I've got a weird one that I can't find any good information on, so I'm hoping someone here can help? When driving long-distance, after ~30-40 minutes, my A/C will just stop blowing. If I turn the engine off and then immediately restart it, I get another ~30-40 minutes of A/C before it shuts off again. Rinse, repeat for however long the drive is.
The only relevant fault codes I find are:
These codes will not clear or stay gone. Every time I start the car I get the warning Electrical System: low battery charge. Battery will be charged while driving. The 12V battery is at 100% SOC (and even exceeds its amp ratings), and when looking in module 61, the 48V MHEV battery is above 50% SOC.
Any ideas how I can clear this annoying code and keep my A/C running?
405505 - Blower Output Reduction due to Energy Management
B10CE 00 [00001000] - -
Reset counter: 181
Mileage: 68057 km
Date: 2024.06.19
Time: 20:22:21
average_Voltage_terminals: 15.20 V
Outside air temperature sensor-Outside air temperature on CAN: 26.50 °C
interior_temperature: 28.50 °C
Vehicle speed: 0.00 km/h
405507 - Functional Limitation due to Energy Management
B10CD 00 [00001001] - -
[Function limitation due to energy management system]
Reset counter: 141
Mileage: 68057 km
Date: 2024.06.19
Time: 20:54:48
average_Voltage_terminals: 12.20 V
Outside air temperature sensor-Outside air temperature on CAN: 28.50 °C
interior_temperature: 29.00 °C
IDE08817 Charge state: cell 01 53 %
IDE08818 Charge state: cell 02 53 %
IDE08819 Charge state: cell 03 53 %
IDE08820 Charge state: cell 04 53 %
IDE08821 Charge state: cell 05 53 %
IDE08822 Charge state: cell 06 53 %
IDE08823 Charge state: cell 07 53 %
IDE08824 Charge state: cell 08 52 %
IDE08825 Charge state: cell 09 53 %
IDE08826 Charge state: cell 10 53 %
IDE08827 Charge state: cell 11 53 %
IDE08828 Charge state: cell 12 53 %
IDE08829 Charge state: cell 13 55 %
Wednesday,19,June,2024,20:57:50:19409
VCDS Version: 24.5.0.0 (x64) HEX-NET2 CB: 0.4643.5
VIN: WAUV2AF21KN017665 License Plate:
Chassis Type: F2-AU58 (4K0)
Scan: 01 02 03 09 13 15 16 17 19 22 36 3C 42 44 46 47 52 5F 61 6D
75 81 82 A5 BB BC C4 CA CC CD CF D6 D7 DB DC DE
VIN: WAUV2AF21KN017665 Mileage: 68057km-42288miles
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
CD-Laser Scanner -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (J623-DLZA) Labels:. 06M-907-309-V1.clb
Part No SW: 4K0 907 559 A HW: 06M 907 309 G
Component: V6 3.0l TFSI H11 0007
Revision: B8H11000 CVN: 2F6F2645
Coding: 1A6500122366010E34286000000400000000000000000000
Shop #: WSC 03993 004 1048576
ASAM Dataset: EV_ECM30TFS0114K0907559A 001007
ROD: EV_ECM30TFS0114K0907559A.rod
VCID: 3338708D9BB1D5829A1-8066
VINID: 9D196609158205B78004718614A4E0D3DC
13859 - EVAP System Leak Detection Pump
P148D 00 [01100101] - Implausible Frequency
Mileage: 68057 km
Date: 2024.06.19
Time: 20:36:59
Engine RPM: 0.00 /min
Vehicle speed: 255 km/h
Coolant temperature: 100 °C
Intake air temperature: 52 °C
Ambient air pressure: 910 mbar
Voltage terminal 30: 15.320 V
Engine status: COENG_FINISH
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 5
Readiness: 1010 0101
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4K0 927 153 M HW: 0HL 927 156 B
Component: 0HL 30TFSINAR H01 0003
Revision: --H01--- Serial number: 0000001359 CVN: E458A77D00000000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL382021 002031
ROD: EV_TCMDL382021_AU58.rod
VCID: 3720449D8FB939A2A69-8162
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041180169002488
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-V1.clb
Part No SW: 4N0 907 379 AC HW: 4N0 907 379 P
Component: ESP9 Premium H06 0850
Dataset Number: 4K8909504H 0001 CVN: 2C285638
Coding: 58AA159729A30B9D11A44C97208252E3F439C91AA894D08832044AC72F9C93
ROD: EV_ESP9BOSCHCMP_004_AU58.rod
VCID: 79A482A5F92DEFD210D-812C
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 DE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H10 0652
Dataset Number: 4K0909514M 0035
Coding: 07000B63C0291CDD070E57881CEF9C68131B37110406009781050A0019331C0108490A024010000000000303004308180802000044010100000000000000000000
Shop #: WSC 17873 123 50804
ASAM Dataset: EV_BCM1BOSCHAU651 014010
ROD: EV_BCM1BOSCHAU651_014.rod
VCID: 74BAB391DE3F92BA43B-8020
Subsystem 1 - Part No SW: 4K1 955 119 HW: 4K1 955 119
Component: J400FRWISCH 063 0740
Serial number: 00000001805170401074
Coding: 7DC727
Serial number: 21590312X81A955555A0
Coding: 02006E
Subsystem 3 - Part No SW: 4K1 941 501 A HW: 4K1 941 501 A
Component: E1 - LTM H09 0086
Serial number: 13S12.07.1800300250
Subsystem 4 - Part No SW: 4N0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H10 0100
Serial number: 0000009600350Z01DH02
Coding: 250000
Subsystem 5 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE109051823510877
Interior Light Module:
Subsystem 6 - Part No SW: 4K0 947 135 E HW: 4K0 947 135 E
Component: Dachmodul H42 0413
Serial number: C00050999
Coding: 0D0104
Subsystem 7 - Part No SW: 80A 907 705 HW: 80A 907 705
Component: J866-EVLS-SG H03 0100
Serial number: WA133160000051753202
Coding: 0A0700
Subsystem 8 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V512 LLR1SLvL H01 0012
Serial number: L84AI11501612
Subsystem 9 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V514 LLR1SKvL H01 0012
Serial number: L84AI11501602
Subsystem 10 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V516 LLR1SLvR H01 0012
Serial number: L84AI11501615
Subsystem 11 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V518 LLR1SKvR H01 0012
Serial number: L84AI11501620
Front windshield washer pump:
Subsystem 12 - Part No SW: 4N0 907 605 A HW: 4N0 907 605 A
Component: J1100/SWP H09 0005
Serial number: 00000000001818400449
Coding: 020000
Reset counter: 181
Mileage: 68057 km
Date: 2024.06.19
Time: 20:22:21
Reset counter: 141
Mileage: 68057 km
Date: 2024.06.19
Time: 20:54:48
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 4K0 907 561 D HW: 4K0 907 561
Component: LRR4R H04 0332
Dataset Number: 4K2909863L 0001
Coding: D6659F5458082C00010360E1000000BE4A1246484481009E04
Shop #: WSC 00022 444 00000
ASAM Dataset: EV_ACCBOSCHAU65X 002023
ROD: EV_ACCBOSCHAU65X.rod
VCID: 2F307CFD77E9F162FE9-817A
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 4N0 959 655 K HW: 4N0 959 655 K
Component: AirbagVW31 H02 2710
Serial number: 003YUM0041T. Dataset Number: 4K0909602AC 0004
Coding: BFCCFCC000C00000A000003FF20D410000C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
VCID: 44DA2351CE6F623A33B-8110
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2018177344900000
Coding: 04F001
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2017333019400000
Coding: 04F001
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J180009RF2F0D
Coding: 303135
Subsystem 4 - Part No SW: ----------- HW: 480 001 007 18
Serial number: 3570000000079141113%
Subsystem 5 - Part No SW: ----------- HW: 480 000 907 18
Serial number: 358000000005640DE03I
Subsystem 6 - Part No SW: ----------- HW: 480 032 806 18
Component: SideSensor_Dr 002 0149
Serial number: 351001C10F451020BFF5
Subsystem 7 - Part No SW: ----------- HW: 480 032 806 18
Component: SideSensor_Pr 002 0149
Serial number: 352001C10F44D521286+
Subsystem 8 - Part No SW: ----------- HW: 480 030 507 18
Component: FrontSensor_D 002 0149
Serial number: 355001C08C2C75D1089H
Subsystem 9 - Part No SW: ----------- HW: 480 030 507 18
Component: FrontSensor_P 002 0149
Serial number: 356001C08C247DB01E5I
Part No SW: 4N0 907 129 N HW: 4N0 907 129 N
Component: Lenks.Modul H03 0005
ROD: EV_SMLSKLOAU736_VW53.rod
VCID: 3C2A5BB1B69F1AFA4BB-8168
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 4K0 920 890 A HW: 4K0 920 890 A
Component: FBenUSAACC--- H11 0151
Dataset Number: 4K0909525B 0021
Coding: 83CE50C3EC88D7050283E1609880C80008002000
ROD: EV_DashBoardAU65X_001_AU58.rod
VCID: 2C0A6BF146FF8A7ADBB-8178
Part No SW: 4K0 907 468 C HW: 4K0 907 468 C
Component: Gateway H05 0117
Serial number: 18F01000667801 Dataset Number: 4K0909515B 0027
Coding: 020100050004064054960000005B0132DC3A004710000000097D078E10000000
GVL: F1D13C080800000002DC88008000C800100E0070000000000000000000000100
ASAM Dataset: EV_Gatew31xAU65x 003160
ROD: EV_Gatew31xAU65x_AU58.rod
VCID: 343A73919ECFD2BA83B-8160
Subsystem 1 - Part No SW: 4K0 951 523 J HW: 4K0 951 523 J
Component: E221__MFL H06 0003
Subsystem 2 - Part No SW: 4K0 915 181 HW: 4K0 915 181
Serial number: 74186311001806090BE0
Address 22: AWD (J492) Labels:| 0CJ-927-749.clb
Part No SW: 4K0 927 755 HW: 0CJ 927 749 A
Component: C8_DL4_N_SD2H01 0008
Serial number: 18020A4914
Coding: 110C0000
ASAM Dataset: EV_AWDCQUOD31 001052
ROD: EV_AWDCQUOD31.rod
VCID: 72B6B589A45B9C8A517-8126
Part No SW: 4M6 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0064
Serial number: 00000332846728 Dataset Number: 4K8909856VD 0001
Coding: 015C1A400000B4010003010101010000000000000000000000000000004000
VCID: 7BA898ADF311DDC2021-812E
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4N0 907 566 E HW: 4N0 907 566 A
Component: MRR_HR H12 0265
Dataset Number: 4K8909535D 0020
Coding: 0FDC00
ASAM Dataset: EV_RearRadarS1DelphAU651 001018
ROD: EV_RearRadarS1DelphAU651.rod
VCID: 382247A182A736DAAF3-816C
Part No SW: 4M1 959 793 J HW: 4M1 959 793 D
Component: TSG FS001 0430
Serial number: YE007RFR05798 Dataset Number: 4K8909872C 0036
Coding: 001DCB4352001480A009A430
ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
VCID: 46DE3959F853502A2DF-8112
Part No SW: 4N0 909 144 D HW: 4N0 909 144 A
Component: EPS_MLBEVO2BS H21 0504
Dataset Number: 4KF909852G 0001
Coding: B4002101010000
ASAM Dataset: EV_EPSVWBSAU426 009015
ROD: EV_EPSVWBSAU426_009.rod
VCID: 31347A8561DDE792E8D-8164
Part No SW: 4N0 907 064 BD HW: 4N0 907 064 D
Component: BCM2 MLBevo H14 0145
Dataset Number: 4K8909501D 0033
Coding: 0134000049A100C0658FA0046C00080203034001810422502F0400000F04823F001E0101011F01
ASAM Dataset: EV_BCM2CONTIAU651 008007
ROD: EV_BCM2CONTIAU651_008_AU58.rod
ID - sensor:
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099345686
left tail lamp 1:
Subsystem 3 - Part No SW: 4K8 945 069 C HW: 4K8 945 069 C
Component: Slali1AU583 H03 0404
Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Subsystem 4 - Part No SW: 3G0 962 243 B HW: 3G0 962 243 B
Component: GEB.F.Heckoef H17 0904
Serial number: 58528686
Rear spoiler control module:
Subsystem 5 - Part No SW: 4K8 959 252 HW: 4K8 959 252
Component: J223 HSP 0304 H02 0200
Serial number: WA133030000051538284
Coding: 00FF00
left tail lamp 2:
Subsystem 6 - Part No SW: 4K8 945 217 C HW: 4K8 945 217 C
Component: Slali2AU583 H03 0404
Right rear tail lamp 1:
Subsystem 7 - Part No SW: 4K8 945 070 C HW: 4K8 945 070 C
Component: Slare1AU583 H03 0404
Right rear tail lamp 2:
Subsystem 8 - Part No SW: 4K8 945 218 C HW: 4K8 945 218 C
Component: Slare2AU583 H03 0404
Part No SW: 4N0 035 223 C HW: 4N0 035 223
Component: MIB2_amp_P_D5 H01 0170
Revision: 00000001 Serial number: AUZ8ZAJ6S0047Q3 Dataset Number: 4K8909510C 0006
Coding: 0185030000AAAA2FAA0000010000
ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001006
ROD: EV_AMPMst16C1Gen2pALPI.rod
VCID: 241A83D12E2F423A13B-8170
Part No SW: 4M1 959 792 J HW: 4M1 959 792 D
Component: TSG BFS001 0430
Serial number: YE007RG526554 Dataset Number: 4K8909873C 0036
Coding: 001DCB035E001480A009A430
ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
VCID: 45DC3E55C5555B32245-8110
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4K0 035 084 D HW: 4K0 035 084 A
Component: MU-H-LNS-US 046 2711
Dataset Number: 4K8909545C 0024
Coding: 0185030200000000C1220002061C00302F0001E401F008048E
VCID: 270094DD5F19A922369-8172
Subsystem 1 - Part No: V03 959 804 BS
Component: MIB2P_NA_Q317 0249
Multimedia System 1:
Subsystem 2 - Part No SW: 4K0 919 605 C HW: 4K0 919 605 A
Component: DU AU58x High H42 0147
Serial number: INX00130041800060456
Compact disc data bank:
Component: Gracenote2 3006
Volume Control 1:
Subsystem 4 - Part No SW: 4K1 919 616 B HW: 4K1 919 616 A
Component: LSR-D5/C8 H33 0110
Serial number: 00004418000140029037
Multimedia System 5:
Subsystem 5 - Part No SW: 4K0 919 603 B HW: 4K0 919 603
Component: DU AU58x Bot H41 0147
Serial number: INX00117041800080310
Media socket:
Subsystem 6 - Part No SW: 4N0 035 726 A HW: 4N0 035 726
Component: MediaConnectL 014 0133
Serial number: 051800434158001
Reset counter: 141
Mileage: 68057 km
Date: 2024.06.19
Time: 20:15:55
Voltage terminal 30: 15.3 V
Satellite radio tuner status-Audio Signal: available.
Satellite radio tuner status-Antenna current: 106 mA
Satellite radio tuner status-Reception quality: optimum_signal
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 05
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 05
Address 61: Battery Regul. (J1120) Labels: 4N0-915-105.clb
Part No SW: 4N0 915 105 B HW: 4N0 915 105 B
Component: BMS_48V_LiIon H06 0108
ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
ROD: EV_BMS48VLiIonLGAU536_AU58.rod
VCID: 290492E5490D9F5220D-817C
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0166
Revision: -------- Serial number: 32013056100000 Dataset Number: 4K8909541A 0004
Coding: 1630
VCID: 48C23761F247465ADF3-811C
Part No SW: 4K1 035 283 HW: 4K1 035 283
Component: ConBox H07 0100
Serial number: 005CCA12F040023 Dataset Number: 4K0909612B 0011
Coding: 01C020FF4040800000
ASAM Dataset: EV_ConBoxAU651 001004
ROD: EV_ConBoxAU651_001_AU58.rod
VCID: 659CDED565957B32C45-8130
Address 81: Gear Shift (J587) Labels: 4KX-713-041-81.clb
Part No SW: 4K1 713 041 H HW: 4K1 713 041 H
Component: GSM-LL H14 0050
Serial number: 18.191 40051
ASAM Dataset: EV_GSMKAMAU581 001005
ROD: EV_GSMKAMAU581.rod
VCID: 280297E15207A65A3F3-817C
Address 82: Head Up Display (J898) Labels:| 4Nx-919-617-V1.clb
Part No SW: 4K8 919 617 B HW: 4K8 919 617 B
Component: HeadupDisplay H13 1815
Coding: 4700E0
ASAM Dataset: EV_HeadUpDisplAU65X 001010
ROD: EV_HeadUpDisplAU65X_VW53.rod
VCID: 3A265DA9BCAB24CA597-816E
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* 4N0-907-107-V2.clb
Part No SW: 4KE 907 107 AR HW: 4N0 907 107 H
Component: zFAS Var C H09 0295
Dataset Number: 4K0909466N 0050
Coding: 020186000000000000FFD60000F0054C139F760000000000000000000096D401019BA8000000000000000080000000000000000000000000F980400000000000000098D0008000B000800080000000000080400000E0
Shop #: WSC 00022 444 12345
ASAM Dataset: EV_ZFASAU516 001006
ROD: EV_ZFASAU516_001.rod
VCID: 0F70DC7DD7A9D162DE9-815A
2117711 - Internal Fault
B200F F9 [00001000] - Unknown Error Elaboration
[ZGT Überwachung am SRH fehlgeschlagen]
Reset counter: 181
Mileage: 68057 km
Date: 2024.06.19
Time: 20:37:23
Platform_zFAS_Error_Handler_Master-ErrorHandlerMaster: 01 00 48 11 93 11 00 00 00 00 00 00 00 00 00 00
Platform_zFAS_Error_Handler_SSH-ErrorHandlerSSH: FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Platform_zFAS_Error_Handler_SRH-ErrorHandlerSRH: FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Part No SW: 4M1 959 795 J HW: 4M1 959 795 D
Component: TSG HFS003 0430
Serial number: YE007RG42321A Dataset Number: 4K8909897C 0037
Coding: 000DCB0300001480E008A020
ROD: EV_DCU2RearDriveMAXHKLO_VW38.rod
Component: TSG HBFS003 0430
Serial number: YE007RG421437 Dataset Number: 4K8909896C 0037
ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C4: DC/DC Converter (A7) Labels: 4M0-959-663.clb
Part No SW: 4M0 959 663 C HW: 4M0 959 663 C
Component: PCU10 022 0324
Dataset Number: 4K0909475A 0007
ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
ROD: EV_DCDC48V210ABOSCHAU736.rod
Part No SW: 4M0 907 594 BG HW: 4M0 907 594
Component: SAD_STG_1 014 0007
Dataset Number: 4K0909469C 0009
Coding: 268040058301
ASAM Dataset: EV_SunRoofCONTIAU736 008010
ROD: EV_SunRoofCONTIAU736_008.rod
VCID: 7CAA9BB1F61FDAFA0BB-8128
Address CC: Starter-Generator (C29) Labels:* None
Part No SW: 4N0 903 028 P HW: 4N0 903 028 P
Component: BSG-HP1-65 H18 0527
Serial number: 16012300030287
Coding: 20000400000000
Shop #: WSC 04152 004 1048576
ASAM Dataset: EV_Start48VAU651 002007
ROD: EV_Start48VAU651_002.rod
Address CD: Laser Scanner (J1122) Labels: None
Part No SW: 4K8 907 660 C HW: 4N0 907 660
Component: LASER_SCANNER H36 0205
Dataset Number: 4K8909639K 0005
ASAM Dataset: EV_LaserScannAU651 013017
ROD: EV_LaserScannAU651_013.rod
VCID: 363E499988B3C0AABDF-8162
Address CF: Lane Chge Asst 2 (J770) Labels:* None
Component: MRR_HL H12 0265
Dataset Number: 4K8909468D 0020
Coding: 0FDC00
ASAM Dataset: EV_RearRadarS2DelphAU651 001018
ROD: EV_RearRadarS2DelphAU651.rod
Address D6: Light Ctrl Left 2 Labels:
VCID: 55FCEE153C05EBB2545-8000
Part No SW: 4K0 941 592 AC HW: 4K0 941 592 A
Component: LMS_MLBevo H11 0030
Dataset Number: 4K0909472L 0021
ROD: EV_LMSRightHELLAAU58X_AU58.rod
VCID: 71B4BA85A12DA792A8D-8024
Address DB: Frt Corner Rdar 1 (J1089) Labels:* None
Part No SW: 4N0 907 669 E HW: 4N0 907 669 A
Component: MRR_VR H12 0265
Dataset Number: 4K8909482C 0017
Coding: 001000
ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
ROD: EV_FrontCorneRadarS1AU651.rod
Address DC: Frt Corner Rdar 2 (J1088) Labels:* None
Component: MRR_VL H12 0265
Dataset Number: 4K8909483C 0018
Coding: 001000
ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
ROD: EV_FrontCorneRadarS2AU651.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:| 4N0-035-502.clb
Part No SW: 4K0 035 502 A HW: 4K0 035 502 A
Component: WLC Front H10 0061
Coding: 800000
ROD: EV_Charg1MobilDevicAU651_004_VW53.rod
VCID: 1F108C3D074961E24E9-814A
End----------(Elapsed Time: 04:05, VBatt start/end: 12.7V/12.2V)-----------
;SW:4N0-915-105-B HW:4N0-915-105-B --- Battery Regul.
;Component:BMS_48V_LiIon H06 0108 Coding:
;EV_BMS48VLiIonLGAU536 1001 EV_BMS48VLiIonLGAU536_AU58.rod
;Wednesday 19 June 2024
;VCDS Version: Release 24.5.0 (x64) Data version: 20240429 DS355.0
;VCID: 290492E5490D9F5220D-817C
Group Description Actual
IDE00019 Voltage terminal 30 12.5 V
IDE00021 Engine RPM 0 /min
IDE00025 Coolant temperature 100 °C
IDE00056 History data 1 30
IDE00056 History data 1 ||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 03 E6 28|00 00 00 00|00 00 00 00|00 03 A3 5B|00 00 0E 6F|00 09 1C 18|01 36 7B 96|00 00 F4 3A|00 00 00 00|00 00 21 6D|00 02 FA F1|00 74 0C D5|07 49 C1 07|00 07 1B 6A|00 00 00 00|00 00 00 00|00 07 EB 50|00 04 FB 1D|00 53 74 78|00 00 62 5F|00 00 00 00|00 00 00 00|00 00 00 00|00 00 0A CA|00 00 C3 7A|00 00 02 99|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|
IDE00056 History data 1 0
IDE00057 History data 2 ||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 2C 7F|00 00 02 83|00 00 01 64|00 00 00 6E|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 04 EF F5|00 00 B0 85|00 00 4D 2D|00 00 72 CA|00 00 2F 53|00 00 00 00|00 00 00 00|00 00 00 00|00 45 F6 0F|00 15 78 77|00 0B 0F 21|00 14 2D 06|00 08 91 F7|00 00 00 00|00 00 00 00|00 00 00 00|00 21 05 0B|00 0E A8 2B|00 06 2D D7|00 0B CE 19|00 03 8B C0|00 00 00 00|00 00 00 00|00 00 00 00|00 05 B5 A2|00 03 82 09|00 01 39 89|00 00 B2 50|00 00 07 7C|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|
IDE00057 History data 2 0
IDE00058 History data 3 40
IDE00058 History data 3 8
IDE00058 History data 3 ||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 40 56|00 00 00 DF|00 00 00 28|00 00 00 05|00 00 00 43|00 00 00 17|00 00 00 00|00 00 00 00|00 0B 1E 23|00 00 3B A0|00 00 18 0E|00 00 1F DF|00 00 11 16|00 00 00 C0|00 00 00 00|00 00 00 00|01 88 FB 86|00 06 9E 64|00 04 5A 1C|00 06 2E CC|00 01 D2 C2|00 00 14 E7|00 00 00 00|00 00 00 00|00 E0 90 72|00 03 E7 F4|00 02 C4 21|00 04 0A 64|00 00 F9 8D|00 00 09 25|00 00 00 00|00 00 00 00|00 19 10 3C|00 00 C6 DF|00 00 88 F9|00 00 48 D7|00 00 07 05|00 00 00 1D|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|
IDE00058 History data 3 0
IDE00060 History data 5 6
IDE00060 History data 5 ||00 00 1D 7C|00 00 54 36|00 0E 60 FF|00 5E AA 52|00 01 82 03|00 00 00 00|
IDE00061 History data 6 2
IDE00061 History data 6 0A
IDE00061 History data 6 14
IDE00061 History data 6 ||00 03 DA 92|00 00 77 7E|00 00 5B AB|00 00 0C DA|00 00 01 68|00 00 00 31|00 00 00 28|00 00 00 00|00 00 00 00|00 00 00 00|00 04 0E D6|00 00 65 B6|00 00 4F B5|00 00 11 75|00 00 01 F7|00 00 00 4E|00 00 00 28|00 00 00 04|00 00 00 02|00 00 00 00|
IDE00064 History data 9 ||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 25 98|00 00 25 98|00 00 25 98|00 00 25 94|00 00 25 98|
IDE00064 History data 9 0
IDE00065 History data 10 0A
IDE00065 History data 10 ||00 46 38 5C|00 26 E0 14|00 01 E6 96|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|
IDE00066 History data 11 8
IDE00066 History data 11 2
IDE00066 History data 11 ||00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 09|00 00|00 00|00 00|
IDE00066 History data 11 0
IDE00067 History data 12 ||00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|
IDE00067 History data 12 0
IDE00068 History data 13 8
IDE00068 History data 13 ||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|
IDE00069 History data 14 ||6E|6D|6E|6C|6D|6D|6E|6C|6D|6E|6D|6E|70|
IDE00069 History data 14 70 00
IDE00069 History data 14 00 00
IDE00070 History data 15 00 28
IDE00070 History data 15 1
IDE00070 History data 15 ||C0|C2|C2|C2|C2|C2|C2|C0|BE|BE|BC|BA|BA|BA|B8|B8|B6|B6|B6|B6|B4|B4|B4|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|
IDE00071 History data 16 ||00 5A|00 5A|00 5B|00 5B|00 5B|00 5B|00 5A|00 5C|00 5B|00 5B|00 5B|00 5B|00 5B|
IDE00071 History data 16 5B 00
IDE00071 History data 16 0
IDE00071 History data 16 00 00
IDE00075 Vehicle speed 0 km/h
IDE00085 Normed load value 0 %
IDE00086 Accelerator pedal position 14.9 %
IDE00322 Status of basic setting not active
IDE00323 Security Access: Number of invalid keys 0
IDE00445 Unlearning counter according OBD 255
IDE00556 Outside temperature 29 °C
IDE00601 Monitoring status since erasing DTC memory
IDE00602 Monitoring status in current driving cycle
IDE00773 Terminal 15 status via CAN On
IDE00961-MAS05695 Malfunction Indicator Lamp-Start request not active
IDE01021 Current of H-V / hybrid battery 0 A
IDE01028-MAS01422 Coolant temperature of H-V / hybrid battery-Intake 36 °C
IDE01028-MAS01423 Coolant temperature of H-V / hybrid battery-Exhaust 36 °C
IDE01718 Crash signal not active
IDE01803 History data 17 ||1D 94|00 01|00 01|00 00|
IDE01803 History data 17 0
IDE01804 History data 18 4
IDE01804 History data 18 ||01 07 C0 D7|00 07 3D D9|01 08 4F 4E|00 0A F6 AB|
IDE01805 History data 19 5
IDE01805 History data 19 ||00 FC 99 09|00 F1 CE D8|00 0A 61 CF|00 00 65 5F|00 00 03 03|
IDE01806 History data 20 ||00 21 A4 3D|00 01 B2 81|00 1E DD 7A|00 01 0F 83|00 00 04 BF|
IDE01806 History data 20 0
IDE01838 Battery temperature 36 °C
IDE01839 Battery charge level 54 %
IDE04006 Drive battery remaining runtime 53.7 %
IDE06346 H-V battery voltage 48 V
IDE06422 IUMPR_1 0
IDE06422 IUMPR_1 7516
IDE06422 IUMPR_1 6766 km
IDE06422 IUMPR_1 1766
IDE06673 Initialization status not active
IDE06948 High-volt. battery mode: spec. value Driving mode
IDE06973 Power reduction status not active
IDE07044-MAS01420 Predictive limit for charge current-Limit for charge current 80 A
IDE07045-MAS01420 Dynamic limit for charge current-Limit for charge current 200 A
IDE07227-IDE01024 Voltage in H-V system-Voltage of hybrid battery after protection 48 V
IDE07341 H-V battery: nominal capacity 9.1 Ah
IDE08215 Current 2 of H-V / hybrid battery -0.2 A
IDE08217-MAS01234 maximum voltage for battery cells-Index 1 13
IDE08217-MAS02985 maximum voltage for battery cells-Value 3.71 V
IDE08218-MAS01234 minimum voltage for battery cells-Index 1 8
IDE08218-MAS02985 minimum voltage for battery cells-Value 3.69 V
IDE08230-MAS01421 Dynamic limit for discharge current-Limit for discharge current 300 A
IDE08231-MAS01421 Predictive limit for discharge current-Limit for discharge current 80 A
IDE10320-MAS01146 Workshop code and date of last reset of crash shutdown-Workshop code 00 01 01 00 00 00
IDE10320-MAS01230 Workshop code and date of last reset of crash shutdown-Date 00 00 00
IDE11799 Minimum discharge voltage 39 V
IDE11801 Maximum charging voltage 54 V
IDE11802 Minimum predictive charging voltage 50 V
IDE11803 Minimum predictive discharge voltage 45.9 V
IDE11804 Minimum dynamic charging voltage 51.5 V
IDE11805 Minimum dynamic discharge voltage 42.6 V
MAS01302 Protection of posit. terminal of high voltage / hybrid battery closed
MAS04266 Temperature sensor 1 36 °C
MAS04267 Temperature sensor 2 38 °C
MAS04649 Cell 1 3.69 V
MAS04650 Cell 2 3.69 V
MAS04651 Cell 3 3.69 V
MAS04652 Cell 4 3.69 V
MAS04653 Cell 5 3.69 V
MAS04654 Cell 6 3.69 V
MAS04655 Cell 7 3.7 V
MAS04656 Cell 8 3.69 V
MAS04657 Cell 9 3.69 V
MAS04658 Cell 10 3.7 V
MAS04659 Cell 11 3.7 V
MAS04660 Cell 12 3.69 V
MAS04661 Cell 13 3.71 V
MAS04721-MAS01234 Minimum charge level-Index 1 8
MAS04721-MAS02985 Minimum charge level-Value 52 %
MAS04722-MAS01234 Maximum charge level-Index 1 13
MAS04722-MAS02985 Maximum charge level-Value 55 %
MAS06761 Sum of voltage of all battery cells 48.04 V
MAS07827 Mode HV battery actual value Driving mode
ENG101413 Calibration Identification ||4M0105 0108 |
ENG99697 Calibration Verification Numbers ||6D BC 13 8A|
ENG102274 Control Module Voltage 12.501 V
ENG100152 ECUNAME |ECU ECUNAME|BECM
I finally found what I was looking for, and after letting the car sit for a couple days, here's the results. It does appear that I need a new 12V battery.
