Hi everyone.
Last time my neighbour ask me if it is possible to retrofit the OEM Power tailgate set for Octavia 3 MQB Estate.
I just made 4 times that kind of retrofits in Skoda Superb Estate, and as I can see the wiring diagrams looks almost the same in MQB platform.
The difference is that electric "hook" (don't know how to call it in eng.) is now connected to the Power Lid ECU, but before it was connected to the CECM.
In Superb's I was need to use VAS or Odis tool to code and adapt the CECM to get it working.
Now, I would like to help my friend - the work to be done looks easy as usual, but I'm not sure what's about component protection.
I know, that OEM xenon kits, OEM High Beam Assistants are accepted by High Gateway and suppose the same of the Power Lid ECU.
Let me know Your's opinions. I will try it anyway - the part's prices are piece of cake, but would like to know if somebody tried it before.
Bolow pro-forma autoscan, done loooooooooooooong time ago. No necessary to scan it every day.
Monday,26,May,2014,20:17:05:24735
VCDS Version: 14.5.2.0
Data version: 20140520
Dealer/Shop Name: Enriquez
Workshop Code: 790 33361 000001
VIN: TMBLD9NE6E00XXXXXX License Plate: ELWXXXXX
Mileage: 9316km-5788mi Repair Order: Piotr
Chassis Type: NE (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 42 44 52 55 5F
VIN: TMBLD9NE6E0064545 Mileage: 9316km-5788miles
Address 01: Engine (J623-CJSB) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 264 B HW: 06K 907 425 A
Component: 1.8l R4 TFSI H09 0002
Revision: --H09---
Coding: 0C9D00322426010B0000
Shop #: WSC 73430 031 00104
ASAM Dataset: EV_ECM18TFS0218V0906264B 001002
ROD: EV_ECM18TFS0218V0906264_SK37.rod
VCID: 3B5BF8E7B2053FE3AE-806E
Part No SW: 0D9 300 011 L HW: 02E 927 770 AN
Component: DQ250-6A MQB H52 4029
Revision: 05652104 Serial number: TFK01308150182
ROD: EV_TCMDQ250021_SK37.rod
VCID: 1E1D117301D74ACBA9-804B
P1734 00 [002] - -
Fault Status: 00000010
Fault Frequency: 0
Reset counter: 0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 62483000000463
Coding: 1C076A9134262970007C070441C82938562C9400E08294F0004100004009
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_SE37.rod
VCID: 4BBBA827E2A58F631E-801E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5E0 907 044 HW: 5E0 907 044
Component: Climatronic H02 0604
Revision: 00001K06
Coding: 02010004000100011005004000100000
Shop #: WSC 33361 790 00001
ASAM Dataset: EV_ACClimaBHBVW37X 002017
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 62E56583752F2E2BCD-8037
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011324600116
Coding: 0C001B42C24722FB07A04082B10C07280008000000000000000000000000
Shop #: WSC 73430 790 00104
ROD: EV_BCMBOSCH_SK37.rod
VCID: 77D324D7CEADDB838A-8022
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119
Component: WWS371 130824 041 0570
Serial number: 130830102852
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M08D21H06M46S49S1
Coding: 02805D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY13169088D
Serial number: 00000000000027690253
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H02 0033
Revision: -------- Serial number: 94231324904406
Coding: 0031051051
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_EPHVA18AU3700000 002019
ROD: EV_EPHVA18AU3700000_AU37.rod
Part No SW: 3Q0 959 655 AB HW: 3Q0 959 655 AB
Component: Airbag VW20 011 0188
Revision: -------- Serial number: 003P3PB0SMG4
Coding: 98FCC000000000005C5400CC000800000065
ROD: EV_AirbaVW20TS6VW48X_SK37.rod
VCID: 7EDD31F3E197EACBC9-802B
Subsystem 1 - Part No SW: ----------- HW: 454 003 008 13
Serial number: 3576U0000001B8481D0B
Subsystem 2 - Part No SW: ----------- HW: 454 003 008 13
Serial number: 3586U0000001F8481D0G
Subsystem 3 - Part No SW: ----------- HW: 454 802 708 13
Component: SideSensor_Dr 111 0148
Serial number: 3516R6668D9010000005
Subsystem 4 - Part No SW: ----------- HW: 454 803 008 13
Component: SideSensor_Pr 111 0148
Serial number: 3526RC6FB9501000000G
Subsystem 5 - Part No SW: ----------- HW: 454 802 008 13
Component: FrontSensor_D 114 0149
Serial number: 3556V8281E3010000001
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AJ HW: 5Q0 953 549 A
Revision: -------- Serial number: 09091308491230
Coding: 1400
ROD: EV_SMLSKLOMQB_SE37.rod
Part No SW: 5E0 920 871 B HW: 5E0 920 871 B
Component: KOMBI 333 2210
Coding: 07A40808A880000801082A00000000
ROD: EV_DashBoardVDDMQBAB_SK37.rod
VCID: 277334975E8D8B03DA-8072
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0000982274
Coding: 030100042B085800EF00024A1C0F00010001000000000000000000000000
ROD: EV_GatewLear_AU37.rod
Subsystem 2 - Part No SW: 5E0 919 719 B HW: 5E0 919 719 B
Component: E221__MFL-PR6 H04 0120
Serial number: 000000000A0051230813
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 6143661303
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 5G0 857 511 D HW: 5G0 857 511
Component: FLA H04 0002
Revision: AA001001
Coding: 02018F6B76765D525220343E01
ASAM Dataset: EV_HighBeamAssisAU37X 001009
ROD: EV_HighBeamAssisAU37X.rod
VCID: 2B7BC8A74265AF633E-807E
Part No SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000074523389
Coding: 00150020D000020000001100
ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
VCID: 02254503956F8E2BAD-8057
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Component: FOND_FHSG_DRV 005 0004
Serial number: 00000000000000482234
Coding: 010200
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 M
Component: EPS_MQB_ZFLS 127 1021
Coding: 81
ROD: EV_SteerAssisMQB.rod
VCID: 3D5FF6FFAC1131D390-8068
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000074254926
ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
VCID: 01274A0F90699533B4-8054
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Component: FOND_FHSG_PSG 005 0004
Serial number: 00000000000000625150
Coding: 190200
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 03EA02003F000000
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B
Component: LeiMo links H06 0009
Coding: 3E0000
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B
Component: LeiMo rechts H06 0009
Coding: 3E0000
Part No SW: 5E0 035 819 A HW: 5E0 035 819 A
Component: MU-S--ER 040 0421
Serial number: S1C01109131691
Coding: 03730200FF00000011110001000000002F0000840100010000
ROD: EV_MUStd4CPASE_SE37.rod
VCID: 256F3E9F24819913E8-8070
Media Player Position 1:
Subsystem 1 - Part No SW: 5E0 919 605 HW: 5E0 919 605
Component: ABT_Std_Radio H50 0022
Serial number: SKZ8Z9NL2006M0
End-------------------------(Elapsed Time: 03:06)--------------------------
