- Jun 8, 2024
- 3
- 0
- Houston, TX, USA
- C?ID=64767
I have had 4 GTIs in the past and traded in my last one for a new 2024 Golf R. I have changed all of them to use the "Komfort Blinken" to 4 with no issues. Until now. Found this previous post and learned there is some new security added in to make things harder for owners to change stuff. Yay! I hope this is not the case. I just want one more blink.
First ran into an message: The diagnostics firewall was ON when VCDS connected to this controller. You should open the hood in order to perform Advanced Functions on this car.
So pressed the off button. Opened the hood. Turned ignition back on and message no longer present.
Now step through and got two errors:
Error01 Error02
Any ideas?
Autoscan and I was surprised to see this many DTCs for a new car:
Error01 Error02
Any ideas?
Monday,03,June,2024,18:36:33:39551
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WVWFB7CD0RW149398 License Plate:
Mileage: 1227km-762mi Repair Order:
Chassis Type: CD-VW38 (5WA)
Scan: 01 03 05 08 09 10 13 14 15 17 19 23 2B 36 3C 42 44 47 4B 52
5F 6C 75 82 A5 A9 CA D6 D7 8126 8127 C002 C003
VIN: WVWFB7CD0RW149398 Mileage: 1227km-762miles
CA-Sunroof -- Status: OK 0000
8126-Trq distrib RearL axle -- Status: OK 0000
8127-Trq distrib RearR axle -- Status: OK 0000
Address 01: Engine (J623-DSFF) Labels:. 06K-907-425-V1.clb
Part No SW: 5H0 906 259 J HW: 06K 907 425 N
Component: R4 2.0l TFS H08 0001
Dataset Number: 06Q909102H 0010 CVN: D72AC06EFCD25DD3
Coding: 091900322466000E30040000000000000000000000000000
ASAM Dataset: EV_ECM20TFS0205H0906259J 001002
ROD: EV_ECM20TFS020_VW38.rod
VCID: 36352246C8CEDA4ABDF-8062
VINID: 9E69D64874D40229C11090C920980842D6
12 Faults Found:
23039 - Implausible Data Received from Brake System Control Module
U0418 00 [00100000] - -
[Invalid Data Received from Brake System Control Module "A"]
40466 - Fuel Injection Malfunction
P0148 00 [01100000] - -
15357 - Torque Restriction due to Coolant Temperature
P102A 00 [01100000] - -
[Torque limitation due to coolant temperature]
Reset counter: 12
Mileage: 13 km
Date: 2024.02.03
Time: 22:32:59
Engine RPM: 1341.75 /min
Normed load value: 12.2 %
Coolant temperature: 58 C
Intake air temperature: 50 C
Voltage terminal 30: 12.324 V
Unlearning counter according OBD: 12
ECU_STATE: SYN_ENG_IGK_ON
Cruise control switch actuation-Main switch: Not operated
Cruise control switch actuation-Set: Not operated
Cruise control switch actuation-Resume: Not operated
Cruise control switch actuation-Accelerate: Not operated
Cruise control switch actuation-DELAY: Not operated
Cruise control switch actuation-Cancel: Not operated
Cruise control switch actuation-Main switch hardware: Not operated
Cruise control switch actuation-Limit button: Not operated
Cruise control switch actuation-Main switch CAN: Not operated
Cruise control switch actuation-Large increment: Not operated
Engine status: Idle
T_AST_SAE: 8 s
T_ES: 244 min
Calculated oil temperature: 57.0 C
41197 - Voltage Supply 1 for Control Module
U3501 00 [00100000] - Too Low
41198 - Voltage Supply 1 for Control Module
41200 - System Voltage
P0562 00 [00100000] - Too Low
15058 - Fuel Rail/System Pressure
P0087 00 [01100000] - Too Low
15059 - Fuel Rail/System Pressure
43404 - Fuel Pressure too Low during Cold Start
P053F 00 [01100000] - -
Reset counter: 12
Mileage: 13 km
Date: 2024.02.03
Time: 22:32:52
Engine RPM: 1283.25 /min
Normed load value: 22.7 %
Coolant temperature: 57 C
Intake air temperature: 51 C
Voltage terminal 30: 12.500 V
FUP_H_SAE: 490 kPa
High fuel pressure: specified value: 127.9 bar
FAC_LAM_LIM[1]: 0.000 %
Rail pressure regulation: status: Control operation
FTL_SAE: 71.0 %
Accelerator pedal position: 0.00 %
Activation of fuel pump electronics: 31.04 %
37722 - Fuel Rail/System Pressure
17176 - Databus
U1123 00 [00100000] - Received Error Message
38468 - Implausible Data Received from ESP Control Module
U0416 00 [00100000] - -
Address 03: ABS Brakes (J104) Labels: 5WA-614-517-V1.clb
Part No SW: 5WA 614 517 CF HW: 5WA 614 517 N
Component: ESC H13 0135
Serial number: 63093000011707 Dataset Number: V03935397FY 0001 CVN: D77D4621
Coding: 76FC6E9076246E75527A6E0976CB60064A525A55528803C02014B831018FF100002814
ASAM Dataset: EV_Brake1ESCEPBMQB37W 013058
ROD: EV_Brake1ESCEPBMQB37W_013_VW38.rod
VCID: 0E45AAA690DEC28AD5F-805A SFD
16 Faults Found:
8472 - Implausible Data Received from Airbag Control Module
U0452 00 [00100000] - -
[CCan_AB_Gurtschloss_FA_ext_inv]
8563 - Control Module for Steering Assist
U10BB 00 [00100000] - Implausible Signal
[CCan_EPS_BLW_QBit]
8749 - Control Module for Torque Distribution; Rear Left
C13A6 29 [00100000] - Signal Implausible
[CCan_TSL_Sperrgrad_L_inv]
8752 - Control Module for Torque Distribution; Rear Right
C13A7 29 [00100000] - Signal Implausible
[CCan_TSR_Sperrgrad_R_inv]
C1146 02 [00100000] - Signal Failure
[RKA+: missing input signal(s)]
409344 - Display for Tire Pressure Monitoring
C1146 54 [00100000] - Missing Calibration / Basic Setting
4609 - Brake booster
C1187 00 [00100000] - Faulty
[EBooster_hbc_request]
4611 - Brake booster
[EBooster_no_ebr]
331360 - Function Restricted due to Insufficient Voltage
U1400 00 [00100000] - -
[IpbX_PbcSupp_0_Fail_00]
33008 - Parking Brake Motors
C10E1 F0 [00100000] - Opened Insufficiently
[IpbX_Res_Brake_Torque_Fail]
0141 - Control Module Improper Shut Down
U3001 00 [00100000] - -
[Powerlatch_defect]
0294 - Steering Angle Sensor
B1168 F2 [01100000] - Not Initialized
[Swa_init_fail]
131104 - Function Restricted due to Insufficient Voltage
131120 - Supply voltage
U1011 00 [00100000] - Voltage too Low
[Undervoltage2]
1981 - Function Restricted due to Insufficient Voltage
[Uv_related_fail_replace]
4499 - System Voltage
[Vpre_low_uv]
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 Q HW: 5WA 959 436 Q
Component: Kessy IOBOX 100 0725
Serial number: --------------- Dataset Number: V03935341VY 0001
ASAM Dataset: EV_Kessy37w 004024
ROD: EV_Kessy37w_004_VW38.rod
VCID: 629DAE1634C616EA217-8036
Address 08: Auto HVAC (J979) Labels:* Redir Fail!
Part No SW: 5WA 907 007 AC HW: 5WA 907 007 AC
Component: AC Automat H31 3623
Serial number: --------------- Dataset Number: V03935418JG 0001
Coding: 002000110210120011101010111111110000131100200100000000000000
ASAM Dataset: EV_ACClimaPREVW38X 001102
ROD: EV_ACClimaPREVW38X_VW38.rod
VCID: 08499CBEF2BA9CBA1F3-805C
Air quality sensor:
Subsystem 1 - Part No SW: 5Q0 907 659 D HW: 5Q0 907 659 D
Component: G238 _AQS H02 0003
Serial number: 00000000000002672127
Subsystem 2 - Part No SW: 11A 907 049 B HW: 11A 907 049 B
Component: E265 KPH SH H02 0184
Serial number: G06S12.09.2300972291
Interior temperature sensor:
Subsystem 3 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00001301023131657516
Part No SW: 5WA 937 086 BT HW: 5WA 937 086 BB
Component: BCM37w_H134 0183
Serial number: BXJ53F041123940 Dataset Number: V03935400FM 0001
ASAM Dataset: EV_BCM37w 007001
ROD: EV_BCM37w_007_VW38.rod
VCID: 2411E80E6E5258DA13B-8070 SFD
Subsystem 1 - Part No SW: 5H1 955 119 B HW: 5H1 955 119
Component: FWISCHER_MYJT 003 0061
Serial number: 907453F0302325002256
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 054 0206
Serial number: SAY23M11D18H18M16S26
Subsystem 3 - Part No SW: 5H0 941 193 AL HW: 5H0 941 193 AL
Component: LiSi H06 0008
Serial number: 92471WF60005H
Subsystem 4 - Part No SW: 5H0 925 200 R HW: 5H0 925 200 R
Component: DiETa H07 0008
Serial number: 92471WK2002XE
Subsystem 5 - Part No SW: 5H0 959 561 BQ HW: 5H0 959 561 BQ
Component: -VW----LINDA- 504 0831
Serial number: MW3LND17112300012954
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0102
Serial number: ESE3847653
Subsystem 7 - Part No SW: 3G0 963 345 A HW: 3G0 963 345 A
Component: SysNameFanLin 015 0102
Serial number: ESE3895052
Subsystem 8 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE3848418
Subsystem 9 - Part No SW: 3G0 963 345 A HW: 3G0 963 345 A
Serial number: ESE3829484
Steering Column Switch:
Subsystem 10 - Part No SW: 5Q1 953 507 GB HW: 5Q1 953 549 F
Component: J527 SMLS MQB 005 0080
Serial number: 00000019092308491361
15400960 - Secure Onboard Communication
U14FD 00 [00101000] - Time Server not Available
[Sichere on-board Kommunikation: Zeitserver nicht verf gbar]
Fault Frequency: 47
Reset counter: 26
Mileage: 63 km
Date: 2024.03.19
Time: 02:57:14
Terminal 15 status: OFF
Terminal 50 status: OFF
Engine run: OFF
Status of brake lamp switch: discrete: OFF
Brake lamp switch via CAN: status: OFF
Voltage: 11.7 V
Outside temperature: 29.0 C
Light switch position: automatic
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5R3 919 298 A HW: 5R3 919 298
Component: PLA 12 Kanal H05 1570
Serial number: 000995442323308 Dataset Number: V03935394RP 0001
Coding: 0200026001
ASAM Dataset: EV_EPHVA2CVW3800000 002036
ROD: EV_EPHVA2CVW3800000_VW38.rod
VCID: 41DF419A91006DF218D-8014
13647889 - Databus
[Bremsensteuerger t - VMM_02.VZM_Systemstatus - Fehlerspeicher auslesen]
13688835 - Databus
[Steuerger t f r Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
13637426 - Databus
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5WA 907 572 C HW: 5WA 907 572 A
Component: ACC BOSCH MQB H45 0461
Dataset Number: V03935392FC 0001
Coding: 06230094400780451247400000804004AE4020000000000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW380 004021
ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
VCID: 4EC56AA6505E828A95F-801A
33 Faults Found:
1089 - Databus
U1121 00 [00100000] - Missing Message
[FAULT_TIMEOUT_ESP_10]
1092 - Databus
[FAULT_TIMEOUT_ESP_21]
1387 - Supply voltage
[FAULT_VBAT_LOW]
1389 - Function Restricted due to Insufficient Voltage
[FAULT_VBAT_BUSMON_LOW]
1561 - Databus
[FAULT_BV_AVAILABILITY_ERROR]
1594 - Function Restricted due to Insufficient Voltage
U1400 00 [01100000] - -
[FAULT_VBAT_BUSMON_LOW_TIMESTAMP]
2055 - Databus
U1122 00 [00100000] - Implausible Message
[FAULT_ALP_STEERING_WHEEL_INIT]
2056 - Databus
[FAULT_ESP_BPRESSURE_ERROR]
2060 - Databus
[FAULT_CONST_PLAUS_CONTROL_UNIT_TYPE]
2068 - Databus
U1123 00 [00101000] - Received Error Message
[FAULT_TSK_IRREV_ERROR]
Reset counter: 12
Mileage: 13 km
Date: 2024.02.03
Time: 02:50:40
2081 - Databus
[FAULT_GEAR_ERROR]
2082 - Databus
[FAULT_EPB_SWITCH_ERROR]
209153 - Databus
[FAULT_KAMERA_HIGH_SYSTEMZUSTAND_ERROR]
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM_ERROR]
2126 - Databus
[FAULT_TSK_ROAD_SLOPE_ERROR]
2425 - Databus
[FAULT_SENSORFUSION_INPUT_CAMERA_NOT_AVAILABLE]
0522 - Databus
[FAULT_TIMEOUT_ESC_50]
0523 - Databus
[FAULT_TIMEOUT_ESC_51]
0534 - Databus
[FAULT_TIMEOUT_VMM_01]
0535 - Databus
[FAULT_TIMEOUT_VMM_02]
0563 - Databus
[FAULT_ESP_TRANSVERSE_ACCELERATION_ERROR]
0567 - Databus
[FAULT_HMS_FAILURE_STATUS_ERROR]
0571 - Databus
[FAULT_HMS_STANDSTILL_ERROR]
0577 - Databus
[FAULT_VZM_SYSTEM_STATUS_ERROR]
0616 - Databus
[FAULT_QBIT_TRANSVERSE_ACCELERATION_INVALID]
0723 - Databus
[FAULT_BV_RELEVANT_ERROR]
0790 - Databus
[FAULT_RB_PER_HV_OOS_SERVICE]
0800 - Databus
[FAULT_SWA_RELEVANT_ERROR]
0822 - Databus
[FAULT_QBIT_LONGITUDINAL_ACCELERATION_INVALID]
0828 - Databus
[FAULT_QBIT_YAW_RATE_INVALID]
0854 - Databus
[FAULT_ESP_LONGITUDINAL_ACCELERATION]
0855 - Databus
[FAULT_ESP_YAW_RATE_ERROR]
0859 - Databus
[FAULT_KAMERA_HIGH_SYSTEMZUSTAND_INIT]
Address 14: Susp. Elect. (J250) Labels: 1EA-907-376.clb
Part No SW: 1EA 907 376 C HW: 1EA 907 376
Component: DAEMPFUNGS-SG H05 0457
Serial number: 2C7673241306032 Dataset Number: V03935344MR 0001
ASAM Dataset: EV_DCC3CONTITEMIC 002006
ROD: EV_DCC3CONTITEMIC_002_VW38.rod
VCID: 3A2D3676FCD63E2A597-806E
1048576 - Supply voltage
U1011 00 [01100000] - Voltage too Low
[Supply_voltage_below_the_9V_lower_limit]
Address 15: Airbags (J234) Labels:* 5WA-959-655.clb
Part No SW: 5WA 959 655 M HW: 5WA 959 655 M
Component: AirbagVW40 011 0636
Serial number: 000000003C0J3RA Dataset Number: V03935370MB 0001
Coding: 8CCC000000FCC00000000000000000005100000000000000000036F800130065
ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
ROD: EV_AirbaVW40SMEVW38X.rod
VCID: 619FA11A31C00DF238D-8034 SFD
Component: ------------- H17 0022
Serial number: IBH00000000000LERZU1
Subsystem 2 - Part No SW: ----------- HW: 480 050 911 23
Component: SideSensor_Dr 000 0149
Serial number: 3510000C0CC7220C243Y
Subsystem 3 - Part No SW: ----------- HW: 480 050 911 23
Component: SideSensor_Pr 000 0149
Serial number: 3520000BECC72218099B
Subsystem 4 - Part No SW: ----------- HW: 480 000 610 23
Serial number: 35700000000DD2090C6R
Subsystem 5 - Part No SW: ----------- HW: 480 002 509 23
Serial number: 3580000000094641CB6Q
Subsystem 6 - Part No SW: ----------- HW: 480 050 811 23
Component: FrontSensor_D 000 014A
Serial number: 3550000BAC8FFF83C654
Subsystem 7 - Part No SW: ----------- HW: 480 050 811 23
Component: FrontSensor_P 000 014A
Serial number: 3560000BAC8FFF8A42E9
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 5H0 920 340 C HW: 5H0 920 340 C
Component: KOMBI 310 7380
Dataset Number: V03935364SX 0001
Coding: 08BC02027B9CCF050280620B2000000810300000
ASAM Dataset: EV_DashBoardVDDMQB37W 003035
ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
VCID: 221DEE16744656EA617-8076 SFD
16777022 - Control unit for information electronics 1
U1054 00 [00001000] - No Communication
[NAV_SD_0x32 communication error bap_error_timeout heartbeat]
Reset counter: 84
Mileage: 66 km
Date: 2024.04.26
Time: 23:29:27
Part No SW: 5WA 907 530 AB HW: 5WA 907 530 L
Component: GW2020 High 778 7105
Revision: -------- Serial number: 771049110023303 Dataset Number: V03935393AA 0001
Coding: 0000800D0E00000000000000012303307302610902000300030100000001010000000000000000000000000000000000
GVL: 3D080000020840DC800080824C00104004404002004000300200000000000044
ASAM Dataset: EV_GatewMQB2020 006012
ROD: EV_GatewMQB2020_006_VW38.rod
VCID: 08499CBEF2BA9CBA1F3-805C SFD
Generator:
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 5WA 915 181 C HW: 5WA 915 181 C
Component: J367-BDMHella H11 9080
Serial number: 3013243206
Subsystem 3 - Part No SW: 1EA 959 442 F HW: 1EA 959 442 F
Component: MFL H03 0219
Serial number: 17038315112202300935
Subsystem 4 - Part No SW: 5H0 959 542 N HW: 5H0 959 542 N
Component: KLR_JSS_1Zone 089 0023
Serial number: 3136188AA23304217703
13 Faults Found:
1049254 - Ethernet Databus Branch 6
U1231 00 [00100000] - No Communication
[Ethernet_databus_no_communication_branch_6_/_port_7]
2506779 - Ethernet Module for Head-Up Display
U1641 00 [00101000] - No Communication
[Head-up_display_control_module_no_communication_vlan]
2494569 - Ethernet Module for Back-Up Cam
U1643 00 [00101000] - No Communication
[Rearview_camera_system_control_module_no_communication_vlan]
2498675 - Ethernet Module for Information Electronics 1
U1645 00 [00100000] - No Communication
[Information_electronics_control_module_1_no_communication_vlan]
8397569 - Quiescent Current
U1406 00 [00100000] - Too High
8397571 - LV Energy Management
B1802 F1 [00100000] - Warning Triggered
1282 - Supply voltage
8472065 - Databus
[function_error_PaCo_Timeout_CANMessage]
B184C 00 [00100000] - -
[Unlock_protection_of_vehicle_diagnosis_active]
8466689 - VKMS
B18B0 F0 [00100000] - Missing Adaptation
[VKMS_new_download_container_required_due_to_vehicle_change]
1298 - Function Restricted due to Insufficient Voltage
8482819 - Activatable Functions
B18D3 F3 [00101000] - Faulty Vehicle Configuration
[Fs_id_configuration_error]
8398594 - Control unit for battery monitoring
U1050 00 [00100000] - No Communication
[BDMs_FuSi_no_communication]
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5WA 909 059 AB HW: 3Q0 909 059 D
Component: EBKV H09 0372
Serial number: 7XM369101023014 Dataset Number: V03935367RC 0001
Coding: 5003C5409B00009C73CE39E7000049922449922400
ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
ROD: EV_BrakeBoostG2BoschVW37W_016_VW38.rod
VCID: 1079B4DE8AEAD47AC73-8044 SFD
24 Faults Found:
106576 - Control Module for Brake Electronics
U0129 00 [00100000] - No Communication
[ComScl_ESC_50_Timeout]
106592 - Control Module for Brake Electronics
[ComScl_ESC_51_Timeout]
106608 - Brake Control Module
U12DC 00 [00100000] - Received Malfunction Message
[Scl_ESC_51_ESC_aktBr_Volumenstrom_Error]
106752 - Brake Control Module
[Scl_ESC_51_ESC_Bremsdruck_02_Error]
106816 - Brake Control Module
[Scl_ESC_50_ESC_Raddruck_max_Invalid]
106832 - Brake Control Module
[Scl_ESC_50_ESC_Raddruck_max_Error]
107040 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [00100000] - -
[ComScl_Motor_14_Timeout]
107056 - Engine Control Module
U12DB 00 [00100000] - Received Malfunction Message
[Scl_Motor_14_MO_Gangposition_Error]
107088 - No Communication with Engine Control Module (SAE ECM/PCM)
[ComScl_Motor_18_Timeout]
107120 - No Communication with Engine Control Module (SAE ECM/PCM)
[ComScl_Motor_54_Timeout]
107136 - No Communication with Engine Control Module (SAE ECM/PCM)
[ComScl_Motor_Code_01_Timeout]
107584 - Control Module for Brake Electronics
[ComScl_ESP_21_Timeout]
107600 - Brake Control Module
[Scl_ESP_21_ESP_v_Signal_Error]
107616 - Brake Control Module
[Scl_ESP_21_ESP_v_Signal_Invalid]
108336 - Brake Control Module
[Scl_ESC_50_EPB_Status_02_Error]
172400 - System Voltage
[PSCUnderVoltageLevel1]
172416 - System Voltage
[PSCUnderVoltageLevel2]
172544 - System Voltage
[PSCUnderVoltageShutDownLevel]
172592 - System Voltage
[RBNET_Undervoltage_Replacement_1_Trip]
172624 - System Voltage
[RBNET_Undervoltage_Replacement_2_Trip]
172656 - Function Restricted due to Insufficient Voltage
[RBNET_Undervoltage_Replacement_Non_OBD]
368912 - Motor for Electromechanical Brake Booster
C1188 16 [00100000] - Voltage Too Low
[RBBLM_MuxerTimeoutError]
369232 - Control Module Improper Shut Down
1024368 - Brake Booster
C1187 F6 [00100000] - Function Limitation due to External Brake Pressure Build-Up
[ActiveRestrictionDetected]
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 B HW: 2Q0 905 861 B
Component: ELV-MQBB H10 0040
Serial number: 23000246462009 Dataset Number: V03935336NF 0001
Coding: 0000000000000000
ROD: EV_ELVMarqMQBA0_VW38.rod
VCID: 323D1E5624A6C66A917-8066
Part No SW: 5WA 959 760 H HW: 5WA 959 760 H
Component: MEM-FS 009 0362
Serial number: 23A1901KA00507 Dataset Number: V03935307MP 0001
Coding: 01589A40000020408803010101010000000000212100000000000000215000
VCID: 59EF89FA1990D53270D-800C
Address 3C: Lane Change (J1086) Labels:* Redir Fail!
Part No SW: 2Q0 907 686 J HW: 2Q0 907 686 J
Component: HRE_Master H27 0288
Serial number: 00000628605028 Dataset Number: V03935373GS 0001
Coding: 569945D0
ASAM Dataset: EV_HREntryHellaGen3Mstr 001016
ROD: EV_HREntryHellaGen3Mstr_VW38.rod
Subsystem 1 - Part No SW: 2Q0 907 685 J HW: 2Q0 907 685 J
Component: HRE_Slave H27 0288
Serial number: 00000632078212
Lane change assistance display left:
Subsystem 2 - Part No SW: 5H1 949 145 HW: 5H1 949 145
Component: SWA LED VL H05 0005
Serial number: 00000000000016909060
Lane change assistance display right:
Subsystem 3 - Part No SW: 5H1 949 146 HW: 5H1 949 146
Component: SWA LED VR H05 0005
8 Faults Found:
1441795 - Control Module for Lane Change Assistance
C1114 16 [00100000] - Voltage Too Low
[Supply-Voltage too low for long time - Master]
1441796 - Control Module 2 for Lane Change Assistance
C1115 16 [00100000] - Voltage Too Low
[Supply-Voltage too low for long time - Slave]
1441798 - Function Restricted due to Insufficient Voltage
[Function Restriction Supply-Voltage too low]
2236426 - Databus
[databus unreasonable message - LWI_Lenkradwinkel]
2236417 - Databus
[databus unreasonable message - LWI_QBit_Lenkradwinkel]
2240563 - Databus
[databus error value received - ESC_50 - ESP_QBit_Gierrate]
2236437 - Databus
[databus error value received - Parkhilfe_04 - APSOPS_PaCo_MainState]
2252891 - Databus
[databus error value received - VMM_02 - VZM_Systemstatus]
Part No SW: 5Q0 959 593 L HW: 5Q0 959 593 F
Component: TSG FS004 0350
Serial number: YE007WJQ01183 Dataset Number: V03935387Z 0001
Coding: 003B13205200040008000000
ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
VCID: 4ACD66B6AC36AEAAC97-801E
Subsystem 1 - Part No SW: 5Q0 959 408 G HW: 5Q0 959 164 C Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000075630132
Coding: 111000
Address 44: Steering Assist (J500) Labels:| 5WA-907-14X-V1.clb
Part No SW: 5WA 907 145 G HW: 5WA 907 145 C
Component: BASGEN1MQB37 502 1040
Serial number: 03300762 Dataset Number: V03935358SR 0001
Coding: 0000000000000001000002010100010000000100010101
ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
0513 - Supply voltage
0515 - Function Restricted due to Insufficient Voltage
U1400 00 [01100100] - -
[DTC_LVOLTAGE_RLKU_2]
Mileage: 64 km
Date: 2024.04.04
Time: 21:03:11
MonitorId: 02 6A
HybridDriveReady: 00000001
IgnitionEnabled: 00000000
Communication control: 00000000
Diagnostic session: 00000000
ComM_ModeType: 00000000
NM_Signal_Fahrbereit: 00000000
NM Signal V gr 7: 00000000
System status: 3
ECU Status: 0
HWLib Status: 1
Support power reduction: 0.0 %
Voltage terminal 30: 6.750 V
Vehicle speed: 10 km/h
Temperature circuit board: 29 C
Output stage temperature: 23 C
Rackposition: 0.00 mm
Rackspeed: 0.23 mm/s
pinion angle dependent amplitude factor: 0
Steering wheel angle: 0.25 /s
SupplierFreezeFrameData: 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
5407 - Terminal 30
U140A 00 [00100000] - Open Circuit
[DTC_RESET_SDK]
5411 - Software error detected
C113E 00 [00100000] - -
[DTC_MTL_LIMIT_ACTIVE]
5423 - Steering Angle Sensor
B1168 F2 [00100000] - Not Initialized
[DTC_RACKPOS_NOINIT]
Part No SW: 5H0 035 456 A HW: 5H0 035 456 A
Component: AMPeth12CDoIP H06 4319
Serial number: A1129C00242626 Dataset Number: V03935345SG 0001
Coding: 23000000000000000000000000000000000000000000000000
ASAM Dataset: EV_AMPEthMQB37w 001005
ROD: EV_AMPEthMQB37w_VW38.rod
VCID: 2517F50A6568A1D2045-8070 SFD
[Function restriction due to insufficient voltage - lower limit value not reached]
1537 - Supply voltage
[Supply voltage - lower limit value not reached]
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 5WA 907 338 B HW: 5WA 907 338
Component: FCM2020 Low H14 1447
Serial number: 250151223452100 Dataset Number: V03935346BX 0001
Coding: 000000000900071206112310040003070300000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW38X 004012
ROD: EV_MultiModulContiVW38X_004_VW38.rod
VCID: 4DC76DAA5D58B992EC5-8018 SFD
Part No SW: 5Q0 959 592 L HW: 5Q0 959 592 F
Component: TSG BFS004 0350
Serial number: YE007WJQ14828 Dataset Number: V03935386XH 0001
Coding: 003B13205E00040000800000
ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
VCID: 49CF59BAA930A5B2C0D-801C
Subsystem 1 - Part No SW: 5Q0 959 407 G HW: 5Q0 959 163 C Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000075675868
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 5H0 035 877 C HW: 5H0 035 877
Component: MU-O-NS-US H61 1939
Serial number: WG8LGM161023000 Dataset Number: V03935418MQ 0001
Coding: 23800000000100000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB37w 001002
ROD: EV_MUOIMQB37w_001_VW38.rod
VCID: 2E050A26309EE28AF5F-807A SFD
Subsystem 1 - Part No SW: 5H0 919 605 B HW: 5H0 919 605 B
Component: ABT_W_10 H44 3080
Serial number: VDD02406112312216084
Subsystem 2 - Part No SW: V03 959 820 GP HW: -----------
Component: NAR 2023/24 --- 9085
Address 6C: Back-up Cam. (J772) Labels:| 5WA-980-556.clb
Part No SW: 5WA 980 556 D HW: 5WA 980 556 B
Component: RV eCompact H31 0344
Serial number: FCLK20290823010 Dataset Number: V03935359FC 0001
Coding: 02030004E43000
ASAM Dataset: EV_CamSysRVCCompaFicos 010024
ROD: EV_CamSysRVCCompaFicos_010_VW38.rod
VCID: 52FD7ED64466E66AB17-8006
Part No SW: 5WA 035 285 D HW: 5WA 035 285 A
Component: OCU3HMQB37W H12 0021
Serial number: 0000000307VICLE Dataset Number: V03935379BN 0001
Coding: 023800209068AC209025460070502E07
ASAM Dataset: EV_OCU3HMQB37W 002012
ROD: EV_OCU3HMQB37W_002_VW38.rod
VCID: 48C95CBEB23A5CBADF3-801C SFD
Address 82: Head Up Display (J898) Labels:| 5H1-919-608.clb
Part No SW: 5H1 919 608 HW: 5H1 919 608
Component: HeadupDisplay H17 2045
Dataset Number: V03935332ET 0001
Coding: 5740A0
ASAM Dataset: EV_HeadUpDisplMQB37W 001018
ROD: EV_HeadUpDisplMQB37W_VW38.rod
VCID: 6FBBD722F714AB82BE9-803A
13894400 - Function limitation due to excessive temperature
B1050 00 [00001000] - -
[ECU_function_restriction_overtemperature]
Mileage: 471 km
Date: 2024.05.15
Time: 13:20:16
16777040 - Function Restricted due to Interrupted Communications
U1110 00 [00001000] - -
[NAV_0x32_communication_error_bap_error_timeout_heartbeat]
Mileage: 1227 km
Date: 2024.06.03
Time: 18:33:29
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 5WA 980 653 D HW: 5WA 980 653
Component: MQB MFK 3.0 H12 3405
Serial number: EB7590904232690 Dataset Number: V03935412E 0001
Coding: 00000A88116CC040109F00001020002000418000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005055
ROD: EV_MFK3ValeoMQB_005_VW38.rod
VCID: 50F974DE4A6A947A873-8004
1126451 - Databus
[ACC_18_ACC_Status_ACC_irreversibel_ERROR]
Reset counter: 12
Mileage: 13 km
Date: 2024.02.03
Time: 02:50:41
1126424 - Internal Fault
B200F F2 [00001000] - Unknown Error Elaboration
[Safe_State_Active_lane_change_ready]
Mileage: 62 km
Date: 2024.03.19
Time: 00:03:53
Part No SW: 5H0 907 159 A HW: 4K0 907 159
Component: SAS-GEN 2.5 H08 0002
Serial number: 231024290571
ROD: EV_SoundActuaGen2AU64X_003_VW27.rod
VCID: 2D070D2A3D989992CC5-8078
Part No SW: 4K1 907 594 CB HW: 4K1 907 594
Component: SAD_STG_1 006 0040
Dataset Number: V03935402SS 0001
Coding: 008000738001
VCID: 77ABEF428F44E342669-8022
Part No SW: 992 941 571 AH HW: 992 941 571 A
Component: LED1L H25 9204
ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
VCID: 6889BC3ED2FA7CBAFF3-803C
131093 - Function Restricted due to Insufficient Voltage
[functional limitations due to undervoltage]
Component: LED1R H25 9204
ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
Address 8126: Trq distrib RearL axle (J492) Labels: 08E-907-554.clb
Part No SW: 08E 907 554 J HW: 08E 525 130
Component: 4Motion H06 0160
Serial number: 01AV7R7
Coding: 00010100
ASAM Dataset: EV_TorquSplitLeftMAGNA 001005
ROD: EV_TorquSplitLeftMAGNA.rod
VCID: 3537254AD5C8D152B45-8060
Address 8127: Trq distrib RearR axle (J492) Labels: 08E-907-554.clb
Serial number: 01AV7RC
Coding: 00010100
ASAM Dataset: EV_TorquSplitRightMAGNA 001005
ROD: EV_TorquSplitRightMAGNA.rod
End----------(Elapsed Time: 02:01, VBatt start/end: 12.2V/12.2V)-----------
Monday,03,June,2024,18:47:41:39551
12 Faults Found:
P0148 00 [00100000] - -
P102A 00 [00100000] - -
Reset counter: 12
Mileage: 13 km
Date: 2024.02.03
Time: 22:32:59
Engine status: Idle
T_AST_SAE: 8 s
T_ES: 244 min
P053F 00 [00100000] - -
Reset counter: 12
Mileage: 13 km
Date: 2024.02.03
Time: 22:32:52
FUP_H_SAE: 490 kPa
FTL_SAE: 71.0 %
P0087 00 [00100000] - Too Low
17176 - Databus
16 Faults Found:
[CCan_EPS_BLW_QBit]
[EBooster_no_ebr]
[Powerlatch_defect]
[Swa_init_fail]
[Undervoltage2]
[Vpre_low_uv]
Air quality sensor:
Fault Frequency: 47
Reset counter: 26
Mileage: 63 km
Date: 2024.03.19
Time: 02:57:14
Engine run: OFF
Voltage: 11.7 V
Coding: 0200026001
13647889 - Databus
13688835 - Databus
13637426 - Databus
33 Faults Found:
1089 - Databus
1092 - Databus
[FAULT_VBAT_LOW]
1561 - Databus
2055 - Databus
2056 - Databus
2060 - Databus
2068 - Databus
Reset counter: 12
Mileage: 13 km
Date: 2024.02.03
Time: 02:50:40
2081 - Databus
[FAULT_GEAR_ERROR]
2082 - Databus
209153 - Databus
2101 - Databus
2126 - Databus
2425 - Databus
0522 - Databus
0523 - Databus
0534 - Databus
0535 - Databus
0563 - Databus
0567 - Databus
0571 - Databus
0577 - Databus
0616 - Databus
0723 - Databus
0790 - Databus
0800 - Databus
0822 - Databus
0828 - Databus
0854 - Databus
0855 - Databus
0859 - Databus
Reset counter: 84
Mileage: 66 km
Date: 2024.04.26
Time: 23:29:27
Generator:
13 Faults Found:
8472065 - Databus
8466689 - VKMS
24 Faults Found:
Coding: 569945D0
8 Faults Found:
2236426 - Databus
2236417 - Databus
2240563 - Databus
2236437 - Databus
2252891 - Databus
Coding: 111000
Mileage: 64 km
Date: 2024.04.04
Time: 21:03:11
MonitorId: 02 6A
System status: 3
ECU Status: 0
HWLib Status: 1
5407 - Terminal 30
[DTC_RESET_SDK]
Coding: 091000
Coding: 5740A0
Mileage: 471 km
Date: 2024.05.15
Time: 13:20:16
Mileage: 1227 km
Date: 2024.06.03
Time: 18:33:29
1126451 - Databus
Reset counter: 12
Mileage: 13 km
Date: 2024.02.03
Time: 02:50:41
Mileage: 62 km
Date: 2024.03.19
Time: 00:03:53
Coding: 00010100
Coding: 00010100
End----------(Elapsed Time: 01:58, VBatt start/end: 12.3V/12.3V)-----------
Monday,03,June,2024,18:53:28:39551
5F 6C 75 82 A5 A9 CA 8126 8127 C002 C003
12 Faults Found:
Reset counter: 12
Mileage: 13 km
Date: 2024.02.03
Time: 22:32:59
Engine status: Idle
T_AST_SAE: 8 s
T_ES: 244 min
Reset counter: 12
Mileage: 13 km
Date: 2024.02.03
Time: 22:32:52
FUP_H_SAE: 490 kPa
FTL_SAE: 71.0 %
17176 - Databus
16 Faults Found:
[CCan_EPS_BLW_QBit]
[EBooster_no_ebr]
[Powerlatch_defect]
[Swa_init_fail]
[Undervoltage2]
[Vpre_low_uv]
Air quality sensor:
Fault Frequency: 47
Reset counter: 26
Mileage: 63 km
Date: 2024.03.19
Time: 02:57:14
Engine run: OFF
Voltage: 11.7 V
Coding: 0200026001
13647889 - Databus
13688835 - Databus
13637426 - Databus
33 Faults Found:
1089 - Databus
1092 - Databus
[FAULT_VBAT_LOW]
1561 - Databus
2055 - Databus
2056 - Databus
2060 - Databus
2068 - Databus
Reset counter: 12
Mileage: 13 km
Date: 2024.02.03
Time: 02:50:40
2081 - Databus
[FAULT_GEAR_ERROR]
2082 - Databus
209153 - Databus
2101 - Databus
2126 - Databus
2425 - Databus
0522 - Databus
0523 - Databus
0534 - Databus
0535 - Databus
0563 - Databus
0567 - Databus
0571 - Databus
0577 - Databus
0616 - Databus
0723 - Databus
0790 - Databus
0800 - Databus
0822 - Databus
0828 - Databus
0854 - Databus
0855 - Databus
0859 - Databus
Reset counter: 84
Mileage: 66 km
Date: 2024.04.26
Time: 23:29:27
Generator:
13 Faults Found:
8472065 - Databus
8466689 - VKMS
24 Faults Found:
Coding: 569945D0
8 Faults Found:
2236426 - Databus
2236417 - Databus
2240563 - Databus
2236437 - Databus
2252891 - Databus
Coding: 111000
Mileage: 64 km
Date: 2024.04.04
Time: 21:03:11
MonitorId: 02 6A
System status: 3
ECU Status: 0
HWLib Status: 1
5407 - Terminal 30
[DTC_RESET_SDK]
Coding: 091000
Coding: 5740A0
Mileage: 471 km
Date: 2024.05.15
Time: 13:20:16
Mileage: 1227 km
Date: 2024.06.03
Time: 18:33:29
1126451 - Databus
Reset counter: 12
Mileage: 13 km
Date: 2024.02.03
Time: 02:50:41
Mileage: 62 km
Date: 2024.03.19
Time: 00:03:53
Coding: 00010100
Coding: 00010100
End----------(Elapsed Time: 01:54, VBatt start/end: 12.3V/12.4V)-----------
