Hi..
Have an issue.
My car is a audi q5 with xenon before facelift
For mounting FLA in my audi Q5 I had to change the diagnose interface at Address 19 from canbus-low(4 channels) to canbus-high( 5channels).
Everything about changing the module went well. The audi-partner removed the component protection and coded the interface Again with same codes as the old one. The problem is now, that I cannot access address 55, headlight range module any more. No fault codes are coming in any module.
In the installation list address 55 is listed. if I remove I get errors at address 09 and address 55 says then not installed.
What can be the case - everything seems to be ok. I have attached a "scan" with the "old" canbus before change and one with the new canbus after change.
Is the the new diagnoseinterface faulty? or what do you think?. Could the audipartner has missed out something?
I have read in this forum that newer facelift cars do not have address 55 at all.
BEfore changing the canbus( scan is a bit old - last saved but performed also before changing and the result was the same as below.:
AFter changing the canbus
thanks
Have an issue.
Sunday,28,December,2014,14:42:20:28804
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: WAUZZZ8R5CA059884 License Plate: AR87965
Mileage: 81500km-50641mi Repair Order:
Chassis Type: 8R (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 55 56 5F 62 69 72
VIN: WAUZZZ8R5CA059884 Mileage: 81500km-50641miles
Address 01: Engine (J623-CJCA) Labels: 03L-906-018-CGL.clb
Part No SW: 03L 906 018 DG HW: 03L 906 018 DN
Component: R4 2,0L EDC H25 7795
Revision: 45H25---
Coding: 2A194012043403080000
ASAM Dataset: EV_ECM20TDI01103L906018DG 003005
ROD: EV_ECM20TDI01103L906018DG.rod
VCID: 72E1FB63A5DFA5B169F-8027
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 8R0 907 379 J HW: 8R0 907 379 J
Component: ESP8 front H07 0110
Coding: 119544
VCID: 47977AB7F6DD7019EE1-8012
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 EE HW: 8K0 907 064 EE
Component: BCM2 2.0 H10 0530
Coding: 03A54000000000000000
Shop #: WSC 06335 000 00000
VCID: 77F7CA77C6BDC0995E1-8022
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H60 0072
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H39 0046
Part No SW: 8T1 820 043 AH HW: 8T1 820 043 AH
Component: KLIMA 1 ZONE H08 0180
Revision: A1000000 Serial number: 01061120112119
Coding: 34310000
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000001289339
Coding: 2600D0914034AF010001000300001D0D0F1C070806010101000000
Shop #: WSC 06335 123 12345
VCID: 3C7D155BBF1B23C1733-8069
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 111025 H11 0050
Coding: 01DD13
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 024D25
Component: E1 - LDS H03 0031
Address 15: Airbags (J234) Labels: 8R0-959-655.clb
Part No SW: 8R0 959 655 G HW: 8R0 959 655 G
Component: AirbagVW-AU10 H44 0610
Serial number: 003JPD0BBZJ7
Coding: 30463331313030303030554A304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 4895798BF3C37F61E7B-801D
Serial number: 6334MSME6541655BG
Serial number: 6344MSME663325717
Serial number: 6352QSME3E5E3548X
Serial number: 6362QSME6D5E045E$
Serial number: 63732SME7C621E604
Serial number: 63832SME7C624640+
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KJQ0018I
Coding: 000017
VCID: 3D7B185FA4012AC944D-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
Part No SW: 8R0 920 931 B HW: 8R0 920 931 B
Component: KOMBIINSTR. H22 0258
Revision: 00000000 Serial number: EK17176CC
Coding: 0F04220002000008010000
VCID: 346D3D7B974BEB81BB3-8061
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AH HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0120
Revision: EC101057 Serial number: 5700E11A240526
Coding: 00CF07
VCID: 0717BAB7B65DB0192E1-8052
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 M HW: 8K0 959 793 M
Component: TSG FA H12 0357
Revision: Serial number: 0000121716778
Coding: 011D02204000440004
VCID: 4A914383E5CF8D71F1F-801F
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0162669553
Coding: 0100062020B904408520053680000000
03073 - Rear Lid Closed Sensor 1
Fault Frequency: 44
Reset counter: 88
Mileage: 78498 km
Date: 2014.11.22
Time: 12:33:08
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 M HW: 8K0 959 792 M
Component: TSG BF H12 0357
Revision: Serial number: 0000017481555
VCID: 49937C8FE0C98669F85-801C
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 20000000139685
Address 55: Headlight Range (J431) Labels: None
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 111104-0002-240
Coding: 1197961010020300
ROD: EV_HeadlRegulBasic.rod
VCID: 2D5B281F7C61BA49F4D-8078
Part No SW: 4G1 035 053 D HW: 4G1 035 053
Component: Radio U Basic H41 0094
Revision: AB001007 Serial number: 226KR0B7505020
Coding: 010003020100000001
VCID: 2045C12B33B367214FB-8075
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 652 H HW: 8T1 035 652 D
Component: B-BN-EU H62 0175
Revision: -------- Serial number: 323KU0B7701451
Coding: 01010006000581EC01000B0C000000030000
VCID: 3A711343B52F1DF161F-806F
Subsystem 1 - Part No: 4G0 919 884 N
Component: EUR 2014 1702
Subsystem 2 - Part No SW: 8T0 919 604 HW: 8T0 919 604
Component: DU6 Basic H42 0098
Subsystem 3 - Part No SW: 8T0 919 609 HW: 8T0 919 609
Component: E0380 Bedient H08 0100
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 F HW: 8K0 959 795 F
Component: TSG HL H11 0357
Revision: Serial number: 0000017760288
Coding: 010C02204000240004
VCID: 458B70BFCCD162091CD-8010
Address 69: Trailer (J345) Labels: 8K0-907-383.clb
Part No SW: 8K0 907 383 D HW: 8K0 907 383 D
Component: Anhaenger H09 0100
Revision: 1G001001 Serial number: 00000193473308
Coding: 0100000000000000
VCID: 356B007F9C31F2898CD-8060
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H11 0357
Revision: Serial number: 0000017761332
End-------------------------(Elapsed Time: 03:05)--------------------------
Thursday,22,October,2015,21:43:36:28804
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 15.7.1.0
Data version: 20150904
Mileage: 107550km-66828mi Repair Order:
Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 55 56 5F 62 69 6C 72
VIN: WAUZZZ8R5CA059884 Mileage: 107550km-66828miles
Revision: 45H25---
Shop #: WSC 00068 204 00001
VCID: 72E1FB63A5DFA5AE5B-8026
Coding: 119544
VCID: 47977AB7F6DD7006DC-8012
VCID: 77F7CA77C6BDC0866C-8022
Coding: 34310000
VCID: 3C7D155BBF1B23DE41-8068
Coding: 01DD13
Coding: 024D25
VCID: 4895798BF3C37F7ED5-801C
Coding: 000017
VCID: 3D7B185FA4012AD676-8068
VCID: 346D3D7B974BEB9E89-8060
Part No SW: 8T0 907 468 AE HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0117
Revision: FB900055 Serial number: 5500F09B2701AF
Coding: 00CF07
VCID: 040DADBB876B9B1E79-8050
VCID: 4A914383E5CF8D6EC3-801E
VCID: 49937C8FE0C98676CA-801C
VCID: 2045C12B33B3673E7D-8074
Coding: 01010006000581EE01000B0C000000030000
VCID: 3A711343B52F1DEE53-806E
VCID: 458B70BFCCD162162E-8010
VCID: 356B007F9C31F296BE-8060
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H09--- Serial number: 525PA8-J4XA1T0
Coding: 1000110
VCID: 346D3D7B574BEB9E89-8060
03006 - Back-up Camera System not calibrated
Reset counter: 216
End-------------------------(Elapsed Time: 03:02)--------------------------
thanks
