A fuse blew, and now VCDS cannot connect to Module 03
2stroke
Sweden
C?ID=200316
:) Hello !
Car: ( 2012 ) Skoda Octavia-2 FL -----> same architecture as VW Golf-6
Car info: 6-speed manual gearbox and 4-motion ( Haldex-4 )
Yesterday Sunday morning the car was driven and everything worked as usual.
After about 3 hours I was going to leave again and then suddenly the instrument cluster was completely black and nothing in the instrument cluster worked.
Tried to start the engine, but it died immediately after about 2 seconds.
Tried a couple more times but each time the engine started and ran for about 2 seconds and then died.
( felt roughly like the immobilizer came into play. )
After looking at the fuses I found that fuse # 6 was blown.
( Has never happened before )
With a new fuse, the instrument cluster started working and the car could be started and worked :thumbs: perfectly.
...Today when I did a fault code reading with VCDS to see which error codes were left,
I discovered that in Module-03 there were error codes,
but when I tried to delete them, VCDS could not communicate with that module....
I tried several times to delete the error codes but it is not possible
to delete the errors as VCDS replies that it cannot communicate with Modul-03
:confused: What is going on and why can't VCDS communicate with Module-03 ? :confused:
FUSE # 6. ( 5 Ampere )
Instrument cluster, Control unit for automatic gearbox,
Control unit for electromechanical power steering, Parking aid, Haldex clutch.
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: TMBKK61Z3C2064867   License Plate:
Mileage: 191510 km       Repair Order:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 52 55 56 62 69 72
VIN: TMBKK61Z3C2064867   Mileage: 191510 km
   Revision: 00H31001
   Coding: 113B401C0A2800FE881302EA50200041310000
   Shop #: WSC 73430 790 00083
   VCID: 7BA3F0FAA3E70BB27A1-802E
7 Faults Found:
01324 - Control Module for All Wheel Drive (J492)
                    Reset counter: 157
                    Mileage: 191453 km
                    Date: 2018.11.01
                    Time: 14:51:28
                    Count: 32768
                    Count: 4608
                    Count: 8202
                    Count: 50944
                    Count: 1
                    Count: 1793
                    Reset counter: 157
                    Count: 16384
                    Count: 12
                    Count: 12800
                    Count: 8213
                    Count: 43776
                    Count: 1279
                    Reset counter: 157
                    Count: 16386
                    Count: 12
                    Count: 12800
                    Count: 8208
                    Count: 44032
                    Count: 1535
03391 - Coding Not Possible
                    Reset counter: 157
                    Count: 2
                    Count: 12
                    Count: 12288
                    Count: 8254
                    Count: 44544
                    Count: 1279
                    Reset counter: 157
                    Count: 2
                    Count: 12
                    Count: 12288
                    Count: 8211
                    Count: 44544
                    Count: 1279
                    Reset counter: 157
                    Count: 2
                    Count: 12
                    Count: 12288
                    Count: 8233
                    Count: 44544
                    Count: 1279
                    Reset counter: 158
                    Count: 16386
                    Count: 12
                    Count: 12800
                    Count: 166
                    Count: 44032
                    Count: 1279
   Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
   Component: BOLERO        010 0061
   Revision: 0A001001    Serial number: SKZ1Z3L9543733
   Coding: 0F0004000001
   VCID: 353726C2C5431DC2CC5-8060
00857 - CD Changer Unit (R41)
                    Reset counter: 121
                    Mileage: 191510 km
                    Date: 2018.11.01
                    Time: 18:55:16
End---------- ( Elapsed Time: 01:12, VBatt start/end: 14.2V/14.1V ) -----------
Jef
HQ
So just address 03 (ABS) and address 56 are the only 2 modules that report during the Auto-Scan. But the Gateway Installation List implies most things are good and happy.
Ignition on (engine running if possible) - [Select] - [01-Engine] Does the Open Controller screen load up or do you an error message?
2stroke
Sweden
C?ID=200316
1. Is the address-03 and address-56 the only 2 modules that report back during the Auto-Scan ?
( Gateway Installation List implies most things are good and happy. )
2. Ignition on (engine running if possible) - [Select] - [01-Engine] Does the Open Controller screen load up or do you get an error message ?
1. No, when doing an Auto-Scan all modules ( 1 - 72 ) report back ( I just shortened the posted scan a bit since the rest is OK ).
2. When I open address-01 the open controller screen starts.
I wonder if @2stroke edited out all the modules that don't have any fault codes?
FWIW, that's considered bad form here.
Jef
HQ
Please do not edit the Auto-Scan, post the complete report.
2stroke
Sweden
C?ID=200316
I think 2stroke edited out all the modules that don't have any fault codes.
OK,
...here comes the entire unedited complete scan:
Monday,10,June,2024,19:56:50:09910
Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
   Part No SW: 3T0 907 115 G    HW: 1Z0 907 115 F
   Component: 1.8l R4/4V TFSI     0030
   Revision: AAH18---    Serial number:
   Coding: 0203000C180F0160
   Shop #: WSC 66565 257 00032
   VCID: 353726C2C9431DC2CC5-8060
   VINID: 91D49B6C606A0D30801842061C1CFEA286
Readiness: 0010 0100
   Revision: 00H31001
7 Faults Found:
                    Reset counter: 157
                    Mileage: 191453 km
                    Date: 2018.11.01
                    Time: 14:51:28
                    Count: 32768
                    Count: 4608
                    Count: 8202
                    Count: 50944
                    Count: 1
                    Count: 1793
                    Reset counter: 157
                    Count: 16384
                    Count: 12
                    Count: 12800
                    Count: 8213
                    Count: 43776
                    Count: 1279
                    Reset counter: 157
                    Count: 16386
                    Count: 12
                    Count: 12800
                    Count: 8208
                    Count: 44032
                    Count: 1535
                    Reset counter: 157
                    Count: 2
                    Count: 12
                    Count: 12288
                    Count: 8254
                    Count: 44544
                    Count: 1279
                    Reset counter: 157
                    Count: 2
                    Count: 12
                    Count: 12288
                    Count: 8211
                    Count: 44544
                    Count: 1279
                    Reset counter: 157
                    Count: 2
                    Count: 12
                    Count: 12288
                    Count: 8233
                    Count: 44544
                    Count: 1279
                    Reset counter: 158
                    Count: 16386
                    Count: 12
                    Count: 12800
                    Count: 166
                    Count: 44032
                    Count: 1279
   Part No SW: 3T0 907 044 BL    HW: 3T0 907 044 BL
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 7DA7FEE2BD730582445-8028
   Part No SW: 1K0 937 087 Q    HW: 1K0 937 087 Q
   Component: BCM PQ35  H   110 0651
   Revision: 00110 AC
   Coding: 40000AB8E00508C040080084510011A4437000AE726D8D605CC540000040
   VCID: 3FDB44EAF77FD792169-806A
   Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 20091  26  0601
   Coding: 00D7B7
   Component: RLS 150911 05  54  0403
   Coding: 0730ED
Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
   Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0005
   Revision: --H11---    Serial number: 75461125900531
   Coding: 118010
   Shop #: WSC 13765 790 00083
   ASAM Dataset: EV_EPHVA14SKxxx0000 001001
   ROD: EV_EPHVA14SKxxx0000_001.rod
   VCID: 333318DACBB703F2E21-8066
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2SZFTT
   Coding: 0020790
   VCID: 3D273EE2F173C582045-8068
   Subsystem 1 - Serial number: 6332MSME623354554
   Subsystem 2 - Serial number: 6342MSME6513211A1
   Subsystem 3 - Serial number: 6351HSME291618745
   Subsystem 4 - Serial number: 6361HSME287B72319
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20110907300607
   Coding: 1082140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79AFEAF2A95B39A268D-802C
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 800000
   Part No SW: 1Z0 920 843 Q    HW: 1Z0 920 843 Q
   Component: KOMBI         H05 0607
   Coding: 120E00
   Shop #: WSC 73430 031 00083
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
   VCID: 46D5510EA825865A55F-8012
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 140911F1001174
   Coding: 352302
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   VCID: 45D7560299A38D425C5-8010
   Component: IMMO          H05 0607
   VCID: 6A8DC5BEDCFD823A917-803E
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2119
   Coding: 0004342
   VCID: 76B5E1CE94C556DA05F-8022
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 69     3201
   Revision: 00H20000
   VCID: 34311BC6C23904CAFBB-8060
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0004342
   VCID: 48C95F36AEB1902AA73-801C
Address 55: Headlight Range        Labels: 5M0-907-357-V2.clb
   Coding: 1507354
   Component: AFS-Lst.-Modul l    0005
   Coding: 00000023
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0005
   Coding: 00000023
                    Reset counter: 121
                    Mileage: 191510 km
                    Date: 2018.11.01
                    Time: 18:55:16
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012563
   VCID: 323D1DDE382D0AFAE97-8066
   Revision: 3A001001    Serial number: 00000155230775
   Coding: 410D000100000000
   VCID: 303917D63A2138EA9F3-8064
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 333318DAC73703F2E21-8066
End----------( Elapsed Time: 01:12, VBatt start/end: 14.2V/14.1V )-----------
Jef
HQ
Please check the following with VCDS:
From what I can tell, ABS wiring diagram number 30:
Anti-lock brake system (ABS) with differential lock (EDL), Traction control system (TCS), electronic stabilisation program (ESP), hill hold control (HHC), (L0L)
As of May 2011
Please take a look at the following fuses:
  • SC2 (5A)
  • SB4 (20A)
  • SB25 (40A)
Take a couple of cell phone photos of fuse panels BEFORE you remove those fuses. Look for signs of hot spotting or discolored metal (fuse and terminals).
Unplug ABS module. Any visual issues found? Load test the powers/ground for the ABS module:
  • T47a/1 (SB25)
  • T47a/32 (SB4)
  • T47a/8 (SC2)
  • T47a/47 (ground, on lower part of right A-pillar)
