- Jun 21, 2024
- 6
- 0
- Plantersville, TX, USA
- C?ID=449472
Stock 19 Jetta S 1.8 T(G)DI
Friday,21,June,2024,15:32:18:57722
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.5
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 4F 52 5F 61 62 72
VIN: 1VWAS7A38GC027064 Mileage: 186110km-115643miles
Address 01: Engine (J623-CPKA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 906 071 AF HW: 06K 907 425 C
Component: R4 1.8l TFS H13 4869
Revision: --H13--- CVN: 6CBF5F95
Coding: 001A0092242400160000
Shop #: WSC 09003 957 00200
ASAM Dataset: EV_ECM18TFS02006K906071AF 001008
ROD: EV_ECM18TFS02006K906071AF.rod
VCID: 6FBC0A9D17131BD2BE9-803A
VINID: 0669D18C74432174C008700610C5071D93
26370 - MAP/MAF <-> Throttle Position Correlation
P0068 00 [00100000] - -
17178 - Databus
U1123 00 [00101111] - Received Error Message
Fault Frequency: 35
Mileage: 180964 km
Date: 2024.05.25
Time: 08:24:08
Engine RPM: 2277.50 /min
Vehicle speed: 128 km/h
Coolant temperature: 89 °C
Intake air temperature: 35 °C
Voltage terminal 30: 13.828 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-ESP system error: No
21320 - Implausible Data Received from ABS Control Module
U0415 00 [00101110] - -
Fault Frequency: 79
Mileage: 180964 km
Date: 2024.05.25
Time: 08:24:08
Engine RPM: 2277.00 /min
Voltage terminal 30: 13.847 V
Engine: operating status: PU
ECU_STATE: SYN_ENG_IGK_ON
Engine oil temperature: 99.0 °C
Time since engine start: 1896.3 s
T_ES: 0 min
Cruise control switch actuation-Main switch: Not operated
Cruise control switch actuation-Set: Not operated
Cruise control switch actuation-Resume: Not operated
Cruise control switch actuation-Accelerate: Not operated
Cruise control switch actuation-DELAY: Not operated
Cruise control switch actuation-Cancel: Not operated
Cruise control switch actuation-Main switch hardware: Not operated
Cruise control switch actuation-Limit button: Not operated
Cruise control switch actuation-Main switch CAN: Not operated
Cruise control switch actuation-Large increment: Not operated
STATE_ERR_ABC_PRED: 7
21323 - Implausible Data Received from ABS Control Module
U0415 00 [00101111] - -
Fault Frequency: 14
Mileage: 185808 km
Date: 2024.06.15
Time: 09:14:13
Engine RPM: 881.50 /min
Normed load value: 23.1 %
Coolant temperature: 66 °C
Intake air temperature: 48 °C
Voltage terminal 30: 13.535 V
Engine: operating status: IS
Engine oil temperature: 55.0 °C
Time since engine start: 77.8 s
T_ES: 0 min
23128 - Implausible Data Received from ABS Control Module
Fault Frequency: 79
Mileage: 180964 km
Date: 2024.05.25
Time: 08:24:08
Engine RPM: 2274.50 /min
Vehicle speed: 124 km/h
STATE_LS_SAE[1]: CL
T_AST_SAE: 1894 s
MAP_MES_SAE: 25 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.812 V
FAC_TPS_1_SAE: 13.281250 %
FUP_H_SAE: 12780.0 kPa
23131 - Implausible Data Received from ABS Control Module
Fault Frequency: 14
Mileage: 185808 km
Date: 2024.06.15
Time: 09:14:13
Engine RPM: 883.75 /min
Voltage terminal 30: 13.554 V
STATE_LS_SAE[1]: CL
T_AST_SAE: 76 s
MAP_MES_SAE: 59 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.987 V
FAC_TPS_1_SAE: 13.671875 %
FUP_H_SAE: 14940.0 kPa
Address 02: Auto Trans (J217) Labels:* 09G-927-749-V1.clb
Part No SW: 09G 927 749 AN HW: 09G 927 749 AN
Component: AISIN AG6 G3 129 2941
CVN: CA96F2E3
Coding: 000348
ASAM Dataset: EV_TCMAQ250031 002009
ROD: EV_TCMAQ250031_002_VW23.rod
VCID: 0550483525AF3182645-8050
22968 - Implausible Data Received from ABS Control Module
U0415 00 [00101010] - -
Fault Frequency: 71
Reset counter: 83
Mileage: 180964 km
Engine RPM: 803.0 /min
Transmission input speed: 855 /min
Transmission output speed: 340 /min
Engine torque: 356 Nm
ATF temperature: 80 °C
Accelerator pedal position: 0.0 %
Clutch_C1: closed
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: closed
Clutch_B2: Open
Lock Up Clutch: Open
Electrical Oil Pump target revolution: 65534 /min
Electrical Oil Pump actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
Electrical Oil Pump target current: 65278 mA
22971 - Implausible Data Received from ABS Control Module
U0415 00 [00101011] - -
Reset counter: 105
Mileage: 185808 km
Engine RPM: 888.0 /min
Transmission input speed: 0 /min
Engine torque: 684 Nm
ATF temperature: 55 °C
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: closed
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: C54BC0F549240001A30B03EA921D004120100012
VCID: 75B038F575CF2102745-8020
9 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Reset counter: 143
Mileage: 181862 km
Date: 2018.10.19
Time: 01:55:12
Count: 32768
Count: 12800
Count: 33
Count: 49788
Count: 1
Count: 764
Fault Frequency: 20
Reset counter: 144
Mileage: 182713 km
Date: 2018.10.19
Time: 09:20:04
Count: 3
Count: 12
Count: 29184
Count: 16390
Count: 50688
Count: 253
Reset counter: 147
Mileage: 185816 km
Date: 2018.11.08
Time: 01:25:51
Count: 16387
Count: 12
Count: 4096
Count: 128
Count: 42240
Count: 256
Count: 510
Count: 8448
03839 - RPM Sensor Front Left: Incorrect Signal
Reset counter: 111
Mileage: 591619 km
Date: 2002.00.02
Time: 16:24:03
Count: 1024
Count: 413
Count: 43008
Count: 83
Count: 320
Count: 4353
Count: 32
Count: 26649
Fault Status: 00100011
Reset counter: 111
Mileage: 185808 km
Date: 2018.11.06
Time: 09:14:14
Count: 16387
Count: 4
Count: 12800
Count: 88
Count: 48640
Count: 510
Count: 14848
Fault Frequency: 25
Reset counter: 104
Mileage: 180964 km
Date: 2018.10.16
Time: 08:24:09
Count: 17472
Count: 32768
Count: 12800
Count: 4193
Count: 48141
Count: 65535
Count: 508
Count: 1280
Fault Status: 01101100
Fault Frequency: 21
Reset counter: 111
Mileage: 182713 km
Date: 2018.10.19
Time: 09:20:04
Count: 3
Count: 12
Count: 29184
Count: 16390
Count: 50688
Count: 253
Reset counter: 168
Mileage: 163655 km
Date: 2018.05.01
Time: 15:01:28
Count: 3
Count: 12
Count: 12800
Count: 16401
Count: 52224
Count: 511
02214 - Tire Pressure Warning
Fault Status: 01100010
Reset counter: 112
Mileage: 181148 km
Date: 2018.10.18
Time: 10:14:09
Count: 16387
Count: 12
Count: 16384
Count: 39
Count: 45829
Count: 510
Part No SW: 561 907 044 AN HW: 561 907 044 AN
Component: Climatronic H07 0910
Revision: 00001K04
Coding: 0070019002
VCID: 639476ADCBDBAFB22A1-8036
9474161 - Motor for Defroster Flap
B1090 71 [00001001] - Actuator Stuck
Reset counter: 168
Mileage: 163655 km
Date: 2023.12.09
Time: 15:01:00
9472881 - Motor for Fresh Air / Recirculated Air Flap
B108B 71 [00001000] - Actuator Stuck
Fault Frequency: 48
Reset counter: 151
Mileage: 183776 km
Date: 2024.06.04
Time: 03:13:37
9476885 - Position Sensor for Fresh/Recirculated Flap Motor
B109B 15 [00001000] - Open or Short to Plus
Reset counter: 143
Mileage: 185729 km
Date: 2024.06.14
Time: 11:05:28
Part No SW: 5K0 937 085 AE HW: 5K0 937 085 AE
Component: BCM PQ35 B+ 122 0183
Revision: BH122001
Coding: EF200E18902B08D4088800010400044800F1000640801920E48062000C70
VCID: 76B23FF968C92A1A7DF-8022
03188 - Bulb for Side Marker Light; Front Left
Fault Status: 00101010
Reset counter: 146
Mileage: 181148 km
Date: 2018.10.18
Time: 09:05:04
Voltage: 14.10 V
Address 15: Airbags (J234) Labels:* 561-959-655.clb
Part No SW: 561 959 655 HW: 561 959 655
Component: AirbagVW11 001 0207
Serial number: 003RXM02Y6FD Dataset Number: 561003V____ 0012
Coding: 8CCCCC00000000005000001A020800000065
ASAM Dataset: EV_AirbaVW11SMEVW411 001002
ROD: EV_AirbaVW11SMEVW411.rod
Component: BF-Gewichtss. H12 0021
Serial number: IBH00000000000457BJ6
Coding: 303245
Subsystem 2 - Part No SW: ----------- HW: 480 001 711 15
Serial number: 35700000000C57A4C71U
Subsystem 3 - Part No SW: ----------- HW: 480 001 711 15
Serial number: 35800000000B6B40C71P
Subsystem 4 - Part No SW: ----------- HW: 480 022 610 15
Component: SideSensor_Dr 000 0148
Serial number: 3510001B51C24B8633A0
Subsystem 5 - Part No SW: ----------- HW: 480 022 710 15
Component: SideSensor_Pr 000 0148
Serial number: 3520001BF1E054A662ED
Subsystem 6 - Part No SW: ----------- HW: 480 022 010 15
Component: FrontSensor_D 000 0189
Serial number: 3550001A51BE60631791
Subsystem 7 - Part No SW: ----------- HW: 480 022 010 15
Component: FrontSensor_P 000 0189
Serial number: 3560001A51BE606496AB
B10B3 00 [00001000] - Function Restriction due to Implausible Message(s)
Fault Frequency: 56
Reset counter: 151
Mileage: 180969 km
Date: 2024.05.25
Time: 09:58:18
Part No SW: 5K0 953 569 BC HW: 5K0 953 569 BC
Component: LENKS.MODUL 018 0230
Revision: --X01--- Serial number: 20200825200095
Coding: 0882440008
Shop #: WSC 01286 386 08256
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 7AAA2BC95C514E7A197-802E
Subsystem 1 - Part No SW: 6C0 959 442 G HW: 6C0 959 442 G Labels: 3C8-959-537.CLB
Serial number: 3281518031202037BE2B
Coding: 280000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 971 HW: 561 920 971
Component: KOMBI H04 1008
Coding: 231E010000
VCID: 58EE5141829D7C6A4F3-800C
Part No SW: 7N0 907 530 BB HW: 7N0 907 530 AM
Component: J533 Gateway H55 1663
Revision: H55 Serial number: 11111503000050
Coding: 461020
VCID: 71B80CE501A70D22A8D-8024
Component: IMMO H04 1008
ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
VCID: 6A8A1B892CF1FEFAE97-803E
Part No SW: 561 959 701 B HW: 3C0 959 793 H
Component: TUER-SG FT 002 0637
Revision: 13100010 Serial number: 0010184527
Coding: 040495
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1D600055AD3FD9425C5-8048
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 C HW: 561 959 811 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 019 1471
Serial number: 14202746151207214736
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 311 3501
Revision: 00H22000
VCID: 3928F4C51557856250D-806C
Fault Status: 11101101
Fault Frequency: 62
Reset counter: 111
Mileage: 186059 km
Date: 2018.11.11
Time: 02:09:39
Voltage: 13.75 V
DU
Temperature: 48.0°C
RPM: 896 /min
Speed: 14.0 km/h
Speed: 14.0 km/h
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1663
Coding: 00000008
VCID: 6FBC0A9D17931BD2BE9-803A
Subsystem 1 - Part No SW: 561 919 204 C HW: 561 919 204 C
Component: Analoguhr 001 0002
Part No SW: 561 959 702 B HW: 3C0 959 792 H
Component: TUER-SG BT 002 0637
Revision: 15100010 Serial number: 0010054693
Coding: 040494
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1E620759A039C25A45F-804A
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 C HW: 561 959 812 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 019 1471
Serial number: 14102747151212144501
131584 - Motor for Rear Window Regulator
B11EE 54 [00001000] - Missing Calibration / Basic Setting
Reset counter: 130
Mileage: 182915 km
Date: 2024.06.03
Time: 04:31:57
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 561 035 150 HW: 561 035 150
Component: MU-E--US 857 6495
Serial number: 24091500011303 Dataset Number: 5K7CV1v__A_ 0001
Coding: 02140100BE00000041220001001000001F0000D40000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
ROD: EV_MUEnt4CGen2LGE_VW27.rod
VCID: 4ACABB094C311EFAC97-801E
Part No SW: 7N0 907 534 HW: 7N0 907 530 AM
Component: Batt.regelung H55 1663
Coding: E1200859
End----------(Elapsed Time: 01:02, VBatt start/end: 13.6V/13.6V)-----------
For last 40+K miles Had TPMS MIL illuminated, although verified pressure multiple times. Couldn't VCDS scan as lost module through move 2-3 years ago. Now ABS, ESP, Airbag and Yellow steering lights. All OEM parts in this area except front brake pads. ABS doesn't work correctly when MIL off (slower pulses) and not at all when MIL on. Also has immobilized the cruise control (won't set speed).
Working to get wiring diagram.
Was figuring on replacing sensors first and seeing how that improves / changes....except I don't think that'll address this code?
Not concerned about Battery - voltages look OK...haven't checked fuses - Why>
P.S. I'm an old Detroit boy, and computer geek. I'm looking forward to learning where to find all this information and what it means.
