- Nov 9, 2022
- 1,669
- 848
- ON, Canada
- C?ID=568688
I was logging tranny temps yesterday, and noticed my rpm was about 1/4 of actual... found this really weird, as I'm sure I've logged this value in this controller previously (on prior VCDS builds) and it was correct.
I'll try to dig up a prior scan with said correct value if useful.....
Is it possible that there's a bug in the current version which would report the same IDE differently across various controllers?
Very weird
Engine controller = correct
Tranny controller = 1/4 value
Autoscan
Very weird
Wednesday,12,June,2024,18:20:46:38535
VCDS Version: 24.5.0.0
VIN: WVGEP9BPXED013866 License Plate: ENGINE
Address 01: Engine (7P0 907 401 K)
18:20:38
IDE00021 Engine RPM 759 /min
IDE00025 Coolant temperature 90 °C
IDE00192 Coolant temperature at radiator outlet: actual value 43.2 °C
IDE00196 Engine oil temperature 94.3 °C
IDE03582 Temperature sensor for engine temperature management 102.7 °C
Wednesday,12,June,2024,18:22:24:38535
VIN: WVGEP9BPXED013866 License Plate: TRANS
Address 02: Auto Trans (0C8 927 750 CF)
18:22:19
IDE00021 Engine RPM 190 /min
IDE00024 ATF temperature 88 °C
IDE00025-ENG104170 Coolant temperature-Coolant Temperature VW526 88.50 °C
Autoscan
Wednesday,12,June,2024,12:29:27:38535
VIN: WVGEP9BPXED013866 License Plate: TOUAREG
Mileage: 207107km-128690mi Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
62 65 69 6C 6D 72
VIN: WVGEP9BPXED013866 Mileage: 207107km-128690miles
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 K HW: 7P0 907 401 K
Component: 3.0TDI FSA H21 0011
Revision: 56H21--- CVN: E7FCBDE438D3FF82755A21130E1FC39E
Coding: 292A4012233600050000
Shop #: WSC 93288 999 00000
ASAM Dataset: EV_ECM30TDI0117P0907401K 001012
ROD: EV_ECM30TDI0117P0907401K.rod
VCID: B777000D0EDB832E32-80E2
VINID: 9E65D58094A0A1550004320618BB2177C4
22838 - Particulate Filter (Bank 1)
P226D 00 [01100101] - Damaged or Substrate Missing
Mileage: 207097 km
Date: 2024.06.12
Time: 05:50:20
Engine RPM: 1408.00 /min
Normed load value: 67.1 %
Vehicle speed: 86 km/h
Coolant temperature: 92 °C
Intake air temperature: 16 °C
Voltage terminal 30: 14.580 V
Engine status: COENG_RUNNING
29012 - Particulate Filter (Bank 1)
P226D 00 [11101101] - Damaged or Substrate Missing
Mileage: 207075 km
Date: 2024.06.11
Time: 17:12:50
Engine RPM: 1419.00 /min
Normed load value: 70.2 %
Vehicle speed: 9 km/h
Coolant temperature: 89 °C
Intake air temperature: 30 °C
Voltage terminal 30: 14.540 V
Particle filter: soot mass measured: 20.04 g
Particle filter: soot mass calculated: 22.26 g
Particle sensor: soot volume in exhaust: 0.47 mg/m³
Particle sensor: exhaust temperature: 240.0 °C
Particle sensor: cleaning deviation reaction time: 0.374
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217) Labels:| 0C8-927-7XX-V1.clb
Part No SW: 0C8 927 750 CF HW: 0C8 927 750 CF
Component: AL1000 AISIN 002 3376
Serial number: CVN: 187C4FCF
Coding: 00B168
Shop #: WSC 47391 001 104857
ASAM Dataset: EV_TCMAL991031 002115
ROD: EV_TCMAL991031_002_VW52.rod
VCID: F2E1F11925392606C5-80A6
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 P HW: 7P0 907 379 A
Component: MK25A H36 0446
Revision: -------- Serial number: 408840010EC818 Dataset Number: 7P0012v____ 0001
Coding: 5B7613C349252556DAFCC89992D8A4407300
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 008001
ROD: EV_ESPMK25A00800.rod
VCID: CA9149F96D290EC65D-809E
Part No SW: 4H0 907 064 FK HW: 4H0 907 064 EK
Component: BCM2 2.0 H36 0551
Coding: 0D860000000000000000
Shop #: WSC 63086 001 1048576
VCID: F7F7C00D465B432EF2-80A2
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Serial number: 0213000390009010
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BR HW: 7P6 907 040 BR
Component: Klima 2 Zonen H21 1306
Coding: B686000A80
VCID: 850BBAC504B721BEF0-80D0
Part No SW: 4H0 907 063 CD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0130
Revision: 15012002 Serial number: 00000001883690
Coding: 26001012D63C5D010020180780005D0C431C660882010261800000020000
VCID: ECDDEF610F1DF0F60F-80B8
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 140423 033 0021
Serial number: 90243400140508230309
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20317072
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Serial number: 00000000002005140341
Component: USHL4.2 H30 0030
Serial number: 0000002274555RB6ZK03
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA108664000005784112
Coding: 010300
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 C HW: 7N0 919 475
Component: PARKHILFE 8K H05 0026
Revision: -------- Serial number: 28231413800002
Coding: 318501
ASAM Dataset: EV_VW526ParkiAssis2 001012
ROD: EV_VW526ParkiAssis2.rod
VCID: C38F64DD4A03DF8E9E-8096
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 E HW: 7P0 959 655 E
Component: VW10Airbag02B H10 0043
Revision: -------- Serial number: 003NK00015FO Dataset Number: 7P6003V____ 1547
Coding: 000000000000000000000000000000003242
ASAM Dataset: EV_AirbaVW10BPAVW526 002001
ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R143040JLC8
Serial number: 3575LRB40572B5M689OA
Serial number: 3585LRB401C50OF8B941
Serial number: 3517ARB40652KQAOP8G
Serial number: 3527ARB40652KQAOOPLH
Serial number: 3557BRB401C50QDH8SAL
Serial number: 3567BRB401C50QLON3L
Part No SW: 4H0 953 568 H HW: 7P6 953 507 M
Revision: -------- Serial number: 01335NEE000P2
Coding: 000C15
VCID: B87503310BC58C563B-80EC
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0047512 TRW 20140421
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 882 M HW: 7P6 920 882 M
Component: Kombi H13 0419
Revision: 13240270 Serial number: 658210514592010
Coding: 0B3733012B000008020004
ASAM Dataset: EV_KombiUDSRBVW526 001020
ROD: EV_KombiUDSRBVW526_VW52.rod
VCID: C79770CD7E3BF3AE42-8092
Part No SW: 7P6 907 530 J HW: 7P6 907 530 F
Component: GW-CAN-L-MOST H13 6032
Revision: -------- Serial number: 00000001394142 Dataset Number: 7P6067v____ 0040
Coding: 000103AD00
GVL: FB4F40455D7F000000
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
VCID: BF87682D26EBBB6EFA-80EA
Subsystem 1 - Part No SW: 7P0 915 181 B HW: 7P0 915 181
Component: Batt_Sensor H07 0190
Serial number: 41128155225701197223
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000099669702
Coding: 00581B0000004001000001010101202020202121202020
VCID: B46D370117AD683617-80E0
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H02 0306
Revision: -------- Serial number: 0000102810077
Coding: 011D17205E00453005080000
VCID: FAF1D93975495E468D-80AE
Revision: 00002001 Serial number: 0335488971
Coding: 0186163A68B9509580A00620210A08000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Serial number: 1361424141
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.055 H01 0008
Serial number: WOO29327928
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.055 H01 0008
Serial number: WOO29447628
Coding: 191100
Subsystem 5 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 93222408
Part No SW: 7P6 035 466 HW: 7P6 035 466
Component: DSP Prem H01 0090
Revision: 00001001 Serial number: 10811003178507
VCID: F5EBCA055C57313EE0-80A0
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000102860422
VCID: C89573F17B25FCD64B-809C
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1451300316 Dataset Number: A001
Coding: 01040200
ROD: EV_ParkbA7.rod
VCID: B6690D0909D17A2629-80E2
Slave 3:
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Revision: -------- Serial number: -------------- Dataset Number: 7P0036v____ 0010
Coding: 010A00010F000400
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
VCID: FCFDDF21777D60769F-80A8
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0003
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0003
Coding: 130000
Revision: AB001007 Serial number: 156E.0E8010399
Coding: 020007010000000001
VCID: A44DC741A74DF8B687-80F0
Part No SW: 7P6 035 664 F HW: 7P6 035 664 A
Component: H-BN-NA H40 0821
Revision: -------- Serial number: 273ET0EB001901
Coding: 020200050040E1EF41022B0E00000003F00001030000000000
VCID: BB7F1C3D3AF3A74ED6-80EE
Subsystem 1 - Part No: 7P6 060 884 J
Component: NAR 2017/2018 1602
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H27 0045
Serial number: VWZ8Z9PA3007YZ
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: CD-Database 5950
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H03 0306
Revision: -------- Serial number: 0000103045387
Coding: 011817200000253005080000
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 K HW: 7P6 907 273 K
Component: RDKBERU25 H09 0009
Serial number: 10000000130690 Dataset Number: 7P6096v____ 0022
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
VCID: C48D67C14F0DD8B6A7-8090
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 7P0 907 383 F HW: 7P0 907 383 B
Component: Anhaenger H11 0110
Revision: 5A001001 Serial number: 00008200376188
Coding: 020D000000000000
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H08000 Serial number: 525 PA8J442396
Coding: 0130001
VCID: B777000DC6DB832E32-80E2
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 131400152 Dataset Number: 7P6959107C D045
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
Component: TSG HR H03 0306
Revision: -------- Serial number: 0000102895888
End-------------------------(Elapsed Time: 05:58)--------------------------
