 2600376B598AAA0B0D-8073
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 0066F609031F037E070308014240C2010000
   ROD: EV_RGS_L.rod
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   ROD: EV_RGS_R.rod
jakematic
NC USA
C?ID=129085
ps - Noticed some missing label files. Let me know if you want more maps done.
United States
Hi Jake,
It looks like MVB group 021 is the most recent alarm source (followed by 022, 023 and 024). Per your map:
21,0,,
21,1,,,
;12,,
21,2,,,
;2014:04:26,,
21,3,,,
;23:04 h,,
21,4,,,
:) Pretty cool. Looks like the alarm went off @ 23:04 h on 4/26/2014 for alarm code #12. If the date and time aren't adding up we can check the 17-Instrument cluster or simply set the alarm off by opening a door and see if the stamps are accurate. #12 should be "Intelligent siren" so I would need to dig through the SSP or repair manual to see what's what but you have a whooping list of subsystem slave modules in this car and I believe one of those would quality as Intelligent siren.
On that note MVB 018 is a Siren value and the last siren alarm code was 2 which is communication break.
If that alarm system needs to be diagnosed we can dig into this and move all of it to a repair thread but I suspect a LIN Bus/Intelligent siren of some sort failed to communicate momentarily and set the alarm off.
jakematic
NC USA
C?ID=129085
Hi Dana-
Firstly, you guys freaking rock!
I looked at the file and couldn't make heads nor tails of it, and in retrospect didn't think to search on the time.
Timestamp confirmed:
No kidding, this one has the most modules I've ever seen.
No need to dig into it further - am due for my two year time based service this month.
Time based... note the mileage in the scan :p
Any thoughts on the Auto-Scan autosave, or is that just me not having the ASAM data fully updated at that point ?
Will scan in infra mode tomorrow now that CB 0.4102 is on the HEX-NET and see if it improves the module comms.
Thanks again!
Don't forget to update your VCDS too. :cool:
jakematic
NC USA
C?ID=129085
You see, this is what happens when I go sneak away from the desk for a glass of wine.... Updating now :p
jakematic
NC USA
C?ID=129085
Apologies for the delay on this - allergies turned into a cold, turned into bronchitis, and work is trying their very best to kill me anyway....
This new version is much, much faster than previous ones :cool:
VCDS-Mobile: 62 and 72 are back in the scan, 09 is still missing.
Did leave the doors unlocked - not sure that matters after this test.
USB attach: This was interesting...
VCDS could not find the CAN gateway, so I disconnected USB and pulled the HEX-NET from the DLC, waited, restarted everything, same result.
Same procedure again, same result - could not access any modules.
Pulled HEX-NET, shut down vehicle, waited 60 seconds and it was working again.
Did not get a Network scan from VCDS Beta as time was running thin.
Let me know what you need next. THanks!
#hndoc:?docid=00000347&xt=hnh:3DBC21060B2E13A9A643BA455BB5CDCD113ADC21A379F3AA160B9948910FE235
VCDS Mobile 0.4102.0.4
	Revision: N5H07---
	VCID: 2A1791ABD5B2A1427AB7D7-807F
	Revision: --H08---
	Coding: 000002
	VCID: 814596078844021A8B1D88-80D4
	Revision: --------
	VCID: 322789CBFD62E982C2E72F-8067
	VCID: 6C9B57B31FC66772C82BA1-8039
	Subsystem 1 -
	Revision: AA000000
	VCID: 352DB2D70C0CE6BAE7054C-8060
	VCID: 250D6297BCAC8E3A57659C-8070
	Revision: AA001001
	VCID: 2207798BAD82610232477F-8077
	Revision: 11001001
	Coding: 280902
	VCID: 3B39A4EF2A2828CA11418A-806E
	Coding: 3601020201
	VCID: 29156EA7D0B4AA5A738DC0-807C
	Revision: --------
	VCID: 3731B8DF16000CAAF53966-8062
	Revision: --------
	Coding: 0000BC
	VCID: 3731B8DF160014AAF53966-8062
	Revision: 32480030
	ROD: EV_RBD4K.rod
	VCID: 302383C3F36EDB92B4F315-8065
	Revision: --------
	Coding: 00C1034A00
	VCID: 342B8FD30776E7B2D01B39-8061
	VCID: 312586C7F864D29ABBFD18-8064
	Coding: 008002
	VCID: 2C1B97B3DF46BF7288ABE1-8079
	Revision: AA000000
	Revision: --------
	ROD: EV_SARA.rod
	VCID: EC9BD7B39FC6FF72482B21-80B9
	U1111 00 [032] -
	Coding: 0000002
	VCID: 2E1F9DBBE95A5562A6DFFB-807B
	Revision: --------
	VCID: 43C9DC0F52D8480A59B1E2-8016
	Coding: 020200
	Subsystem 4 - 	Part Number: 4H0-947-135-BRí>8
	Coding: 070000
	Coding: 020200
	Coding: 020200
	Coding: 020200
	Component: 0130H07
	Revision: CJ007000
	Coding: 030000
	VCID: 1C7B47738FE657F2F80B31-8049
	Revision: AA000000
	VCID: F1A5C6C7B8E40A9A7B7D58-80A4
	Revision: --------
	VCID: 3A37A1EB251209C20A5787-806F
	Revision: --------
	Revision: AB001007
	VCID: 20037383A38E7312245365-8075
	Revision: AA000000
	Revision: --------
	VCID: 29156EA7D0B4B25A738DC0-807C
	Subsystem 1 - 	Part Number: 8R0-060-884-ADí>8
	Revision: --------
	VCID: 3935BEE7201402DA032D70-806C
	Coding: 1080003
	VCID: 260F659BC1AA1D225E6FA3-8073
	Revision: 10011001
	Coding: 0210044100
	VCID: 3D3DAAF7343C26FA2F75A4-8068
	Revision: --------
	ROD: EV_Ambie.rod
	VCID: E389BC8F7218B00AF9F1C2-80B6
Address 72: Door, Rear Right  (J389)	Labels:None
	Revision: --------
	Revision: 0L0D5012
	VCID: 2B1994AFDA48B84A81A1DA-807E
	Revision: --------
	VCID: E58DA2977C2CCE3A17E5DC-80B0
	VCID: 2F2180BFEE50C46AADC90E-807A
	VCID: 2E1F9DBBE95ACD62A6DFFB-807B
	Coding: 3601020201
	VCID: 2711689FC6A09C2A6599B6-8072
	ROD: EV_BC7.rod
	VCID: 260F659BC1AA85225E6FA3-8073
	ROD: EV_RGS_L.rod
	ROD: EV_RGS_R.rod
Scan with USB cable using VCDS classic.
Sunday,11,May,2014,11:56:46:62017
VCDS Version: 14.5.0.0
Data version: 20140501
Mileage: 13640km-8475mi   Repair Order:
          8E 8F 90
VIN: WAURVAFD6CN014370   Mileage: 13640km-8475miles
   Revision: N5H07---
   VCID: 2A18C3264D0D686BD9-807F
   Revision: --H08---
   Coding: 000002
   VCID: 014A448A90FB4B33A8-8054
   VCID: 3228DB4665DD20AB61-8067
   VCID: 6C94053E8F79B65B6B-8039
   VCID: 3522E05A9CB3379344-8060
   Coding: 480122BECC
   VCID: 2502301A24134713F4-8070
   VCID: 6E900F36B965444B45-803B
   Coding: 0045F7
   Coding: 025523
   Coding: 100000
   Coding: 100000
   Coding: 020300
   Revision: AA001001
   VCID: 22082B063D3DB02B91-8077
   Coding: 280902
   VCID: 3B36F662B297E1E3B2-806E
   Coding: 3601020201
   VCID: 291A3C2A480B6373D0-807C
   VCID: 373EEA528EBFC58356-8062
   Coding: 0000BC
   VCID: 373EEA5286BFC58356-8062
   ROD: EV_RBD4K.rod
   VCID: 302CD14E6BD112BB17-8065
   Analog_clock:
   Coding: 00C1034A00
   VCID: 3424DD5E9FC92E9B73-8061
   Coding: 0000000000
   VCID: 312AD44A60DB1BB318-8064
   Coding: 008002
   VCID: 2C14C53E47F9765B2B-8079
   ROD: EV_SARA.rod
   VCID: 6C94053E8779B65B6B-8039
          U1111 00 [032] - -
   Coding: 0000002
   VCID: 2E10CF36B9E5044B05-807B
   VCID: 43C68E82C2679923FA-8016
   Coding: 020200
   Coding: 070000
   Coding: 020200
   Coding: 020200
   Coding: 020200
   Coding: 030000
   VCID: 1C7415FE1F5986DB5B-8049
   VCID: 71AA144AA85B5BB358-8024
   VCID: 3A38F366B5ADD8EBA9-806F
   VCID: 200C210E3331A23B87-8075
   VCID: 291A3C2A400B6373D0-807C
   VCID: 393AEC6AB0ABD3F3A0-806C
   Coding: 1080003
   VCID: 2600371691154C0BFD-8073
   Coding: 0210044100
   VCID: 3D32F87AAC83EFD38C-8068
   ROD: EV_Ambie.rod
   VCID: 63866E026AA7F923DA-8036
   VCID: 2B16C62242F7716322-807E
   Coding: E9060000
   VCID: 6582701A6493871334-8030
   Coding: 764FF2
   VCID: 2F2ED23276EF0D430E-807A
   Coding: 364FF2
   Coding: 200F00
   VCID: 2E10CF3671E5044B05-807B
   Coding: 3601020201
   VCID: 271E3A125E1F5503C6-8072
   Coding: 200F00
   ROD: EV_BC7.rod
   VCID: 2600371659154C0BFD-8073
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
Edit: As an FYI
bureau:Desktop jake$ grep None mob.txt
bureau:Desktop jake$ grep None Log-WAURVAFD6CN014370-13640km-8475mi.txt
bureau:Desktop jake$ grep -i fail Log-WAURVAFD6CN014370-13640km-8475mi.txt
bureau:Desktop jake$ grep None mob.txt Log-WAURVAFD6CN014370-13640km-8475mi.txt  | awk -F: '{print $2}' | sort -u
Address 01
Address 02
Address 06
Address 08
Address 0E
Address 13
Address 15
Address 16
Address 19
Address 28
Address 34
Address 36
Address 3B
Address 3C
Address 42
Address 47
Address 48
Address 52
Address 56
Address 5B
Address 62
Address 6D
Address 6F
Address 72
Address 81
Address 85
Address 88
Address 89
Address 8A
Address 8B
Address 8D
jakematic
NC USA
C?ID=129085
Latest test:
APP Id (1) CodeBlock V0.4104 API V4
FW version: 0.184.
Dataset: 00000026
VCDS 14.5.1
The elapsed time is insanely long because I ran in Debug Level 2, smoked a lot of cigarettes, and wished I'd had a beer :D
Maps emailed to support to go in the queue.
Observations:
- every time I change modes (cable/net/mobile) the HEX-NET needs to be unplugged and the vehicle shut down or it will not get access to 19, at all
-- typically reports "Function Not Supported in Gateway"
-- choosing the chassis does not help
- in cabled mode module 62 did not reply - noticed it said K-Line Init in VCDS
- several unplug/shutdown iterations require to switch to net mode
-- tested fine in options every time
- net mode hangs on 09, had to force quit/restart everything multiple times
- never got anywhere in mobile mode after restarting multiple times
-- could never get access to 19
- gave up after idling for 2 hours
Let me know if you need anything additional. THanks!
Tuesday,20,May,2014,15:55:06:62017
VCDS Version: 14.5.1.0
Data version: 20140515
Mileage: 13686km-8504mi   Repair Order:
          8E 8F 90
VIN: WAURVAFD6CN014370   Mileage: 13686km-8504miles
   Revision: N5H07---
   VCID: 2A18C3264D0D686BD3-807F
   Revision: --H08---
   Coding: 000002
   VCID: 014A448A90FB4B33A2-8054
   VCID: 3228DB4665DD20AB6B-8067
Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.CLB
   VCID: 6C94053E8F79B65B61-8039
Address 06: Seat Mem. Pass (J521)       Labels: NONE
   VCID: 3522E05A9CB337934E-8060
   Coding: 480122BECC
   VCID: 2502301A24134713FE-8070
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.CLB
   VCID: 6E900F36B965444B4F-803B
   Coding: 0045F7
   Coding: 025523
   Coding: 100000
   Coding: 100000
   Coding: 020300
Address 0E: Media Player 1 (R161)       Labels: NONE
   Revision: AA001001
   VCID: 22082B063D3DB02B9B-8077
   Coding: 280902
   VCID: 3B36F662B297E1E3B8-806E
   Coding: 3601020201
   VCID: 291A3C2A480B6373DA-807C
   VCID: 373EEA528EBFC5835C-8062
Address 16: Steering wheel (J527)       Labels: NONE
   Coding: 0000BC
   VCID: 373EEA5286BFC5835C-8062
   ROD: EV_RBD4K.rod
   VCID: 302CD14E6BD112BB1D-8065
   Analog_clock:
   Coding: 00C1034A00
   VCID: 3424DD5E9FC92E9B79-8061
   Coding: 0000000000
   VCID: 312AD44A60DB1BB312-8064
   Coding: 008002
   VCID: 2C14C53E47F9765B21-8079
Address 36: Seat Mem. Drvr (J136)       Labels: NONE
   ROD: EV_SARA.rod
   VCID: 6C94053E8779B65B61-8039
          U1111 00 [032] - -
Address 3C: Lane Change        Labels: NONE
   Coding: 0000002
   VCID: 2E10CF36B9E5044B0F-807B
Address 42: Door Elect, Driver (J386)       Labels: NONE
   VCID: 43C68E82C2679923F0-8016
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.CLB
   Coding: 020200
   Coding: 070000
   Coding: 020200
   Coding: 020200
   Coding: 020200
Address 47: Sound System (J525)       Labels: NONE
   Coding: 030000
   VCID: 1C7415FE1F5986DB51-8049
Address 48: Seat, Rear, DS (J876)       Labels: NONE
   VCID: 71AA144AA85B5BB352-8024
Address 52: Door Elect, Pass. (J387)       Labels: NONE
   VCID: 3A38F366B5ADD8EBA3-806F
Address 56: Radio (R)       Labels: NONE
   VCID: 200C210E3331A23B8D-8075
Address 5B: Seat,Rear,PS (J877)       Labels: NONE
Address 5F: Information Electr. (J794)       Labels: 4E0-035-6XX-5F.CLB
   VCID: 291A3C2A400B6373DA-807C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.CLB
   Coding: 1080003
   VCID: 2600371691154C0BF7-8073
   Coding: 0210044100
   VCID: 3D32F87AAC83EFD386-8068
   ROD: EV_Ambie.rod
   VCID: 63866E026AA7F923D0-8036
Address 72: Door, Rear Right (J389)       Labels: NONE
   VCID: 393AEC6AB0ABD3F3AA-806C
   VCID: 2B16C62242F7716328-807E
   Coding: E9060000
   VCID: 6582701A649387133E-8030
   Coding: 764FF2
   VCID: 2F2ED23276EF0D4304-807A
   Coding: 364FF2
   Coding: 200F00
   VCID: 2E10CF3671E5044B0F-807B
   Coding: 3601020201
   VCID: 271E3A125E1F5503CC-8072
   Coding: 200F00
   ROD: EV_BC7.rod
   VCID: 2600371659154C0BF7-8073
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 90:35)--------------------------
Edit:
Much improved labels list in this version.
Edit II:
I stand corrected, I did not grep ignoring case...
bureau:Desktop jake$ grep -i none j.txt
One of these days, I'm going to stop there in my travels and hook you up with some vape toys. I feel 10 years younger since I switched, and the switch was painless. In fact, I ended up with a new hobby. :cool:
Both? That makes little sense. I've run a lot of scans (recently including a bunch with debug level 2) and switch between USB and NET (typically AP) all the time, no muss, no fuss.
bureau: Desktop jake$ grep -i none j.txt
This makes us wonder whether you're running Windows in a VM with some other OS as a host?
jakematic
NC USA
C?ID=129085
<Bangs head on desk thinking about another hobby>
This has been an issue since the last CB/FW update - not the current one, the previous one.
Typically whatever the initial connection type is will work, but the next mode will fail - sometimes going into the module in question fails.
I think there is a timing or some other issue talking to some of the modules on this vehicle.
Did notice some low (?) sample rates today in the 4's compared to everything else in the 8-9 range.
If I recall correctly this all started about the time the dual ECU conversation / fixes came about.
09 has been troublesome all along, and now the CAN gateway has started.
Really wish I hadn't let my VCHUC go at this point for comparative testing.
For what it's worth I see this behaviour on both HEX-NETS but the last two have been the same one.
I'm using a Dell Venue 8 Pro with Win8.1, 32bit I think.
Once I run the scans the Venue goes back on my network and I have to hopscotch through a Win8.1 VM to retrieve the files because Winders gets pi$$y about the Mac.
On the Mac I can use real tools to look at the raw data :cool:
Well, it doesn't have to be one, but for me, I think turning it into one was an important component. One of these days, I'll start a thread in the bar.
That's good to know, thanks.
Sample rates are expected to vary dramatically between modules; this variation is due primarily to how quickly a particular module answers our requests.
I think it would be worth RTs while to fix that.
Right. Somehow I'd forgotten that. I picked one up not that long ago, 'cause they were heavily discounted with the purchase of a new desktop. We did some scans with it; it seemed to work well enough, but I haven't used it extensively since. I also don't have the correct USB adapter/cable handy; will have to find one. Then all we need is a current A8, a current Touareg, and old Phaeton -- that should give us the ability to duplicate most of the remaining substantial issues I can think of.
Makes perfect sense. :)
jakematic
NC USA
C?ID=129085
This little $6 gem works very well, even with my YubiKey.
I may order another one just in case the first gets lost.
For now I'm leaving it attached to the HEX-NET cable in the door pocket.
Let me know how I can help, and I may be your way next month if you want to use my A8.
For some reason I missed this reply last night.
Think it's time to empty the cache on Chrome as it is acting up with several forums lately...
At your leisure, can you give 0.4015 a try for these issues? I'm by no means asking you to spend another couple of hour, just a quick check to see if there any improvement specifically with 19 and maybe with 09.
Thanks!
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
For the Phaeton, I think we just had a dual ECU regression (which I think you can deal with in-house if you haven't already) and the infotainment / nav issue. My offer still stands to get you a nav computer for a few weeks; it's very easy to pull out. Also, I happen to know Michael is sitting on a complete working spare infotainment unit. He was willing to leave you his whole car, so I'll venture a guess he would discuss a far simpler and easier loan too.
I'm surprised you have trouble getting access to current stuff. I had always imagined Ross-Tech would have relationships with local dealer service departments, some sort of "box of free interfaces for ongoing occasional test drives" type thing.
Jason
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Wow. Which modules does that car not have?
Jason
jakematic
NC USA
C?ID=129085
Certainly will - should be much quicker without level 2 this time :)
I don't mind the time at all, it's just a matter of finding it.
Betas are a two way street and it's the very least we can do to help.
Night vision, topview, and RSE are the only ones I know of short of it being a W12.
Those would likely bump it from 44 to over 50 :D
